Latest post Fri, Apr 15 2022 9:49 AM by Jeroen van Eekeres. 1 replies.
Page 1 of 1 (2 items)
  • Thu, Apr 14 2022 4:43 PM
    • Adman
    • Atlanta Georgia, USA
    • Posts 5,487
    • Points 62,205
    • BlogAuthor
      Moderator: Avid Free DV
      Moderator: Avid Xpress DV PC
      Moderator: Avid Xpress Studio
    Media Composer 2021.12.2 launched today
    Great News!!! Avid is pleased to announce the release of Media Composer 2021.12.2 today, April 14, 2022, at noon ET. This is a maintenance release for MC 2021 users.
    Location at Launch: The Media Composer v2021.12.2 (Mac and PC) will be available on the Download Center only.
    Status of Support Plan: The ability to launch this Media Composer 2021.12.2 software is dependent on the status of your Upgrade and Support Plan on the date this software version is released. Media Composer 2021.12.2 is released on Thursday, April 14th, 2022 noon EDT.
    This release fixes the installation issues that some users were seeing in MC 2021.12.1 if they were either on Mojave 10.14.6 or on the new macOS 12.3.
    Installation Behavior
    The Avid Media Composer application icon is no longer automatically added to the dock. Refer
    to your macOS documentation for instructions on adding an application icon to the dock.
    What’s Fixed in 2021.12.2The following has been fixed.
    • Bug Number: MCCET-4330. Background transcoding of ProRes RAW files to another format failed to complete.
    • Bug Number: MCCET-4558. Media Composer Enterprise was not able to launch when using Avid NEXIS client software.
    • Bug Number: MCCET-4570. In some instances, when working in a standalone environment (local drives), you could not successfully perform a Send To Playback.
    • Bug Number: MCCET-4563. When logging in to Production Management or
    MediaCentral | Cloud UX from the Media Composer project window, the password remained in the password text box after you logged out.
    • Bug Number: MCCET-4465. In some cases Media Composer options would not be seen in
    Media Composer when Media Composer used Cloud Licensing.
    • Bug Number: MCCET-4535. Using keyboard shortcut to open multiple bins resulted in floating panels instead of tabbed bins.
    • Bug Number: MCCET-4527. Exporting BXF files caused a crash.
    • Bug Number: MCCET-4442. JKL playback did not work properly when switching workspaces with Calculator tool open.
    • Bug Number: MCCET-4577. Saving a new bin view made bin columns wider.
    • Bug Number: MCCET-4485. Insert Export was not working properly.
    • Bug Number: MCCET-4265. A sequence containing grouped XDCAM 50 clips with
    FrameFlex did not retain FrameFlex after performing a mixdown.
    • Bug Number: MCCET-4490. Sorting by Date in the Find window did not sort correctly when Regional Format was set to English (United Kingdom).
    • Bug Number: MCCET-4361. You could not capture from the front XLR input of the Avid Artist DNxIO.
    • Bug Number: MCCET-4378. (NDI) In some instances, the Media Composer monitor was
    either behind or ahead of the NDI stream.
    • Bug Number: MCCET-4242. When working with some AudioSuite plug-ins, rendering stereo audio was slow in a Production Management/Avid NEXIS environment.
    • Bug Number: MCCET-4360. In some instances, exporting to a P2 device resulted in pixelated and inverted images.
    • Bug Number: MCCET-4399. If you performed an Export as Graphic and NDI was active, you might have received an “AMEResourceManager ReconfigHW_LegendBoB_Capture” error.
    • Bug Number: MCCET-3854. During export some AAF Sound settings did not save.
    • Bug Number: MCCET-4481. (Production Management) Clips with the Restrictions did not appear with the red triangle in the Media Composer bin.
    • Bug Number: . MCCET-4497 (macOS) Performing a Select Media Relatives on a sequence crashed the application.
    • Bug Number: MCCET-4509. In some instances, the image appeared garbled after loading a sequence in a Color Correction workspace.
    • Bug Number: MCCET-4449. In some instances, when working with MultiCam sequences, Media Composer was sluggish.
    • Bug Number: MCCET-4402. With Gang enabled, selecting all Timeline Clip Notes resulted in a hang.
    • Bug Number: MCCET-4395. (ScriptSync) If you added color to a range of script indicators, when you closed and then reopened the script, the indicators were filled even if they were not previously filled.
    • Bug Number: MCCET-4499. (macOS) Using the Enter key to Adjust Pan / Volumes IN to OUT did not work.
    • Bug Number: MCCET-4513. (Production Management) In some instances, you might have experience a significant slowdown when performing an Edit While Capture.
    • Bug Number: MCCET-4498. Lassoing in Bin Frame View using Shift or Ctrl did not work properly.
    • Bug Number: MCCET-4056. Applying a Matte key effect to a ProRes 4444 file did not preserve the fill layer.
    • Bug Number: MCCET-4437. Selecting “Set Audio Suite Plugin In/Out” from the AudioSuite Plugin fast menu does not work on rendered effect after performing an Undo.
    • Bug Number: MCCET-4519. In some circumstances you might have received an error when using Color Correction with dupe detection enabled.
    • Bug Number: MCCET-4382. In some instances, Dynamic Relink settings unexpectedly reverted to Most Recent.
    • Bug Number: MCCET-4562. In some instances, LTC signals did not parse correctly in Read Audio Timecode.
    • Bug Number: MCCET-4332. Transcoding linked 50fps h264 clips to 50i resulted in the wrong duration.
    • Bug Number: MCCET-4371. (macOS) When working with a vector based object, Shift-clicking a direction handle did not create an asymmetrical handle.
    • Bug Number: MCCET-4479. When moving bins in a project, it can take too long for the bin to respond and in some instances the beachball appears when moving the bin.
    • Bug Number: MCCET-4443. You might have received a “m_qDrag deleted with deleteLater” error after dragging a button from the Command Palette to another button under the Composer Window.
    • Bug Number: MCCET-4501. If a floating Timeline window is made smaller, scrolling with the mouse wheel does not work properly.
    • Bug Number: MCCET-4450. Media Composer | Enterprise might have launched as Media Composer standard.
    • Bug Number: MCCET-4436. If Dynamic Relink was enabled, an imported audio file might have appeared offline.
    • Bug Number: MCCET-4494. (Production Management) In some instances, after checking in sequences, the thumbnail in Access would display “No head frame.
    For details on the complete bug fixed, see the attached document on the Knowledge Base Media Composer 2021 Documentation .
    ReadMe: The new ReadMe is attached to this Community Alert #481 and will be uploaded to the Knowledge Base Media Composer 2021 Documentation page at launch.
    Mac Pro, Monterey, 64GB Ram. 1TB SSD system drive, 250Gb SSD external (media) drive. QHD Ultra wide, thunderbolt LG monitor, MC 2021.12 Pro Tools 2021... [view my complete system specs]
  • Fri, Apr 15 2022 9:49 AM In reply to
    Re: Media Composer 2021.12.2 launched today
    Thanks for the update Robert.
    Just a question. I see the old .1 patch has been pulled all together. So both a Mac and PC 2021.12.2 version was released. That could mean the PC .2 version is 100% identical to the .1 version and there is no reason for pc users to download and install this update.
    Or was the issue that the patch wasn't checking for a media composer 2021.12 base install being present also fixed on the PC side? Not that it matters for those that managed to install it.
    Jeroen van Eekeres
    www.mediaoffline.com
