Im getting strange behavior with MC. Playback stutters, I have to render on pictures with basic text above it (even that doesn't help sometimes). I am using title plus, not sure if there is an issue there. I have no clue what the issue is. Im thinking I may have a driver issue with my card but wanted to get some insight from those here. Yes I know its not a certified system. If anyone who uses a similar setup and is running fine, any tips or advice is greatly appericated. Only working with HD projects, no 4k.
Ryzen 7 8 core 3.59 ghz
62gb ram
geroforce rtx 2060 with 511.23 driver
MC 2021.9
dew:I am using title plus
Titler+ is probably the problem. If you want to know for sure, remove the titles from the sequence and see if performance improves.
Ok will do. Thank you
