Latest post Tue, Feb 8 2022 8:27 PM by CraigS. 8 replies.
Page 1 of 1 (9 items)
  • Thu, Jan 27 2022 6:55 PM
    • CraigS
    • Joined on Thu, Jan 27 2022
    • Posts 6
    • Points 60
    Migrating Media from Older Isis Server
    Hi, my client needs to move all the media off an older Unity Isis server. They no longer have support for this system but they need to move all the media from it. When they attempt to copy the media, from a PC they get error message "Error 0x8007045D: The request could not be performed because of an I/O device error". On the Mac it says "'file' can't be read or written. (Error code-36)". When we attempted to copy/paste the media, the Mac gave the same code, then pasted a corrupt file.
    On the PC, it does allow you to move small filess like jpg and png but not footage.
    Here are the specs if helpful:
    EVO 16 Bay Base 16X12TB – 2X10GbE Optical;
    EVO Base System: 3U, 64bit Multi-core CPU, 16 Bay,
    192 TB RAW (16 x 12TB SATA 6Gb/s), 4 x 16b Ethernet,
    EVO Ethernet Expansion: Ports (iSCSI/NAS), 2 x 10GbE
    Optical, Asset Management, Cloud Access, Avid Project/Bin Sharing,
    Adobe and Apple Project Sharing, File/Volume Sharing, NAS (AFP/SMB/NFS/SFTP) and SAN in the same box.
    Can anyone share any tips on getting around these codes to move the media to another drive? Thanks!
  • Thu, Jan 27 2022 10:25 PM In reply to
    Re: Migrating Media from Older Isis Server
    Are you able to copy footage to an internal or USB or Thunderbolt drive?
    MC 2024.12, W11, ASUS z690m, Intel 13900K, MSI 4090 Suprim Liquid, 128GB RAM, Samsung 980 Pro M2 SSD, BM Mini monitor & Dell UP2718Q. MBP 2019, Sonoma... [view my complete system specs]
  • Thu, Jan 27 2022 11:09 PM In reply to
    • CraigS
    • Posts 6
    • Points 60
    Hi Dom,
    No, we can't copy to local or external. On the PC it spends a bit then gives the error code. Connecting from a Mac sometimes will copy the file over with the error code mentioned but the file will be corrupt, pixelated and incomplete.
  • Thu, Jan 27 2022 11:17 PM In reply to
    • CraigS
    • Posts 6
    • Points 60
    I've attached a couple of screen shots to show the messages.
  • Fri, Jan 28 2022 9:51 AM In reply to
    • B3n3d1kt
    • Joined on Tue, Mar 24 2020
    • Germany
    • Posts 24
    • Points 265
    Have you checked the hardware if a drive is dead/dying?
    Have you try to reboot? We have been suggested to make a reboot every 4 weeks to prevent harddrives to fail.
    MC 2019.12 (Win 10 1909) custom Workstation: AMD Threadripper 3960X (NH-U14S TR4-SP3 + NF-A15), ASUS TRX40-E Gaming, 64GB DDR4-3200 Corsair, MSI RTX 2070... [view my complete system specs]
  • Fri, Jan 28 2022 4:37 PM In reply to
    • CraigS
    • Posts 6
    • Points 60
    Hmm, how can you tell if the drive is dying? Also, what is the proper way to reboot the server?
  • Fri, Jan 28 2022 7:02 PM In reply to
    • B3n3d1kt
    • Germany
    • Posts 24
    • Points 265
    When one drive from our ISIS died, we got an error while consolidating. We also got some error logs in the ISIS web view.
    Login to the ISIS server using VNC or connect a monitor. Then look for the raid controller software
    ISIS 5000: Start->Programs->MegaRAID Storage Manager->StartupUI
    Login and the you see all drives in the tab "Physical". Look for "Media Error Count" and "Pred Fail Count" for each drive. They all should be 0.
    Reboot:
    - Disconnect all clients
    - login to ISIS server
    - Start "Avid ISIS System Director Control Panel"
    - Click "Stop System Director"
    - Reboot and make a coffee because it take at least 10 minutes Smile
    - you can check if the server is up by cmd-> ping "ISIS IP" -t
  • Mon, Jan 31 2022 1:26 PM In reply to
    • CraigS
    • Posts 6
    • Points 60
    Thanks so much! We'll give this a try.
  • Tue, Feb 8 2022 8:27 PM In reply to
    • CraigS
    • Posts 6
    • Points 60
    It looks like my client was unable to resolve the issue. I'm hoping someone on here can point me to an independent tech support person or company in the DMV, (Washington DC/Maryland or Virginia) area that could come in help us resolve the problem and recover the media from the server.
    Thanks everyone for the help.
