Latest post Tue, Jul 5 2022 6:11 PM by sloppygrilledcheese. 12 replies.
Page 1 of 1 (13 items)
  • Wed, Jan 19 2022 8:58 PM
    • Rowan Copeland
    • Joined on Wed, Jan 19 2022
    • London, United Kingdom
    • Posts 3
    • Points 55
    No Video Playback
    I've been having a problem using Media Composer and there doesn't seem to be a solution online and some people I've asked don't seem to know what's causing the problem either.
    It's simply the case of there being no video playback when hitting play. Hitting space, L or using the cursor makes the symbol go green but nothing happens. I'm able to scrub through the timeline perfectly fine or even go frame by frame. Sometimes hitting play and pause over and over eventually forces it to play. However, as you can imagine this is very frustrating and makes trying to edit seem impossible. My friend who has the same system and versions also has the exact same issue. So surely if I'm able to easily replicate the issue then more people must have had a similar problem and there could potentially be a solution.
    I've tried a lot of different methods to fix the problem. Here is a list of methods I've tried that I can remember:
    - Creating a new user profile
    - Reinstalling the software
    - Trying an older version
    - Deleting the database for the video files
    - Creating a new project and using different video files
    - Transcoding files different ways
    - Disabled high quality scaling
    - Increasing video memory
    - Increasing file cache size
    - Disconnecting 2nd display
    It's a very weird issue that's stopping me from using the software. So if there are any other methods I could try please let me know.
    MacBook Pro | MacOS 12.1 | Media Composer 21.12 | Processor - Core i5 (i5-1038NG7) | RAM - 16GB 3733 Mhz | Video Card - Iris Plus [view my complete system specs]
  • Thu, Jan 20 2022 6:39 PM In reply to
    • Adman
    • Atlanta Georgia, USA
    • Posts 5,473
    • Points 62,045
    • BlogAuthor
      Moderator: Avid Free DV
      Moderator: Avid Xpress DV PC
      Moderator: Avid Xpress Studio
    Re: No Video Playback
    Am I to assume this is a new install and you haven't had Media Composer running on this system previously?
    Mac Pro, Monterey, 64GB Ram. 1TB SSD system drive, 250Gb SSD external (media) drive. QHD Ultra wide, thunderbolt LG monitor, MC 2021.12 Pro Tools 2021... [view my complete system specs]
  • Thu, Jan 20 2022 7:18 PM In reply to
    • Rowan Copeland
    • Posts 3
    • Points 55
    That's correct.
  • Thu, Jan 20 2022 9:02 PM In reply to
    Hi Rowan, I'm following up the support case I made on your behalf ;)
    I tried all sorts of things on your system and couldn't get it working. Including turning GPU acceleration off and playing around with render on the fly etc.
    The initial response from support was that your I5 processor isn't qualified, but my ryzen 7 isn't qualified either and has been working fine for years. Although... I've never used your configuration on a MAC system though.. so not sure. Still can't imagine that to be the issue. Will ask them to investigate further.
    If anyone has any ideas please chime in.
    Editing Movie Magic.
    My Equipment & System Specs
    Media Composer Ultimate 2022.7 | Pro Tools Studio 2022.7 | Avid Play | Sibelius Artist 2022.7
  • Fri, Jan 21 2022 10:57 AM In reply to
    This type of problem is normally related to display driver issues. When the clip is parked or scrubbed or frame stepped a still image is displayed on the screen. However in playback the display operates in a different way and its the failure of this that prevents the playback image to show. On a PC I'd be looking at the graphics card. Its onboard memory or the shared memory settings. The display driver version and settings. But less familiar with the Mac side.
  • Sat, Jan 22 2022 6:31 PM In reply to
    • MikeyB
    • Edlesborough, UK
    • Posts 607
    • Points 7,590
    I've had this happen a few times recently with v2021.12 on my Monterey Mac. Although it seems like it's Video that's the problem, it actually appears to be Audio related. If you disable the Audio tracks in the timeline, does it then play?
    If so, try holding the Alt key as you start the software.  Keep hanging on as it runs, and eventually it'll come up with a dialogue asking which 'audio card' you want to use. Choose 'Mac OS' or some such. Then all should be well.
    2021 MacBook Pro 16" (M1 Max 32GB), 2019 iMac 27" (8-core i9, 40GB) [view my complete system specs]
  • Sun, Jan 30 2022 3:40 PM In reply to
    • Rowan Copeland
    • Posts 3
    • Points 55
    After a lot of testing I've found a fix for this issue. Disabling Phonetic Indexing has completely fixed the playback issue. Enabling Phonetic Indexing causes the playback issue to come back. I thought lowering video memory helped, but changing that setting didn't make a difference.
    Potentially a bug, because I assume this feature should work fine. Avid MC works perfectly fine now with my specs, even after I was told my hardware isn't "qualified".
  • Sun, Jan 30 2022 6:08 PM In reply to
    • Adman
    • Posts 5,473
    • Points 62,045
    • BlogAuthor
    Rowan Copeland:
    In Avid® Media Composer® v2021.12:
    "Turn off Phonetic Indexing. Access this option by pressing Ctrl + F to open the Find Window.
    Click the Settings button (gear icon) in the Find window and click Stop Indexing."
  • Wed, Jun 29 2022 1:24 AM In reply to
    I'm having the exact issue with no playback when I press the spacebar/play buttons. I've tried disabling Phonetic Indexing but that doesn't seem to solve the issue. Very rarely, it will play and then revert back to no playback whatsoever.
    My MediaComposer is 2012.12.2.
    I was on macOS Monterey 12.4 when the issue started happening. I have since downgraded to Big Sur 11.6.7 to troubleshoot but the issue still exists. I am on an Intel Mac Mini (2018), 3.2 GHz 6-Core Intel Core i7, 64GB, Intel UHD Graphics 630.
    I have also noticed that with MC open, if I jump into Google Chrome to play something on Youtube, it loads and loads and never plays.
    Any thoughts?
  • Thu, Jun 30 2022 2:09 PM In reply to
    Hi, Do you have an I/O box connected to your system at all?
  • Fri, Jul 1 2022 6:00 PM In reply to
    Hi, I do not. I have been able to edit without it in the past, but I have tried so many ways to troubleshoot at this point, that if it's an I/O box I need to avoid this problem, I'll get one. Any recs on what I should get? The outputs I need are just two video monitors and stereo speakers.
  • Mon, Jul 4 2022 10:07 AM In reply to
    Well if MC won't play without a I/O box - It wouldn't play with one either.
    Have you tried resetting your Avid user settings?
    Also, could you go into settings > site > media cache and see what your video memory settings look like?
  • Tue, Jul 5 2022 6:11 PM In reply to
    Good to know. Yes I've rebuilt my Avid profile from scratch.
    My media cache settings are:
    Video Memory: 32GB (out of 64 max)
    File Cache: 32GB (out of 64 max)
    I have toggled the Enable Playback Video Frame Cache and the Enable FX Editing Video Frame Cache both on and off - did not observe any changes.
    Thumbnail and source browser caches are set to local destination, while I am cutting off of two external hard drives with DNxSQ.
