Latest post Tue, Sep 6 2022 10:05 PM by CBMEDIA. 4 replies.
  • Wed, Dec 1 2021 10:29 PM
    • dharia
    • Joined on Fri, Sep 19 2008
    • Posts 214
    • Points 2,775
    Can't import Mp4 or Mp3 or M4a to AVID 2021 Catalina
    Here is a video clip
    https://vimeo.com/652228301/2a0703db71
    On Mojave (I know its QT7 based and 32bit) I could easily import a M4a voice memo from a iPhone 12, or a MP4 file from Adobe Media Encoder (just a standard Youtube Facebook format) or a Mp3 file from a VO Artist.
    But now I can't use the import function to do that, nor can I just drag it into the bin, I have to go to the SOURCE BROWSER, and then choose import, and then it pops up a message saying the file isn't supported, so then I have to click yes to convert it then it places it into the bin.
    How can I make it so these super simple file formats that are coming out of Adobe 2021 and an iPhone 12 , or even Adobe 2015 and an iPhone 6, all go into AVID fast like the Mojave 2021 AVID supported just fine like all AVID's before.
    Everything else works great, I can drag a OP1A MXF into the bin, I can drag Pro Res and DNX and Quicktimes like that into the bin or import, everything works but why not simple viewable quality files?
  • Thu, Dec 2 2021 9:26 AM In reply to
    Re: Can't import Mp4 or Mp3 or M4a to AVID 2021 Catalina
    dharia:
    As you mention in the first part of your post, Catalina and later MacOS no longer supports 32-bit apps like Quicktime, and that obviously has an effect on import in Media Composer.
    If you look at 'MacOS Catalina support' and 'Avid Universal Media Engine' in the What's New document for 2020.4, this issue is addressed in more detail.
    https://resources.avid.com/SupportFiles/attach/WhatsNew_MediaComposer_v20.4.pdf
    Media Composer 2024.6 w/Symphony/SS/PF options, HP Z-Book G6 17", i7-9850H 2.60GHz, 64gb RAM, NVIDIA Quadro RTX 3000, Blackmagic UltraStudio Mini... [view my complete system specs]
  • Thu, Dec 2 2021 10:33 AM In reply to
    • dharia
    • Posts 214
    • Points 2,775
    Yes but is there a way to make it so its super easy to just drag stuff in and have it convert on the fly to the UME/MXF?  I mean still in Premiere 2022 I can drag anything in the bin and it'll work and play. AVID 2021 on Mojave did the same. So on Catalina how it can it be such a step back that you can't drag in or import simple formats in one step? I would understand complex formats, but these are standard things that have been around forever.
    It'd be like in Microsoft Word 2022 if you couldn't open any old word files or text files without converting them first and then bringing them in.
  • Thu, Dec 2 2021 12:55 PM In reply to
    dharia:
    Mojave supports 32-bit apps, like Quicktime. Catalina doesn't.
    dharia:
    The first thing to try is linking and transcoding. If the files link, transcode them to whatever resolution you'd use if you were importing.
    I don't know of a way to link & transcode in one step. You can OPT+drag files into a bin to link them, but you'll still have to select them to transcode them.
  • Tue, Sep 6 2022 10:05 PM In reply to
    • CBMEDIA
    • Joined on Wed, Feb 16 2022
    • Posts 8
    • Points 60
    THANK YOU!
    I was having the same issue pretty much on mac os monterey + Avid 2022.7
    (both recently upgraded, not sure that was a great idea!)
    The source browswer was not recognising mp3s... or wavs (when I converted them)...
    just showing up as unrecognisable CLIPS that would not link or import (or drag to import0.
    BUT DRAGGING+OPTION as per your suggestion WORKED:
    *** You can OPT+drag files into a bin to link them, but you'll still have to select them to transcode them. ***
    (Then I transcoded them all - solid, phew. was very worried I couldn't import audio any more on the new AVID!)
