Latest post Sun, May 28 2023 2:50 PM by pcr. 20 replies.
  • Sat, Oct 30 2021 9:06 PM
    Maintaining Resize Information When Exporting AAF to Resolve
    Hi all,
    In past projects utilizing a Media Composer to Resolve workflow, my AAFs would maintain Resize effects used in MC and translate appropriately to Resolve; however, the most recent project I'm working on does not translate the resize, forcing me to apply the effects again manually. I'm making sure to check "use sizing information" in Resolve - still no luck.
    Any help would be appreciated! Thanks.
  • Sun, Oct 31 2021 1:30 AM In reply to
    • jef
    • Joined on Sun, Feb 26 2006
    • Maryland
    • Posts 4,181
    • Points 50,460
    Re: Maintaining Resize Information When Exporting AAF to Resolve
    Resolve will only recognize 3D Warp efffects for Resize, not the classic Resize effects.  Resolve also does not recognize Frameflex effects.
    Jef
    Avid DS 11.0.2 R.I.P | MC "Well, it depends ..." 2023.3.1 iMac w Big Sur and 2018.12.7 on Windows 10 Boot Camp [view my complete system specs]
    Jef Huey
  • Sun, Oct 31 2021 11:57 AM In reply to
    jef:
    Jef
    Jef, might there be a list somewhere outlining all the effects resolve supports when doing an AAF?
    Thanks in advance.
    Editing Movie Magic.
    My Equipment & System Specs
    Media Composer Ultimate 2022.12.2 | Pro Tools Studio 2022.21 | Sibelius Artist 2022.12
  • Sun, Oct 31 2021 2:51 PM In reply to
    • jef
    • Maryland
    • Posts 4,181
    • Points 50,460
    Yes - the Resolve Reference Manual.  In fact, there is an excellant discription of the the entire roundtrip method in this document.  In the current v17 edition a chart showing supported effects is on page 945.
    This document can be downloaded from the BlackMagic design support website.
    Jef
    EDIT: Sorry - really page 946.
    Jef Huey
  • Sun, Oct 31 2021 6:29 PM In reply to
    jef:
    Jef
    946 pages 😅
    Thank you.
  • Sun, Oct 31 2021 6:31 PM In reply to
    Ah, thanks for the quick info! I'll go ahead and translate all of my resize into 3D Warp then. Thanks!
  • Tue, Nov 2 2021 8:29 PM In reply to
    • touviere7
    • Joined on Mon, Mar 15 2010
    • los angeles
    • Posts 704
    • Points 8,035
    Philip Kapadia:
    946 pages 😅
    Thank you.
    3605 pages actually...Stick out tongue
    symphony 2020.12 - win 10 pro64 v.21H2 - nVidia gtx1080 OC (472.47 studio) - intel i7 6800k @4.2ghz water cooled by corsair H100i V2 - MSI X99A - 112GB... [view my complete system specs]
  • Tue, Nov 2 2021 9:10 PM In reply to
    touviere7:
    Philip Kapadia:
    946 pages 😅
    Thank you.
    *runs away*
  • Fri, Nov 5 2021 1:07 PM In reply to
    • oklaroma
    • Joined on Thu, Apr 12 2018
    • Posts 8
    • Points 105
    Clarification: Resolve will recognize Frameflex effects, with one caveat--you need a keyframe.
    In Avid, when you make Frameflex adjustments in the bin, the entire clip is affected and no keyframes are created; however, when you make Frameflex adjustments to the clip in the timeline, a keyframe is automatically created.
    So, as a workaround to the Frameflex issue in the Resolve roundtrip, keyframes are the solution.
    In my case, I created a hotkey to add a Frameflex keyframe to the first frame of the clip in Avid. In essense, this "commits" the Frameflex setting on the clip. Granted, you have to repeat the process for each affected clip, but the hotkey speeds up the process. Then, when you export the AAF, the Frameflex resize "sticks" and translates to Resolve. (Note: if using proxy media, be sure to execute this step before re-linking to source clips or the resize data will be lost in the re-link.)
    It's not ideal, and it takes a little time, but it works in my circumstance, and sure beats trying to re-create the sizing in Resolve. A "Commit Frameflex" feature request?
  • Fri, Nov 5 2021 2:42 PM In reply to
    • jef
    • Maryland
    • Posts 4,181
    • Points 50,460
    oklaroma:
    Very interesting.  I will give this a try today.  Thank you for sharing.
    Jef
    Jef Huey
  • Fri, Nov 5 2021 3:13 PM In reply to
    • jef
    • Maryland
    • Posts 4,181
    • Points 50,460
    oklaroma:
    So I am testing this and it is NOT working for me.  Avid 2021.6.0 to Resolve 17.3.1.
    I am using SD footage into a HD sequence. Key frames added to clips in the sequence.  Once I am in Resolve, the clips are all postage stamps no matter what sizing / positioning I tried.
    Thoughts?
    Jef
    Jef Huey
  • Fri, Nov 5 2021 3:29 PM In reply to
    • jef
    • Maryland
    • Posts 4,181
    • Points 50,460
    Another quick test seems to show that it works with UHD source into an HD sequence.  I am going to keep fiddling with it.  I have come up with a convoluted workflow for getting SD sizing/position into an HD AAF for Resolve.  I will post it once I am a bit more confident.
    But this whole mess underscores my long running complaints about FrameFlex.
    Jef
    Jef Huey
  • Fri, Nov 5 2021 3:34 PM In reply to
    • oklaroma
    • Posts 8
    • Points 105
    Correct--my workflow is using UHD source material in an HD sequence. I have not experimented with SD, but I would like to hear your workflow.
  • Wed, Nov 10 2021 11:07 PM In reply to
    • N Ryan
    • Joined on Thu, Jul 3 2014
    • Melbourne, Australia
    • Posts 96
    • Points 1,200
    I did some tests sending Avid AAFs to Resolve (the first half of roundtripping) just to get my head around the difference for Resolve of receiving sizing information from FrameFlex versus a filter (3DWarp etc.)
    I got a UHD clip and cut it into a HD Sequence (common formatting for me) multiple times. There was no Frameflex action in the source clp.
    I then applied different resizing methods to obtain the same effect. Static, no moves.
    Here's what went across, successfully:
    clip 1: Frameflex with one keyframe
    clip 2: Frameflex with no keyframes
    clip 3: 3DWarp
    clip 4: Resize
    clip 5: which was a HD clip with a Resize
    What doesn't go across of course, is combinations - they become like Nested Effects, which are not supported. So using Frameflex + 3DWarp or Frameflex + Resize does not combine the sizing attributes into one for Resolve. In both these cases, the Frameflex numbers went through and the 3DWarp or Resize was excluded.
    So, just to reiterate, RESIZE works for me.
    MC 2021.9      DaVinci Resolve 17.2.1
    Media Composer 2021.9 HP Z6 G4 Workstation 32.00 GB RAM Intel(R) Xeon(R) Silver 4116 CPU @ 2.10GHz Boris Continuum 2021.5 Avid Nexus [view my complete system specs]
    Neil.
  • Thu, Nov 11 2021 12:53 AM In reply to
    Neil - thank you so much for your experimentation! This corroborates my prior memory of having a Resize effect go over. I think I applied a FrameFlex to all my clips because I'm working a slightly odd UHD aspect ratio that's native to ARRI Mini cameras and I didn't want to set up a custom sequence size - when I get home, I'll remove the frameflex and try exporting again. Thanks so much!
