I normally have the timeline setting enabled that makes clicking on the TC ruler disable smart tools.
In CC mode clocking on the tC ruler throws you back in source/record workspace.If you then choose CC workspace to return it won't work until you 'return the workspace to saved' or reset it to default.This restore the CC workspace.
Bug?
nigelad: I normally have the timeline setting enabled that makes clicking on the TC ruler disable smart tools. In CC mode clocking on the tC ruler throws you back in source/record workspace.If you then choose CC workspace to return it won't work until you 'return the workspace to saved' or reset it to default.This restore the CC workspace. Bug?
You're a certified instructor so I'm sure you know more about this than I do; Have you tried to re-set your user settings?
Editing Movie Magic.
My Equipment & System Specs
Hi Philip,
Yes, it happens consistently with a new user.Can somebody report this as a bug for 21.6?
nigelad: Hi Philip, Yes, it happens consistently with a new user.Can somebody report this as a bug for 21.6?
If feasible, Could you try to upgrade to the latest version and see if you can re-create the error? If you can, submit a support case: https://avid.secure.force.com/pkb/articles/en_US/how_to/Support-Plan-Case-Creation
The support representatives can report this as a bug to the engineering team.
