Latest post Mon, Jan 24 2022 4:35 PM by Jasper Quispel. 10 replies.
Page 1 of 1 (11 items)
  • Mon, Oct 11 2021 1:39 PM
    • insch
    • Posts 372
    • Points 4,390
    DISK_LOCKED errors and MC crashes
    I am getting sporadic DISK_LOCKED errors with my current project and then it crashes. Otherwise the project seems to be stable. I am not aware of any locked disks and I checked that none were running very full as I read that can be the cause of this error message sometimes. I am using a mixture of linked 4k and HD media from several drives and some transcoded media on the project. I'm using MC version 2021.9.
    Any thoughts/advice?
    Mac Pro, 3.7 GHz Quad-core, 64GB RAM, G-Tech G-RAID Studio 6TB and 10TB etc. [view my complete system specs]
  • Mon, Oct 11 2021 10:00 PM In reply to
    • hbrock
    • Bainbridge Island, WA
    • Posts 5,578
    • Points 64,975
    • Moderator: MCA Mac
    Re: DISK_LOCKED errors and MC crashes
    Check permissions on the drive where your Project is located to make sure you have Read/Write access.
    Also, if you're running Mojave and you've installed Legacy Components you might need to change the permissions to Read/Write for Everyone on the Site Attributes file inside of Applications/Avid Media Composer/Settings.
    To change permissions, click on the file, Get Info (Cmd-I), unlock by clicking on the padlock in the lower left corner and change.
  • Wed, Oct 13 2021 8:12 AM In reply to
    • insch
    • Posts 372
    • Points 4,390
    hbrock:
    Thank you
    Top level of my Mac HD doesn't have me listed for permissions - see grab - and I can't add myself. But I do have permissions for my User folder where the Avid Projects folder resides. This DISK_LOCKED error comes and goes which is rather strange. Site Attributes has permissions for everyone. Any other thoughts?
  • Thu, Oct 14 2021 11:10 AM In reply to
    • insch
    • Posts 372
    • Points 4,390
    Still no joy with this issue. I am still getting the DISK-LOCKED error and sporadic crashes with my MC project. The disk that the project is hosted on is not locked and I have permissions to the relevant folders. The drive is also not full. Any advice on how to resolve this?
  • Thu, Oct 14 2021 12:03 PM In reply to
    Have you tried fixing permissions on the relevant drive? Macs can end up with orphaned permissions that aren't reflected in that top level permissions detail.
    T 07581 201248 | E [email protected]
  • Thu, Oct 14 2021 2:34 PM In reply to
    • insch
    • Posts 372
    • Points 4,390
    Pat Horridge:
    Thanks Pat. I am working with Big Sur. There no longer seems to be an option to fix permissions as a separate act but I booted into Recovery Mode and ran First Aid. Will that suffice?
  • Fri, Oct 15 2021 6:34 PM In reply to
    • insch
    • Posts 372
    • Points 4,390
    MC still crashing after disk first aid but not sure if I've seen the error. Some of crash report below:
    Process:               AvidMediaComposer [10170]
    Path:                  /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/MacOS/AvidMediaComposer
    Identifier:            AvidMediaComposer
    Version:               21.9.0.55465 (21.9.0)
    Code Type:             X86-64 (Native)
    Parent Process:        ??? [1]
    Responsible:           AvidMediaComposer [10170]
    User ID:               501
    Date/Time:             2021-10-15 19:15:30.689 +0100
    OS Version:            macOS 11.6 (20G165)
    Report Version:        12
    Anonymous UUID:        D785EB87-0928-857B-A388-D48D9A7CC808
    Time Awake Since Boot: 40000 seconds
    System Integrity Protection: enabled
    Crashed Thread:        225  Dispatch queue: com.apple.audio.HALB_DQ.ClientNormalPrioritySerialQueue
    Exception Type:        EXC_CRASH (SIGABRT)
    Exception Codes:       0x0000000000000000, 0x0000000000000000
    Exception Note:        EXC_CORPSE_NOTIFY
    Application Specific Information:
    abort() called
    AvidMediaComposer(10170,0x700007ebb000) malloc: *** error for object 0xffffffff: pointer being freed was not allocated
  • Tue, Oct 19 2021 7:46 AM In reply to
    • insch
    • Posts 372
    • Points 4,390
    I am still getting the DISK_LOCKED error - intermittently, which is strange. I host my Avid Projects folder in my Dropbox folder on my Mac HD so I can easily work on projects across my different Macs. I have never had any problems working this way before. Could this now be causing an issue with MC and intermittent disk permissions issues? Obviously I have Read/Write permissions on my Dropbox folder. I have now moved my Avid Projects folder to an external drive outside of Dropbox to see if that makes a difference.
    Any thoughts?
  • Tue, Oct 19 2021 10:45 AM In reply to
    • insch
    • Posts 372
    • Points 4,390
    Moving Avid Projects folder to another location didn't fix it - not sure about whether a DISK_LOCKED error came up but I went out to walk the dog and came in to find the project had crashed again.
    Actually just saw in the crash report that DISK_LOCKED is still there - this is a new location on a different drive - neither of which are locked.
    Crashed Thread:        0  Main Thread  Dispatch queue: com.apple.main-thread
    terminating with uncaught exception of type XError: DISK_LOCKED
    abort() called
    Have now tried creating a new project and putting my bins in there.
  • Sat, Oct 30 2021 11:27 AM In reply to
    • insch
    • Posts 372
    • Points 4,390
    Anyone?
    This problem hasn't gone away - new Mac, new SSD, same problem with Media Composer crashes and DISK_LOCKED errors - below is latest crash report.
    Crash report:
    Process:               AvidMediaComposer [43771]
    Responsible:           AvidMediaComposer [43771]
    User ID:               501
    Date/Time:             2021-10-30 11:27:43.993 +0100
    Report Version:        12
    Bridge OS Version:     5.5 (18P4759a)
    Anonymous UUID:        B4D51BF7-CD96-FD4C-A2CB-01B0B2CCE4EC
    Time Awake Since Boot: 98000 seconds
    abort() called
    Thread 0 Crashed:: Main Thread  Dispatch queue: com.apple.main-thread
    0   libsystem_kernel.dylib            0x00007fff203b792e __pthread_kill + 10
    1   libsystem_pthread.dylib           0x00007fff203e65bd pthread_kill + 263
    2   libsystem_c.dylib                 0x00007fff2033b406 abort + 125
    3   com.avid.mediacomposer            0x0000000103bf1092 mcabort(int) + 74
    4   libsystem_platform.dylib          0x00007fff2042bd7d _sigtramp + 29
    5   ???                               0x00007ffeec0808d0 0 + 140732858370256
    6   libsystem_c.dylib                 0x00007fff2033b406 abort + 125
    7   libc++abi.dylib                   0x00007fff203a9ef2 abort_message + 241
    8   libc++abi.dylib                   0x00007fff2039b5e5 demangling_terminate_handler() + 242
    9   libobjc.A.dylib                   0x00007fff20294595 _objc_terminate() + 104
    10  libc++abi.dylib                   0x00007fff203a9307 std::__terminate(void (*)()) + 8
    11  libc++abi.dylib                   0x00007fff203a92a9 std::terminate() + 41
    12  com.avid.mediacomposer            0x0000000104ff755c BlipPlayer::PlayBlipField(BlipPlayUIMonPane&, int, int, int, videoField_t, int) + 918
    13  com.avid.mediacomposer            0x000000010508bc91 ObsoleteHighLevelPlayer::CropAndPlayBlipField(bool, BlipPlayUIMonPane&, int, int, int, videoField_t, int) + 173
    14  com.avid.mediacomposer            0x0000000105068b74 MonPane::PlayBlipOnscreen(int, unsigned char, AvRect*, AvRect*, unsigned char, unsigned char) + 728
    15  com.avid.mediacomposer            0x000000010500095d AMonitorPane::PlayBlip(int, unsigned char, AvRect*, unsigned char) + 1029
    16  com.avid.mediacomposer            0x0000000104fe89e6 MonViewPane::DrawVideoFrame(int, AvRect*, unsigned char, unsigned char, unsigned char) + 246
    17  com.avid.mediacomposer            0x0000000104fe8564 MonViewPane::DrawWithAudio(AvRect*, unsigned char, unsigned char) + 2172
    18  libUIshell.dylib                  0x00000001213a0714 APane::Draw(AvRect*, void*) + 214
    19  libUIshell.dylib                  0x00000001213a1a49 APane::DrawDetail(AvRect*, AvRGBColor, void*) + 1007
    20  libUIshell.dylib                  0x00000001213a13a8 APane::DrawInterior(AvRect*, void*) + 540
    21  libUIshell.dylib                  0x00000001213a0714 APane::Draw(AvRect*, void*) + 214
    22  libUIshell.dylib                  0x00000001213a1a49 APane::DrawDetail(AvRect*, AvRGBColor, void*) + 1007
    23  libUIshell.dylib                  0x00000001213a13a8 APane::DrawInterior(AvRect*, void*) + 540
    24  libUIshell.dylib                  0x00000001213a0714 APane::Draw(AvRect*, void*) + 214
    25  libUIshell.dylib                  0x00000001213a1a49 APane::DrawDetail(AvRect*, AvRGBColor, void*) + 1007
    26  libUIshell.dylib                  0x00000001213a13a8 APane::DrawInterior(AvRect*, void*) + 540
    27  libUIshell.dylib                  0x00000001213a0714 APane::Draw(AvRect*, void*) + 214
    28  libUIshell.dylib                  0x0000000121394102 AWindow::Update(void*, Mac2Qt::EventRecord*, int, int) + 454
    29  libUIshell.dylib                  0x000000012139785a AWindow::DoWindowMsg(windowMsgID_t, void*, Mac2Qt::EventRecord*, int, int, int) + 112
    30  com.avid.mediacomposer            0x00000001045cd0ba ComposerWindow::DoWindowMsg(windowMsgID_t, void*, Mac2Qt::EventRecord*, int, int, int) + 164
    31  libUIshell.dylib                  0x0000000121392e0e AWindow::SendMsg(windowMsgID_t, Mac2Qt::EventRecord*, int, int, int) + 188
    32  libUIshell.dylib                  0x00000001213ba9fd AApplication::HandleEvent(Mac2Qt::EventRecord*) + 1105
    33  com.avid.mediacomposer            0x0000000103bf792a MediaComposerApp::HandleEvent(Mac2Qt::EventRecord*) + 100
    34  libUIshell.dylib                  0x00000001213bb09c AApplication::ProcessCurrentEventImpl(bool, bool, bool*) + 510
    35  libUIshell.dylib                  0x00000001213c17f6 AApplication::CarbonEventHandlerProc(Mac2Qt::Private::EventHandlerCall*, Mac2Qt::Private::EventQueueItem*, void*) + 410
    36  com.avid.Mac2Qt                   0x0000000126d01220 Mac2Qt::Private::EventHandlerCall::invokeNextHandler() + 278
    37  com.avid.Mac2Qt                   0x0000000126d00fa1 Mac2Qt::Private::DispatchEventToCallbacks(Mac2Qt::Private::EventQueueItemSmartPtr const&) + 324
    38  com.avid.Mac2Qt                   0x0000000126d030a8 Mac2Qt::Private::Mac2QtEventWaiter::eventFilter(QObject*, QEvent*) + 132
    39  org.qt-project.QtCore             0x0000000108027bb1 QCoreApplicationPrivate::sendThroughApplicationEventFilters(QObject*, QEvent*) + 193
    40  org.qt-project.QtWidgets          0x00000001091ecc62 QApplicationPrivate::notify_helper(QObject*, QEvent*) + 66
    41  org.qt-project.QtWidgets          0x00000001091ee0f7 QApplication::notify(QObject*, QEvent*) + 471
    42  com.avid.Mac2Qt                   0x0000000126d10bbe Mac2Qt::AQtApplication::notify(QObject*, QEvent*) + 406
    43  org.qt-project.QtCore             0x0000000108027a24 QCoreApplication::notifyInternal2(QObject*, QEvent*) + 212
    44  org.qt-project.QtCore             0x0000000108028a32 QCoreApplicationPrivate::sendPostedEvents(QObject*, int, QThreadData*) + 402
    45  libqcocoa.dylib                   0x0000000130611712 QCocoaEventDispatcherPrivate::processPostedEvents() + 322
    46  libqcocoa.dylib                   0x0000000130611e28 QCocoaEventDispatcherPrivate::postedEventsSourceCallback(void*) + 40
    47  com.apple.CoreFoundation          0x00007fff204de2bc __CFRUNLOOP_IS_CALLING_OUT_TO_A_SOURCE0_PERFORM_FUNCTION__ + 17
    48  com.apple.CoreFoundation          0x00007fff204de224 __CFRunLoopDoSource0 + 180
    49  com.apple.CoreFoundation          0x00007fff204ddfa4 __CFRunLoopDoSources0 + 242
    50  com.apple.CoreFoundation          0x00007fff204dc9cc __CFRunLoopRun + 893
    51  com.apple.CoreFoundation          0x00007fff204dbf8c CFRunLoopRunSpecific + 563
    52  com.apple.HIToolbox               0x00007fff287241f3 RunCurrentEventLoopInMode + 292
    53  com.apple.HIToolbox               0x00007fff28723f55 ReceiveNextEventCommon + 587
    54  com.apple.HIToolbox               0x00007fff28723cf3 _BlockUntilNextEventMatchingListInModeWithFilter + 70
    55  com.apple.AppKit                  0x00007fff22ce5172 _DPSNextEvent + 864
    56  com.apple.AppKit                  0x00007fff22ce3945 -[NSApplication(NSEvent) _nextEventMatchingEventMask:untilDate:inMode:dequeue:] + 1364
    57  com.apple.AppKit                  0x00007fff22cd5c69 -[NSApplication run] + 586
    58  libqcocoa.dylib                   0x0000000130610c2c QCocoaEventDispatcher::processEvents(QFlags<QEventLoop::ProcessEventsFlag>) + 2652
    59  org.qt-project.QtCore             0x0000000108023b9f QEventLoop::exec(QFlags<QEventLoop::ProcessEventsFlag>) + 431
    60  org.qt-project.QtCore             0x0000000108027fb2 QCoreApplication::exec() + 130
    61  com.avid.Mac2Qt                   0x0000000126d0223b Mac2Qt::Private::Mac2QtEventWaiter::RunApplicationEventLoop() + 73
    62  com.avid.Mac2Qt                   0x0000000126cf7959 Mac2Qt::RunApplicationEventLoop() + 29
    63  libUIshell.dylib                  0x00000001213ba3c7 AApplication::Run() + 9
    64  libUIshell.dylib                  0x00000001213b7718 AApplication::Go() + 98
    65  com.avid.mediacomposer            0x0000000103be1570 main + 738
    66  libdyld.dylib                     0x00007fff20401f3d start + 1
    Thread 1:: com.apple.NSEventThread
    0   libsystem_kernel.dylib            0x00007fff203b12ba mach_msg_trap + 10
    1   libsystem_kernel.dylib            0x00007fff203b162c mach_msg + 60
    2   com.apple.CoreFoundation          0x00007fff204de49f __CFRunLoopServiceMachPort + 316
    3   com.apple.CoreFoundation          0x00007fff204dcb7f __CFRunLoopRun + 1328
    4   com.apple.CoreFoundation          0x00007fff204dbf8c CFRunLoopRunSpecific + 563
    5   com.apple.AppKit                  0x00007fff22e6b23a _NSEventThread + 124
    6   libsystem_pthread.dylib           0x00007fff203e68fc _pthread_start + 224
    7   libsystem_pthread.dylib           0x00007fff203e2443 thread_start + 15
    Thread 2:
    2   com.googlecode.google-breakpad    0x000000011f5ec6d1 google_breakpad::ExceptionHandler::WaitForMessage(void*) + 231
    3   libsystem_pthread.dylib           0x00007fff203e68fc _pthread_start + 224
    4   libsystem_pthread.dylib           0x00007fff203e2443 thread_start + 15
    Thread 3:: MTThreadCoreThreads
    0   libsystem_kernel.dylib            0x00007fff203b12f6 semaphore_wait_trap + 10
    1   libdispatch.dylib                 0x00007fff2023cc9b _dispatch_sema4_wait + 16
    2   libdispatch.dylib                 0x00007fff2023d16d _dispatch_semaphore_wait_slow + 98
    3   com.avid.AvidCoreThreads          0x000000011f17f31e Threads::SemaRepNative::Decrement(char const*, long) + 214
    4   com.avid.AvidCore                 0x0000000120286a7c MTSemaphoreCoreThreads::Decrement(unsigned long, unsigned int) + 124
    5   com.avid.AvidStorageAPI           0x000000012bf813ce StorageAPI::CommandProcessor::Body(StorageAPI::MTThread*) + 70
    6   com.avid.AvidStorageAPI           0x000000012bf829e9 StorageAPI::MTThread::Run() + 27
    7   com.avid.AvidCoreThreads          0x000000011f1818e0 Threads::ThreadImp::StarterFluid(void*) + 258
    8   libsystem_pthread.dylib           0x00007fff203e68fc _pthread_start + 224
    9   libsystem_pthread.dylib           0x00007fff203e2443 thread_start + 15
    Thread 4:: MTThreadCoreThreads
    Thread 5:: MTThreadCoreThreads
    Thread 6:: MTThreadCoreThreads
    Thread 7:: MTThreadCoreThreads
    Thread 8:: MTThreadCoreThreads
    Thread 9:
    0   libsystem_kernel.dylib            0x00007fff203b3cde __psynch_cvwait + 10
    1   libsystem_pthread.dylib           0x00007fff203e6e49 _pthread_cond_wait + 1298
    2   com.avid.AvidCoreThreads          0x000000011f185b0a Threads::NativeCondWait(_opaque_pthread_cond_t*, _opaque_pthread_mutex_t*, long, int, void**) + 59
    3   com.avid.AvidCoreThreads          0x000000011f186be2 CoreThreadsMessageQueue::RemoveNext(Threads::Message**, long*, bool*, Threads::Message**, long*, bool*, long, int, void**, bool (*)(Threads::Message const*)) + 130
    4   com.avid.AvidCoreThreads          0x000000011f182896 Threads::ThreadImp::WaitForThreadMessage(Threads::Message**, long, bool (*)(Threads::Message const*), int, void**) + 880
    5   com.avid.AvidCoreThreads          0x000000011f17c486 Threads::Messaging::WaitForThreadMessage(Threads::Message**, long, bool (*)(Threads::Message const*), int, void**) + 90
    6   com.avid.AvidCoreThreads          0x000000011f17f9e9 Threads::Body::ThreadBody() + 33
    Thread 10:
    5   com.apple.CoreFoundation          0x00007fff205628b2 CFRunLoopRun + 40
    6   com.apple.AVCVideoServices        0x0000000273d46596 AVS::AVCVideoServicesThreadStart(AVS::AVCVideoServicesThreadParams*) + 129
    7   libsystem_pthread.dylib           0x00007fff203e68fc _pthread_start + 224
    8   libsystem_pthread.dylib           0x00007fff203e2443 thread_start + 15
    Thread 11:: FlamethrowerThreadedLinkManagerRep::m_pLinkManagerThread
    6   com.avid.macflamethrowerohci      0x0000000273c2a45f (anonymous namespace)::FlamethrowerThreadedLinkManagerThread::ThreadBody() + 177
    Thread 12:: Pyromaniac DIO FireBOBEventThread
    Thread 13:: Pyromaniac DIO DevicePortBusResetThread
    Thread 14:: *PMDIO_IOManagerRep::IOThread
    6   com.apple.diopyromaniacohci       0x000000027392be72 PMDIO_IOThreadBody::ThreadBody() + 74
    Thread 15:: PMDIO_InputModeRep::AudioInCBThread
    Thread 16:: PMDIO_OutputModeRep::VideoCBThread
    Thread 17:: *PMDIO_OutputModeRep::AudioCBThread
    Thread 18:: AVCReceiverThread
    6   com.apple.diopyromaniacohci       0x000000027393c95e PMDIODeviceControlRep::AVCReceiverThread() + 96
    7   com.apple.diopyromaniacohci       0x000000027393c8fe AVCReceiverThreadJacket(void*) + 9
    8   com.avid.AvidCoreThreads          0x000000011f1818e0 Threads::ThreadImp::StarterFluid(void*) + 258
    9   libsystem_pthread.dylib           0x00007fff203e68fc _pthread_start + 224
    10  libsystem_pthread.dylib           0x00007fff203e2443 thread_start + 15
    Thread 19:: AMEParameterControlManager::ConsolidateThreadBody
    6   libameLibrary.dylib               0x00000001222f84c9 AMEParameterControlManager::ConsolidateThreadBody() + 99
    Thread 20:: QThread
    0   libsystem_kernel.dylib            0x00007fff203b79ca poll + 10
    1   org.qt-project.QtCore             0x0000000108088060 qt_safe_poll(pollfd*, unsigned int, timespec const*) + 480
    2   org.qt-project.QtCore             0x00000001080897c2 QEventDispatcherUNIX::processEvents(QFlags<QEventLoop::ProcessEventsFlag>) + 978
    3   org.qt-project.QtCore             0x0000000108023b9f QEventLoop::exec(QFlags<QEventLoop::ProcessEventsFlag>) + 431
    4   org.qt-project.QtCore             0x0000000107e45593 QThread::exec() + 131
    5   org.qt-project.QtCore             0x0000000107e464b9 QThreadPrivate::start(void*) + 329
    Thread 21:: Qt bearer thread
    Thread 22:: QNetworkAccessManager thread
    Thread 23:: NDIVideoThread
    2   com.avid.AvidCoreThreads          0x000000011f185ba0 Threads::NativeCondWait(_opaque_pthread_cond_t*, _opaque_pthread_mutex_t*, long, int, void**) + 209
    3   com.avid.AvidCoreThreads          0x000000011f17df50 RealTimeMessageQueueCondWait::WaitForMessageQueueSignal(long, int, void**) + 144
    4   com.avid.AvidCoreThreads          0x000000011f17ddce Threads::RealTimeMessageQueue::RemoveNext(Threads::Message**, long*, bool*, Threads::Message**, long*, bool*, long, int, void**, bool (*)(Threads::Message const*)) + 116
    5   com.avid.AvidCoreThreads          0x000000011f182896 Threads::ThreadImp::WaitForThreadMessage(Threads::Message**, long, bool (*)(Threads::Message const*), int, void**) + 880
    6   com.avid.AvidCoreThreads          0x000000011f17c486 Threads::Messaging::WaitForThreadMessage(Threads::Message**, long, bool (*)(Threads::Message const*), int, void**) + 90
    7   com.Avid.OpenIO-NDI               0x000000027d78c636 ThreadBase::DoWaitThreadMessage(long long, Threads::Message**) const + 22
    8   com.Avid.OpenIO-NDI               0x000000027d783dee NDI_PlayThread::DoProcess() + 332
    9   com.Avid.OpenIO-NDI               0x000000027d78bf7f ThreadBase::ThreadBody() + 99
    10  com.avid.AvidCoreThreads          0x000000011f1818e0 Threads::ThreadImp::StarterFluid(void*) + 258
    11  libsystem_pthread.dylib           0x00007fff203e68fc _pthread_start + 224
    12  libsystem_pthread.dylib           0x00007fff203e2443 thread_start + 15
    Thread 24:: HWSDK Audio Events
    7   com.Avid.HWSDK                    0x000000027dd92a8b HWSDK::AudioSignal::ThreadBody() + 573
    Thread 25:: Waveform Cache Thread
    Thread 26:: Waveform Cache Thread
    Thread 27:: Waveform Cache Thread
    Thread 28:: Waveform Cache Thread
    Thread 29:
    2   libc++.1.dylib                    0x00007fff2034fe03 std::__1::condition_variable::__do_timed_wait(std::__1::unique_lock<std::__1::mutex>&, std::__1::chrono::time_point<std::__1::chrono::system_clock, std::__1::chrono::duration<long long, std::__1::ratio<1l, 1000000000l> > >) + 93
    3   com.paceap.eden.WrapPersist       0x0000000297424bc2 0x29722e000 + 2059202
    4   com.paceap.eden.WrapPersist       0x000000029742c37d 0x29722e000 + 2089853
    5   com.paceap.eden.WrapPersist       0x000000029742c304 0x29722e000 + 2089732
    6   com.paceap.eden.WrapPersist       0x000000029742c1d9 0x29722e000 + 2089433
    Thread 30:: Tsk_ManagerImpl #0
    1   com.digidesign.framework.PlatformSupport    0x000000029066e90b CSyncPrim_Semaphore_MachImp::Acquire(unsigned long long) + 87
    2   com.digidesign.framework.MoreFoundation    0x000000029198c9a4 Tsk_ManagerImpl::Thread_WorkerFn(Tsk_ManagerImpl::ThreadCtx*) + 66
    3   com.digidesign.framework.MoreFoundation    0x000000029198c923 Tsk_ManagerImpl::Thread_WorkerFn_Static(void*, IPSThread*) + 73
    4   com.digidesign.framework.PlatformSupport    0x000000029066f669 CTask_Imp::MacOSXMasterThreadProc(void*) + 115
    5   libsystem_pthread.dylib           0x00007fff203e68fc _pthread_start + 224
    6   libsystem_pthread.dylib           0x00007fff203e2443 thread_start + 15
    Thread 31:: Tsk_ManagerImpl #1
    Thread 32:: Tsk_ManagerImpl #2
    Thread 33:: Tsk_ManagerImpl #3
    Thread 34:: High Latency Thread
    2   com.avid.framework.AAE            0x0000000292528b3a CSimpleThread::Wait() + 26
    3   com.avid.framework.AAE            0x00000002924f4d2d CHighLatencyThread::Exec() + 35
    4   com.avid.framework.AAE            0x000000029252877f CSimpleThread::StaticThreadProc(void*, IPSThread*) + 15
    5   com.digidesign.framework.PlatformSupport    0x000000029066f669 CTask_Imp::MacOSXMasterThreadProc(void*) + 115
    Thread 35:: LL Thread 0
    2   com.digidesign.framework.CoreFoundation    0x00000002916af6cf Sys_SpinningSemaphore::Acquire(bool, bool*) + 159
    3   com.avid.framework.AAE            0x00000002924950fa avid::aae::CHostWorkerEngineThreadingPolicy::Wait(CProcessingThread*, bool const&, bool, CProcessorExecutionTimer*, bool&, bool&, InterruptProfiler*) + 180
    4   com.avid.framework.AAE            0x000000029255c570 avid::aae::CHostWorkerEngineProcessingThreadPool::ProcessLoop(CProcessingThread*) + 182
    5   com.avid.framework.AAE            0x000000029252877f CSimpleThread::StaticThreadProc(void*, IPSThread*) + 15
    6   com.digidesign.framework.PlatformSupport    0x000000029066f669 CTask_Imp::MacOSXMasterThreadProc(void*) + 115
    Thread 36:: LL Thread 1
    Thread 37:: LL Thread 2
    Thread 38:: LL Thread 3
    Thread 39:: LL Thread 4
    Thread 40:: LL Thread 5
    Thread 41:: LL Thread 6
    Thread 42:: LL Thread 7
    Thread 43:: LL Thread 8
    Thread 44:: LL Thread 9
    Thread 45:: LL Thread 10
    Thread 46:: LL Thread 11
    Thread 47:: LL Thread 12
    Thread 48:: LL Thread 13
    Thread 49:: LL Thread 14
    Thread 50:: LL Thread 15
    Thread 51:: LL Thread 16
    Thread 52:: LL Thread 17
    Thread 53:: LL Thread 18
    Thread 54:: LL Thread 19
    Thread 55:: LL Thread 20
    Thread 56:: LL Thread 21
    Thread 57:: LL Thread 22
    Thread 58:: LL Thread 23
    Thread 59:: HBL Thread 0
    Thread 60:: HBL Thread 1
    Thread 61:: HBL Thread 2
    Thread 62:: HBL Thread 3
    Thread 63:: HBL Thread 4
    Thread 64:: HBL Thread 5
    Thread 65:: HBL Thread 6
    Thread 66:: HBL Thread 7
    Thread 67:: HBL Thread 8
    Thread 68:: HBL Thread 9
    Thread 69:: HBL Thread 10
    Thread 70:: HBL Thread 11
    Thread 71:: HBL Thread 12
    Thread 72:: HBL Thread 13
    Thread 73:: HBL Thread 14
    Thread 74:: HBL Thread 15
    Thread 75:: HBL Thread 16
    Thread 76:: HBL Thread 17
    Thread 77:: HBL Thread 18
    Thread 78:: HBL Thread 19
    Thread 79:: HBL Thread 20
    Thread 80:: HBL Thread 21
    Thread 81:: HBL Thread 22
    Thread 82:: HBL Thread 23
    Thread 83:: HL Thread 0
    Thread 84:: HL Thread 1
    Thread 85:: HL Thread 2
    Thread 86:: HL Thread 3
    Thread 87:: HL Thread 4
    Thread 88:: HL Thread 5
    Thread 89:: HL Thread 6
    Thread 90:: HL Thread 7
    Thread 91:: HL Thread 8
    Thread 92:: HL Thread 9
    Thread 93:: HL Thread 10
    Thread 94:: HL Thread 11
    Thread 95:: HL Thread 12
    Thread 96:: HL Thread 13
    Thread 97:: HL Thread 14
    Thread 98:: HL Thread 15
    Thread 99:: HL Thread 16
    Thread 100:: HL Thread 17
    Thread 101:: HL Thread 18
    Thread 102:: HL Thread 19
    Thread 103:: HL Thread 20
    Thread 104:: HL Thread 21
    Thread 105:: HL Thread 22
    Thread 106:: HL Thread 23
    Thread 107:: AAXH PluginIdleTask
    0   libsystem_kernel.dylib            0x00007fff203b130e semaphore_timedwait_trap + 10
    1   com.digidesign.framework.PlatformSupport    0x000000029066e8fc CSyncPrim_Semaphore_MachImp::Acquire(unsigned long long) + 72
    2   com.digidesign.framework.PlatformSupport    0x000000029067889b CSyncPrim_AutoResetEvent_Imp::Acquire(unsigned long long) + 19
    3   com.digidesign.framework.CoreFoundation    0x0000000291697c7d Sys_BlockingTimer_PS::WaitOnTimer() + 183
    4   com.digidesign.framework.CoreFoundation    0x0000000291682d04 Sys_RawThreadTimerTask::Exec() + 132
    5   com.digidesign.framework.CoreFoundation    0x0000000291682885 Sys_RawThreadTask::Run() + 45
    6   com.digidesign.framework.CoreFoundation    0x0000000291697f01 Sys_RawThread_PS::ThreadMethod(IPSThread*) + 13
    7   com.digidesign.framework.CoreFoundation    0x0000000291697f21 non-virtual thunk to Sys_RawThread_PS::ThreadMethod(IPSThread*) + 13
    8   com.digidesign.framework.PlatformSupport    0x000000029066f655 CTask_Imp::MacOSXMasterThreadProc(void*) + 95
    Thread 108:: AAXH PluginComponentBackground
    Thread 109:
    5   com.digidesign.framework.CoreFoundation    0x00000002916dcaaf Sys_FolderWatchMacOS::ThreadMethod() const + 117
    6   com.digidesign.framework.CoreFoundation    0x00000002916dc776 Sys_FolderWatchMacOS::ThreadMethod_Static(void*, IPSThread*) + 10
    7   com.digidesign.framework.PlatformSupport    0x000000029066f669 CTask_Imp::MacOSXMasterThreadProc(void*) + 115
    Thread 110:: AudioSuiteThread
    6   libAMPIHost.dylib                 0x000000011f610a92 AMPIAudioSuiteManagerRep::AudioSuiteThreadBody() + 78
    Thread 111:: AMCP Logging Spool
    1   com.apple.audio.caulk             0x00007fff284a38da caulk::mach::semaphore::wait_or_error() + 16
    2   com.apple.audio.caulk             0x00007fff28490836 caulk::semaphore::timed_wait(double) + 110
    3   com.apple.audio.caulk             0x00007fff28490784 caulk::concurrent::details::worker_thread::run() + 30
    4   com.apple.audio.caulk             0x00007fff28490502 void* caulk::thread_proxy<std::__1::tuple<caulk::thread::attributes, void (caulk::concurrent::details::worker_thread::*)(), std::__1::tuple<caulk::concurrent::details::worker_thread*> > >(void*) + 45
    Thread 112:: MVP_Host_Processing
    Thread 113:: MSP_Host_Processing
    Thread 114:
    2   libc++.1.dylib                    0x00007fff2034fd72 std::__1::condition_variable::wait(std::__1::unique_lock<std::__1::mutex>&) + 18
    3   com.avid.LEPCore                  0x00000002967f30bb LEP::Event::Wait(unsigned int) + 187
    4   com.avid.LEPCore                  0x0000000296822b41 LEP::Logger::ThreadFunc() + 193
    5   com.avid.LEPCore                  0x00000002968234e1 std::__1::__async_assoc_state<int, std::__1::__async_func<int (LEP::Logger::*)(), LEP::Logger*> >::__execute() + 49
    6   com.avid.LEPCore                  0x00000002968235c1 void* std::__1::__thread_proxy<std::__1::tuple<void (std::__1::__async_assoc_state<int, std::__1::__async_func<int (LEP::Logger::*)(), LEP::Logger*> >::*)(), std::__1::__async_assoc_state<int, std::__1::__async_func<int (LEP::Logger::*)(), LEP::Logger*> >*> >(void*) + 113
    Thread 115:
    4   com.avid.LEPCore                  0x00000002967f46e0 LEP::ExecutionPool::DispatcherEntry() + 208
    5   com.avid.LEPCore                  0x00000002967f70c1 std::__1::__async_assoc_state<int, std::__1::__async_func<int (LEP::ExecutionPool::*)(), LEP::ExecutionPool*> >::__execute() + 49
    6   com.avid.LEPCore                  0x00000002967f7271 void* std::__1::__thread_proxy<std::__1::tuple<void (std::__1::__async_assoc_state<int, std::__1::__async_func<int (LEP::ExecutionPool::*)(), LEP::ExecutionPool*> >::*)(), std::__1::__async_assoc_state<int, std::__1::__async_func<int (LEP::ExecutionPool::*)(), LEP::ExecutionPool*> >*> >(void*) + 113
    Thread 116:
    3   com.avid.LEPCore                  0x00000002967f3550 std::__1::cv_status std::__1::condition_variable::wait_until<std::__1::chrono::steady_clock, std::__1::chrono::duration<long long, std::__1::ratio<1l, 1000000000l> > >(std::__1::unique_lock<std::__1::mutex>&, std::__1::chrono::time_point<std::__1::chrono::steady_clock, std::__1::chrono::duration<long long, std::__1::ratio<1l, 1000000000l> > > const&) + 128
    4   com.avid.LEPCore                  0x00000002967f3073 LEP::Event::Wait(unsigned int) + 115
    5   com.avid.LEPCore                  0x00000002967f4f97 LEP::ExecutionPool::WorkerEntry() + 807
    6   com.avid.LEPCore                  0x00000002967f70c1 std::__1::__async_assoc_state<int, std::__1::__async_func<int (LEP::ExecutionPool::*)(), LEP::ExecutionPool*> >::__execute() + 49
    7   com.avid.LEPCore                  0x00000002967f7271 void* std::__1::__thread_proxy<std::__1::tuple<void (std::__1::__async_assoc_state<int, std::__1::__async_func<int (LEP::ExecutionPool::*)(), LEP::ExecutionPool*> >::*)(), std::__1::__async_assoc_state<int, std::__1::__async_func<int (LEP::ExecutionPool::*)(), LEP::ExecutionPool*> >*> >(void*) + 113
    Thread 117:
    1   com.apple.CoreServices.CarbonCore    0x00007fff228ba320 MPWaitOnSemaphore + 74
    2   REDR3D.dylib                      0x000000029c35ec87 0x29c217000 + 1342599
    3   REDR3D.dylib                      0x000000029c315e02 0x29c217000 + 1043970
    4   libsystem_pthread.dylib           0x00007fff203e68fc _pthread_start + 224
    5   libsystem_pthread.dylib           0x00007fff203e2443 thread_start + 15
    Thread 118:
    2   REDR3D.dylib                      0x000000029c35f807 0x29c217000 + 1345543
    Thread 119:
    Thread 120:
    Thread 121:
    Thread 122:
    Thread 123:
    Thread 124:
    Thread 125:
    Thread 126:
    Thread 127:
    Thread 128:
    Thread 129:
    Thread 130:
    Thread 131:
    Thread 132:
    Thread 133:
    Thread 134:
    Thread 135:
    Thread 136:
    Thread 137:
    Thread 138:
    Thread 139:
    Thread 140:
    Thread 141:
    Thread 142:
    6   com.avid.AMADeviceMonitor         0x000000029da302e4 AMA::Impl::CAMADeviceMonitor::ThreadMain(void*) + 164
    Thread 143:
    2   mt.dylib                          0x00000001263e9deb CMTSingleTaskThread::ThreadFunctionImplementation() + 155
    3   mt.dylib                          0x00000001263e96ba CMTThreadImpl::Entry_point(void*) + 10
    Thread 144:
    2   ilgpu.dylib                       0x000000027b8061bd siilgpu::CommandProcessor::Execute() + 477
    3   mt.dylib                          0x00000001263e9d88 CMTSingleTaskThread::ThreadFunctionImplementation() + 56
    4   mt.dylib                          0x00000001263e96ba CMTThreadImpl::Entry_point(void*) + 10
    Thread 145:: Viewer Worker Thread
    6   com.avid.AvidCore                 0x0000000120366422 Viewer::ViewerThreadBody::ThreadBody() + 98
    Thread 146:: Viewer Worker Thread
    Thread 147:: Viewer Worker Thread
    Thread 148:: Viewer Worker Thread
    Thread 149:: Viewer Worker Thread
    Thread 150:: Viewer Worker Thread
    Thread 151:: Viewer Worker Thread
    Thread 152:: Viewer Worker Thread
    Thread 153:: Viewer Worker Thread
    Thread 154:: Viewer Worker Thread
    Thread 155:: Viewer Worker Thread
    Thread 156:: Viewer Worker Thread
    Thread 157:: Viewer Worker Thread
    Thread 158:: Viewer Worker Thread
    Thread 159:: Viewer Worker Thread
    Thread 160:: Viewer Worker Thread
    Thread 161:: Viewer Worker Thread
    Thread 162:: Viewer Worker Thread
    Thread 163:: Viewer Worker Thread
    Thread 164:: Viewer Worker Thread
    Thread 165:: Viewer Worker Thread
    Thread 166:: Viewer Worker Thread
    Thread 167:: Viewer Worker Thread
    Thread 168:: Viewer Worker Thread
    Thread 169:: Viewer Worker Thread
    Thread 170:: Viewer Worker Thread
    Thread 171:: Viewer Worker Thread
    Thread 172:: Viewer Worker Thread
    Thread 173:: Viewer Worker Thread
    Thread 174:: Viewer Worker Thread
    Thread 175:: Viewer Worker Thread
    Thread 176:: Viewer Worker Thread
    Thread 177:
    1   libtbb.dylib                      0x000000012bfb361a tbb::internal::rml::private_worker::thread_routine(void*) + 362
    2   libsystem_pthread.dylib           0x00007fff203e68fc _pthread_start + 224
    3   libsystem_pthread.dylib           0x00007fff203e2443 thread_start + 15
    Thread 178:
    Thread 179:
    Thread 180:
    Thread 181:
    Thread 182:
    Thread 183:
    Thread 184:
    Thread 185:
    Thread 186:
    Thread 187:
    Thread 188:
    Thread 189:
    Thread 190:
    Thread 191:
    Thread 192:
    Thread 193:
    Thread 194:
    Thread 195:
    Thread 196:
    Thread 197:
    Thread 198:
    Thread 199:
    Thread 200:
    Thread 201:
    Thread 202:
    Thread 203:
    Thread 204:
    Thread 205:
    Thread 206:
    Thread 207:
    Thread 208:
    Thread 209:
    Thread 210:
    Thread 211:
    Thread 212:
    Thread 213:
    3   com.avid.CodecToolkit.CTSharedResourceHandling    0x00000002a1ccb36f 0x2a1cbd000 + 58223
    4   com.avid.CodecToolkit.CTSharedResourceHandling    0x00000002a1ccbd0b 0x2a1cbd000 + 60683
    Thread 214:
    Thread 215:
    Thread 216:
    Thread 217:
    Thread 218:
    Thread 219:
    Thread 220:
    Thread 221:
    Thread 222:
    Thread 223:
    Thread 224:
    Thread 225:
    Thread 226:
    Thread 227:
    Thread 228:
    Thread 229:
    Thread 230:
    Thread 231:
    Thread 232:
    Thread 233:
    Thread 234:
    Thread 235:
    Thread 236:
    Thread 237:
    2   com.apple.audio.midi.CoreMIDI     0x00007fff34e0bbd6 XServerMachPort::ReceiveMessage(int&, void*, int&) + 94
    3   com.apple.audio.midi.CoreMIDI     0x00007fff34e3c473 MIDIProcess::MIDIInPortThread::Run() + 111
    4   com.apple.audio.midi.CoreMIDI     0x00007fff34e224e2 XThread::RunHelper(void*) + 10
    5   com.apple.audio.midi.CoreMIDI     0x00007fff34e2365b CAPThread::Entry(CAPThread*) + 77
    Thread 238:: AsyncRead
    6   com.avid.mediacomposer            0x0000000104669352 OSXSerialIO::AsyncReadThread() + 442
    7   com.avid.mediacomposer            0x0000000104667a76 AsyncReadThreadJacket(void*) + 47
    Thread 239:: AsyncWrite
    6   com.avid.mediacomposer            0x000000010466940a OSXSerialIO::AsyncWriteThread() + 122
    7   com.avid.mediacomposer            0x0000000104667acb AsyncWriteThreadJacket(void*) + 47
    Thread 240:: AsyncRead
    Thread 241:: AsyncWrite
    Thread 242:: Viewer Worker Thread
    Thread 243:: Viewer Worker Thread
    Thread 244:: Viewer Worker Thread
    Thread 245:: Viewer Worker Thread
    Thread 246:: Viewer Worker Thread
    Thread 247:: Viewer Worker Thread
    Thread 248:: Viewer Worker Thread
    Thread 249:: Viewer Worker Thread
    Thread 250:: Viewer Worker Thread
    Thread 251:: Viewer Worker Thread
    Thread 252:: Chron
    6   com.avid.AvidCore                 0x0000000120279130 ChronBody::ThreadBody() + 354
    Thread 253:: ProgressBarOpenGLRender
    1   org.qt-project.QtCore             0x0000000108087ef0 qt_safe_poll(pollfd*, unsigned int, timespec const*) + 112
    Thread 254:: QThread
    Thread 255:: AsyncRead
    Thread 256:: AsyncWrite
    Thread 257:: Viewer Worker Thread
    Thread 258:: QThread
    Thread 259:: QThread
    Thread 260:: ThreadedPeriodicTimer kExtraHighPriority Thread
    4   com.avid.AvidCore                 0x000000012033bdcc ThreadedPeriodicTimer::ProcessCallbacks() + 296
    5   com.avid.AvidCoreThreads          0x000000011f1818e0 Threads::ThreadImp::StarterFluid(void*) + 258
    Thread 261:: com.apple.CFSocket.private
    0   libsystem_kernel.dylib            0x00007fff203b9656 __select + 10
    1   com.apple.CoreFoundation          0x00007fff20504a03 __CFSocketManager + 630
    Thread 262:: PendingMediaHelper
    Thread 263:: QThread
    Thread 264:: PHTBody
    6   libameLibrary.dylib               0x00000001222130d5 PHT::PlayerHostThread::ThreadBody() + 85
    Thread 265:: AMEDeferredTaskExecutor 00
    4   com.avid.AvidCore                 0x00000001202411d3 AMEDeferredTaskExecutor::ThreadBody() + 1215
    Thread 266:: AMEDeferredTaskExecutor 00
    Thread 267:: AMEDeferredTaskExecutor 01
    Thread 268:: AMEDeferredTaskExecutor 02
    Thread 269:: AMEDeferredTaskExecutor 03
    Thread 270:: AMEDeferredTaskExecutor 04
    Thread 271:: AMEDeferredTaskExecutor 05
    Thread 272:: AMEDeferredTaskExecutor 06
    Thread 273:: AMEDeferredTaskExecutor 07
    Thread 274:: AMEDeferredTaskExecutor 08
    Thread 275:: AMEDeferredTaskExecutor 09
    Thread 276:: AMEDeferredTaskExecutor 10
    Thread 277:: AMEDeferredTaskExecutor 11
    Thread 278:: AMEDeferredTaskExecutor 12
    Thread 279:: AMEDeferredTaskExecutor 13
    Thread 280:: AMEDeferredTaskExecutor 14
    Thread 281:: AMEDeferredTaskExecutor 15
    Thread 282:: AMEDeferredTaskExecutor 16
    Thread 283:: AMEDeferredTaskExecutor 17
    Thread 284:: AMEDeferredTaskExecutor 18
    Thread 285:: AMEDeferredTaskExecutor 19
    Thread 286:: AMEDeferredTaskExecutor 20
    Thread 287:: AMEDeferredTaskExecutor 21
    Thread 288:: AMEDeferredTaskExecutor 22
    Thread 289:: AMEDeferredTaskExecutor 23
    Thread 290:: AMEDeferredTaskExecutor 00
    Thread 291:: AMEDeferredTaskExecutor 01
    Thread 292:: AMEDeferredTaskExecutor 02
    Thread 293:: AMEDeferredTaskExecutor 03
    Thread 294:: AMEDeferredTaskExecutor 04
    Thread 295:: AMEDeferredTaskExecutor 05
    Thread 296:: AMEDeferredTaskExecutor 06
    Thread 297:: AMEDeferredTaskExecutor 07
    Thread 298:: AMEDeferredTaskExecutor 08
    Thread 299:: AMEDeferredTaskExecutor 09
    Thread 300:: AMEDeferredTaskExecutor 10
    Thread 301:: AMEDeferredTaskExecutor 11
    Thread 302:: AMEDeferredTaskExecutor 12
    Thread 303:: AMEDeferredTaskExecutor 13
    Thread 304:: AMEDeferredTaskExecutor 14
    Thread 305:: AMEDeferredTaskExecutor 15
    Thread 306:: AMEDeferredTaskExecutor 16
    Thread 307:: AMEDeferredTaskExecutor 17
    Thread 308:: AMEDeferredTaskExecutor 18
    Thread 309:: AMEDeferredTaskExecutor 19
    Thread 310:: AMEDeferredTaskExecutor 20
    Thread 311:: AMEDeferredTaskExecutor 21
    Thread 312:: AMEDeferredTaskExecutor 22
    Thread 313:: AMEDeferredTaskExecutor 23
    Thread 314:: AMEDeferredTaskExecutor 00
    Thread 315:: AMEDeferredTaskExecutor 01
    Thread 316:: AMEDeferredTaskExecutor 02
    Thread 317:: AMEDeferredTaskExecutor 03
    Thread 318:: AMEDeferredTaskExecutor 04
    Thread 319:: AMEDeferredTaskExecutor 05
    Thread 320:: AMEDeferredTaskExecutor 06
    Thread 321:: AMEDeferredTaskExecutor 07
    Thread 322:: AMEDeferredTaskExecutor 08
    Thread 323:: AMEDeferredTaskExecutor 09
    Thread 324:: AMEDeferredTaskExecutor 10
    Thread 325:: AMEDeferredTaskExecutor 11
    Thread 326:: AMEDeferredTaskExecutor 12
    Thread 327:: AMEDeferredTaskExecutor 13
    Thread 328:: AMEDeferredTaskExecutor 14
    Thread 329:: AMEDeferredTaskExecutor 15
    Thread 330:: Background Bin Save Worker
    6   com.avid.AvidCore                 0x000000012027a1dd Threads::MCThreadBody::ThreadBody() + 33
    Thread 331:: Viewer Worker Thread
    Thread 332:: SbStatusChecker Thread
    Thread 333:
    0   libsystem_pthread.dylib           0x00007fff203e2420 start_wqthread + 0
    Thread 334:
    Thread 335:
    Thread 336:: QThread
    Thread 337:: QNetworkAccessManager thread
    Thread 338:: Thread (pooled)
    2   org.qt-project.QtCore             0x0000000107e4e1b0 QWaitConditionPrivate::wait_relative(QDeadlineTimer) + 256
    3   org.qt-project.QtCore             0x0000000107e4df1e QWaitConditionPrivate::wait(QDeadlineTimer) + 94
    4   org.qt-project.QtCore             0x0000000107e4de93 QWaitCondition::wait(QMutex*, QDeadlineTimer) + 83
    5   org.qt-project.QtCore             0x0000000107e4a8ad QThreadPoolThread::run() + 621
    6   org.qt-project.QtCore             0x0000000107e464b9 QThreadPrivate::start(void*) + 329
    Thread 339:: PlayLoopThread
    6   libameLibrary.dylib               0x0000000121b3148d PlayLoopThread::ThreadBody() + 181
    Thread 340:: schedulerThread
    6   libameLibrary.dylib               0x0000000121b9c119 ThreadWrapper(void*) + 47
    Thread 341:: PlayLoopThread
    Thread 342:: schedulerThread
    Thread 343:
    1   libdispatch.dylib                 0x00007fff2023cd15 _dispatch_sema4_timedwait + 72
    2   libdispatch.dylib                 0x00007fff2023d145 _dispatch_semaphore_wait_slow + 58
    3   libdispatch.dylib                 0x00007fff2024b656 _dispatch_worker_thread + 284
    Thread 344:
    Thread 345:: AsyncMSMRescan
    Thread 346:
    Thread 0 crashed with X86 Thread State (64-bit):
      rax: 0x0000000000000000  rbx: 0x0000000109d94e00  rcx: 0x00007ffeec080788  rdx: 0x0000000000000000
      rdi: 0x0000000000000103  rsi: 0x0000000000000006  rbp: 0x00007ffeec0807b0  rsp: 0x00007ffeec080788
       r8: 0x0000000000007fff   r9: 0x0000000000008000  r10: 0x0000000000000000  r11: 0x0000000000000246
      r12: 0x0000000000000103  r13: 0x0000003000000008  r14: 0x0000000000000006  r15: 0x0000000000000016
      rip: 0x00007fff203b792e  rfl: 0x0000000000000246  cr2: 0x0000000105472670
    Logical CPU:     0
    Error Code:      0x02000148
    Trap Number:     133
    Thread 0 instruction stream:
      9a 0e 0b 00 39 c8 89 85-64 ff ff ff 8b 85 64 ff  ....9...d.....d.
      ff ff 89 c1 c1 c1 1c 81-e1 1e 1e 1e 1e 89 c2 81  ................
      e2 00 00 00 10 89 c6 c1-c6 04 81 e6 e1 e1 e1 e1  ................
      09 ce 89 f1 c1 e9 02 8d-0c 91 81 e1 66 66 66 66  ............ffff
      c1 e8 1a 83 e0 01 81 e6-66 66 66 26 8d 04 b0 09  ........fff&....
      c8 89 45 9c eb 13 b8 0a-c8 00 00 b8 b3 cc 00 00  ..E.............
     [c3]c3 c3 c3 c3 c3 c3 c3-c3 49 81 f7 6b 7d 4e 69  .........I..k}Ni    <==
      48 85 c8 49 85 c9 49 81-f7 6b 7d 4e 69 e8 34 00  H..I..I..k}Ni.4.
      00 00 48 31 ca 48 31 d1-48 81 fa e6 3d ff 72 48  ..H1.H1.H...=.rH
      31 ca 48 01 ca 48 29 d1-49 85 ca 48 f7 d9 49 83  1.H..H).I..H..I.
      f2 ff 4d 8d 52 01 49 81-f8 93 be 29 7f 49 f7 da  ..M.R.I....).I..
      48 29 ca bb a5 ab 48 8b-14 24 48 81 f9 69 e6 39  H)....H..$H..i.9
    Thread 0 last branch register state not available.
    Binary Images:
           0x103b7b000 -        0x106598fff +com.avid.mediacomposer (21.9.0.55465 - 21.9.0) <A2CDC49A-1453-3E1E-B8DA-B4A3D7588A23> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/MacOS/AvidMediaComposer
           0x107e25000 -        0x108393fff +org.qt-project.QtCore (5.15 - 5.15.3) <E8141AA0-A4E7-3AA0-8EB3-18BC389A193B> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/Frameworks/QtCore.framework/Versions/5/QtCore
           0x108667000 -        0x108b4ffff +org.qt-project.QtGui (5.15 - 5.15.3) <9C781A63-6079-32E8-A9B5-469AAF9879EB> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/Frameworks/QtGui.framework/Versions/5/QtGui
           0x108ec8000 -        0x108efcfff +org.qt-project.QtXml (5.15 - 5.15.3) <960E2264-3A82-3F01-93F4-B25BA45A3C64> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/Frameworks/QtXml.framework/Versions/5/QtXml
           0x108f36000 -        0x108f6bfff +org.qt-project.QtSvg (5.15 - 5.15.3) <3C8F5CEB-BBAA-3D5D-98AB-5328BF61BECB> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/Frameworks/QtSvg.framework/Versions/5/QtSvg
           0x108fac000 -        0x1090bdfff +org.qt-project.QtNetwork (5.15 - 5.15.3) <1D4031B2-E454-3C5F-89AB-A43D24CA8519> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/Frameworks/QtNetwork.framework/Versions/5/QtNetwork
           0x1091dc000 -        0x10960bfff +org.qt-project.QtWidgets (5.15 - 5.15.3) <6DEEBD2D-5A89-3A96-9D99-4BCC8D8BF4E2> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/Frameworks/QtWidgets.framework/Versions/5/QtWidgets
           0x10999e000 -        0x1099c8fff +org.qt-project.QtPrintSupport (5.15 - 5.15.3) <AB225F28-05DC-3E18-8C7B-8089A973DC2D> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/Frameworks/QtPrintSupport.framework/Versions/5/QtPrintSupport
           0x109a0d000 -        0x109a73fff +com.SafeNet.SuperPro (SuperPro version 6.6.0 - 6.6.0) /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/Frameworks/SuperPro.framework/Versions/A/SuperPro
           0x109a8e000 -        0x109bd0fff +libicuucAvid.62.1.dylib (0) <D6901B2C-A48C-39D0-AE61-645F7ECC9E67> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/MacOS/libicuucAvid.62.1.dylib
           0x109c44000 -        0x109c4cfff +libicuioAvid.62.1.dylib (0) <C8C51C88-D0F4-3DD6-BCB6-04044BCFBB66> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/MacOS/libicuioAvid.62.1.dylib
           0x109c58000 -        0x109c73fff +org.qt-project.QtWebSockets (5.15 - 5.15.3) <BBEC651A-CF4D-342D-AF57-C6C5977DA4C1> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/Frameworks/QtWebSockets.framework/Versions/5/QtWebSockets
           0x109ca6000 -        0x109cb3fff +libjpegV4.dylib (1) <0B49A8C3-09BB-9697-D719-F60621D279E0> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/MacOS/libjpegV4.dylib
           0x109cbd000 -        0x109d58fff  dyld (852.2) <0CC19410-FD43-39AE-A32A-50273F8303A4> /usr/lib/dyld
           0x109dd5000 -        0x109fabfff +libicui18nAvid.62.1.dylib (0) <B35B55DC-BCA9-37E2-AAFB-FFA6DDA94D40> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/MacOS/libicui18nAvid.62.1.dylib
           0x10a0a7000 -        0x10ba3ffff +libicudataAvid.62.1.dylib (0) <13FECFE0-CF5B-3F16-90E4-ECE130A25540> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/MacOS/libicudataAvid.62.1.dylib
           0x10ba78000 -        0x10baadfff +org.qt-project.QtOpenGL (5.15 - 5.15.3) <22C9786D-3921-3D8B-BB2E-F69DB92AD8D6> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/Frameworks/QtOpenGL.framework/Versions/5/QtOpenGL
           0x10baf9000 -        0x113fa4fff +org.qt-project.Qt.QtWebEngineCore (5.15 - 5.15.3) <2A32157F-3DC3-30B1-982F-79733556E4FB> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/Frameworks/QtWebEngineCore.framework/Versions/5/QtWebEngineCore
           0x11d894000 -        0x11d8c6fff +org.qt-project.QtWebEngine (5.15 - 5.15.3) <BA6A9346-9427-33BB-BA83-E84893181150> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/Frameworks/QtWebEngine.framework/Versions/5/QtWebEngine
           0x11d941000 -        0x11d964fff +org.qt-project.QtWebEngineWidgets (5.15 - 5.15.3) <F3CAE531-CC48-3B60-9A80-3815FFE8EB20> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/Frameworks/QtWebEngineWidgets.framework/Versions/5/QtWebEngineWidgets
           0x11d9b6000 -        0x11d9cffff +org.qt-project.QtWebChannel (5.15 - 5.15.3) <78459777-FDC0-38D7-AC2F-4B99827ABA31> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/Frameworks/QtWebChannel.framework/Versions/5/QtWebChannel
           0x11d9f1000 -        0x11d9f9fff +org.qt-project.QtMacExtras (5.15 - 5.15.3) <B9C72465-8363-3E5E-B9D7-6703C7CA07DF> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/Frameworks/QtMacExtras.framework/Versions/5/QtMacExtras
           0x11da09000 -        0x11da2afff +org.qt-project.QtSql (5.15 - 5.15.3) <D6A6841E-FAF6-38C1-AED6-222F3ADFE767> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/Frameworks/QtSql.framework/Versions/5/QtSql
           0x11da5a000 -        0x11dd3dfff +org.qt-project.QtXmlPatterns (5.15 - 5.15.3) <B38DC1EE-B7E9-3F89-8A99-5124A76A383D> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/Frameworks/QtXmlPatterns.framework/Versions/5/QtXmlPatterns
           0x11e077000 -        0x11e423fff +org.qt-project.QtDesigner (5.15 - 5.15.3) <EDDAAFB5-8F25-3048-A7DF-1830084A177F> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/Frameworks/QtDesigner.framework/Versions/5/QtDesigner
           0x11e661000 -        0x11ec13fff +libELF_libc++_xcode.dylib (0) <56D76E1C-E201-34D9-AACB-2BE80977A0D4> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/MacOS/libELF_libc++_xcode.dylib
           0x11ec56000 -        0x11eed9fff +com.avid.FTF (1.9.0 - 1.9.0) <12990F82-2CB0-3FAF-A088-794C59762BF7> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/Frameworks/FTF.framework/Versions/A/FTF
           0x11efb6000 -        0x11f103fff +gk.dylib (0) <BC8B9FE8-0733-3ABB-88E5-EA5E36EAFE0B> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/MacOS/gk.dylib
           0x11f17a000 -        0x11f190fff +com.avid.AvidCoreThreads (20.1.0d242591 - 20.1.0) <0AF1678F-E834-3F7B-9181-A54DBB9885F1> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/Frameworks/AvidCoreThreads.framework/Versions/A/AvidCoreThreads
           0x11f1c2000 -        0x11f1c7fff +com.avid.AvidCoreUtils (20.1.0d242591 - 20.1.0) <BBCBEC48-3F88-395A-9E79-459728E0FDB9> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/Frameworks/AvidCoreUtils.framework/Versions/A/AvidCoreUtils
           0x11f1db000 -        0x11f1fdfff +com.avid.AvidCoreServices (20.1.0d242591 - 20.1.0) <1C8F32F1-C7D4-30C6-848B-DEA2A067357F> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/Frameworks/AvidCoreServices.framework/Versions/A/AvidCoreServices
           0x11f251000 -        0x11f279fff +libHwControl.dylib (0) <512CEE75-8CBC-3A66-BEDE-1B69FB5166D8> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/MacOS/libHwControl.dylib
           0x11f2cb000 -        0x11f3bdfff +libimf_orchestrator.dylib (0) <15635C69-1426-389B-A4A9-4D4E90F0C2C8> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/MacOS/libimf_orchestrator.dylib
           0x11f417000 -        0x11f46dfff +libMediaComposerUI.dylib (0) <245A7F17-691D-3D27-85E7-8C0B37F9E47F> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/MacOS/libMediaComposerUI.dylib
           0x11f4e4000 -        0x11f551fff +com.avid.MCCloud (1.0 - 1) <1330D6EA-A906-3F33-931D-5DC57596150C> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/Frameworks/MCCloud.framework/Versions/A/MCCloud
           0x11f5ea000 -        0x11f5f3fff +com.googlecode.google-breakpad (1.0) <68E4677B-AF8A-349C-9B9E-21C8F4F3CD96> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/Frameworks/Breakpad.framework/Versions/A/Breakpad
           0x11f609000 -        0x11f669fff +libAMPIHost.dylib (0) <C8A3C756-BA8D-3F1B-87E4-C4C145C6173F> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/MacOS/libAMPIHost.dylib
           0x11f734000 -        0x11f789fff +com.avid.DMF (1.0 - 1) <8B24988F-B532-3F47-90F2-55E1D275FED3> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/Frameworks/DMF.framework/Versions/A/DMF
           0x11f7e3000 -        0x11fad6fff +com.avid.UIShellQt (1.0 - 1.0) <B8CAEBEE-37ED-31DA-A443-B3AC08B791A4> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/Frameworks/UIShellQt.framework/Versions/A/UIShellQt
           0x11fd13000 -        0x11fd18fff +com.avid.backgroundqueue (1.0 - 1) <0826701F-7F8B-35FE-A3C2-88516F3F6563> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/Frameworks/BackgroundQueue.framework/Versions/A/BackgroundQueue
           0x11fd33000 -        0x11fe1dfff +libAed.dylib (0) <87832FBC-4D59-31EB-AD33-1853EE964916> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/MacOS/libAed.dylib
           0x11ffd0000 -        0x1200affff +libAeu.dylib (0) <7C8DF54A-C389-3C80-B521-CB38F19F5F38> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/MacOS/libAeu.dylib
           0x12020d000 -        0x12021bfff +libAut.dylib (0) <1F131C11-D38D-3EBE-8F9F-B70FCBA03A69> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/MacOS/libAut.dylib
           0x120236000 -        0x120620fff +com.avid.AvidCore (5.12.0 - 5.12.0) <1B424626-A1CA-3691-A44E-F09FE85B6498> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/Frameworks/AvidCore.framework/Versions/A/AvidCore
           0x120987000 -        0x1209a2fff +com.avid.DigitalIO (5.12.0 - 5.12.0) <36A3AEC1-43EC-3C04-BD7F-F1ECA5161AB4> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/Frameworks/AvidDigitalIO.framework/Versions/A/AvidDigitalIO
           0x1209f2000 -        0x120a36fff +libACME.dylib (0) <174FEB81-CC60-3363-8AFC-EB4B4310C7FB> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/MacOS/libACME.dylib
           0x120a99000 -        0x120aedfff +com.avid.AMI (1.0.0 - 1.0.0) <A7D1056F-5F48-3F3D-83F8-26D4882C2C1A> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/Frameworks/Ami.framework/Versions/A/Ami
           0x120bb6000 -        0x120c9afff +libAuiCore.dylib (0) <951A20FF-7BE7-325C-B3EA-97C9F4648EA8> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/MacOS/libAuiCore.dylib
           0x120df6000 -        0x120e48fff +libMVCore.dylib (0) <CE74FBCB-6C24-3799-9F95-1C2F3A7C37D9> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/MacOS/libMVCore.dylib
           0x120efd000 -        0x120f08fff +com.avid.RPE (1.0.0 - 1.0.0) <14E30788-9631-393A-A1C5-92A83D5F6338> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/Frameworks/RPE.framework/Versions/A/RPE
           0x120f2a000 -        0x120fdafff +libAMI_Mob.dylib (0) <E0BC7BD5-2A69-3E45-A7D1-7BE088C936A0> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/MacOS/libAMI_Mob.dylib
           0x1210ef000 -        0x12113dfff +libLegacyVideoEffects.dylib (0) <6A9CD478-6F9F-300F-B653-DB7045C6D5E0> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/MacOS/libLegacyVideoEffects.dylib
           0x12118d000 -        0x121219fff +libClassicEffects.dylib (0) <FF359582-33D0-33B8-950E-E595D45A928C> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/MacOS/libClassicEffects.dylib
           0x1212ec000 -        0x121323fff +AVX2PluginHost.dylib (1.3) <3C435BC7-63D1-325D-92CD-74277E240A79> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/MacOS/AVX2PluginHost.dylib
           0x12135e000 -        0x12147afff +libUIshell.dylib (0) <D3305A6A-2305-3B02-98A4-FFC8EF7CF038> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/MacOS/libUIshell.dylib
           0x121670000 -        0x1229b9fff +libameLibrary.dylib (0) <B9227FDB-7530-3685-90F5-163E0E2B6A85> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/MacOS/libameLibrary.dylib
           0x124128000 -        0x12445ffff +libameImportExport.dylib (0) <B2260A5B-9F8C-3418-976B-E7773E79B681> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/MacOS/libameImportExport.dylib
           0x124640000 -        0x124646fff +libDynViewUIShell.dylib (0) <688A52C8-F0C5-3C9A-B198-C1C6257E96A9> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/MacOS/libDynViewUIShell.dylib
           0x12466a000 -        0x12467cfff +libameQuickTime.dylib (0) <895ED1EE-6DEE-3DBA-9BEF-C1663C3E3D4E> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/MacOS/libameQuickTime.dylib
           0x1246bb000 -        0x1246e1fff +libADMCommon.dylib (0) <4EB10154-4C05-3DA5-ADFA-9562135D5B3E> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/MacOS/libADMCommon.dylib
           0x12471e000 -        0x124786fff +libADMDevices.dylib (0) <89C306A1-59A5-32AC-9898-DDD06EA935D3> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/MacOS/libADMDevices.dylib
           0x124804000 -        0x12480efff +AVXLibrary.dylib (0) <41AAD027-3F6C-34C1-8283-3BA365A84991> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/MacOS/AVXLibrary.dylib
           0x12483c000 -        0x12493cfff +libQM.dylib (0) <A95DB9FF-97AE-32EF-AFD7-E4D44AB6F8DB> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/MacOS/libQM.dylib
           0x1249c9000 -        0x124a9cfff +com.avid.LavaFlow (5.12.0d61826 - 5.12.0) <46285AEF-BDF9-33DD-BEF7-830193E3FF87> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/Frameworks/lavaFlow.framework/Versions/A/lavaFlow
           0x124b41000 -        0x124b45fff +libMultiTouchSurfaceControl.dylib (0) <D0FD8CE7-4730-3307-9EE1-6FD511BE1BE1> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/MacOS/libMultiTouchSurfaceControl.dylib
           0x124b58000 -        0x124b78fff +libConfigClient.dylib (0) <D0D3A56B-4BC5-38E2-914C-276B7457BE87> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/MacOS/libConfigClient.dylib
           0x124bb7000 -        0x125c61fff +il.dylib (0) <E7CA2558-3ACA-35C0-89D2-C81B2D7F3F62> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/MacOS/il.dylib
           0x1263e0000 -        0x1263ecfff +mt.dylib (0) <D50BE64F-6157-3BEA-972F-4680E79A88DB> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/MacOS/mt.dylib
           0x1263fa000 -        0x126830fff +ml.dylib (0) <A9624B6A-CAA6-32BE-B618-473E41213D00> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/MacOS/ml.dylib
           0x126937000 -        0x126a9bfff +libmesa.dylib (0) <8ADCDDF9-B1D5-365F-917E-A38035365127> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/MacOS/libmesa.dylib
           0x126bbe000 -        0x126c6ffff +com.avid.AvidSwrtFx (5.12.0 - 5.12.0) <90E77960-25A0-3BC7-8E20-02217E256167> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/Frameworks/AvidSwrtFx.framework/Versions/A/AvidSwrtFx
           0x126ce4000 -        0x126d87fff +com.avid.Mac2Qt (1.0 - 1.0) <EFAD6671-6F02-34BE-ACE4-1CC81F8A2271> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/Frameworks/Mac2Qt.framework/Versions/A/Mac2Qt
           0x126e52000 -        0x126e8afff +libameWaveformEngine.dylib (0) <CE3E20DB-DC01-3E3D-97B4-A9F2F83B266F> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/MacOS/libameWaveformEngine.dylib
           0x126ef1000 -        0x126ef5fff +com.avid.TaskScheduler (5.0.0.0 - 5.0.0.0) <682AE0BC-AA77-37F8-B225-28A1B0D66C7D> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/Frameworks/TaskScheduler.framework/Versions/A/TaskScheduler
           0x126f04000 -        0x12714dfff +libDMSClientLib.dylib (0) <832960CB-78D1-3483-B1DA-A4ECAB77886B> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/MacOS/libDMSClientLib.dylib
           0x12724c000 -        0x12724efff +com.avid.AvidBSMClient (1.0.1 - 1) <0299FE64-1C7F-3D55-ABEC-C0567C7F3042> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/Frameworks/AvidBSMClient.framework/Versions/A/AvidBSMClient
           0x12725a000 -        0x12727cfff +libHiip_Library.dylib (0) <B4E02EC1-36E6-3554-B85E-2C7F60F5CCA6> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/MacOS/libHiip_Library.dylib
           0x1272ac000 -        0x127506fff +com.avid.CaptionManager (1.0 - 1) <466688EF-0556-3DF4-8DC4-55CB4941D7FF> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/Frameworks/CaptionManager.framework/Versions/A/CaptionManager
           0x127612000 -        0x1294aafff +libDolbyVisionSupport.dylib (0) <2F3A5BCA-FC65-39F4-85B5-2F028C11F6C3> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/MacOS/libDolbyVisionSupport.dylib
           0x12951c000 -        0x129859fff +org.qt-project.QtQuick (5.15 - 5.15.3) <2F585777-E664-3997-BFB1-37BD4BFBFAD9> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/Frameworks/QtQuick.framework/Versions/5/QtQuick
           0x129c62000 -        0x129cbafff +org.qt-project.QtQmlModels (5.15 - 5.15.3) <5902BD07-F290-3B8F-8FFC-B57EE37D0589> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/Frameworks/QtQmlModels.framework/Versions/5/QtQmlModels
           0x129d2d000 -        0x12a092fff +org.qt-project.QtQml (5.15 - 5.15.3) <D6113FE4-6954-31CB-A250-99D298522C21> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/Frameworks/QtQml.framework/Versions/5/QtQml
           0x12a387000 -        0x12a3eafff +org.qt-project.QtPositioning (5.15 - 5.15.3) <3AB0043F-7319-3263-8C96-C220A0215D84> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/Frameworks/QtPositioning.framework/Versions/5/QtPositioning
           0x12a47a000 -        0x12a486fff +org.qt-project.QtQuickWidgets (5.15 - 5.15.3) <2A3D513D-9B8A-3F92-8FCC-5CE9773CA5B0> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/Frameworks/QtQuickWidgets.framework/Versions/5/QtQuickWidgets
           0x12a49c000 -        0x12a573fff +libIMF_SDK_1.1.8.dylib (0) <8EBF10F5-A87E-39A5-852F-8C28BC1E966D> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/MacOS/libIMF_SDK_1.1.8.dylib
           0x12a5de000 -        0x12a622fff +liblog4cplusU-1.1.7.dylib (0) <C84A7BE0-5EF8-3032-8BF3-DAD5C2B92D04> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/MacOS/liblog4cplusU-1.1.7.dylib
           0x12a65f000 -        0x12a978fff +libcom-api.dylib (0) <E69861A1-2DF7-34AC-B8E7-FFE687BA616A> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/Frameworks/libcom-api.dylib
           0x12ac9a000 -        0x12acf4fff +libAssetRegistry.dylib (0) <02C29082-BC66-33B3-98BB-BCD9612D6134> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/MacOS/libAssetRegistry.dylib
           0x12ad72000 -        0x12ad75fff +libboost_chrono-clang-darwin73-mt-x64-1_70.dylib (0) <0D01FE78-7195-3A2F-84B1-7E916E62B0BC> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/MacOS/libboost_chrono-clang-darwin73-mt-x64-1_70.dylib
           0x12ad80000 -        0x12ad84fff +libboost_date_time-clang-darwin73-mt-x64-1_70.dylib (0) <B52F3313-E0D0-3638-8181-9CE3E546308F> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/MacOS/libboost_date_time-clang-darwin73-mt-x64-1_70.dylib
           0x12ad92000 -        0x12ada1fff +libboost_filesystem-clang-darwin73-mt-x64-1_70.dylib (0) <F0A708CC-EF3E-32FB-A69A-E18850AF82D6> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/MacOS/libboost_filesystem-clang-darwin73-mt-x64-1_70.dylib
           0x12adb0000 -        0x12adb0fff +libboost_system-clang-darwin73-mt-x64-1_70.dylib (0) <9DFEE551-F414-3DFD-9911-4901AB966ACA> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/MacOS/libboost_system-clang-darwin73-mt-x64-1_70.dylib
           0x12adb6000 -        0x12adc3fff +libboost_thread-clang-darwin73-mt-x64-1_70.dylib (0) <C1928A5D-572B-3346-BEB1-43E691552757> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/MacOS/libboost_thread-clang-darwin73-mt-x64-1_70.dylib
           0x12add7000 -        0x12b0f1fff +libAvidMXF_SDK_4.7.8.dylib (0) <D110A71E-D44C-3C06-900F-1071C44816E7> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/MacOS/libAvidMXF_SDK_4.7.8.dylib
           0x12b339000 -        0x12b563fff +libxerces-c-clang-703-3.1.dylib (0) <6FF2C6DA-8F6C-3A3A-93E0-36994B4D6F55> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/MacOS/libxerces-c-clang-703-3.1.dylib
           0x12b7d7000 -        0x12b99afff +libxalan-c-clang-703-111.0.dylib (0) <91AD40D2-8519-35B1-A965-0117071E27C6> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/MacOS/libxalan-c-clang-703-111.0.dylib
           0x12bb11000 -        0x12be0afff +libxqilla-clang-703-3.dylib (0) <A82D71E5-AD96-3083-9446-48F1283B4728> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/MacOS/libxqilla-clang-703-3.dylib
           0x12bf6a000 -        0x12bf6ffff +libxalanMsg-clang-703-111.0.dylib (0) <FBBB70A8-0091-3DAF-8EBB-2D585335E0FA> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/MacOS/libxalanMsg-clang-703-111.0.dylib
           0x12bf79000 -        0x12bf8afff +com.avid.AvidStorageAPI (20.4.0d113580 - 20.4.0) <FA05B665-C906-35AE-90F2-A1D5B90C7F2B> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/Frameworks/AvidStorageAPI.framework/Versions/A/AvidStorageAPI
           0x12bfa4000 -        0x12bfd6fff +libtbb.dylib (0) <6B3D5E03-E6EC-3A5B-9834-D7D749343DB3> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/MacOS/libtbb.dylib
           0x12c00c000 -        0x12c033fff +libtbbmalloc.dylib (0) <C83A878A-540B-3872-9C1F-9128493A53B2> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/MacOS/libtbbmalloc.dylib
           0x12c067000 -        0x12c076fff +breakpadUtilities.dylib (0) <EB9CF81E-EBB5-3D88-A024-8C35C48B1E95> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/Frameworks/Breakpad.framework/Versions/A/Resources/breakpadUtilities.dylib
           0x12c088000 -        0x12c09afff +HWcommon (1.0 - 1.0) <3D8FF19D-29B7-3108-9692-F390034AAF46> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/Frameworks/HWcommon.framework/Versions/A/HWcommon
           0x12c0b4000 -        0x12c0f9fff +com.avid.AvidMPEG2Parser (5.12.0 - 5.12.0) <27CE4177-5A15-392B-A6CF-A4F3D9338FBD> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/Frameworks/AvidMPEG2Parser.framework/Versions/A/AvidMPEG2Parser
           0x12c145000 -        0x12ca87fff +libmi-client-dynamic.dylib (0) <7A47139F-B7BB-34A7-AA06-5F2503C5BB5B> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/MacOS/libmi-client-dynamic.dylib
           0x12d854000 -        0x12d854fff +libMvInt.dylib (0) <A1671832-3305-3DF7-A418-9542DA515239> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/MacOS/libMvInt.dylib
           0x12d85c000 -        0x12db23fff +com.avid.AmiMDK (1.0.0 - 1.0.0) <4F79D6D9-02A6-3D73-8F41-8A1893F13151> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/Frameworks/AmiMDK.framework/Versions/A/AmiMDK
           0x12dea6000 -        0x12dea6fff +libEvents.dylib (0) <1B89AB53-2170-3F04-AC34-A7B68E35BA5B> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/MacOS/libEvents.dylib
           0x1302e0000 -        0x1302e0fff +libAvidVidSatInterface.dylib (0) <1DAF3249-44EA-31B9-A169-0493488BC412> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/MacOS/libAvidVidSatInterface.dylib
           0x1302e9000 -        0x130323fff +libAvidVideoSlave.dylib (0) <9D20C431-A1DB-3274-92DD-1F4159378CE3> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/MacOS/libAvidVideoSlave.dylib
           0x13035b000 -        0x1303acfff +com.digidesign.framework.SystemLink (20.0.10.203 - 20.0.10d203) <59846870-7DEF-38EF-B879-8D5890300735> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/Frameworks/SatelliteLink.framework/Versions/A/SatelliteLink
           0x130423000 -        0x130436fff +com.digidesign.framework.TCPE (20.0.10.203 - 20.0.10d203) <85CD5944-31AC-3466-B70B-9BF8DD2536B5> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/Frameworks/TCPE.framework/Versions/A/TCPE
           0x1305ca000 -        0x1305cdfff  com.apple.textencoding.unicode (7.0 - 7.0) <649ADC36-F7A2-3D2D-9FB6-AD05523FDDDA> /System/Library/TextEncodings/Unicode Encodings.bundle/Contents/MacOS/Unicode Encodings
           0x1305da000 -        0x130738fff +libqcocoa.dylib (0) <218F8207-F1A1-3162-9A26-FA7ABCB9E8A4> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/PlugIns/platforms/libqcocoa.dylib
           0x1314cc000 -        0x1314dbfff  libobjc-trampolines.dylib (824) <C1B6BD90-D6AA-388B-B692-D66D512630AA> /usr/lib/libobjc-trampolines.dylib
           0x131622000 -        0x131775fff  com.apple.AMDRadeonX6000GLDriver (4.6.20 - 4.0.6) <AA0EE593-B96A-313F-ABE1-27DA165D8213> /System/Library/Extensions/AMDRadeonX6000GLDriver.bundle/Contents/MacOS/AMDRadeonX6000GLDriver
           0x13237a000 -        0x13239efff +libqmacstyle.dylib (0) <FABD1395-CD38-377B-984F-3512ECD92303> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/PlugIns/styles/libqmacstyle.dylib
           0x1323c0000 -        0x1323c7fff +libqgif.dylib (0) <FD081424-7350-3E5A-93D6-7F6C6F2F23CB> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/PlugIns/imageformats/libqgif.dylib
           0x1323d2000 -        0x1323d9fff +libqicns.dylib (0) <18527A73-F9A5-303C-BED3-B614F4C4264D> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/PlugIns/imageformats/libqicns.dylib
           0x1323e5000 -        0x1323eafff +libqico.dylib (0) <EDF7BEAA-D591-3815-8399-C0BE5FA22023> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/PlugIns/imageformats/libqico.dylib
           0x1323f5000 -        0x132457fff +libqjpeg.dylib (0) <3A889470-8A53-3326-8B38-A38E1C374908> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/PlugIns/imageformats/libqjpeg.dylib
           0x132472000 -        0x132478fff +libqmacheif.dylib (0) <B0E2E81D-D3EF-3D59-A867-3B03DC264792> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/PlugIns/imageformats/libqmacheif.dylib
           0x132484000 -        0x132489fff +libqmacjp2.dylib (0) <B2D8269C-3BEC-3059-914A-D20694119C59> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/PlugIns/imageformats/libqmacjp2.dylib
           0x132495000 -        0x13249afff +libqpdf.dylib (0) <3294F771-605A-31FB-BFB3-8893DE6C3F47> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/PlugIns/imageformats/libqpdf.dylib
           0x1324a5000 -        0x132accfff +org.qt-project.QtPdf (5.15 - 5.15.3) <95449D5A-F4BA-3A67-B918-7952FAB03061> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/Frameworks/QtPdf.framework/Versions/5/QtPdf
           0x132db8000 -        0x132dbdfff +libqsvg.dylib (0) <F7827D92-13FD-305A-8D03-83710E50B464> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/PlugIns/imageformats/libqsvg.dylib
           0x132dc8000 -        0x132dccfff +libqtga.dylib (0) <51B489AF-8DC2-361A-A088-A3929216E5E2> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/PlugIns/imageformats/libqtga.dylib
           0x132dd7000 -        0x132e3dfff +libqtiff.dylib (0) <7F92CD6C-FB32-3BCF-8887-B2D302F59F2C> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/PlugIns/imageformats/libqtiff.dylib
           0x132e67000 -        0x132e6bfff +libqwbmp.dylib (0) <982772A1-D08F-3EAF-AF6F-7FDB602E56D5> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/PlugIns/imageformats/libqwbmp.dylib
           0x132e75000 -        0x132f0ffff +libqwebp.dylib (0) <B35D7622-EEA2-323F-8877-2BE1232BBBC7> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/PlugIns/imageformats/libqwebp.dylib
           0x133dd6000 -        0x133dd6fff +libboost_chrono-clang-darwin42-mt-1_61.dylib (0) <FBB5DC70-ACF9-39EF-8FAE-82CCD94C5A64> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/MacOS/libboost_chrono-clang-darwin42-mt-1_61.dylib
           0x133dde000 -        0x133ddffff +libboost_system-clang-darwin42-mt-1_61.dylib (0) <285DA50F-E6EB-313A-B52C-9AD3F364C73F> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/MacOS/libboost_system-clang-darwin42-mt-1_61.dylib
           0x135178000 -        0x13517bfff +com.avid.ByteBlock (19.1.0.24556 - 19.1.0) <5876DC34-19C8-36C9-9972-A3A4BDF885EC> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/SharedSupport/AVX2_Plug-Ins/AMA/ByteBlock.avx/Contents/MacOS/ByteBlock
           0x273921000 -        0x2739a0fff  com.apple.diopyromaniacohci (5.12.0 - 5.12.0) <00B0C586-84D0-3D03-A265-E151C0425C01> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/SharedSupport/DIOPyromaniacOHCI_v001_MC.bundle/Contents/MacOS/DIOPyromaniacOHCI_v001_MC
           0x273c07000 -        0x273c3dfff +com.avid.macflamethrowerohci (5.12.0 - 5.12.0) <36B7B4E8-9D71-315B-B726-0F62F3E1B329> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/SharedSupport/MacFlamethrowerOHCI_MC.bundle/Contents/MacOS/MacFlamethrowerOHCI_MC
           0x273d36000 -        0x273d69fff  com.apple.AVCVideoServices (1.0 - 42) <AF3D72EF-4DA9-E884-50FF-26366EEB1257> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/Frameworks/AVCVideoServices.framework/Versions/A/AVCVideoServices
           0x273da1000 -        0x273e05fff +avx2 (1.3.0 - 1.3.0) <9A32C2B9-4225-3259-89FD-DB0FCEB72A16> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/SharedSupport/avx2.bundle/Contents/MacOS/avx2
           0x273e7a000 -        0x273f1bfff +com.avid.MSP_MediaProcessor (1.0.57.10056 - ???) <63D22228-604A-3EF2-AD01-3511B3D4A707> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/SharedSupport/AVX2_Plug-Ins/AMA/MSP_MediaProcessor.avx/Contents/MacOS/MSP_MediaProcessor
           0x273f6e000 -        0x2745affff +libMediaProcessor.4.6.0.dylib (0) <FD3488AA-76AB-3DF2-BD12-68373521C9D1> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/SharedSupport/AVX2_Plug-ins/AMA/MSP_MediaProcessor.avx/Contents/MacOS/libMediaProcessor.4.6.0.dylib
           0x274f4f000 -        0x274f9dfff +libcurl.4.dylib (0) <AAB1C444-C820-3982-AA46-D368D07FFDAA> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/SharedSupport/AVX2_Plug-ins/AMA/MSP_MediaProcessor.avx/Contents/MacOS/libcurl.4.dylib
           0x274faf000 -        0x27556ffff +libGenericHelper-14.2.53.0.dylib (0) <BCC6E76F-4153-3C78-88D7-D0A5B042D2D2> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/SharedSupport/AVX2_Plug-ins/AMA/MSP_MediaProcessor.avx/Contents/MacOS/libGenericHelper-14.2.53.0.dylib
           0x2757c7000 -        0x276871fff +il.dylib (0) <E7CA2558-3ACA-35C0-89D2-C81B2D7F3F62> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/Frameworks/il.dylib
           0x276ff0000 -        0x277032fff +libIMEHost.dylib (0) <86B84BEE-F308-3A42-B639-56931AD148AB> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/SharedSupport/AVX2_Plug-ins/AMA/MSP_MediaProcessor.avx/Contents/MacOS/libIMEHost.dylib
           0x2770a4000 -        0x2770dcfff +libIMEX.dylib (0) <A113D260-0A3D-351B-9378-CD6ED0DD723E> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/SharedSupport/AVX2_Plug-ins/AMA/MSP_MediaProcessor.avx/Contents/MacOS/libIMEX.dylib
           0x27713b000 -        0x27720efff +libIMF_SDK_1.1.7.dylib (0) <03845116-A898-367A-BB75-FF52E71746F2> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/SharedSupport/AVX2_Plug-ins/AMA/MSP_MediaProcessor.avx/Contents/MacOS/libIMF_SDK_1.1.7.dylib
           0x27727b000 -        0x2772ecfff +libturbojpeg-1.5.2.dylib (0) <D43BF906-FF1E-3059-831A-9D3918D925C5> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/SharedSupport/AVX2_Plug-ins/AMA/MSP_MediaProcessor.avx/Contents/MacOS/libturbojpeg-1.5.2.dylib
           0x277302000 -        0x27732afff +libpicco_1.0.0.54.dylib (0) <4DF17F08-3D6E-39A2-812B-195130369417> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/SharedSupport/AVX2_Plug-ins/AMA/MSP_MediaProcessor.avx/Contents/MacOS/libpicco_1.0.0.54.dylib
           0x27735d000 -        0x2773fefff +libAvOmfToolkit.dylib (0) <D8F6E0ED-BB22-32C1-AD73-D95AAF717FFA> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/SharedSupport/AVX2_Plug-ins/AMA/MSP_MediaProcessor.avx/Contents/MacOS/libAvOmfToolkit.dylib
           0x277421000 -        0x2774c8fff +com.avid.acfpluginhost (1.3.0 - 1.3.0) <BED824E7-B420-3780-BA17-4C3CC947B8AD> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/Frameworks/ACFPluginHost.framework/Versions/A/ACFPluginHost
           0x27756b000 -        0x27759ffff +com.avid.DefaultCaptionDecoder (1.0.5 - 1.0.5) <02D59B86-0354-3F3B-B687-B209600EE876> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/SharedSupport/AVX2_Plug-Ins/DefaultCaptionDecoder.acf/Contents/MacOS/DefaultCaptionDecoder
           0x2775dc000 -        0x2775eafff +com.avid.MediaDialogs (1.0 - 1.0) <CCDAB45D-BDB7-3D27-A9F8-FCF216FAE760> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/SharedSupport/AVX2_Plug-Ins/MediaDialogs.acf/Contents/MacOS/MediaDialogs
           0x277619000 -        0x2777e6fff +com.avid.pxf.plugin (2.4.2.13225 - 2.4.2) <EA99E234-DC68-31FA-8A1E-5B809E8C37CF> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/SharedSupport/AVX2_Plug-Ins/PXFPlugin.avx/Contents/MacOS/PXFPlugin
           0x2778a7000 -        0x277bc1fff +libAvidMXF_SDK_4.7.3.dylib (0) <792E978C-3994-3E01-B585-62FD461587A4> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/SharedSupport/AVX2_Plug-ins/PXFPlugin.avx/Contents/MacOS/libAvidMXF_SDK_4.7.3.dylib
           0x277e02000 -        0x2780d5fff +libxerces-c-clang-900-3.2.dylib (0) <4C1DDC67-058E-385B-A7F1-C52A9A99AE07> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/SharedSupport/AVX2_Plug-ins/PXFPlugin.avx/Contents/MacOS/libxerces-c-clang-900-3.2.dylib
           0x2782c7000 -        0x2787bafff +libxqilla-clang-900-3.dylib (0) <93B99360-5C5C-3243-B27B-8BF767E410DD> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/SharedSupport/AVX2_Plug-ins/PXFPlugin.avx/Contents/MacOS/libxqilla-clang-900-3.dylib
           0x2789b1000 -        0x2789befff +libboost_filesystem-clang-darwin42-mt-1_61.dylib (0) <3F0D4805-7CEC-372A-9613-EC7742AE3D32> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/MacOS/libboost_filesystem-clang-darwin42-mt-1_61.dylib
           0x2789cd000 -        0x2789dafff +libboost_thread-clang-darwin42-mt-1_61.dylib (0) <56B973F6-0B25-32B0-B01A-9C242D9A053B> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/MacOS/libboost_thread-clang-darwin42-mt-1_61.dylib
           0x2789f2000 -        0x27a0d7fff +libnexidia.9.0.dylib (9) <28E5AC04-E141-3318-9755-CEAE0359EC73> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/MacOS/libnexidia.9.0.dylib
           0x27a731000 -        0x27ae65fff +libnxmediaaccessor.9.0.dylib (9) <A61B18C7-CFFB-33CA-B631-34BF1915C63C> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/MacOS/libnxmediaaccessor.9.0.dylib
           0x27b001000 -        0x27b03ffff +com.avid.RemoteAssetsPlugin (1.0 - 1.0) <26356FD7-28B2-38C0-9CB5-8F4B85204AF7> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/SharedSupport/AVX2_Plug-Ins/RemoteAssetsPlugin.avx/Contents/MacOS/RemoteAssetsPlugin
           0x27b0d4000 -        0x27b558fff +com.avid.mpi.imeamahost (1.0 - 1) <0CF4C2E6-CACA-36F0-8EA6-C60CAE0BC2DC> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/SharedSupport/AVX2_Plug-Ins/Utils/AAFProcessor.avx/Contents/MacOS/AAFProcessor
           0x27b74f000 -        0x27b75bfff +com.avid.RestClient (1.0 - 1.0) <9BA4A2E0-3BA5-3F0A-B720-06DA9FED7B38> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/SharedSupport/AVX2_Plug-Ins/RestClient.acf/Contents/MacOS/RestClient
           0x27b77a000 -        0x27b782fff +com.avid.VDM.bridge (4.6.4 - 4.6.4) <4C64C33F-115B-3E5D-81E3-88C1F8508495> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/SharedSupport/AVX2_Plug-Ins/AvidVDM.acf/Contents/MacOS/AvidVDM
           0x27b792000 -        0x27b8effff +ilgpu.dylib (0) <7DD84754-FF14-3014-86F1-F3E66363594C> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/MacOS/ilgpu.dylib
           0x27b99e000 -        0x27ba4ffff +com.avid.amfPlayer ( version 1.0 - 1.0) <8D7A2AC1-1E78-30DD-AFB7-380DCB60A35F> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/SharedSupport/AVX2_Plug-Ins/amfPlayer.avx/Contents/MacOS/amfPlayer
           0x27bbee000 -        0x27d3d4fff +com.absoft.NeatVideo5-MC (Neat Video v5.2.6 Pro plug-in for Media Composer - 5.2.6) <85F9B013-08CB-32BC-91D1-4C06AC5F556C> /Library/Application Support/Avid/*/NeatVideo5
           0x27d77f000 -        0x27d7a6fff +com.Avid.OpenIO-NDI (1.0.0 - 1.0.0) <E905F28E-D8BC-341C-AA7F-AC8860A891D6> /Library/Application Support/Avid/*/OpenIO_NDI
           0x27d7ef000 -        0x27dbbafff +libndi.4.dylib (0) <B6AB38DE-044F-38EC-AEBD-C4B3A0DA0C4F> /Library/Application Support/Avid/*/libndi.4.dylib
           0x27dd07000 -        0x27dd0efff +libqgenericbearer.dylib (0) <DEC411B3-8E45-3984-8286-C87D8FD33A03> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/PlugIns/bearer/libqgenericbearer.dylib
           0x27dd20000 -        0x27dd24fff +com.avid.HWcommon_ACF (19.4.0d236307 - 19.4.0) <16EEE557-C939-3C53-AB0B-695F19E813D7> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/SharedSupport/AVX2_Plug-Ins/HWcommon_ACF.acf/Contents/MacOS/HWcommon_ACF
           0x27dd37000 -        0x27ddb6fff +com.Avid.HWSDK (1.0 - 1) <895DB82E-B376-3A1A-87E2-713B71C0A2E7> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/SharedSupport/AVX2_Plug-Ins/HWSDK.acf/Contents/MacOS/HWSDK
           0x27de9d000 -        0x27dea4fff +HWcommon_Basics (0) <40E1DE51-04A5-35BC-8219-9AB36D064538> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/Frameworks/HWcommon_Basics.framework/Versions/A/HWcommon_Basics
           0x27deb3000 -        0x27dec8fff +com.Avid.OpenIO_Manifold (1.0 - 1) <FF91EBA3-D371-3DFF-9251-9B7C41AC0F00> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/SharedSupport/AVX2_Plug-Ins/OpenIO_Manifold.acf/Contents/MacOS/OpenIO_Manifold
           0x27df00000 -        0x27df0cfff +com.Avid.OpenIO_VirtIO (1.0 - 1) <4976F424-15E9-3A6C-824E-5562A1866A25> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/SharedSupport/AVX2_Plug-Ins/OpenIO_VirtIO.acf/Contents/MacOS/OpenIO_VirtIO
           0x27df32000 -        0x27df4cfff +com.avid.ACFString ( version 1.1.0 - 1.0) <4D18598C-CA0F-3389-B397-E5A24AEA0547> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/SharedSupport/AVX2_Plug-Ins/ACFString.avx/Contents/MacOS/ACFString
           0x290074000 -        0x2900e8fff +acpl_main (???) <85C760FB-8C6C-393F-B354-58417031088B> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/SharedSupport/AVX2_Plug-Ins/acpl_main.acf/Contents/MacOS/acpl_main
           0x29013d000 -        0x2901f6fff +acpl_cpu (???) <8A1CEDD9-4B37-3EFB-8FEC-F6C75978C54B> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/SharedSupport/AVX2_Plug-Ins/acpl_cpu.acf/Contents/MacOS/acpl_cpu
           0x29027c000 -        0x2902e7fff +acpl_gpu (???) <78A429A5-B5ED-3957-A983-0B0A656798A0> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/SharedSupport/AVX2_Plug-Ins/acpl_gpu.acf/Contents/MacOS/acpl_gpu
           0x290347000 -        0x2904befff +libqsqlite.dylib (0) <D2033E59-54AB-37BA-BCA0-4CFCFFFBC888> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/PlugIns/sqldrivers/libqsqlite.dylib
           0x29050b000 -        0x290590fff +com.digidesign.AMPIPluginDSM (20.0.10.203 - 20.0.10d203) <30AE232A-714D-3DE2-B96B-F9E7D2FEF988> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/SharedSupport/Private_Plug-Ins/AMPIPluginDSM.avx/Contents/MacOS/AMPIPluginDSM
           0x290625000 -        0x29063ffff +com.digidesign.framework.AudioFoundation (20.0.10.203 - 20.0.10d203) <20DEC885-FC2E-3DD1-BB47-F2D7E12CBD9A> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/Frameworks/AFnd.framework/Versions/A/AFnd
           0x290664000 -        0x290686fff +com.digidesign.framework.PlatformSupport (20.0.10.203 - 20.0.10d203) <C001A1CB-CCBB-3487-B57A-3C8C0CA4A8FD> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/Frameworks/DigiPlatformSupport.framework/Versions/A/DigiPlatformSupport
           0x2908c2000 -        0x290e98fff +com.digidesign.framework.FileFormat (20.0.10.203 - 20.0.10d203) <F94076CC-3E97-3E45-AD8B-AFCDDBBD46D4> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/Frameworks/FFmt.framework/Versions/A/FFmt
           0x2915d3000 -        0x29183cfff +com.digidesign.framework.CoreFoundation (20.0.10.203 - 20.0.10d203) <18E69C31-7C49-3838-B91B-B91EF7AF16D7> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/Frameworks/CFnd.framework/Versions/A/CFnd
           0x291941000 -        0x291afafff +com.digidesign.framework.MoreFoundation (20.0.10.203 - 20.0.10d203) <FD428BD1-05F2-3DED-B8EB-2662ACC73642> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/Frameworks/MFnd.framework/Versions/A/MFnd
           0x291be6000 -        0x291e49fff +com.digidesign.framework.SMgr (20.0.10.203 - 20.0.10d203) <5403F226-61C5-3D53-BC05-5EE188E1F13B> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/Frameworks/SMgr.framework/Versions/A/SMgr
           0x292490000 -        0x292625fff +com.avid.framework.AAE (20.0.10.203 - 20.0.10d203) <3B007CEF-0E76-3BDC-934C-67280E125655> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/Frameworks/AAE.framework/Versions/A/AAE
           0x292c27000 -        0x292dbefff +com.avid.framework.ClipFX (20.0.10.203 - 20.0.10d203) <6764A05E-FA5A-35EB-9AD2-43E9B08C06B8> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/Frameworks/ClipFX.framework/Versions/A/ClipFX
           0x292e36000 -        0x292eb3fff +taglib.dylib (0) <D71C6855-93C6-3ED3-9294-9B01FE7BE416> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/Frameworks/taglib.dylib
           0x292ef6000 -        0x2932a1fff +com.digidesign.framework.DSI (20.0.10.203 - 20.0.10d203) <46009ECD-49BC-3212-A186-261D347542EB> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/Frameworks/DSI.framework/Versions/A/DSI
           0x2933fe000 -        0x2936e0fff +com.digidesign.framework.DFW (20.0.10.203 - 20.0.10d203) <C53C0D6F-7A38-318C-B27A-8DBD82F41AEC> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/Frameworks/DFW.framework/Versions/A/DFW
           0x2938cc000 -        0x293927fff +com.digidesign.framework.DHS (20.0.10.203 - 20.0.10d203) <67E82154-0052-3FB9-996C-1953C83D7337> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/Frameworks/DHS.framework/Versions/A/DHS
           0x293983000 -        0x2939aafff +com.digidesign.framework.Mdis (20.0.10.203 - 20.0.10d203) <E9F9DDDC-C7CA-31D9-899B-89312BDA1188> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/Frameworks/mdis.framework/Versions/A/Mdis
           0x2939dd000 -        0x293b88fff +com.avid.framework.AAXHost (20.0.10.203 - 20.0.10d203) <28108BF2-143D-394C-A97E-E72791804CD0> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/Frameworks/AAXHost.framework/Versions/A/AAXHost
           0x293c0e000 -        0x293c3cfff +com.digidesign.framework.Mdid (20.0.10.203 - 20.0.10d203) <7C83BFA7-420F-3F1A-A870-979608B23EAE> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/Frameworks/mdid.framework/Versions/A/Mdid
           0x293c5b000 -        0x293c82fff +com.digidesign.framework.Mdie (20.0.10.203 - 20.0.10d203) <76B1E697-3AE3-3C65-BF4C-9555847F2328> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/Frameworks/mdie.framework/Versions/A/Mdie
           0x293cb7000 -        0x293cbafff +com.digidesign.framework.TISys (20.0.10.203 - 20.0.10d203) <C5DF5AEB-449B-3258-9551-D4AB943E1EBF> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/Frameworks/TISys.framework/Versions/A/TISys
           0x293cc4000 -        0x293cedfff +com.digidesign.framework.DSK (20.0.10.203 - 20.0.10d203) <81EA2AEC-1B7C-3337-92EA-39564EB70994> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/Frameworks/DSK.framework/Versions/A/DSK
           0x293d0f000 -        0x293d28fff +com.digidesign.framework.TIDSPMgr (20.0.10.203 - 20.0.10d203) <54CE3F47-DE1B-3F67-863D-82241F4423B9> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/Frameworks/TIDspMgr.framework/Versions/A/TIDspMgr
           0x293d3b000 -        0x293d47fff +com.digidesign.framework.AAXShared (20.0.10.203 - 20.0.10d203) <C83803D2-2D6B-3B4A-A0F4-CEF045BF09AD> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/Frameworks/AAXShared.framework/Versions/A/AAXShared
           0x293d5b000 -        0x293d63fff +com.digidesign.framework.DUI (20.0.10.203 - 20.0.10d203) <E9A2F56F-1975-3578-A650-88927074C60D> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/Frameworks/DUI.framework/Versions/A/DUI
           0x293d7a000 -        0x294044fff +com.avid.framework.TIShellMgr (20.0.10x203 - 20.0.10d203) <514D373F-5439-34FA-8D40-4565BD5C4CA7> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/Frameworks/TIShellMgr.framework/Versions/A/TIShellMgr
           0x294591000 -        0x2945aafff +com.digidesign.framework.CDS (20.0.10.203 - 20.0.10d203) <062717CB-EBC5-34A5-824F-DA4EE7F611B2> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/Frameworks/CDS.framework/Versions/A/CDS
           0x2945bd000 -        0x295f55fff +libicudata.62.1.dylib (0) <C88B8077-24F5-379D-B8D4-72E4A38F2472> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/Frameworks/libicudata.62.1.dylib
           0x295f8e000 -        0x29615bfff +libicui18n.62.1.dylib (0) <34647193-387C-374F-91A5-29B787FB2134> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/Frameworks/libicui18n.62.1.dylib
           0x29625e000 -        0x29639cfff +libicuuc.62.1.dylib (0) <DFAB255E-63B6-311E-B86E-C86033D25CD6> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/Frameworks/libicuuc.62.1.dylib
           0x296414000 -        0x296427fff +com.digidesign.framework.digitrace (20.0.10.203 - 20.0.10d203) <A0D53839-D9E4-3064-9812-2B3B93680434> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/Frameworks/DigiTrace.framework/Versions/A/Digitrace
           0x29643a000 -        0x296479fff +InnerProcessDictionary.dylib (0) <8A1B3FE5-EC39-3227-B954-B3EEDC85C417> /Library/Application Support/Waves/*/InnerProcessDictionary.dylib
           0x2964d9000 -        0x2965f8fff +com.WavesAudio.WavesLicenseEngine.2.0.0 (2.0.0 - 2.0.0.2) <A8C67476-2D40-3527-8FFB-C5140655CAB8> /Library/Application Support/Waves/*/WavesLicenseEngine.bundle/Contents/MacOS/WavesLicenseEngine
           0x29666f000 -        0x296676fff  com.apple.audio.AppleGFXHDAHALPlugIn (100.1.433 - 100.1.433) <2065ABB8-5CB8-32F8-9A0B-DB8E3A39E897> /System/Library/Extensions/AppleGFXHDA.kext/Contents/PlugIns/AppleGFXHDAHALPlugIn.bundle/Contents/MacOS/AppleGFXHDAHALPlugIn
           0x296683000 -        0x296694fff +libAMAUtilLib20.dylib (0) <786D039D-C60F-3F57-8C28-3D6DAD7DDFA3> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/MacOS/libAMAUtilLib20.dylib
           0x2966a7000 -        0x2966b6fff +com.avid.AMALogger (3.5.4.10016 - ???) <1E15EF52-B6EE-3A56-9909-67AD2444041E> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/SharedSupport/AVX2_Plug-Ins/AMA/AMALogger.avx/Contents/MacOS/AMALogger
           0x2966ca000 -        0x296783fff +com.avid.MSP_Q7 (3.6.18.693 - ???) <5042CFE9-9001-32F5-815A-615A762C3314> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/SharedSupport/AVX2_Plug-Ins/AMA/AMA-Avid-Q7/MSP_Q7.avx/Contents/MacOS/MSP_Q7
           0x2967e0000 -        0x296a75fff +com.avid.LEPCore (18.5.0.565 - ???) <9B3FC741-2104-375D-96B3-293DED24629E> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/SharedSupport/AVX2_Plug-Ins/AMA/AMA-Avid-Q7/LEPCore.acf/Contents/MacOS/LEPCore
           0x296d10000 -        0x296d1dfff +com.avid.FeederFactory (18.5.0.565 - ???) <CE54A77F-47F7-3836-9368-E131C7F53364> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/SharedSupport/AVX2_Plug-Ins/AMA/AMA-Avid-Q7/FeederFactory.acf/Contents/MacOS/FeederFactory
           0x296d35000 -        0x296e16fff +com.avid.MSP_AVCHD (1.6.1.342 - ???) <999D4957-46F5-3C4C-B6AE-4832518C78B6> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/SharedSupport/AVX2_Plug-Ins/AMA/MSP_AVCHD.avx/Contents/MacOS/MSP_AVCHD
           0x296e6c000 -        0x296ea0fff +com.avid.TSParser (2.7.9.10007 - ???) <DE0A60D8-6A2C-347B-A521-020F05C46B20> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/SharedSupport/AVX2_Plug-Ins/Codecs/TSParser.acf/Contents/MacOS/TSParser
           0x296ec8000 -        0x296ef6fff +com.avid.AMASampleProviderSupport (3.5.4.10016 - ???) <CA0F0954-870A-3AE1-A319-B00649A2439F> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/SharedSupport/AVX2_Plug-Ins/AMA/AMASampleProviderSupport.avx/Contents/MacOS/AMASampleProviderSupport
           0x296f19000 -        0x296fc1fff +com.avid.MVP_AVCHD (1.6.1.342 - ???) <27EDAAB1-0C2E-330E-B260-9E88CAADE062> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/SharedSupport/AVX2_Plug-Ins/AMA/MVP_AVCHD.avx/Contents/MacOS/MVP_AVCHD
           0x297002000 -        0x2970cafff +libIMF_SDK_1.0.7.dylib (0) <B59AB745-C9A7-349F-84DF-A6A7F7775C64> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/SharedSupport/AVX2_Plug-ins/AMA/MVP_MSP_IMF.avx/Contents/MacOS/libIMF_SDK_1.0.7.dylib
           0x29712a000 -        0x29712efff +libboost_date_time-clang-darwin42-mt-1_61.dylib (0) <FD972B1A-7796-396F-9A76-3B4691A330C4> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/SharedSupport/AVX2_Plug-ins/AMA/MVP_MSP_IMF.avx/Contents/MacOS/libboost_date_time-clang-darwin42-mt-1_61.dylib
           0x29713b000 -        0x297158fff +com.avid.MVP_MediaCollector (2.2.3.10170 - ???) <607B1457-CAD1-3A12-92CB-D0A3C25F7476> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/SharedSupport/AVX2_Plug-Ins/AMA/MVP_MediaCollector.avx/Contents/MacOS/MVP_MediaCollector
           0x297174000 -        0x2971fafff +com.gluetools.GT-PhantomCine-AMA (2.0.3031 - 2.0.3031) <9A4F30B3-3952-36D4-8712-ACE95CE1EC54> /Library/Application Support/Avid/*/GT_PhantomCine_AMA
           0x29722e000 -        0x297521fff +com.paceap.eden.WrapPersist (5.4.1 GM [b3455, 933b85fce7] - 5.4.1.3455) <B284E26C-A8EF-3361-B1BA-D7868EF7C908> /Library/Frameworks/PACEEdenExperience.framework/Versions/Current/WrapPersist.bundle/Contents/MacOS/WrapPersist
           0x297562000 -        0x297fccfff +com.WavesAudio.WaveShell1-AAX.11.0.0 (11.0.0 - 11.0.0127) <F1A65EF8-F56D-37AC-A43D-6B60A8D11E77> /Library/Application Support/Avid/*/WaveShell1-AAX
           0x29880a000 -        0x29929afff +com.WavesAudio.WaveShell1-AAX.12.7.0 (12.7.0 - 12.7.0209) <AD708086-394A-3E77-AB78-AC2D94123FA6> /Library/Application Support/Avid/*/WaveShell1-AAX
           0x299b5c000 -        0x299dd0fff +com.avid.AMA-Avid-IMF (1.0.2.10004 - ???) <FE18DDE1-CC66-3B5B-987F-8D306D211563> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/SharedSupport/AVX2_Plug-Ins/AMA/MVP_MSP_IMF.avx/Contents/MacOS/MVP_MSP_IMF
           0x29a00e000 -        0x29a328fff +libAvidMXF_SDK_4.6.45.dylib (0) <AD34DD8E-28CA-3F42-9D01-C6E4018A4099> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/SharedSupport/AVX2_Plug-ins/AMA/MVP_MSP_IMF.avx/Contents/MacOS/libAvidMXF_SDK_4.6.45.dylib
           0x29a565000 -        0x29a7bffff +com.avid.AMA-Avid-QuickTime (1.10.3.10210 - ???) <E2428480-916C-3633-AFDD-E19F0526FC73> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/SharedSupport/AVX2_Plug-Ins/AMA/MVP_MSP_QuickTime.avx/Contents/MacOS/MVP_MSP_QuickTime
           0x29a81c000 -        0x29aa49fff +com.avid.ama.autodetect (1.4.4.32 - ???) <E92D30B8-3311-3F90-BF0A-EF70383F2C5F> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/SharedSupport/AVX2_Plug-Ins/AMA/AMAAutodetect.avx/Contents/MacOS/AMAAutodetect
           0x29ad11000 -        0x29afe7fff +com.avid.AMA-Avid-AS11 (1.9.6.10172 - ???) <25F8DDDD-96BC-3AE7-89B0-553DB1158622> /Library/Application Support/Avid/*/MSP_AS11
           0x29b183000 -        0x29b41efff +com.avid.AMA-Avid-MXF (1.22.11.10176 - ???) <1289D40B-57FE-3FC3-B50E-029FE09A3B0E> /Library/Application Support/Avid/*/MSP_MXF
           0x29b594000 -        0x29b67afff +com.avid.AMA-Avid-WaveAiff (1.8.7.10175 - ???) <6A2CF95E-95AD-341E-88FE-5737D7C8BA80> /Library/Application Support/Avid/*/MSP_WaveAiff
           0x29b6da000 -        0x29bc22fff +com.avid.AMA-Avid-AS02 (1.12.0.10177 - ???) <18BE4C58-F68D-346C-8E70-D105F49FAE38> /Library/Application Support/Avid/*/MVP_MSP_AS02
           0x29bfd8000 -        0x29c09bfff +com.avid.MVP_MSP_AvidImageSequencer (1.4.6.10174 - ???) <6B54E5E2-C73A-3E43-9EA2-855C7C3765F7> /Library/Application Support/Avid/*/MVP_MSP_AvidImageSequencer
           0x29c0ea000 -        0x29c1bafff +com.avid.AMA_Avid_REDR3D (1.19.21.10112 - ???) <30FA4512-11EA-38BE-BDCE-F6672292056B> /Library/Application Support/Avid/*/MVP_MSP_REDR3D
           0x29c217000 -        0x29c43afff +REDR3D.dylib (0) <3F88935C-39CB-3D8F-AA68-478BEF1CC694> /Library/Application Support/Avid/*/REDR3D.dylib
           0x29c466000 -        0x29c657fff +REDOpenCL.dylib (0) <D54DBEDF-8CEB-3FFF-9C86-D92670D10D66> /Library/Application Support/Avid/*/REDOpenCL.dylib
           0x29c6c0000 -        0x29c6e1fff +com.avid.AAC_ContainerHandler (9.0.20.10099 - ???) <F7EFCD6E-7137-3497-9348-44CBBBB65D1C> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/SharedSupport/AVX2_Plug-Ins/AMA/AMA-Avid-Q7/AAC_ContainerHandler.acf/Contents/MacOS/AAC_ContainerHandler
           0x29c702000 -        0x29c72efff +com.avid.MP3_ContainerHandler (4.0.21.10041 - ???) <A0F5E73F-65D2-3832-9977-3344EA3FB8C6> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/SharedSupport/AVX2_Plug-Ins/AMA/AMA-Avid-Q7/MP3_ContainerHandler.acf/Contents/MacOS/MP3_ContainerHandler
           0x29c754000 -        0x29cb9cfff +com.avid.QTFFContainerHandler (10.0.35.622 - ???) <F2E8D420-5100-32A6-96CB-8E44855ED801> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/SharedSupport/AVX2_Plug-Ins/AMA/AMA-Avid-Q7/QTFFContainerHandler.acf/Contents/MacOS/QTFFContainerHandler
           0x29cef7000 -        0x29cf66fff +com.avid.ImageSeq_ContainerHandler (1.2.4.154 - ???) <1516AB5A-C0D3-37AC-BA47-E48CBCFF2215> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/SharedSupport/AVX2_Plug-Ins/UME/ImageSeq_ContainerHandler.acf/Contents/MacOS/ImageSeq_ContainerHandler
           0x29cfa9000 -        0x29d22ffff +com.avid.MXF_ContainerHandler (1.2.4.315 - ???) <4C19230B-9614-38C3-B3D1-50E5F271033D> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/SharedSupport/AVX2_Plug-Ins/UME/MXF_ContainerHandler.acf/Contents/MacOS/MXF_ContainerHandler
           0x29d421000 -        0x29d44ffff +com.avid.JPEGContainerHandler (9.0.17.10065 - ???) <D0299AAE-F211-3933-8E19-B5F5E3951B23> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/SharedSupport/AVX2_Plug-Ins/AMA/AMA-Avid-Q7/JPEGContainerHandler.acf/Contents/MacOS/JPEGContainerHandler
           0x29d476000 -        0x29d4fefff +com.avid.TiffContainerHandler (9.0.18.10071 - ???) <4335A679-C4E0-35FD-98D0-2FDBBA3B708F> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/SharedSupport/AVX2_Plug-Ins/AMA/AMA-Avid-Q7/TiffContainerHandler.acf/Contents/MacOS/TiffContainerHandler
           0x29d533000 -        0x29d571fff +com.avid.DPX_ContainerHandler (1.0.14.52 - ???) <DC00D13A-8870-3B4A-B759-FE02D5623F6F> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/SharedSupport/AVX2_Plug-Ins/UME/DPX_ContainerHandler.acf/Contents/MacOS/DPX_ContainerHandler
           0x29d5a3000 -        0x29d8a9fff +com.avid.OpenEXR_ContainerHandler (1.0.18.10031 - ???) <29EF194F-934F-30F9-A60D-2DE3E95732E3> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/SharedSupport/AVX2_Plug-Ins/UME/OpenEXR_ContainerHandler.acf/Contents/MacOS/OpenEXR_ContainerHandler
           0x29d937000 -        0x29d9aefff +com.avid.PNG_ContainerHandler (1.0.17.50 - ???) <79C4B4AB-89A6-33B0-9F7C-A7F637AF98A0> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/SharedSupport/AVX2_Plug-Ins/UME/PNG_ContainerHandler.acf/Contents/MacOS/PNG_ContainerHandler
           0x29d9e9000 -        0x29da09fff +com.avid.TGA_ContainerHandler (1.0.4.10009 - ???) <C28E0C1B-6288-3B67-B30A-12B3DAEBDBE7> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/SharedSupport/AVX2_Plug-Ins/UME/TGA_ContainerHandler.acf/Contents/MacOS/TGA_ContainerHandler
           0x29da2a000 -        0x29da40fff +com.avid.AMADeviceMonitor (3.5.4.10016 - ???) <83015949-F94D-39EC-AD37-6B321FFB735C> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/SharedSupport/AVX2_Plug-Ins/AMA/AMADeviceMonitor.avx/Contents/MacOS/AMADeviceMonitor
           0x29dc79000 -        0x29dd60fff +com.avid.AvidTitlerPlus (1.0 - 1.0) <AB92DD7F-A4CE-3E09-A2D3-02E01FA380AC> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/SharedSupport/AVX2_Plug-Ins/AvidTitlerPlus.avx/Contents/MacOS/AvidTitlerPlus
           0x29de10000 -        0x29fd4ffff +DekoLibrary.dylib (0) <CB934FF7-AE93-3C96-B9B2-20DC19D09554> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/MacOS/DekoLibrary.dylib
           0x2a0517000 -        0x2a055afff +acpl_processing (???) <710DBB19-416C-399C-A880-07AC61ADAA45> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/SharedSupport/AVX2_Plug-Ins/acpl_processing.acf/Contents/MacOS/acpl_processing
           0x2a05a9000 -        0x2a05c5fff +acpl_convert (???) <E431E5B0-B30F-32E6-AD2D-CDD4E3400557> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/SharedSupport/AVX2_Plug-Ins/acpl_convert.acf/Contents/MacOS/acpl_convert
           0x2a05ec000 -        0x2a06ebfff +com.avid.AcplEffects (1.0 - 1.0) <610D7FC0-26B6-334A-B840-B5966E558866> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/SharedSupport/AVX2_Plug-Ins/AcplEffects.avx/Contents/MacOS/AcplEffects
           0x2a1c26000 -        0x2a1c8dfff +com.avid.CodecToolkit.CodecMaster (3.15.9.301 - 3.15.9.301) <713E3AB8-7AA2-3D08-B7A3-31327BE3B2AD> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/SharedSupport/AVX2_Plug-Ins/CodecToolkit/codecmaster.acf/Contents/MacOS/CodecMaster
           0x2a1cbd000 -        0x2a1ce0fff +com.avid.CodecToolkit.CTSharedResourceHandling (3.15.9.301 - 3.15.9.301) <C60FC7C2-5FB3-3624-AE62-F6235BF78CDC> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/SharedSupport/AVX2_Plug-Ins/CodecToolkit/CTSharedResourceHandling.acf/Contents/MacOS/CTSharedResourceHandling
           0x303677000 -        0x30377ffff +com.avid.MCEffects (1.0 - 1.0) <D6247653-10BA-3DF4-BE77-DAFC935557EB> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/SharedSupport/AVX2_Plug-Ins/MCEffects.avx/Contents/MacOS/MCEffects
           0x32820b000 -        0x328524fff +libcom-api.dylib (0) <E69861A1-2DF7-34AC-B8E7-FFE687BA616A> /Library/Application Support/Avid/libcom-api.dylib
           0x328846000 -        0x3289b1fff  com.apple.CodecsManager (1.0.0 - 1.0.0) <FC164B4D-5A67-D658-631F-3CE78F2FA7C6> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/SharedSupport/AVX2_Plug-Ins/Codecs/CodecManager.avx/Contents/MacOS/CodecManager
           0x3289f2000 -        0x328aa6fff +com.avid.codecs.10packed (2.0.0 - 2.0.0) <3AA088B8-0C1F-253C-14CB-2779EBDED635> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/SharedSupport/AVX2_Plug-Ins/Codecs/CMAvid10PackerCodec.avx/Contents/MacOS/CMAvid10PackerCodec
           0x328ae8000 -        0x329094fff +com.yourcompany.CMAvidAVCIntraCodec (2.0.0 - 2.0.0) <AB556A57-44C7-CA5E-AD49-D74474009033> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/SharedSupport/AVX2_Plug-Ins/Codecs/CMAvidAVCIntraCodec.avx/Contents/MacOS/CMAvidAVCIntraCodec
           0x329226000 -        0x329511fff +com.avid.codecs.dv100 (2.0.0 - 2.0.0) <F063437D-AC2C-DA6D-4262-C0AFB4286D1D> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/SharedSupport/AVX2_Plug-Ins/Codecs/CMAvidDV100Codec.avx/Contents/MacOS/CMAvidDV100Codec
           0x3295a7000 -        0x329901fff +com.avid.codecs.dv (2.0.0 - 2.0.0) <7E5EFFF1-E9BC-22B7-DE9D-D9615B4DE82C> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/SharedSupport/AVX2_Plug-Ins/Codecs/CMAvidDVCodec.avx/Contents/MacOS/CMAvidDVCodec
           0x3299b3000 -        0x32a382fff  com.apple.carbonframeworktemplate (2.0.0 - 2.0.0) <6A2766B2-84D4-FA91-C3E0-54ECB7648B20> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/SharedSupport/AVX2_Plug-Ins/Codecs/CMAvidH264IBPCodecD2.avx/Contents/MacOS/CMAvidH264IBPCodecD2
           0x32a479000 -        0x32a788fff +com.avid.avxplugin.CMAvidHDCodec (2.0.0 - 2.0.0) <E0167A90-3AA9-092F-53AA-FECF1174FCA0> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/SharedSupport/AVX2_Plug-Ins/Codecs/CMAvidHDCodec.avx/Contents/MacOS/CMAvidHDCodec
           0x32a892000 -        0x32aca7fff +com.yourcompany.CMAvidJ2KCodec (2.0.0 - 2.0.0) <D47F76F0-DB76-A2EB-0297-FDF9DABE0DF2> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/SharedSupport/AVX2_Plug-Ins/Codecs/CMAvidJ2KCodec.avx/Contents/MacOS/CMAvidJ2KCodec
           0x32adab000 -        0x32b09dfff +com.avid.codecs.jpeg (2.0.0 - 2.0.0) <05D4A8D1-3DAB-C54C-38F4-C7EC9C5A6609> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/SharedSupport/AVX2_Plug-Ins/Codecs/CMAvidJPEGCodec.avx/Contents/MacOS/CMAvidJPEGCodec
           0x32b126000 -        0x32b407fff +com.avid.codecs.MPEG2EncoderBridge (2.0.0 - 2.0.0) <A3A89169-4760-E6A4-1B0C-6526FCD4FE12> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/SharedSupport/AVX2_Plug-Ins/Codecs/CMAvidMPEG2EncoderBridge.avx/Contents/MacOS/CMAvidMPEG2EncoderBridge
           0x32b493000 -        0x32b7b7fff +com.avid.codecs.mpeg2 (2.0.0 - 2.0.0) <5057BBA7-9B70-39FE-6BCB-5CDD3E3B3AB4> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/SharedSupport/AVX2_Plug-Ins/Codecs/CMAvidMPEG2IBPCodec.avx/Contents/MacOS/CMAvidMPEG2IBPCodec
           0x32b853000 -        0x32bb4dfff +com.avid.codecs.mpeg2iframe (2.0.0 - 2.0.0) <074A9CD4-14F9-B776-850B-2980F3A9A763> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/SharedSupport/AVX2_Plug-Ins/Codecs/CMAvidMPEG2IFrameCodec.avx/Contents/MacOS/CMAvidMPEG2IFrameCodec
           0x32bbe9000 -        0x32beddfff +com.avid.codecs.mpeg2imx (2.0.0 - 2.0.0) <00FA8613-7F4D-B199-7633-989274FED7D2> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/SharedSupport/AVX2_Plug-Ins/Codecs/CMAvidMPEG2IMXCodec.avx/Contents/MacOS/CMAvidMPEG2IMXCodec
           0x32bf7b000 -        0x32c334fff +com.avid.codecs.mpeg4 (2.0.0 - 2.0.0) <4232160E-AB81-4B9E-5189-4C97A148A98D> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/SharedSupport/AVX2_Plug-Ins/Codecs/CMAvidMPEG4Codec.avx/Contents/MacOS/CMAvidMPEG4Codec
           0x32c3d3000 -        0x32c714fff +com.avid.codecs.ProResCodec (2.0.0 - 2.0.0) <F126A6F9-ED6D-2EF1-27DE-E1AB88215E45> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/SharedSupport/AVX2_Plug-Ins/Codecs/CMAvidProResCodec.avx/Contents/MacOS/CMAvidProResCodec
           0x32c7f7000 -        0x32c883fff +com.avid.codecs.rgbpacker (2.0.0 - 2.0.0) <C22E052B-2267-B423-2543-F19BC085EC9A> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/SharedSupport/AVX2_Plug-Ins/Codecs/CMAvidRGBPacker.avx/Contents/MacOS/CMAvidRGBPacker
           0x32c8d3000 -        0x32cbadfff +com.avid.codecs.rle (2.0.0 - 2.0.0) <1522F954-037F-7F62-CE65-8521E09BEFFE> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/SharedSupport/AVX2_Plug-Ins/Codecs/CMAvidRLECodec.avx/Contents/MacOS/CMAvidRLECodec
           0x32cc20000 -        0x32cc76fff  com.apple.uncompressed (2.0.0 - 2.0.0) <B3640907-14DF-A60E-C041-6139131C2C3D> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/SharedSupport/AVX2_Plug-Ins/Codecs/CMAvidUncompressedCodec.avx/Contents/MacOS/CMAvidUncompressedCodec
           0x32cca1000 -        0x32cd14fff +com.avid.CodecToolkit.BasicFilters (3.15.9.301 - 3.15.9.301) <482698DE-1C15-39BB-AF0F-AE2DDE9F8C8E> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/SharedSupport/AVX2_Plug-Ins/CodecToolkit/BasicFilters.acf/Contents/MacOS/BasicFilters
           0x32cd26000 -        0x32cd92fff +com.avid.CodecToolkit.CTSharedCoreClasses (3.15.9.301 - 3.15.9.301) <472A66BE-A7A8-3DC6-A9C0-6F7CB84F27C1> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/SharedSupport/AVX2_Plug-Ins/CodecToolkit/CTSharedCoreClasses.acf/Contents/MacOS/CTSharedCoreClasses
           0x32cda2000 -        0x32ce5afff +com.avid.CodecToolkit.CATAAC (3.15.9.301 - 3.15.9.301) <1DFBC6CF-4D84-350D-8F1C-6B5FE4CD21A5> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/SharedSupport/AVX2_Plug-Ins/CodecToolkit/CATAAC.acf/Contents/MacOS/CATAAC
           0x32ce6a000 -        0x32ce9cfff +com.avid.CodecToolkit.CATALAC (3.15.9.301 - 3.15.9.301) <21148601-04F8-3F32-BDEA-DDFD8AEACEE8> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/SharedSupport/AVX2_Plug-Ins/CodecToolkit/CATALAC.acf/Contents/MacOS/CATALAC
           0x32cea8000 -        0x32d844fff +com.avid.CodecToolkit.CATAVC (3.15.9.301 - 3.15.9.301) <6090706B-A3F5-31B5-9343-55462CF3146A> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/SharedSupport/AVX2_Plug-Ins/CodecToolkit/CATAVC.acf/Contents/MacOS/CATAVC
           0x32e03c000 -        0x32e26cfff +com.avid.CodecToolkit.CATJ2K (3.15.9.301 - 3.15.9.301) <6D1888AA-DDE4-3B71-8678-3E66521B80E3> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/SharedSupport/AVX2_Plug-Ins/CodecToolkit/CATJ2K.acf/Contents/MacOS/CATJ2K
           0x32e28f000 -        0x32e367fff +com.avid.CodecToolkit.CATMJPEG (3.15.9.301 - 3.15.9.301) <588A8F7C-A7DF-37FC-AEC2-8C9EB0032E7D> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/SharedSupport/AVX2_Plug-Ins/CodecToolkit/CATMJPEG.acf/Contents/MacOS/CATMJPEG
           0x32e37a000 -        0x32e3d6fff +com.avid.CodecToolkit.CATMP2 (3.15.9.301 - 3.15.9.301) <7FF2C845-4A17-37F1-B176-D030E3D2F86F> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/SharedSupport/AVX2_Plug-Ins/CodecToolkit/CATMP2.acf/Contents/MacOS/CATMP2
           0x32e3e4000 -        0x32e4b6fff +com.avid.CodecToolkit.CATMP3 (3.15.9.301 - 3.15.9.301) <C6EE18A6-BA70-3AF3-A889-BEB4E0928B84> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/SharedSupport/AVX2_Plug-Ins/CodecToolkit/CATMP3.acf/Contents/MacOS/CATMP3
           0x32e4e8000 -        0x32e986fff +com.avid.CodecToolkit.CATMPEG2 (3.15.9.301 - 3.15.9.301) <8A2BCA55-D6E5-361F-97A0-1D909044123E> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/SharedSupport/AVX2_Plug-Ins/CodecToolkit/CATMPEG2.acf/Contents/MacOS/CATMPEG2
           0x32f54e000 -        0x32f580fff +com.avid.CodecToolkit.CTAC3 (3.15.9.301 - 3.15.9.301) <F739739F-FC5C-316B-82CD-FF371EF0EE23> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/SharedSupport/AVX2_Plug-Ins/CodecToolkit/CTAC3.acf/Contents/MacOS/CTAC3
           0x32f58d000 -        0x32f919fff +com.avid.CodecToolkit.CTACES (3.15.9.301 - 3.15.9.301) <F76DA26F-7DB4-3D37-9019-4CE71C0006D5> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/SharedSupport/AVX2_Plug-Ins/CodecToolkit/CTACES.acf/Contents/MacOS/CTACES
           0x32f93f000 -        0x32f966fff +com.avid.CodecToolkit.CTAES3 (3.15.9.301 - 3.15.9.301) <D0E6A358-85A1-3E94-B150-46DF1A1AD75F> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/SharedSupport/AVX2_Plug-Ins/CodecToolkit/CTAES3.acf/Contents/MacOS/CTAES3
           0x32f972000 -        0x32fc49fff +com.avid.CodecToolkit.CTDNxUncompressed (3.15.9.301 - 3.15.9.301) <939922BA-4B92-339E-9525-77FCDABF409C> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/SharedSupport/AVX2_Plug-Ins/CodecToolkit/CTDNxUncompressed.acf/Contents/MacOS/CTDNxUncompressed
           0x32fc9b000 -        0x32fcecfff +com.avid.CodecToolkit.CTDPX (3.15.9.301 - 3.15.9.301) <8BA1A74A-CE4B-332C-9963-B3B47215D343> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/SharedSupport/AVX2_Plug-Ins/CodecToolkit/CTDPX.acf/Contents/MacOS/CTDPX
           0x32fcfe000 -        0x330bf0fff +com.avid.CodecToolkit.CTHEVC (3.15.9.301 - 3.15.9.301) <2DFBEF88-AD28-3AE7-9AC2-B437E42FE533> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/SharedSupport/AVX2_Plug-Ins/CodecToolkit/CTHEVC.acf/Contents/MacOS/CTHEVC
           0x3317cb000 -        0x331c03fff +com.avid.CodecToolkit.CTMPEG4 (3.15.9.301 - 3.15.9.301) <7EDA6224-1E00-3A77-8CEA-EEA330F0302E> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/SharedSupport/AVX2_Plug-Ins/CodecToolkit/CTMPEG4.acf/Contents/MacOS/CTMPEG4
           0x332798000 -        0x332b2efff +com.avid.CodecToolkit.CTOpenEXR (3.15.9.301 - 3.15.9.301) <D103B863-F8F4-3E2D-AF71-12A89F7F22E6> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/SharedSupport/AVX2_Plug-Ins/CodecToolkit/CTOpenEXR.acf/Contents/MacOS/CTOpenEXR
           0x332b54000 -        0x332bc3fff +com.avid.CodecToolkit.CTPNG (3.15.9.301 - 3.15.9.301) <1BEF423F-4539-33E6-B422-2D2945222D73> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/SharedSupport/AVX2_Plug-Ins/CodecToolkit/CTPNG.acf/Contents/MacOS/CTPNG
           0x332bd3000 -        0x332bf6fff +com.avid.CodecToolkit.CTProResDecoder (3.15.9.301 - 3.15.9.301) <B9973D46-AF72-3C45-9652-79156EC8D935> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/SharedSupport/AVX2_Plug-Ins/CodecToolkit/CTProResDecoder.acf/Contents/MacOS/CTProResDecoder
           0x332c00000 -        0x332cfcfff +com.avid.CodecToolkit.ProResDecoderCore (1.5.0.191 - 1.5.0.191) <F4F6BF7C-6804-3177-AA7C-4C52879ABE34> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/SharedSupport/AVX2_Plug-Ins/CodecToolkit/ProResDecoderCore.acf/Contents/MacOS/ProResDecoderCore
           0x332d09000 -        0x332d2ffff +com.avid.CodecToolkit.CTProResEncoder (3.15.9.301 - 3.15.9.301) <8B3CCB78-02EB-3787-B94E-1921C8508CCA> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/SharedSupport/AVX2_Plug-Ins/CodecToolkit/CTProResEncoder.acf/Contents/MacOS/CTProResEncoder
           0x332d39000 -        0x332e31fff +com.avid.CodecToolkit.ProResEncoderCore (1.5.0.191 - 1.5.0.191) <C2851EB0-4C35-3E79-BA6D-AC1553785FBF> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/SharedSupport/AVX2_Plug-Ins/CodecToolkit/ProResEncoderCore.acf/Contents/MacOS/ProResEncoderCore
           0x332e3e000 -        0x332e87fff +com.avid.CodecToolkit.CTProResRAW (3.15.9.301 - 3.15.9.301) <98E27054-44B2-3A13-8621-EC826B3883B5> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/SharedSupport/AVX2_Plug-Ins/CodecToolkit/CTProResRAW.acf/Contents/MacOS/CTProResRAW
           0x332e99000 -        0x332ee0fff +com.avid.CodecToolkit.CTQTRle (3.15.9.301 - 3.15.9.301) <F16BD12B-9CB1-38FB-8398-64336C51A3C3> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/SharedSupport/AVX2_Plug-Ins/CodecToolkit/CTQTRle.acf/Contents/MacOS/CTQTRle
           0x332ef1000 -        0x332f22fff +com.avid.CodecToolkit.CTTGA (3.15.9.301 - 3.15.9.301) <96421700-A715-3C15-9247-C85C3C5C9DB2> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/SharedSupport/AVX2_Plug-Ins/CodecToolkit/CTTGA.acf/Contents/MacOS/CTTGA
           0x332f31000 -        0x332fcdfff +com.avid.CodecToolkit.CTTIFF (3.15.9.301 - 3.15.9.301) <AD650988-E18E-391C-99BF-D8F844057D20> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/SharedSupport/AVX2_Plug-Ins/CodecToolkit/CTTIFF.acf/Contents/MacOS/CTTIFF
           0x332fe1000 -        0x33329dfff +com.avid.CodecToolkit.CATDNX (3.15.9.301 - 3.15.9.301) <DC17F88E-2170-3257-AFAF-6608D81BA5F5> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/SharedSupport/AVX2_Plug-Ins/CodecToolkit/catdnx.acf/Contents/MacOS/CATDNX
           0x3332ec000 -        0x333350fff +com.avid.CodecToolkit.CTExtra (3.15.9.301 - 3.15.9.301) <667D42CA-4BCA-3FE7-8C55-9164CC967484> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/SharedSupport/AVX2_Plug-Ins/CodecToolkit/CTExtra.acf/Contents/MacOS/CTExtra
           0x3d31f8000 -        0x3d3437fff +com.avid.XMLPlugin (3.5.4.10016 - ???) <B31F8D2D-A4E2-34B9-8DF4-D9CBEACE8A06> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/SharedSupport/AVX2_Plug-Ins/AMA/XMLPlugin.avx/Contents/MacOS/XMLPlugin
           0x3d36b4000 -        0x3d36b7fff +com.avid.DynViewLoader (1.0 - 1.0) <F6DFB81E-207E-37CD-9AF3-4DEB9DEC4D2E> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/SharedSupport/AVX2_Plug-Ins/DynViewLoader.acf/Contents/MacOS/DynViewLoader
           0x3d36c6000 -        0x3d36ccfff +com.avid.DynViewEngineQt4 (1.0 - 1.0) <964DA600-CFA2-35FC-8768-C3C5CEFFDC5E> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/SharedSupport/AVX2_Plug-Ins/DynViewEngineQT4.acf/Contents/MacOS/DynViewEngineQt4
           0x3d36e5000 -        0x3d373efff +com.avid.SearchUIPlugin (1.0 - 1) <DE53AB7B-AEE8-35C9-B386-A5071093E7A2> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/SharedSupport/AVX2_Plug-Ins/SearchUIPlugin.acf/Contents/MacOS/SearchUIPlugin
           0x3d37ae000 -        0x3d37c4fff +com.avid.amf_Search (1.0 - 1) <4FF336A5-4C99-381C-AB48-D140070EE335> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/SharedSupport/AVX2_Plug-Ins/amf_Search.acf/Contents/MacOS/amf_Search
           0x3d37ef000 -        0x3d3834fff +com.avid.searchsupport (1.0 - 1) <E0153D4D-391E-3D7E-B0BB-4A6314820DFD> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/Frameworks/SearchSupport.framework/Versions/A/SearchSupport
           0x3d3877000 -        0x3d3896fff +com.avid.searchdb (1.0 - 1) <F7268EE8-D029-3049-8871-0DACA05AA4C0> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/Frameworks/AvidSearchDB.framework/Versions/A/AvidSearchDB
        0x7fff2011e000 -     0x7fff2011ffff  libsystem_blocks.dylib (79) <925E3B6D-184D-3E73-97B1-643C4ADB387A> /usr/lib/system/libsystem_blocks.dylib
        0x7fff20120000 -     0x7fff20155fff  libxpc.dylib (2038.120.1) <FFFB49D7-2CA6-3E1F-AE4E-5697B19B7D76> /usr/lib/system/libxpc.dylib
        0x7fff20156000 -     0x7fff2016dfff  libsystem_trace.dylib (1277.120.1) <7E800ECA-DFDB-3737-A3C5-FFDE37E65383> /usr/lib/system/libsystem_trace.dylib
        0x7fff2016e000 -     0x7fff2020bfff  libcorecrypto.dylib (1000.140.4) <D211160D-E22F-3440-8054-1F5824519C7F> /usr/lib/system/libcorecrypto.dylib
        0x7fff2020c000 -     0x7fff20238fff  libsystem_malloc.dylib (317.140.5) <050E37E1-1458-3F80-BFA3-F1488570169D> /usr/lib/system/libsystem_malloc.dylib
        0x7fff20239000 -     0x7fff2027dfff  libdispatch.dylib (1271.120.2) <8144B0BD-90D2-3EAE-999F-AB0D14082088> /usr/lib/system/libdispatch.dylib
        0x7fff2027e000 -     0x7fff202b7fff  libobjc.A.dylib (824) <8C7C49A1-4211-3E4C-BA3D-160D675EEE96> /usr/lib/libobjc.A.dylib
        0x7fff202b8000 -     0x7fff202bafff  libsystem_featureflags.dylib (28.60.1) <E5C43AE3-19E7-3DAB-8B5D-D79A4B68B5C0> /usr/lib/system/libsystem_featureflags.dylib
        0x7fff202bb000 -     0x7fff20343fff  libsystem_c.dylib (1439.141.1) <3C273899-4CBE-32D5-BB31-7A449743204F> /usr/lib/system/libsystem_c.dylib
        0x7fff20344000 -     0x7fff20399fff  libc++.1.dylib (905.6) <FD6DB1CB-B14B-3404-8BEB-B459C2F6C303> /usr/lib/libc++.1.dylib
        0x7fff2039a000 -     0x7fff203affff  libc++abi.dylib (905.6) <D0CDDF98-1C04-300F-B685-4A4C59C04C42> /usr/lib/libc++abi.dylib
        0x7fff203b0000 -     0x7fff203dffff  libsystem_kernel.dylib (7195.141.6) <78289AAE-61B5-339F-A485-8819BC2388F2> /usr/lib/system/libsystem_kernel.dylib
        0x7fff203e0000 -     0x7fff203ebfff  libsystem_pthread.dylib (454.120.2) <1268FF2D-A513-3B51-BA65-AF2FF5789DDB> /usr/lib/system/libsystem_pthread.dylib
        0x7fff203ec000 -     0x7fff20427fff  libdyld.dylib (852.2) <3DE0178A-0AEE-3D08-AE19-6C6403F69BA1> /usr/lib/system/libdyld.dylib
        0x7fff20428000 -     0x7fff20431fff  libsystem_platform.dylib (254.80.2) <EF52D569-09F5-32E1-B1B3-34E2CA55A017> /usr/lib/system/libsystem_platform.dylib
        0x7fff20432000 -     0x7fff2045dfff  libsystem_info.dylib (542.40.3) <55B39B7F-957B-3D99-A8DF-7CA80D38155D> /usr/lib/system/libsystem_info.dylib
        0x7fff2045e000 -     0x7fff208fbfff  com.apple.CoreFoundation (6.9 - 1778.101) <8CF9D741-ADFF-3D5E-ACDE-DC342701EE0D> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
        0x7fff208fc000 -     0x7fff20b31fff  com.apple.LaunchServices (1122.44 - 1122.44) <C285E620-3D2F-3AD0-8A3D-BB1FC540FE44> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/LaunchServices.framework/Versions/A/LaunchServices
        0x7fff20b32000 -     0x7fff20c06fff  com.apple.gpusw.MetalTools (1.0 - 1) <C41024C5-01E7-3A66-A1F8-D7BC767260D8> /System/Library/PrivateFrameworks/MetalTools.framework/Versions/A/MetalTools
        0x7fff20c07000 -     0x7fff20e63fff  libBLAS.dylib (1336.140.1) <170AFA22-1234-3DE9-9D94-52B3BE18E34E> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBLAS.dylib
        0x7fff20e64000 -     0x7fff20eb1fff  com.apple.Lexicon-framework (1.0 - 86.2) <B7047A55-806D-3B32-A2D6-885D824E54A6> /System/Library/PrivateFrameworks/Lexicon.framework/Versions/A/Lexicon
        0x7fff20eb2000 -     0x7fff20f20fff  libSparse.dylib (106) <1E68BF64-7432-3509-BC85-5DE95379E901> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libSparse.dylib
        0x7fff20f21000 -     0x7fff20f9efff  com.apple.SystemConfiguration (1.20 - 1.20) <8FEB39D4-ACD6-39F2-8D1B-A57CACD5628F> /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/SystemConfiguration
        0x7fff20f9f000 -     0x7fff20fd3fff  libCRFSuite.dylib (50) <BCDD0ED1-D2F4-3556-B218-4420C7EA47D2> /usr/lib/libCRFSuite.dylib
        0x7fff20fd4000 -     0x7fff2120cfff  libmecabra.dylib (929.10) <D780814D-2BB2-3D84-820E-12E4C23C590E> /usr/lib/libmecabra.dylib
        0x7fff2120d000 -     0x7fff2156bfff  com.apple.Foundation (6.9 - 1778.101) <7B7FB88B-01D3-38CE-8029-837DB094C545> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
        0x7fff2156c000 -     0x7fff21654fff  com.apple.LanguageModeling (1.0 - 247.3) <DBFAE8CF-36B2-30D8-9E82-6C412CD935B4> /System/Library/PrivateFrameworks/LanguageModeling.framework/Versions/A/LanguageModeling
        0x7fff21655000 -     0x7fff2178bfff  com.apple.CoreDisplay (237.4 - 237.4) <556BADE0-D3B0-309C-9740-7FEFBD052B6B> /System/Library/Frameworks/CoreDisplay.framework/Versions/A/CoreDisplay
        0x7fff2178c000 -     0x7fff219fcfff  com.apple.audio.AudioToolboxCore (1.0 - 1181.72) <5C3B84EE-B281-34C4-832F-78F00CC63B93> /System/Library/PrivateFrameworks/AudioToolboxCore.framework/Versions/A/AudioToolboxCore
        0x7fff219fd000 -     0x7fff21be2fff  com.apple.CoreText (677.6.0.2 - 677.6.0.2) <10E1382E-7949-3F4E-8B15-A4BD31A75E91> /System/Library/Frameworks/CoreText.framework/Versions/A/CoreText
        0x7fff21be3000 -     0x7fff22274fff  com.apple.audio.CoreAudio (5.0 - 5.0) <5EEA9225-4837-37F3-9105-941A5743169F> /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
        0x7fff22275000 -     0x7fff225ccfff  com.apple.security (7.0 - 59754.140.13) <A196C85A-DB28-3F5B-A415-5BE44AD81668> /System/Library/Frameworks/Security.framework/Versions/A/Security
        0x7fff225cd000 -     0x7fff2282cfff  libicucore.A.dylib (66112) <AC994BC1-F9CC-359C-A7B5-F2821EAEF650> /usr/lib/libicucore.A.dylib
        0x7fff2282d000 -     0x7fff22836fff  libsystem_darwin.dylib (1439.141.1) <2C81A009-45BB-30D7-A4F7-4B2EEC691617> /usr/lib/system/libsystem_darwin.dylib
        0x7fff22837000 -     0x7fff22b22fff  com.apple.CoreServices.CarbonCore (1307.3 - 1307.3) <2C65E0D8-A9C7-31D8-A3D3-3AC1A91C80A5> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framework/Versions/A/CarbonCore
        0x7fff22b23000 -     0x7fff22b61fff  com.apple.CoreServicesInternal (476.1.1 - 476.1.1) <3FC6073F-78E4-3D3B-8765-50E50512C5EB> /System/Library/PrivateFrameworks/CoreServicesInternal.framework/Versions/A/CoreServicesInternal
        0x7fff22b62000 -     0x7fff22b9cfff  com.apple.CSStore (1122.44 - 1122.44) <C103DAAA-A966-359B-97F0-BA3BB56ECBF1> /System/Library/PrivateFrameworks/CoreServicesStore.framework/Versions/A/CoreServicesStore
        0x7fff22b9d000 -     0x7fff22c4bfff  com.apple.framework.IOKit (2.0.2 - 1845.120.6) <720D9AE1-79D6-3E77-8D7A-47F8F6681050> /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
        0x7fff22c4c000 -     0x7fff22c57fff  libsystem_notify.dylib (279.40.4) <2E40EA4A-B124-3010-8379-1B4D7082A08F> /usr/lib/system/libsystem_notify.dylib
        0x7fff22c58000 -     0x7fff22ca5fff  libsandbox.1.dylib (1441.141.4) <C291C059-F7E4-3C20-BCBF-60F7011F0718> /usr/lib/libsandbox.1.dylib
        0x7fff22ca6000 -     0x7fff239f1fff  com.apple.AppKit (6.9 - 2022.60.128) <02EC69A0-D634-341B-BE3D-840F496F5814> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
        0x7fff239f2000 -     0x7fff23c40fff  com.apple.UIFoundation (1.0 - 728.9) <C2E04F0F-AEAA-3B77-9BBA-1CF628341A56> /System/Library/PrivateFrameworks/UIFoundation.framework/Versions/A/UIFoundation
        0x7fff23c41000 -     0x7fff23c53fff  com.apple.UniformTypeIdentifiers (637 - 637) <8FFD3B69-0840-34D6-83AD-7D521B1A2339> /System/Library/Frameworks/UniformTypeIdentifiers.framework/Versions/A/UniformTypeIdentifiers
        0x7fff23c54000 -     0x7fff23ddefff  com.apple.desktopservices (1.21 - 1346.6.1) <F2C97567-5B56-3840-A384-2131E362083B> /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versions/A/DesktopServicesPriv
        0x7fff23ddf000 -     0x7fff23df1fff  com.apple.metadata.SpotlightLinguistics (1.0 - 1) <BA448116-6C8C-3A4B-9F28-9D8CEAAD5769> /System/Library/PrivateFrameworks/SpotlightLinguistics.framework/Versions/A/SpotlightLinguistics
        0x7fff23df2000 -     0x7fff24000fff  com.apple.CoreDuet (1.0 - 1) <BC29FC19-7BE1-3CC9-9668-39209F43C7F1> /System/Library/PrivateFrameworks/CoreDuet.framework/Versions/A/CoreDuet
        0x7fff240be000 -     0x7fff24744fff  libnetwork.dylib (2288.140.7) <42825FCA-35A1-352F-AE68-19D8F695604B> /usr/lib/libnetwork.dylib
        0x7fff24745000 -     0x7fff24be3fff  com.apple.CFNetwork (1240.0.4 - 1240.0.4) <E4BF9BFF-798B-33FF-B37D-6D8175CA708A> /System/Library/Frameworks/CFNetwork.framework/Versions/A/CFNetwork
        0x7fff24be4000 -     0x7fff24bf2fff  libsystem_networkextension.dylib (1295.140.3) <83AA4425-2F1D-36EC-B77B-8D4F03CDDB68> /usr/lib/system/libsystem_networkextension.dylib
        0x7fff24bf3000 -     0x7fff24bf3fff  libenergytrace.dylib (22.100.1) <9E877E0A-5261-3F75-91A0-521423499AD0> /usr/lib/libenergytrace.dylib
        0x7fff24bf4000 -     0x7fff24c50fff  libMobileGestalt.dylib (978.140.1) <D1FF79C3-4B2F-32FB-BF25-9F0B9E160692> /usr/lib/libMobileGestalt.dylib
        0x7fff24c51000 -     0x7fff24c67fff  libsystem_asl.dylib (385) <8D324D65-EE16-3A1A-BD39-ACB1B3050D1F> /usr/lib/system/libsystem_asl.dylib
        0x7fff24c68000 -     0x7fff24c80fff  com.apple.TCC (1.0 - 1) <18F48712-FFF0-3B30-B2C4-8A93AEF86A34> /System/Library/PrivateFrameworks/TCC.framework/Versions/A/TCC
        0x7fff24c81000 -     0x7fff24fe6fff  com.apple.SkyLight (1.600.0 - 588.7) <5F88F814-A3DF-3446-8B35-F0CDD8C1B302> /System/Library/PrivateFrameworks/SkyLight.framework/Versions/A/SkyLight
        0x7fff24fe7000 -     0x7fff25670fff  com.apple.CoreGraphics (2.0 - 1463.17.3) <5EDF86BC-FFDE-3906-9674-142C113B34EF> /System/Library/Frameworks/CoreGraphics.framework/Versions/A/CoreGraphics
        0x7fff25671000 -     0x7fff25767fff  com.apple.ColorSync (4.13.0 - 3473.4.3) <102C423C-E05F-317B-83AE-A2A6B77D653B> /System/Library/Frameworks/ColorSync.framework/Versions/A/ColorSync
        0x7fff25768000 -     0x7fff257c3fff  com.apple.HIServices (1.22 - 716) <B2D34F3F-0CEB-35F1-9B32-E0806CF3FC91> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices.framework/Versions/A/HIServices
        0x7fff257c4000 -     0x7fff25802fff  libAWDSupport.dylib (951) <F10D0972-6D3C-325B-A977-48E0EC6B087D> /System/Library/PrivateFrameworks/WirelessDiagnostics.framework/Versions/A/Libraries/libAWDSupport.dylib
        0x7fff25803000 -     0x7fff2585ffff  libprotobuf.dylib (4205) <25B06010-4F03-3B97-873E-94410285D572> /System/Library/PrivateFrameworks/WirelessDiagnostics.framework/Versions/A/Libraries/libprotobuf.dylib
        0x7fff25860000 -     0x7fff25871fff  libprotobuf-lite.dylib (4205) <035E309C-861F-393B-BB10-D8C42F63E6F6> /System/Library/PrivateFrameworks/WirelessDiagnostics.framework/Versions/A/Libraries/libprotobuf-lite.dylib
        0x7fff25872000 -     0x7fff258b6fff  com.apple.awd (1.0 - 951) <950DBA92-CC7B-3355-BAEE-083FFFBDF500> /System/Library/PrivateFrameworks/WirelessDiagnostics.framework/Versions/A/WirelessDiagnostics
        0x7fff258b7000 -     0x7fff25a77fff  com.apple.Montreal (1.0 - 142) <04ABAAAD-2C28-3AA5-90C9-BD4B7869042F> /System/Library/PrivateFrameworks/Montreal.framework/Versions/A/Montreal
        0x7fff25a78000 -     0x7fff25b69fff  com.apple.NLP (1.0 - 210.2) <0D6A0E1B-1381-316E-B488-3025D5608B4D> /System/Library/PrivateFrameworks/NLP.framework/Versions/A/NLP
        0x7fff25b6a000 -     0x7fff25f89fff  com.apple.CoreData (120 - 1048) <33DE1B26-D4C6-3939-B12E-88897660BB38> /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData
        0x7fff25f8a000 -     0x7fff25f9ffff  com.apple.ProtocolBuffer (1 - 285.24.10.20.1) <AEDEFF64-CA8A-365C-900F-3107383F91D9> /System/Library/PrivateFrameworks/ProtocolBuffer.framework/Versions/A/ProtocolBuffer
        0x7fff25fa0000 -     0x7fff26153fff  libsqlite3.dylib (321.3) <E7377C46-DA4F-3486-B935-0A35C3637215> /usr/lib/libsqlite3.dylib
        0x7fff26154000 -     0x7fff261d0fff  com.apple.Accounts (113 - 113) <2AD45648-B327-313A-ACF2-846FB345A96E> /System/Library/Frameworks/Accounts.framework/Versions/A/Accounts
        0x7fff261d1000 -     0x7fff261e8fff  com.apple.commonutilities (8.0 - 900) <98B456F4-8F4F-387B-B3BB-D3919295AE1D> /System/Library/PrivateFrameworks/CommonUtilities.framework/Versions/A/CommonUtilities
        0x7fff261e9000 -     0x7fff26268fff  com.apple.BaseBoard (526 - 526) <F9D85C3A-D0D6-351B-A6EE-5416CB90179D> /System/Library/PrivateFrameworks/BaseBoard.framework/Versions/A/BaseBoard
        0x7fff26269000 -     0x7fff262b1fff  com.apple.RunningBoardServices (1.0 - 505.100.9) <2ED406CD-2253-33F0-B16A-694DB447CADC> /System/Library/PrivateFrameworks/RunningBoardServices.framework/Versions/A/RunningBoardServices
        0x7fff262b2000 -     0x7fff26326fff  com.apple.AE (918.6 - 918.6) <C5130BB4-18E7-3804-A9D9-915D318426A5> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/AE.framework/Versions/A/AE
        0x7fff26327000 -     0x7fff2632dfff  libdns_services.dylib (1310.140.1) <22BE5030-2F48-3ED6-9DF8-9D102CEF33FF> /usr/lib/libdns_services.dylib
        0x7fff2632e000 -     0x7fff26335fff  libsystem_symptoms.dylib (1431.140.1) <1B4D8837-C951-3B69-B079-85D477749E8B> /usr/lib/system/libsystem_symptoms.dylib
        0x7fff26336000 -     0x7fff264c1fff  com.apple.Network (1.0 - 1) <2155E1AA-2067-36CF-979E-2F96062D5CFE> /System/Library/Frameworks/Network.framework/Versions/A/Network
        0x7fff264c2000 -     0x7fff264f1fff  com.apple.analyticsd (1.0 - 1) <0DF60ECD-742C-39D1-964A-48EC3DEA6319> /System/Library/PrivateFrameworks/CoreAnalytics.framework/Versions/A/CoreAnalytics
        0x7fff264f2000 -     0x7fff264f4fff  libDiagnosticMessagesClient.dylib (112) <A7EC7265-E13C-3C98-81EE-3EFB5CC65AB0> /usr/lib/libDiagnosticMessagesClient.dylib
        0x7fff264f5000 -     0x7fff26541fff  com.apple.spotlight.metadata.utilities (1.0 - 2150.26) <F709AE5E-AF80-3C9B-A3D3-B779164FBA95> /System/Library/PrivateFrameworks/MetadataUtilities.framework/Versions/A/MetadataUtilities
        0x7fff26542000 -     0x7fff265dcfff  com.apple.Metadata (10.7.0 - 2150.26) <D7CE41CA-DDE7-32BE-926C-0DC3048C5E11> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framework/Versions/A/Metadata
        0x7fff265dd000 -     0x7fff265e3fff  com.apple.DiskArbitration (2.7 - 2.7) <8DF059B4-BE32-3171-8CC4-C5FA189FA718> /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskArbitration
        0x7fff265e4000 -     0x7fff26c4bfff  com.apple.vImage (8.1 - 544.4) <E62F9E4F-9A1D-3004-B7F4-6F83F71144C2> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/vImage
        0x7fff26c4c000 -     0x7fff26f29fff  com.apple.QuartzCore (1.11 - 927.24) <88794856-F1F1-3D23-BDDB-0AE28A1D6D6E> /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore
        0x7fff26f2a000 -     0x7fff26f6bfff  libFontRegistry.dylib (309) <300F2208-7274-38F8-B88D-9237BA6B397E> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontRegistry.dylib
        0x7fff26f6c000 -     0x7fff270acfff  com.apple.coreui (2.1 - 692.1) <BC5D8EAA-7CE8-35F3-8EAD-075B18D9606C> /System/Library/PrivateFrameworks/CoreUI.framework/Versions/A/CoreUI
        0x7fff270ad000 -     0x7fff27198fff  com.apple.ViewBridge (553.1 - 553.1) <DF83EA6E-4DA9-3322-BE86-0B3207167451> /System/Library/PrivateFrameworks/ViewBridge.framework/Versions/A/ViewBridge
        0x7fff27199000 -     0x7fff271a4fff  com.apple.PerformanceAnalysis (1.278.3 - 278.3) <6AF20F05-FF15-3174-A504-1AC16BA14729> /System/Library/PrivateFrameworks/PerformanceAnalysis.framework/Versions/A/PerformanceAnalysis
        0x7fff271a5000 -     0x7fff271b4fff  com.apple.OpenDirectory (11.6 - 230.40.1) <84B2D11F-E6C4-3C29-9A9A-939DB906E2F5> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/OpenDirectory
        0x7fff271b5000 -     0x7fff271d4fff  com.apple.CFOpenDirectory (11.6 - 230.40.1) <6BE3204F-2F86-34A7-AD79-4C88320F446F> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/Frameworks/CFOpenDirectory.framework/Versions/A/CFOpenDirectory
        0x7fff271d5000 -     0x7fff271e1fff  com.apple.CoreServices.FSEvents (1290.120.5 - 1290.120.5) <DC473A17-310F-3C16-B545-F75CE3F6D39D> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/FSEvents.framework/Versions/A/FSEvents
        0x7fff271e2000 -     0x7fff27206fff  com.apple.coreservices.SharedFileList (144 - 144) <A13B58B8-6D7A-3F1B-AFB5-E41E0A6B4B81> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SharedFileList.framework/Versions/A/SharedFileList
        0x7fff27207000 -     0x7fff27209fff  libapp_launch_measurement.dylib (14.1) <511EC2A9-6059-3A7D-9D2A-741189922D02> /usr/lib/libapp_launch_measurement.dylib
        0x7fff2720a000 -     0x7fff27251fff  com.apple.CoreAutoLayout (1.0 - 21.10.1) <18113C8E-B54E-3DD3-A1AD-2A5FD949CE66> /System/Library/PrivateFrameworks/CoreAutoLayout.framework/Versions/A/CoreAutoLayout
        0x7fff27252000 -     0x7fff27334fff  libxml2.2.dylib (34.10) <DD2093F0-F9B7-3F30-B46D-B028CE15E2B1> /usr/lib/libxml2.2.dylib
        0x7fff27335000 -     0x7fff27382fff  com.apple.CoreVideo (1.8 - 414.7) <EE991A40-DE38-3B13-891E-A51987D5CD70> /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo
        0x7fff27383000 -     0x7fff27385fff  com.apple.loginsupport (1.0 - 1) <4C358D8E-4BB8-3DD8-8A72-11BD80607BDE> /System/Library/PrivateFrameworks/login.framework/Versions/A/Frameworks/loginsupport.framework/Versions/A/loginsupport
        0x7fff27386000 -     0x7fff273adfff  com.apple.aps.framework (4.0 - 4.0) <A76C4B82-24CD-3AF4-BADD-6135F6E7057A> /System/Library/PrivateFrameworks/ApplePushService.framework/Versions/A/ApplePushService
        0x7fff273ae000 -     0x7fff273c9fff  com.apple.UserManagement (1.0 - 1) <FB298359-31F5-3DDD-B928-604C4B1ED1F3> /System/Library/PrivateFrameworks/UserManagement.framework/Versions/A/UserManagement
        0x7fff273ca000 -     0x7fff2755bfff  com.apple.cloudkit.CloudKit (990 - 990) <A4ADF4E3-AC2D-322B-B76C-BC249AB27395> /System/Library/Frameworks/CloudKit.framework/Versions/A/CloudKit
        0x7fff2755c000 -     0x7fff275ddfff  com.apple.CloudDocs (1.0 - 738.1) <86A6C439-BA71-321C-B330-A60BA4011C99> /System/Library/PrivateFrameworks/CloudDocs.framework/Versions/A/CloudDocs
        0x7fff275de000 -     0x7fff2796dfff  com.apple.CoreML (1.0 - 1) <3845782D-F855-3DD4-ADD3-8CB08C2BCFE5> /System/Library/Frameworks/CoreML.framework/Versions/A/CoreML
        0x7fff2796e000 -     0x7fff282bffff  libwebrtc.dylib (7611.3.10.1.6) <CBCA9241-7714-378B-97C6-5D404C6284A7> /System/Library/Frameworks/WebKit.framework/Versions/A/Frameworks/WebCore.framework/Versions/A/Frameworks/libwebrtc.dylib
        0x7fff282c0000 -     0x7fff2833cfff  com.apple.corelocation (2420.19.23 - 2420.19.23) <1BEB1A0D-4122-3F8C-AC1A-07A12C36C84F> /System/Library/Frameworks/CoreLocation.framework/Versions/A/CoreLocation
        0x7fff2833d000 -     0x7fff2834dfff  libsystem_containermanager.dylib (318.100.4) <1139CD47-9CBA-356F-8694-1D00EB9F0C8F> /usr/lib/system/libsystem_containermanager.dylib
        0x7fff2834e000 -     0x7fff2835ffff  com.apple.IOSurface (290.8.1 - 290.8.1) <8B251196-DA38-38BF-8A91-45AC2B06014C> /System/Library/Frameworks/IOSurface.framework/Versions/A/IOSurface
        0x7fff28360000 -     0x7fff28369fff  com.apple.IOAccelerator (442.9 - 442.9) <F2C3DC87-49D7-3A67-8E6D-12D75D98EFDD> /System/Library/PrivateFrameworks/IOAccelerator.framework/Versions/A/IOAccelerator
        0x7fff2836a000 -     0x7fff2848dfff  com.apple.Metal (244.303 - 244.303) <71B6039E-232E-3AD2-881F-DF8E73C75B99> /System/Library/Frameworks/Metal.framework/Versions/A/Metal
        0x7fff2848e000 -     0x7fff284aafff  com.apple.audio.caulk (1.0 - 70) <F6A09FF3-1DC7-302C-86E3-B2DD9B7130A9> /System/Library/PrivateFrameworks/caulk.framework/Versions/A/caulk
        0x7fff284ab000 -     0x7fff28595fff  com.apple.CoreMedia (1.0 - 2780.10) <6A003180-F8AA-3DFA-B095-61D8E859FE3F> /System/Library/Frameworks/CoreMedia.framework/Versions/A/CoreMedia
        0x7fff28596000 -     0x7fff286f2fff  libFontParser.dylib (305.6.0.4) <C3E552F6-72AD-3F3A-B217-E44A5C565240> /System/Library/PrivateFrameworks/FontServices.framework/libFontParser.dylib
        0x7fff286f3000 -     0x7fff289eefff  com.apple.HIToolbox (2.1.1 - 1062) <DEF01A0C-8B9D-359E-9FE7-B15D551888DC> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox
        0x7fff289ef000 -     0x7fff28a02fff  com.apple.framework.DFRFoundation (1.0 - 267) <EBFDDB28-7661-3B50-BC15-736C5DF05AB3> /System/Library/PrivateFrameworks/DFRFoundation.framework/Versions/A/DFRFoundation
        0x7fff28a03000 -     0x7fff28a06fff  com.apple.dt.XCTTargetBootstrap (1.0 - 18119.1) <DD9E09C3-B658-3BD2-8229-E3E3C5D85552> /System/Library/PrivateFrameworks/XCTTargetBootstrap.framework/Versions/A/XCTTargetBootstrap
        0x7fff28a07000 -     0x7fff28a30fff  com.apple.CoreSVG (1.0 - 149) <C4DC952A-9373-33E5-8A98-F008986B0420> /System/Library/PrivateFrameworks/CoreSVG.framework/Versions/A/CoreSVG
        0x7fff28a31000 -     0x7fff28c6dfff  com.apple.ImageIO (3.3.0 - 2130.7.3) <28C6A501-2548-3187-A13B-9F314280BBB8> /System/Library/Frameworks/ImageIO.framework/Versions/A/ImageIO
        0x7fff28c6e000 -     0x7fff28fe9fff  com.apple.CoreImage (16.3.0 - 1140.2) <3ED3F244-632C-383D-89B0-50F2E0FDBA40> /System/Library/Frameworks/CoreImage.framework/Versions/A/CoreImage
        0x7fff28fea000 -     0x7fff29050fff  com.apple.MetalPerformanceShaders.MPSCore (1.0 - 1) <C12F8828-6D1E-3820-BBF7-80EEA978AE9C> /System/Library/Frameworks/MetalPerformanceShaders.framework/Versions/A/Frameworks/MPSCore.framework/Versions/A/MPSCore
        0x7fff29051000 -     0x7fff29054fff  libsystem_configuration.dylib (1109.140.1) <02F3A5C9-6289-3012-8F5F-F1DB669ADB79> /usr/lib/system/libsystem_configuration.dylib
        0x7fff29055000 -     0x7fff29059fff  libsystem_sandbox.dylib (1441.141.4) <5471601B-5072-3E97-8926-804FF08DC4C0> /usr/lib/system/libsystem_sandbox.dylib
        0x7fff2905a000 -     0x7fff2905bfff  com.apple.AggregateDictionary (1.0 - 1) <B25A1764-0BBC-388B-8FB4-A8FBB8F51C10> /System/Library/PrivateFrameworks/AggregateDictionary.framework/Versions/A/AggregateDictionary
        0x7fff2905c000 -     0x7fff2905ffff  com.apple.AppleSystemInfo (3.1.5 - 3.1.5) <4A803F86-CA61-3508-864A-302F032ADA70> /System/Library/PrivateFrameworks/AppleSystemInfo.framework/Versions/A/AppleSystemInfo
        0x7fff29060000 -     0x7fff29061fff  liblangid.dylib (136) <F4019132-A63D-3A38-A8DB-974C6F1311ED> /usr/lib/liblangid.dylib
        0x7fff29062000 -     0x7fff29106fff  com.apple.CoreNLP (1.0 - 245.2) <203C6AB9-5B07-3370-A056-DA1F2C8A8419> /System/Library/PrivateFrameworks/CoreNLP.framework/Versions/A/CoreNLP
        0x7fff29107000 -     0x7fff2910dfff  com.apple.LinguisticData (1.0 - 399) <AB85B59F-3047-37EC-AB9E-835D87BACF73> /System/Library/PrivateFrameworks/LinguisticData.framework/Versions/A/LinguisticData
        0x7fff2910e000 -     0x7fff297b6fff  libBNNS.dylib (288.100.5) <4BB7A1B7-D1F2-3DC3-BFC7-D57CBD892719> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBNNS.dylib
        0x7fff297b7000 -     0x7fff29989fff  libvDSP.dylib (760.100.3) <DA809F3E-9391-3BE0-98C6-061CCACA809A> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvDSP.dylib
        0x7fff2998a000 -     0x7fff2999bfff  com.apple.CoreEmoji (1.0 - 128.4) <8DB42230-A624-3C13-80F8-EC2CE89C0699> /System/Library/PrivateFrameworks/CoreEmoji.framework/Versions/A/CoreEmoji
        0x7fff2999c000 -     0x7fff299a6fff  com.apple.IOMobileFramebuffer (343.0.0 - 343.0.0) <195E20E7-33BD-3935-92ED-AA354180B7FA> /System/Library/PrivateFrameworks/IOMobileFramebuffer.framework/Versions/A/IOMobileFramebuffer
        0x7fff299a7000 -     0x7fff29a79fff  com.apple.framework.CoreWLAN (16.0 - 1657) <0A58C97E-2ACD-3223-8585-FDA5DA4C38C5> /System/Library/Frameworks/CoreWLAN.framework/Versions/A/CoreWLAN
        0x7fff29a7a000 -     0x7fff29c7bfff  com.apple.CoreUtils (6.6 - 660.37) <0B1ED18A-B228-3840-A0F2-23AC2C37A6CA> /System/Library/PrivateFrameworks/CoreUtils.framework/Versions/A/CoreUtils
        0x7fff29c7c000 -     0x7fff29c9efff  com.apple.MobileKeyBag (2.0 - 1.0) <19D8140C-CC92-35E8-AF78-B335567A7C24> /System/Library/PrivateFrameworks/MobileKeyBag.framework/Versions/A/MobileKeyBag
        0x7fff29c9f000 -     0x7fff29caffff  com.apple.AssertionServices (1.0 - 505.100.9) <850AE031-A3B3-30C0-81A1-71FBCE620BC1> /System/Library/PrivateFrameworks/AssertionServices.framework/Versions/A/AssertionServices
        0x7fff29cb0000 -     0x7fff29d3bfff  com.apple.securityfoundation (6.0 - 55240.40.4) <A7D05091-B54C-317A-81FE-4B174C968C5A> /System/Library/Frameworks/SecurityFoundation.framework/Versions/A/SecurityFoundation
        0x7fff29d3c000 -     0x7fff29d45fff  com.apple.coreservices.BackgroundTaskManagement (1.0 - 104) <98B365F9-8E0C-32C7-AC5A-FFB9A4A0B30A> /System/Library/PrivateFrameworks/BackgroundTaskManagement.framework/Versions/A/BackgroundTaskManagement
        0x7fff29d46000 -     0x7fff29d4afff  com.apple.xpc.ServiceManagement (1.0 - 1) <7D081389-0032-3521-A3D9-84B4667817FB> /System/Library/Frameworks/ServiceManagement.framework/Versions/A/ServiceManagement
        0x7fff29d4b000 -     0x7fff29d4dfff  libquarantine.dylib (119.40.2) <3244B57B-9FDF-373E-9F96-A7BAD7534F23> /usr/lib/system/libquarantine.dylib
        0x7fff29d4e000 -     0x7fff29d59fff  libCheckFix.dylib (31) <AAB549BA-1738-33FD-BBC4-C34B5070C309> /usr/lib/libCheckFix.dylib
        0x7fff29d5a000 -     0x7fff29d71fff  libcoretls.dylib (169.100.1) <FC2811AD-9D76-3403-B760-32A101D07638> /usr/lib/libcoretls.dylib
        0x7fff29d72000 -     0x7fff29d82fff  libbsm.0.dylib (68.40.1) <61577B7F-2C06-365C-9039-E00B0B5258D0> /usr/lib/libbsm.0.dylib
        0x7fff29d83000 -     0x7fff29dccfff  libmecab.dylib (929.10) <D60C5095-3A5F-3284-9699-08C76DA29CBD> /usr/lib/libmecab.dylib
        0x7fff29dcd000 -     0x7fff29dd2fff  libgermantok.dylib (24) <6F2B01E8-6077-3B72-91F3-AB6D0FCB15D6> /usr/lib/libgermantok.dylib
        0x7fff29dd3000 -     0x7fff29de8fff  libLinearAlgebra.dylib (1336.140.1) <A450756D-D3AC-342D-A802-ED6C554A494A> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLinearAlgebra.dylib
        0x7fff29de9000 -     0x7fff2a007fff  com.apple.MetalPerformanceShaders.MPSNeuralNetwork (1.0 - 1) <8AAFA6C5-1FBD-359A-8774-F1D1FBFCCFFE> /System/Library/Frameworks/MetalPerformanceShaders.framework/Versions/A/Frameworks/MPSNeuralNetwork.framework/Versions/A/MPSNeuralNetwork
        0x7fff2a008000 -     0x7fff2a057fff  com.apple.MetalPerformanceShaders.MPSRayIntersector (1.0 - 1) <0C854684-1D62-35D1-83C1-9066DB158189> /System/Library/Frameworks/MetalPerformanceShaders.framework/Versions/A/Frameworks/MPSRayIntersector.framework/Versions/A/MPSRayIntersector
        0x7fff2a058000 -     0x7fff2a1b9fff  com.apple.MLCompute (1.0 - 1) <9255AB44-3AB5-3F3F-8FA2-77FEA1C7C221> /System/Library/Frameworks/MLCompute.framework/Versions/A/MLCompute
        0x7fff2a1ba000 -     0x7fff2a1f0fff  com.apple.MetalPerformanceShaders.MPSMatrix (1.0 - 1) <B7361691-334A-3A33-98E1-A9A623E5D26A> /System/Library/Frameworks/MetalPerformanceShaders.framework/Versions/A/Frameworks/MPSMatrix.framework/Versions/A/MPSMatrix
        0x7fff2a1f1000 -     0x7fff2a247fff  com.apple.MetalPerformanceShaders.MPSNDArray (1.0 - 1) <706E8171-48B3-33A3-B55B-35B5F86F3043> /System/Library/Frameworks/MetalPerformanceShaders.framework/Versions/A/Frameworks/MPSNDArray.framework/Versions/A/MPSNDArray
        0x7fff2a248000 -     0x7fff2a2d8fff  com.apple.MetalPerformanceShaders.MPSImage (1.0 - 1) <3999E177-7A40-358A-BE89-1F20ADF13740> /System/Library/Frameworks/MetalPerformanceShaders.framework/Versions/A/Frameworks/MPSImage.framework/Versions/A/MPSImage
        0x7fff2a2d9000 -     0x7fff2a2e8fff  com.apple.AppleFSCompression (125 - 1.0) <F7163A3A-C4F0-3169-9501-B9AAB8CAE9CD> /System/Library/PrivateFrameworks/AppleFSCompression.framework/Versions/A/AppleFSCompression
        0x7fff2a2e9000 -     0x7fff2a2f5fff  libbz2.1.0.dylib (44) <ECD22F5B-FD6C-39A5-884B-418C6B896263> /usr/lib/libbz2.1.0.dylib
        0x7fff2a2f6000 -     0x7fff2a2fafff  libsystem_coreservices.dylib (127.1) <619CCB6D-226C-35BD-98FB-04A18FD54792> /usr/lib/system/libsystem_coreservices.dylib
        0x7fff2a2fb000 -     0x7fff2a328fff  com.apple.CoreServices.OSServices (1122.44 - 1122.44) <C547575F-985F-31B8-A61C-79D3A673B8D9> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/OSServices.framework/Versions/A/OSServices
        0x7fff2a329000 -     0x7fff2a458fff  com.apple.AuthKit (1.0 - 1) <C72D7981-A3B6-3883-A14F-43485DF54FC4> /System/Library/PrivateFrameworks/AuthKit.framework/Versions/A/AuthKit
        0x7fff2a459000 -     0x7fff2a487fff  com.apple.UserNotifications (1.0 - 348.5) <36B03A58-F8A4-3671-9B0B-1B87FF9D3FA0> /System/Library/Frameworks/UserNotifications.framework/Versions/A/UserNotifications
        0x7fff2a488000 -     0x7fff2a4f6fff  com.apple.CoreSpotlight (1.0 - 2150.26) <4D4F3348-8920-3E95-80D5-304CCCAEF338> /System/Library/Frameworks/CoreSpotlight.framework/Versions/A/CoreSpotlight
        0x7fff2a4f7000 -     0x7fff2a509fff  libz.1.dylib (76) <F805C1CB-1B80-33D0-994C-1D522D347A68> /usr/lib/libz.1.dylib
        0x7fff2a50a000 -     0x7fff2a551fff  libsystem_m.dylib (3186.100.3) <D61B56FE-649B-34A0-8446-25685B2BBBF2> /usr/lib/system/libsystem_m.dylib
        0x7fff2a552000 -     0x7fff2a552fff  libcharset.1.dylib (59) <363A6C40-7446-3A72-B5EA-4731843CFE2F> /usr/lib/libcharset.1.dylib
        0x7fff2a553000 -     0x7fff2a558fff  libmacho.dylib (980) <A4F4D532-7824-3E4E-8FB6-45617415E7DD> /usr/lib/system/libmacho.dylib
        0x7fff2a559000 -     0x7fff2a574fff  libkxld.dylib (7195.141.6) <1121F83B-5D42-368B-B440-100418CD4B23> /usr/lib/system/libkxld.dylib
        0x7fff2a575000 -     0x7fff2a580fff  libcommonCrypto.dylib (60178.120.3) <CF1E0E70-9F6C-3FAF-82B2-D55F7C9EBB03> /usr/lib/system/libcommonCrypto.dylib
        0x7fff2a581000 -     0x7fff2a58bfff  libunwind.dylib (201) <4602E909-C71A-3006-8140-BE616DA241EE> /usr/lib/system/libunwind.dylib
        0x7fff2a58c000 -     0x7fff2a593fff  liboah.dylib (203.58) <F72C2D50-7279-3497-8A59-56908F9661F3> /usr/lib/liboah.dylib
        0x7fff2a594000 -     0x7fff2a59efff  libcopyfile.dylib (173.40.2) <B0F35A80-D5E3-33DD-A47D-ACBFE1300523> /usr/lib/system/libcopyfile.dylib
        0x7fff2a59f000 -     0x7fff2a5a6fff  libcompiler_rt.dylib (102.2) <1C049207-1719-39AC-A2A9-6E5BE28AA138> /usr/lib/system/libcompiler_rt.dylib
        0x7fff2a5a7000 -     0x7fff2a5a9fff  libsystem_collections.dylib (1439.141.1) <F2D775D9-AAEF-371F-AA54-CFB882B9B430> /usr/lib/system/libsystem_collections.dylib
        0x7fff2a5aa000 -     0x7fff2a5acfff  libsystem_secinit.dylib (87.60.1) <EB4516ED-1F8B-3E8A-8C4B-B209A33DCCEF> /usr/lib/system/libsystem_secinit.dylib
        0x7fff2a5ad000 -     0x7fff2a5affff  libremovefile.dylib (49.120.1) <1AEE3D84-32F9-35FB-8036-B178C9E27D20> /usr/lib/system/libremovefile.dylib
        0x7fff2a5b0000 -     0x7fff2a5b0fff  libkeymgr.dylib (31) <698AF6EE-08BB-36CF-B7AD-9EC16E36FA0B> /usr/lib/system/libkeymgr.dylib
        0x7fff2a5b1000 -     0x7fff2a5b8fff  libsystem_dnssd.dylib (1310.140.1) <0685BDB0-9A98-3ADD-B95A-11F221FD80D7> /usr/lib/system/libsystem_dnssd.dylib
        0x7fff2a5b9000 -     0x7fff2a5befff  libcache.dylib (83) <B51FAB34-AA9C-38C5-95F1-E5E54B21EA67> /usr/lib/system/libcache.dylib
        0x7fff2a5bf000 -     0x7fff2a5c0fff  libSystem.B.dylib (1292.120.1) <DBD0A184-CD98-3225-8E9B-D5BFE0D30562> /usr/lib/libSystem.B.dylib
        0x7fff2a5c1000 -     0x7fff2a5c4fff  libfakelink.dylib (3) <BE0E6C60-675A-3739-A47A-67C650B1F790> /usr/lib/libfakelink.dylib
        0x7fff2a5c5000 -     0x7fff2a5c5fff  com.apple.SoftLinking (1.0 - 1) <9E4B6591-74E3-3B36-91C4-851FAA567DAA> /System/Library/PrivateFrameworks/SoftLinking.framework/Versions/A/SoftLinking
        0x7fff2a5c6000 -     0x7fff2a5fdfff  libpcap.A.dylib (98.100.3) <6DD23455-C0CA-313E-89B5-A45F8CD71C20> /usr/lib/libpcap.A.dylib
        0x7fff2a5fe000 -     0x7fff2a6eefff  libiconv.2.dylib (59) <90F749E2-9D2D-3323-A018-31A1F95221A1> /usr/lib/libiconv.2.dylib
        0x7fff2a6ef000 -     0x7fff2a700fff  libcmph.dylib (8) <17871D7D-49C2-3343-AC30-C40E3AD5B2B6> /usr/lib/libcmph.dylib
        0x7fff2a701000 -     0x7fff2a772fff  libarchive.2.dylib (83.100.2) <5AF9560E-5683-33A5-8D60-A469193B94E3> /usr/lib/libarchive.2.dylib
        0x7fff2a773000 -     0x7fff2a7dafff  com.apple.SearchKit (1.4.1 - 1.4.1) <A45AE5BD-9242-351E-B621-3EB50F66AB30> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SearchKit.framework/Versions/A/SearchKit
        0x7fff2a7db000 -     0x7fff2a7dcfff  libThaiTokenizer.dylib (3) <7B40AC51-B945-3AF0-B349-5818050D37FB> /usr/lib/libThaiTokenizer.dylib
        0x7fff2a7dd000 -     0x7fff2a7fffff  com.apple.applesauce (1.0 - 16.28) <7D011403-38CD-37DA-B2C2-00D2D2273422> /System/Library/PrivateFrameworks/AppleSauce.framework/Versions/A/AppleSauce
        0x7fff2a800000 -     0x7fff2a817fff  libapple_nghttp2.dylib (1.41) <E3FCBDB9-6671-3368-B371-B9CAC9BB1B45> /usr/lib/libapple_nghttp2.dylib
        0x7fff2a818000 -     0x7fff2a82efff  libSparseBLAS.dylib (1336.140.1) <78762464-084C-3743-BC56-A2AF5D010909> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libSparseBLAS.dylib
        0x7fff2a82f000 -     0x7fff2a830fff  com.apple.MetalPerformanceShaders.MetalPerformanceShaders (1.0 - 1) <BD2B6B2B-E116-3B97-A25F-71B4AC7B2BA6> /System/Library/Frameworks/MetalPerformanceShaders.framework/Versions/A/MetalPerformanceShaders
        0x7fff2a831000 -     0x7fff2a835fff  libpam.2.dylib (28.40.1) <E73D1903-42B9-3FF9-AE5D-482672F015AC> /usr/lib/libpam.2.dylib
        0x7fff2a836000 -     0x7fff2a855fff  libcompression.dylib (96.120.1) <CFE780B4-AFB0-327C-BB68-A5565AA7C630> /usr/lib/libcompression.dylib
        0x7fff2a856000 -     0x7fff2a85bfff  libQuadrature.dylib (7) <9668C241-61D5-3AE9-9856-708ACDC27F12> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libQuadrature.dylib
        0x7fff2a85c000 -     0x7fff2abf9fff  libLAPACK.dylib (1336.140.1) <8B968A9A-8263-3639-A740-636387467C03> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLAPACK.dylib
        0x7fff2abfa000 -     0x7fff2ac49fff  com.apple.DictionaryServices (1.2 - 341) <617030DF-769F-3CE0-869F-7F5B9B5A3784> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/DictionaryServices.framework/Versions/A/DictionaryServices
        0x7fff2ac4a000 -     0x7fff2ac62fff  liblzma.5.dylib (16) <6DE3F2AA-7140-3F6D-AD12-0DBA19BBBD54> /usr/lib/liblzma.5.dylib
        0x7fff2ac63000 -     0x7fff2ac64fff  libcoretls_cfhelpers.dylib (169.100.1) <0CF72D7A-0A39-3683-82ED-29A09761D6FF> /usr/lib/libcoretls_cfhelpers.dylib
        0x7fff2ac65000 -     0x7fff2ad60fff  com.apple.APFS (1677.141.2 - 1677.141.2) <F42A21D0-F8CE-3DDA-ACE6-C0AC9EE2FA6C> /System/Library/PrivateFrameworks/APFS.framework/Versions/A/APFS
        0x7fff2ad61000 -     0x7fff2ad6efff  libxar.1.dylib (452) <0B0B68CC-D627-3BDC-AE01-007C6AD8E97B> /usr/lib/libxar.1.dylib
        0x7fff2ad6f000 -     0x7fff2ad72fff  libutil.dylib (58.40.2) <0EA3237C-B6E6-351B-AE27-8975D88602D6> /usr/lib/libutil.dylib
        0x7fff2ad73000 -     0x7fff2ad9bfff  libxslt.1.dylib (17.6) <300C3D2D-19B1-3D8E-B212-1D2EB6C8B80A> /usr/lib/libxslt.1.dylib
        0x7fff2ad9c000 -     0x7fff2ada6fff  libChineseTokenizer.dylib (37.1) <B4314553-EF8B-3CD4-A7D8-76CD7FC7142D> /usr/lib/libChineseTokenizer.dylib
        0x7fff2ada7000 -     0x7fff2ae64fff  libvMisc.dylib (760.100.3) <B8F30684-94D1-3A53-80BF-C78F424594AD> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvMisc.dylib
        0x7fff2ae65000 -     0x7fff2aefcfff  libate.dylib (3.0.6) <FA881406-28F3-33BD-B75D-40389CE2ADD1> /usr/lib/libate.dylib
        0x7fff2aefd000 -     0x7fff2af04fff  libIOReport.dylib (64.100.1) <4D638FAC-2FD8-359C-8159-1ED37CBB5704> /usr/lib/libIOReport.dylib
        0x7fff2af05000 -     0x7fff2af18fff  com.apple.CrashReporterSupport (10.13 - 15053.1) <B879B52A-5A65-3CB3-B271-15A032853A35> /System/Library/PrivateFrameworks/CrashReporterSupport.framework/Versions/A/CrashReporterSupport
        0x7fff2af30000 -     0x7fff2afadfff  com.apple.CVNLP (1.0 - 119) <3604CA5C-2547-3C9A-99F5-3A7AB0DBE0B1> /System/Library/PrivateFrameworks/CVNLP.framework/Versions/A/CVNLP
        0x7fff2afcf000 -     0x7fff2b005fff  com.apple.pluginkit.framework (1.0 - 1) <84F2AE60-705A-3B37-B42E-13EF51B1FA1B> /System/Library/PrivateFrameworks/PlugInKit.framework/Versions/A/PlugInKit
        0x7fff2b006000 -     0x7fff2b00dfff  libMatch.1.dylib (38) <85F66EF8-FC5E-385C-AF8F-79532C2AC988> /usr/lib/libMatch.1.dylib
        0x7fff2b00e000 -     0x7fff2b099fff  libCoreStorage.dylib (554.140.2) <249F3E03-6C96-3E20-999A-BBFE36AADECA> /usr/lib/libCoreStorage.dylib
        0x7fff2b09a000 -     0x7fff2b0edfff  com.apple.AppleVAFramework (6.1.3 - 6.1.3) <2CDA1194-F435-3B9C-94A2-220E26E40DE6> /System/Library/PrivateFrameworks/AppleVA.framework/Versions/A/AppleVA
        0x7fff2b0ee000 -     0x7fff2b107fff  libexpat.1.dylib (26.141.1) <84DC54E5-9E75-3F64-9D7F-3CA641674ED8> /usr/lib/libexpat.1.dylib
        0x7fff2b108000 -     0x7fff2b111fff  libheimdal-asn1.dylib (597.140.2) <8D7B3A0D-A699-3947-9E8C-EEA4B4AD6408> /usr/lib/libheimdal-asn1.dylib
        0x7fff2b112000 -     0x7fff2b126fff  com.apple.IconFoundation (479.4 - 479.4) <6ED33568-2A1D-3918-9D32-D1E102002E48> /System/Library/PrivateFrameworks/IconFoundation.framework/Versions/A/IconFoundation
        0x7fff2b127000 -     0x7fff2b193fff  com.apple.IconServices (479.4 - 479.4) <D94D5AF3-6EF6-30D8-A7F8-58A1A3E5641B> /System/Library/PrivateFrameworks/IconServices.framework/Versions/A/IconServices
        0x7fff2b194000 -     0x7fff2b232fff  com.apple.MediaExperience (1.0 - 1) <245932F7-E76A-37A7-A033-7BB62F8ED190> /System/Library/PrivateFrameworks/MediaExperience.framework/Versions/A/MediaExperience
        0x7fff2b233000 -     0x7fff2b25bfff  com.apple.persistentconnection (1.0 - 1.0) <90FBA2DD-E91A-3A9F-80C5-8F94950136A4> /System/Library/PrivateFrameworks/PersistentConnection.framework/Versions/A/PersistentConnection
        0x7fff2b25c000 -     0x7fff2b26afff  com.apple.GraphVisualizer (1.0 - 100.1) <9538C368-5703-367B-ADAE-20EC5C3C5C41> /System/Library/PrivateFrameworks/GraphVisualizer.framework/Versions/A/GraphVisualizer
        0x7fff2b26b000 -     0x7fff2b686fff  com.apple.vision.FaceCore (4.3.2 - 4.3.2) <86110F21-96FE-325C-8D55-9385690C2386> /System/Library/PrivateFrameworks/FaceCore.framework/Versions/A/FaceCore
        0x7fff2b687000 -     0x7fff2b6cefff  com.apple.OTSVG (1.0 - 677.6.0.2) <34AD6D57-71B8-3859-94AF-DB856D8FD6BA> /System/Library/PrivateFrameworks/OTSVG.framework/Versions/A/OTSVG
        0x7fff2b6cf000 -     0x7fff2b6d5fff  com.apple.xpc.AppServerSupport (1.0 - 2038.120.1) <AD03039F-3D12-31FE-A497-EC4A87097683> /System/Library/PrivateFrameworks/AppServerSupport.framework/Versions/A/AppServerSupport
        0x7fff2b6d6000 -     0x7fff2b6e8fff  libhvf.dylib (1.0 - $[CURRENT_PROJECT_VERSION]) <B4F0CDA6-0332-3AB9-A0FB-8CD6EE316D30> /System/Library/PrivateFrameworks/FontServices.framework/libhvf.dylib
        0x7fff2b6e9000 -     0x7fff2b6ebfff  libspindump.dylib (295.2) <8DE7E414-DCEC-30B8-87DC-511D362D49F3> /usr/lib/libspindump.dylib
        0x7fff2b6ec000 -     0x7fff2b7acfff  com.apple.Heimdal (4.0 - 2.0) <30D71BC9-C18F-35C7-B7E1-88E645D4D329> /System/Library/PrivateFrameworks/Heimdal.framework/Versions/A/Heimdal
        0x7fff2b7ad000 -     0x7fff2b7c7fff  com.apple.login (3.0 - 3.0) <0690C64C-DE8C-3AA2-A4A5-BE3EFC3BDC62> /System/Library/PrivateFrameworks/login.framework/Versions/A/login
        0x7fff2b7c8000 -     0x7fff2b89ffff  com.apple.corebrightness (1.0 - 1) <84C0971C-31BB-3E68-9EC1-0EF05986CEEA> /System/Library/PrivateFrameworks/CoreBrightness.framework/Versions/A/CoreBrightness
        0x7fff2b948000 -     0x7fff2b94bfff  libodfde.dylib (26) <6436E5A0-CEF3-302F-86E7-E28C3EBE7A3A> /usr/lib/libodfde.dylib
        0x7fff2b94c000 -     0x7fff2b988fff  com.apple.bom (14.0 - 235) <E428566D-DFA2-33AC-AF3B-C68530D52522> /System/Library/PrivateFrameworks/Bom.framework/Versions/A/Bom
        0x7fff2b989000 -     0x7fff2b9d2fff  com.apple.AppleJPEG (1.0 - 1) <15DCB33B-EB52-38A2-B02F-EC235DC85B52> /System/Library/PrivateFrameworks/AppleJPEG.framework/Versions/A/AppleJPEG
        0x7fff2b9d3000 -     0x7fff2bab2fff  libJP2.dylib (2130.7.3) <20747AB5-CFA0-3C7A-BE41-BF4B54FD2038> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJP2.dylib
        0x7fff2bab3000 -     0x7fff2bab6fff  com.apple.WatchdogClient.framework (1.0 - 98.120.2) <0A097C25-405B-38CD-B6E2-57F51AD77AF0> /System/Library/PrivateFrameworks/WatchdogClient.framework/Versions/A/WatchdogClient
        0x7fff2bab7000 -     0x7fff2baedfff  com.apple.MultitouchSupport.framework (4440.3 - 4440.3) <0DF955E2-E57C-3C1B-96BD-5B81DAD43BC7> /System/Library/PrivateFrameworks/MultitouchSupport.framework/Versions/A/MultitouchSupport
        0x7fff2baee000 -     0x7fff2bc4cfff  com.apple.VideoToolbox (1.0 - 2780.10) <4FF9A4C0-FFB4-3F68-9A84-949B4DB0DB7A> /System/Library/Frameworks/VideoToolbox.framework/Versions/A/VideoToolbox
        0x7fff2bc4d000 -     0x7fff2bc80fff  libAudioToolboxUtility.dylib (1181.72) <9D9EA545-924D-342A-BF27-C19887850F05> /usr/lib/libAudioToolboxUtility.dylib
        0x7fff2bc81000 -     0x7fff2bca1fff  libPng.dylib (2130.7.3) <29756FE6-34E9-3760-9B70-9FF6648BE7CC> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libPng.dylib
        0x7fff2bca2000 -     0x7fff2bd01fff  libTIFF.dylib (2130.7.3) <692B9470-8F28-3C98-9C6A-DAE79FE0136F> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libTIFF.dylib
        0x7fff2bd02000 -     0x7fff2bd1efff  com.apple.IOPresentment (58 - 37) <A86E6181-E216-3691-A7FF-0264A927C8CC> /System/Library/PrivateFrameworks/IOPresentment.framework/Versions/A/IOPresentment
        0x7fff2bd1f000 -     0x7fff2bd26fff  com.apple.GPUWrangler (6.3.5 - 6.3.5) <CC101DAE-349B-3C72-9554-6F569364841E> /System/Library/PrivateFrameworks/GPUWrangler.framework/Versions/A/GPUWrangler
        0x7fff2bd27000 -     0x7fff2bd2afff  libRadiance.dylib (2130.7.3) <1A759A2B-28E8-32C4-940D-BE0239558098> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libRadiance.dylib
        0x7fff2bd2b000 -     0x7fff2bd30fff  com.apple.DSExternalDisplay (3.1 - 380) <3FD5886F-5EDD-313D-9783-FF899E5F2650> /System/Library/PrivateFrameworks/DSExternalDisplay.framework/Versions/A/DSExternalDisplay
        0x7fff2bd31000 -     0x7fff2bd55fff  libJPEG.dylib (2130.7.3) <C0903C97-523A-3822-ABE4-D1047D6785DC> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJPEG.dylib
        0x7fff2bd56000 -     0x7fff2bd85fff  com.apple.ATSUI (1.0 - 1) <F9BEFF92-E409-35B6-89CB-0F221D804D3C> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATSUI.framework/Versions/A/ATSUI
        0x7fff2bd86000 -     0x7fff2bd8afff  libGIF.dylib (2130.7.3) <E92A145C-2B76-39D1-B481-B7C95ACBF989> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libGIF.dylib
        0x7fff2bd8b000 -     0x7fff2bd94fff  com.apple.CMCaptureCore (1.0 - 82.6) <E0EAD649-4C7A-384E-999B-4D82AA9CDA52> /System/Library/PrivateFrameworks/CMCaptureCore.framework/Versions/A/CMCaptureCore
        0x7fff2bd95000 -     0x7fff2bddcfff  com.apple.print.framework.PrintCore (16.1 - 531.1) <035969B9-3323-3AF4-AC4C-1D5B941C7C62> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/PrintCore.framework/Versions/A/PrintCore
        0x7fff2bddd000 -     0x7fff2beaafff  com.apple.TextureIO (3.10.9 - 3.10.9) <4B778275-5F2D-36DA-A6AD-14C8E516E197> /System/Library/PrivateFrameworks/TextureIO.framework/Versions/A/TextureIO
        0x7fff2beab000 -     0x7fff2beb3fff  com.apple.InternationalSupport (1.0 - 61.1) <56A6D4F8-FF5B-3F34-BD1A-249414F182E9> /System/Library/PrivateFrameworks/InternationalSupport.framework/Versions/A/InternationalSupport
        0x7fff2beb4000 -     0x7fff2bf2efff  com.apple.datadetectorscore (8.0 - 674) <CDA8DABD-62A3-3E1C-9A76-B00E1E950254> /System/Library/PrivateFrameworks/DataDetectorsCore.framework/Versions/A/DataDetectorsCore
        0x7fff2bf2f000 -     0x7fff2bf8cfff  com.apple.UserActivity (439 - 439) <C272F369-1086-317C-A4CF-AE2E1EC4FFB4> /System/Library/PrivateFrameworks/UserActivity.framework/Versions/A/UserActivity
        0x7fff2bf8d000 -     0x7fff2c729fff  com.apple.MediaToolbox (1.0 - 2780.10) <AFB06F1B-22BA-3DB7-B6E4-3C55F0A4BECF> /System/Library/Frameworks/MediaToolbox.framework/Versions/A/MediaToolbox
        0x7fff2cb6a000 -     0x7fff2cbd0fff  com.apple.imfoundation (10.0 - 1000) <1D902049-CAD5-3DE0-AE4A-9AACEBB586BE> /System/Library/PrivateFrameworks/IMFoundation.framework/Versions/A/IMFoundation
        0x7fff2cbd1000 -     0x7fff2cbf9fff  com.apple.locationsupport (2420.19.23 - 2420.19.23) <9A015D62-2143-3199-AD14-ECA953A728D3> /System/Library/PrivateFrameworks/LocationSupport.framework/Versions/A/LocationSupport
        0x7fff2cbfa000 -     0x7fff2cc2bfff  libSessionUtility.dylib (76.69) <400DF595-A30C-3AD3-A8BA-25260299ACE6> /System/Library/PrivateFrameworks/AudioSession.framework/libSessionUtility.dylib
        0x7fff2cc2c000 -     0x7fff2cd60fff  com.apple.audio.toolbox.AudioToolbox (1.14 - 1.14) <93226BB9-165F-3A42-8EE3-9670394C4DC9> /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToolbox
        0x7fff2cd61000 -     0x7fff2cdc6fff  com.apple.audio.AudioSession (1.0 - 76.69) <ADC1C8FC-A444-3F15-A396-B4AB688BB326> /System/Library/PrivateFrameworks/AudioSession.framework/Versions/A/AudioSession
        0x7fff2cdc7000 -     0x7fff2cdd9fff  libAudioStatistics.dylib (27.64) <74E8B615-03FE-327B-A8FB-EAC5EF117414> /usr/lib/libAudioStatistics.dylib
        0x7fff2cdda000 -     0x7fff2cde9fff  com.apple.speech.synthesis.framework (9.0.66 - 9.0.66) <CE36276F-23DD-32A3-9863-D3A5DDE5965E> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynthesis.framework/Versions/A/SpeechSynthesis
        0x7fff2cdea000 -     0x7fff2ce56fff  com.apple.ApplicationServices.ATS (377 - 516) <6E601872-2340-3675-9B6F-0C1DB991C54E> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/ATS
        0x7fff2ce57000 -     0x7fff2ce6ffff  libresolv.9.dylib (68) <86A4BABF-3EFC-3113-BE8A-2D1AAAEF0194> /usr/lib/libresolv.9.dylib
        0x7fff2ce70000 -     0x7fff2ce83fff  libsasl2.2.dylib (214) <601780A9-26F4-36A4-83EA-864841219797> /usr/lib/libsasl2.2.dylib
        0x7fff2cef0000 -     0x7fff2cf23fff  com.apple.securityinterface (10.0 - 55149.120.1) <10A7DFC1-8C46-382C-AEF0-89B151767F50> /System/Library/Frameworks/SecurityInterface.framework/Versions/A/SecurityInterface
        0x7fff2cf24000 -     0x7fff2cf3cfff  com.apple.CoreFollowUp-OSX (1.0 - 1) <752290D4-DC17-3A64-BC8C-47D8BF548C7B> /System/Library/PrivateFrameworks/CoreFollowUp.framework/Versions/A/CoreFollowUp
        0x7fff2cf3d000 -     0x7fff2cfa1fff  com.apple.CoreMediaIO (1000.0 - 5325) <42F6129C-48E9-316A-9F30-2FA4D96F709F> /System/Library/Frameworks/CoreMediaIO.framework/Versions/A/CoreMediaIO
        0x7fff2cfa2000 -     0x7fff2d081fff  libSMC.dylib (20) <CF88A94C-B5EE-306F-96A3-1442BA061C46> /usr/lib/libSMC.dylib
        0x7fff2d082000 -     0x7fff2d0e1fff  libcups.2.dylib (494.3) <2CE9752F-8763-3456-83CF-E4BCFB731153> /usr/lib/libcups.2.dylib
        0x7fff2d0e2000 -     0x7fff2d0f1fff  com.apple.LangAnalysis (1.7.0 - 254) <AB67008E-5986-3974-B986-FDBFAC018CAB> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LangAnalysis.framework/Versions/A/LangAnalysis
        0x7fff2d0f2000 -     0x7fff2d0fcfff  com.apple.NetAuth (6.2 - 6.2) <B5806BA7-9A6E-37A0-9AB9-6EC2D61844AC> /System/Library/PrivateFrameworks/NetAuth.framework/Versions/A/NetAuth
        0x7fff2d0fd000 -     0x7fff2d104fff  com.apple.ColorSyncLegacy (4.13.0 - 1) <86D9E9C9-C631-371E-824E-A203FE9E560A> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSyncLegacy.framework/Versions/A/ColorSyncLegacy
        0x7fff2d105000 -     0x7fff2d110fff  com.apple.QD (4.0 - 416) <1D8792FC-4A76-3B4F-82CF-3889C05768FE> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/QD.framework/Versions/A/QD
        0x7fff2d111000 -     0x7fff2d765fff  com.apple.audio.AudioResourceArbitration (1.0 - 1) <C97CD66B-8267-3C39-B025-789864237928> /System/Library/PrivateFrameworks/AudioResourceArbitration.framework/Versions/A/AudioResourceArbitration
        0x7fff2d766000 -     0x7fff2d771fff  com.apple.perfdata (1.0 - 67.40.1) <10E2B0C5-83A4-368A-B972-7AFA40D5338C> /System/Library/PrivateFrameworks/perfdata.framework/Versions/A/perfdata
        0x7fff2d772000 -     0x7fff2d780fff  libperfcheck.dylib (41) <A2D0E1A8-A98F-3DAA-B9FC-C033FC4CD9E0> /usr/lib/libperfcheck.dylib
        0x7fff2d781000 -     0x7fff2d790fff  com.apple.Kerberos (3.0 - 1) <0074E20F-E7D8-31F5-AF41-0D7BF370CD50> /System/Library/Frameworks/Kerberos.framework/Versions/A/Kerberos
        0x7fff2d791000 -     0x7fff2d7e1fff  com.apple.GSS (4.0 - 2.0) <D546E52C-295F-3CCD-9925-03632FE72ECB> /System/Library/Frameworks/GSS.framework/Versions/A/GSS
        0x7fff2d7e2000 -     0x7fff2d7f2fff  com.apple.CommonAuth (4.0 - 2.0) <DF20551B-1514-39B3-A52E-681A2E5F0D1C> /System/Library/PrivateFrameworks/CommonAuth.framework/Versions/A/CommonAuth
        0x7fff2d7f3000 -     0x7fff2d81afff  com.apple.MobileAssets (1.0 - 659.100.21) <14EB0135-6B08-37A0-A517-E23997BAD7D5> /System/Library/PrivateFrameworks/MobileAsset.framework/Versions/A/MobileAsset
        0x7fff2d81b000 -     0x7fff2d847fff  com.apple.CacheDelete (1.0 - 1) <FB1E1322-C50B-38DD-86CE-9AEC925628A3> /System/Library/PrivateFrameworks/CacheDelete.framework/Versions/A/CacheDelete
        0x7fff2d848000 -     0x7fff2d867fff  com.apple.security.KeychainCircle.KeychainCircle (1.0 - 1) <C48DA26A-6A69-3497-B94D-43332354162B> /System/Library/PrivateFrameworks/KeychainCircle.framework/Versions/A/KeychainCircle
        0x7fff2d868000 -     0x7fff2d870fff  com.apple.CorePhoneNumbers (1.0 - 1) <9F49D632-C5F4-37F5-A2A8-2830A7560138> /System/Library/PrivateFrameworks/CorePhoneNumbers.framework/Versions/A/CorePhoneNumbers
        0x7fff2d871000 -     0x7fff2d8fafff  libTelephonyUtilDynamic.dylib (5359.1) <DDF9B2A1-D071-3180-9BC6-A143D6D9E713> /usr/lib/libTelephonyUtilDynamic.dylib
        0x7fff2d9c3000 -     0x7fff2d9c3fff  liblaunch.dylib (2038.120.1) <4A353070-A560-3A98-8869-28C92435C6B2> /usr/lib/system/liblaunch.dylib
        0x7fff2dcbc000 -     0x7fff2df47fff  com.apple.NetworkExtension (1.0 - 1) <727B66BE-EED5-324A-8FDC-14E91844B92E> /System/Library/Frameworks/NetworkExtension.framework/Versions/A/NetworkExtension
        0x7fff2df48000 -     0x7fff2e049fff  com.apple.ids (10.0 - 1000) <F30AC7B8-FACA-3B37-914D-C7AFA47A9DAE> /System/Library/PrivateFrameworks/IDS.framework/Versions/A/IDS
        0x7fff2e04a000 -     0x7fff2e1a4fff  com.apple.idsfoundation (10.0 - 1000) <3EAAA079-B3EE-3A12-B181-3267029FB4B0> /System/Library/PrivateFrameworks/IDSFoundation.framework/Versions/A/IDSFoundation
        0x7fff2e1a5000 -     0x7fff2e2f0fff  com.apple.Sharing (1630 - 1630) <CE657A48-7BDD-34D7-9CBC-B1D6AD94B2B2> /System/Library/PrivateFrameworks/Sharing.framework/Versions/A/Sharing
        0x7fff2e2f1000 -     0x7fff2e412fff  com.apple.Bluetooth (8.0.5 - 8.0.5d7) <D011494A-287B-3487-B817-2329843C2486> /System/Library/Frameworks/IOBluetooth.framework/Versions/A/IOBluetooth
        0x7fff2e413000 -     0x7fff2e427fff  com.apple.AppContainer (4.0 - 509.140.3) <85EE3606-0190-3428-9C49-D32A01706439> /System/Library/PrivateFrameworks/AppContainer.framework/Versions/A/AppContainer
        0x7fff2e428000 -     0x7fff2e42bfff  com.apple.SecCodeWrapper (4.0 - 509.140.3) <1BB9A761-4DE0-34AF-87A6-CB5BF9322F62> /System/Library/PrivateFrameworks/SecCodeWrapper.framework/Versions/A/SecCodeWrapper
        0x7fff2e42c000 -     0x7fff2e485fff  com.apple.ProtectedCloudStorage (1.0 - 1) <EA0958A6-8296-3E23-81BE-297473A6E17E> /System/Library/PrivateFrameworks/ProtectedCloudStorage.framework/Versions/A/ProtectedCloudStorage
        0x7fff2e486000 -     0x7fff2e4e5fff  com.apple.QuickLookFramework (5.0 - 928.4) <C7DA2119-94CA-320B-9FBE-9AB4F9F384DA> /System/Library/Frameworks/QuickLook.framework/Versions/A/QuickLook
        0x7fff2e4e6000 -     0x7fff2e501fff  com.apple.MetalKit (147.1 - 147.1) <F9EF05E2-2410-30A4-B9E0-8E19621D3434> /System/Library/Frameworks/MetalKit.framework/Versions/A/MetalKit
        0x7fff2e6e5000 -     0x7fff2fbe0fff  com.apple.GeoServices (1.0 - 1757.26.6.2.2) <1A271F08-3D05-36BF-A136-7D48B4418CD6> /System/Library/PrivateFrameworks/GeoServices.framework/Versions/A/GeoServices
        0x7fff2fbe1000 -     0x7fff2fbecfff  com.apple.DirectoryService.Framework (11.6 - 230.40.1) <A0B99619-47BD-3D1C-8CAA-EE25139753F6> /System/Library/Frameworks/DirectoryService.framework/Versions/A/DirectoryService
        0x7fff2fbed000 -     0x7fff2fc14fff  com.apple.RemoteViewServices (2.0 - 163) <7DBF2A51-CE8E-352E-9426-B83DC370ADDD> /System/Library/PrivateFrameworks/RemoteViewServices.framework/Versions/A/RemoteViewServices
        0x7fff2fc15000 -     0x7fff2fc24fff  com.apple.SpeechRecognitionCore (6.1.25 - 6.1.25) <076E6A5F-4FEE-378B-9DCD-AFFA1348C64F> /System/Library/PrivateFrameworks/SpeechRecognitionCore.framework/Versions/A/SpeechRecognitionCore
        0x7fff2fc25000 -     0x7fff2fc2cfff  com.apple.speech.recognition.framework (6.0.3 - 6.0.3) <DB80BAB9-5E83-32DB-A424-05BB19044665> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SpeechRecognition.framework/Versions/A/SpeechRecognition
        0x7fff2fc2d000 -     0x7fff2fc3dfff  com.apple.AppleLDAP (11.6 - 54) <1195DAE2-7082-32B1-B45A-ABE4B9A75D28> /System/Library/PrivateFrameworks/AppleLDAP.framework/Versions/A/AppleLDAP
        0x7fff2fe5a000 -     0x7fff2fe5afff  libsystem_product_info_filter.dylib (8.40.1) <78928329-DD98-3799-989D-870DF92FE8D5> /usr/lib/system/libsystem_product_info_filter.dylib
        0x7fff2fed2000 -     0x7fff2fee9fff  libnetworkextension.dylib (1295.140.3) <70743C15-3A7D-308C-9238-7E20FBF73199> /usr/lib/libnetworkextension.dylib
        0x7fff2ff32000 -     0x7fff2ff32fff  com.apple.Accelerate.vecLib (3.11 - vecLib 3.11) <CDB56324-715E-3223-903F-EEC1D4E57F14> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/vecLib
        0x7fff2ff58000 -     0x7fff2ff58fff  com.apple.CoreServices (1122.44 - 1122.44) <104E1757-7D8A-32D3-9B38-B23B1A8EAB17> /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServices
        0x7fff30114000 -     0x7fff30114fff  com.apple.Accelerate (1.11 - Accelerate 1.11) <28463942-495F-3231-9348-32ABC601A1F5> /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate
        0x7fff30155000 -     0x7fff30160fff  com.apple.MediaAccessibility (1.0 - 130) <677557AF-6AC1-3860-B7C4-772B8DA9957B> /System/Library/Frameworks/MediaAccessibility.framework/Versions/A/MediaAccessibility
        0x7fff30161000 -     0x7fff30180fff  com.apple.networking.AlgosScoreFramework (1.0 - 1) <BFF296BB-6E78-3213-B453-31AA58FC13E0> /System/Library/PrivateFrameworks/AlgosScoreFramework.framework/Versions/A/AlgosScoreFramework
        0x7fff30181000 -     0x7fff30185fff  com.apple.AppleSRP (5.0 - 1) <A8B167C6-9E49-3ED9-AD87-36BEA98F6E20> /System/Library/PrivateFrameworks/AppleSRP.framework/Versions/A/AppleSRP
        0x7fff30186000 -     0x7fff30191fff  com.apple.frameworks.CoreDaemon (1.3 - 1.3) <6873367E-2879-3C96-A766-AD6DFD69F36A> /System/Library/PrivateFrameworks/CoreDaemon.framework/Versions/B/CoreDaemon
        0x7fff30192000 -     0x7fff301c9fff  com.apple.framework.SystemAdministration (1.0 - 1.0) <84CB0B6A-46C1-3A8E-81D4-CC44DF0AFF83> /System/Library/PrivateFrameworks/SystemAdministration.framework/Versions/A/SystemAdministration
        0x7fff301ca000 -     0x7fff304a2fff  com.apple.VN (4.3.1 - 4.3.1) <0856C3F0-BF95-30DB-BFFC-BE4ABFDA04B7> /System/Library/Frameworks/Vision.framework/Versions/A/Vision
        0x7fff305fc000 -     0x7fff3067ffff  com.apple.AddressBook.ContactsFoundation (8.0 - 1151.2) <BEBEC756-57B8-3DBA-B0B8-5B9197ECC5A3> /System/Library/PrivateFrameworks/ContactsFoundation.framework/Versions/A/ContactsFoundation
        0x7fff30680000 -     0x7fff306c2fff  com.apple.contacts.ContactsPersistence (1.0 - 3497.5) <DEE423F8-36EB-3E69-9680-E93FA6F8F241> /System/Library/PrivateFrameworks/ContactsPersistence.framework/Versions/A/ContactsPersistence
        0x7fff306c3000 -     0x7fff307f9fff  com.apple.AddressBook.core (1.0 - 2452.7) <721D6700-131B-323E-9FE9-4AAEBECDA243> /System/Library/PrivateFrameworks/AddressBookCore.framework/Versions/A/AddressBookCore
        0x7fff307fa000 -     0x7fff3092efff  com.apple.contacts (1.0 - 3497.5) <73891206-8D41-3206-A10B-118B90EB4C86> /System/Library/Frameworks/Contacts.framework/Versions/A/Contacts
        0x7fff3092f000 -     0x7fff3093cfff  com.apple.PersonaKit (1.0 - 1) <B8FE29A2-D6A5-3AE0-BC97-1AA21755455A> /System/Library/PrivateFrameworks/PersonaKit.framework/Versions/A/PersonaKit
        0x7fff30942000 -     0x7fff30955fff  com.apple.FamilyCircle (1.0 - 113.0.0.10) <32DE900C-77C7-325C-B487-67D46CEEEA19> /System/Library/PrivateFrameworks/FamilyCircle.framework/Versions/A/FamilyCircle
        0x7fff30956000 -     0x7fff309bbfff  com.apple.CoreBluetooth (1.0 - 1) <32288DE3-BD59-35A6-9165-73176E074499> /System/Library/Frameworks/CoreBluetooth.framework/Versions/A/CoreBluetooth
        0x7fff309bc000 -     0x7fff309c5fff  com.apple.SymptomDiagnosticReporter (1.0 - 79.120.1) <9A1589E7-0B3A-3DC5-967C-7A3D4C14ED1E> /System/Library/PrivateFrameworks/SymptomDiagnosticReporter.framework/Versions/A/SymptomDiagnosticReporter
        0x7fff309c6000 -     0x7fff309d8fff  com.apple.PowerLog (1.0 - 1) <7A3E3B4D-5DA4-3D01-9188-4FE8A6859D15> /System/Library/PrivateFrameworks/PowerLog.framework/Versions/A/PowerLog
        0x7fff309d9000 -     0x7fff309e5fff  com.apple.AppleIDAuthSupport (1.0 - 1) <C391F5AD-7903-31AF-8608-7826C0EFB3C5> /System/Library/PrivateFrameworks/AppleIDAuthSupport.framework/Versions/A/AppleIDAuthSupport
        0x7fff309e6000 -     0x7fff30a8efff  com.apple.DiscRecording (9.0.3 - 9030.4.5) <08A9AAA6-7057-3105-BDE1-DC7270C38774> /System/Library/Frameworks/DiscRecording.framework/Versions/A/DiscRecording
        0x7fff30a8f000 -     0x7fff30ac2fff  com.apple.MediaKit (16 - 927.40.2) <86B948D3-5757-37A7-B2DA-F7C50778B108> /System/Library/PrivateFrameworks/MediaKit.framework/Versions/A/MediaKit
        0x7fff30ac3000 -     0x7fff30baefff  com.apple.DiskManagement (14.0 - 1733.140.2) <CF6680B9-9799-3DE8-A600-094260672A4F> /System/Library/PrivateFrameworks/DiskManagement.framework/Versions/A/DiskManagement
        0x7fff30baf000 -     0x7fff30f69fff  com.apple.CoreAUC (326.2.0 - 326.2.0) <58430C09-401A-3B4C-806E-E87C46816939> /System/Library/PrivateFrameworks/CoreAUC.framework/Versions/A/CoreAUC
        0x7fff30f6a000 -     0x7fff30f6dfff  com.apple.Mangrove (1.0 - 25) <0E9FF438-D4B3-3DF1-B8A7-64623282B9B3> /System/Library/PrivateFrameworks/Mangrove.framework/Versions/A/Mangrove
        0x7fff30f6e000 -     0x7fff30f9bfff  com.apple.CoreAVCHD (6.1.0 - 6100.4.1) <80DEBCCB-A598-3CE5-B988-FFC5B81389CF> /System/Library/PrivateFrameworks/CoreAVCHD.framework/Versions/A/CoreAVCHD
        0x7fff30f9c000 -     0x7fff310ebfff  com.apple.FileProvider (349.4.3 - 349.4.3) <E07C8909-299C-3696-BD84-5CF42EE64EE4> /System/Library/Frameworks/FileProvider.framework/Versions/A/FileProvider
        0x7fff310ec000 -     0x7fff3110efff  com.apple.GenerationalStorage (2.0 - 323) <9E36AF92-10E2-382B-A07C-4E3270448690> /System/Library/PrivateFrameworks/GenerationalStorage.framework/Versions/A/GenerationalStorage
        0x7fff31484000 -     0x7fff31552fff  com.apple.CoreTelephony (113 - 8260) <DFBE4145-7D80-3F7B-8C37-746D9D63DAC6> /System/Library/Frameworks/CoreTelephony.framework/Versions/A/CoreTelephony
        0x7fff31553000 -     0x7fff31560fff  com.apple.AppSandbox (4.0 - 509.140.3) <FFB8B6E5-AC15-30EF-81A6-DB88ED9772C5> /System/Library/PrivateFrameworks/AppSandbox.framework/Versions/A/AppSandbox
        0x7fff31577000 -     0x7fff3170bfff  com.apple.AVFCore (1.0 - 2020.10) <85D55F46-61B4-3A08-8B13-1A678B571D66> /System/Library/PrivateFrameworks/AVFCore.framework/Versions/A/AVFCore
        0x7fff3170c000 -     0x7fff3177bfff  com.apple.FrontBoardServices (703.16 - 703.16) <5088E177-3DF7-3F48-B340-7E6FF569C1E2> /System/Library/PrivateFrameworks/FrontBoardServices.framework/Versions/A/FrontBoardServices
        0x7fff3177c000 -     0x7fff317a5fff  com.apple.BoardServices (1.0 - 526) <9932480F-CA31-362C-B5BB-263998D63224> /System/Library/PrivateFrameworks/BoardServices.framework/Versions/A/BoardServices
        0x7fff317a6000 -     0x7fff317d1fff  com.apple.contacts.vCard (1.0 - 3497.5) <34200FAE-9D85-396E-95E1-BD7341334EBB> /System/Library/PrivateFrameworks/vCard.framework/Versions/A/vCard
        0x7fff317e7000 -     0x7fff31802fff  com.apple.ExtensionKit (19.4 - 19.4) <D5A2BF7D-F72D-30D4-A12C-2B23A25C53FF> /System/Library/PrivateFrameworks/ExtensionKit.framework/Versions/A/ExtensionKit
        0x7fff31803000 -     0x7fff31809fff  com.apple.ExtensionFoundation (19.4 - 19.4) <911C2C6B-8D5E-301E-8845-ABE770077044> /System/Library/PrivateFrameworks/ExtensionFoundation.framework/Versions/A/ExtensionFoundation
        0x7fff3180a000 -     0x7fff3184ffff  com.apple.CryptoTokenKit (1.0 - 1) <85356F88-7E90-357C-A0CE-B580616C1CEF> /System/Library/Frameworks/CryptoTokenKit.framework/Versions/A/CryptoTokenKit
        0x7fff31850000 -     0x7fff31866fff  com.apple.LocalAuthentication (1.0 - 827.140.1) <D833E8C1-2038-3C12-9EEC-30D8F9F48702> /System/Library/Frameworks/LocalAuthentication.framework/Versions/A/LocalAuthentication
        0x7fff31867000 -     0x7fff31894fff  com.apple.CoreAuthentication.SharedUtils (1.0 - 827.140.1) <DCB4A9AE-4CE3-302E-8633-4F54DE1C1050> /System/Library/Frameworks/LocalAuthentication.framework/Support/SharedUtils.framework/Versions/A/SharedUtils
        0x7fff31909000 -     0x7fff3194afff  com.apple.CoreHaptics (1.0 - 1) <8B6CA9A4-26B2-31AD-A763-F905F126900D> /System/Library/Frameworks/CoreHaptics.framework/Versions/A/CoreHaptics
        0x7fff31958000 -     0x7fff31997fff  com.apple.AppleVPAFramework (3.26.1 - 3.26.1) <B7DF9782-C63B-32F0-A008-E83503C76E78> /System/Library/PrivateFrameworks/AppleVPA.framework/Versions/A/AppleVPA
        0x7fff31a4a000 -     0x7fff31a85fff  com.apple.DebugSymbols (195.1 - 195.1) <7D2E32A0-DB93-36EE-AE9C-7974708CF4FC> /System/Library/PrivateFrameworks/DebugSymbols.framework/Versions/A/DebugSymbols
        0x7fff31a86000 -     0x7fff31b3bfff  com.apple.CoreSymbolication (12.5 - 64544.81.1) <7215543C-E3B6-30A0-8B21-7FBDFB10F198> /System/Library/PrivateFrameworks/CoreSymbolication.framework/Versions/A/CoreSymbolication
        0x7fff31b3c000 -     0x7fff31b45fff  com.apple.CoreTime (284.0.4) <DAEEF1D8-1C34-37AC-9691-C4540C92E9F9> /System/Library/PrivateFrameworks/CoreTime.framework/Versions/A/CoreTime
        0x7fff31b46000 -     0x7fff31bbbfff  com.apple.Rapport (2.6.0 - 260.3) <55CA4269-E06C-3E4E-BB3D-957469333D9C> /System/Library/PrivateFrameworks/Rapport.framework/Versions/A/Rapport
        0x7fff32490000 -     0x7fff324dcfff  com.apple.coreduetcontext (1.0 - 1) <F343EE71-43B3-366E-A3C3-7FC0DD79D70F> /System/Library/PrivateFrameworks/CoreDuetContext.framework/Versions/A/CoreDuetContext
        0x7fff324dd000 -     0x7fff32a49fff  com.apple.Intents (1.0 - 1) <CA14EA98-180D-3AEC-9900-8B6BE616DA5C> /System/Library/Frameworks/Intents.framework/Versions/A/Intents
        0x7fff32a4a000 -     0x7fff32aadfff  com.apple.framework.Apple80211 (17.0 - 1728) <D89EA57A-D351-3BD1-A470-505C6D8BF4D6> /System/Library/PrivateFrameworks/Apple80211.framework/Versions/A/Apple80211
        0x7fff32aae000 -     0x7fff32bfffff  com.apple.CoreWiFi (3.0 - 341) <0FE4018E-E199-3923-A56D-430E40F5EEB7> /System/Library/PrivateFrameworks/CoreWiFi.framework/Versions/A/CoreWiFi
        0x7fff32c00000 -     0x7fff32c1afff  com.apple.BackBoardServices (1.0 - 1.0) <C21E697A-AB8B-3353-9B92-7DB6C09DE34D> /System/Library/PrivateFrameworks/BackBoardServices.framework/Versions/A/BackBoardServices
        0x7fff32c1b000 -     0x7fff32c52fff  com.apple.LDAPFramework (2.4.28 - 194.5) <327E5362-4AA3-3610-B126-CAC243121EA8> /System/Library/Frameworks/LDAP.framework/Versions/A/LDAP
        0x7fff32c53000 -     0x7fff32c54fff  com.apple.TrustEvaluationAgent (2.0 - 35) <CA7542A0-0CE3-39E9-9FF0-F827CC4633AC> /System/Library/PrivateFrameworks/TrustEvaluationAgent.framework/Versions/A/TrustEvaluationAgent
        0x7fff32c55000 -     0x7fff32d5afff  libcrypto.44.dylib (56.60.2) <90125B07-6FE0-3D39-947D-0C39B9DF6C43> /usr/lib/libcrypto.44.dylib
        0x7fff32d5b000 -     0x7fff32d88fff  libssl.46.dylib (56.60.2) <53F0CF92-264C-3210-852F-B2B65885E675> /usr/lib/libssl.46.dylib
        0x7fff32d89000 -     0x7fff32e38fff  com.apple.DiskImagesFramework (595.140.1 - 595.140.1) <6A804C50-8819-39A1-AF4E-4E71C6BD8DAB> /System/Library/PrivateFrameworks/DiskImages.framework/Versions/A/DiskImages
        0x7fff32e39000 -     0x7fff32e6ffff  com.apple.SystemConfiguration.EAP8021X (14.0.0 - 14.0) <FE03407F-3251-30BD-AA64-8DE2940C0F57> /System/Library/PrivateFrameworks/EAP8021X.framework/Versions/A/EAP8021X
        0x7fff32e70000 -     0x7fff32e7ffff  com.apple.RemoteServiceDiscovery (1.0 - 1.120.1) <8F0CFA90-78B8-3305-BCD3-6C28B7838CE0> /System/Library/PrivateFrameworks/RemoteServiceDiscovery.framework/Versions/A/RemoteServiceDiscovery
        0x7fff32e98000 -     0x7fff32edcfff  com.apple.DataDetectorsNaturalLanguage (1.0 - 159.1) <234D2A46-5B69-3B18-8D45-6DD1F4293C73> /System/Library/PrivateFrameworks/DataDetectorsNaturalLanguage.framework/Versions/A/DataDetectorsNaturalLanguage
        0x7fff32edd000 -     0x7fff32ee0fff  com.apple.help (1.3.8 - 71) <CF14979A-CA27-32D1-A3E8-D99AD6C91464> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Help.framework/Versions/A/Help
        0x7fff32ee1000 -     0x7fff32ee8fff  com.apple.EFILogin (2.0 - 2) <77A5D3D5-3B8D-3B5D-A1BD-A7614C86AF67> /System/Library/PrivateFrameworks/EFILogin.framework/Versions/A/EFILogin
        0x7fff32ee9000 -     0x7fff32ef4fff  libcsfde.dylib (554.140.2) <8B6A31B3-9421-3BAE-882B-8BEF5217E251> /usr/lib/libcsfde.dylib
        0x7fff32ef5000 -     0x7fff32f5bfff  libcurl.4.dylib (121.101.1) <8ACEDAF2-5907-3F4A-9595-F52681D0F470> /usr/lib/libcurl.4.dylib
        0x7fff32f5c000 -     0x7fff32f63fff  com.apple.LoginUICore (4.0 - 4.0) <F8CF5AD4-6A49-3EFC-B1FA-BD83B0095CBB> /System/Library/PrivateFrameworks/LoginUIKit.framework/Versions/A/Frameworks/LoginUICore.framework/Versions/A/LoginUICore
        0x7fff32f64000 -     0x7fff32fc6fff  com.apple.AppSupport (1.0.0 - 29) <7F288248-AB86-3AAC-9528-1A62E0E77528> /System/Library/PrivateFrameworks/AppSupport.framework/Versions/A/AppSupport
        0x7fff33066000 -     0x7fff3312afff  com.apple.GameController (1.0 - 1) <68352436-3E7E-30BE-B804-E8EDE0658BB3> /System/Library/Frameworks/GameController.framework/Versions/A/GameController
        0x7fff33133000 -     0x7fff33133fff  com.apple.ApplicationServices (48 - 50) <52BB5EB6-2C1B-34F9-8665-F50DD078E71B> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/ApplicationServices
        0x7fff33134000 -     0x7fff33136fff  com.apple.InternationalTextSearch (1.0 - 1) <B6F39BE2-4D42-38BD-B8DD-53F4B7E9DA38> /System/Library/PrivateFrameworks/InternationalTextSearch.framework/Versions/A/InternationalTextSearch
        0x7fff33137000 -     0x7fff331affff  com.apple.ClassKit (1.2 - 146.6) <54D86FD1-568D-327F-82CA-B47A16E4CE80> /System/Library/Frameworks/ClassKit.framework/Versions/A/ClassKit
        0x7fff331b0000 -     0x7fff332f4fff  com.apple.AppleAccount (1.0 - 1.0) <B304AA07-C970-3195-B4BE-978E3CA2856F> /System/Library/PrivateFrameworks/AppleAccount.framework/Versions/A/AppleAccount
        0x7fff332f5000 -     0x7fff33334fff  com.apple.AppleIDSSOAuthentication (1.0 - 1) <AB9B31C6-653B-38AF-852A-10FB097BA818> /System/Library/PrivateFrameworks/AppleIDSSOAuthentication.framework/Versions/A/AppleIDSSOAuthentication
        0x7fff33335000 -     0x7fff3338cfff  com.apple.CorePrediction (1.0 - 1) <0858EE22-68F8-31C9-88A2-B94D225CEE9E> /System/Library/PrivateFrameworks/CorePrediction.framework/Versions/A/CorePrediction
        0x7fff33448000 -     0x7fff33448fff  libHeimdalProxy.dylib (79) <A1B83B1E-006D-38A8-8878-FD6ECBBB9B1B> /System/Library/Frameworks/Kerberos.framework/Versions/A/Libraries/libHeimdalProxy.dylib
        0x7fff334fb000 -     0x7fff334fbfff  com.apple.audio.units.AudioUnit (1.14 - 1.14) <0A5BB3A7-D9DC-346C-9FBB-FB075194E7AC> /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit
        0x7fff3351f000 -     0x7fff33562fff  com.apple.StreamingZip (1.0 - 1) <DDE31BAA-F317-3EA3-AF44-7B05CDB95217> /System/Library/PrivateFrameworks/StreamingZip.framework/Versions/A/StreamingZip
        0x7fff33563000 -     0x7fff33581fff  com.apple.DuetActivityScheduler (1.0 - 1) <AEA67F50-E42E-37A5-BF75-6666CD80C19C> /System/Library/PrivateFrameworks/DuetActivityScheduler.framework/Versions/A/DuetActivityScheduler
        0x7fff33596000 -     0x7fff335a2fff  com.apple.IntentsFoundation (1.0 - 1) <90F93D25-8C0E-37FF-A480-0CC95E080E7C> /System/Library/PrivateFrameworks/IntentsFoundation.framework/Versions/A/IntentsFoundation
        0x7fff335a3000 -     0x7fff335a8fff  com.apple.PushKit (1.0 - 1) <02EC6449-963F-376C-BE24-F9CC8083ABD3> /System/Library/Frameworks/PushKit.framework/Versions/A/PushKit
        0x7fff335a9000 -     0x7fff335dcfff  com.apple.C2 (1.3 - 573) <1D8BCCDC-EFB0-3DF8-93A4-4D18388D7C11> /System/Library/PrivateFrameworks/C2.framework/Versions/A/C2
        0x7fff335dd000 -     0x7fff3360dfff  com.apple.QuickLookThumbnailing (1.0 - 135.5) <7B9EC715-B18C-3194-B78C-24358F1BEEFE> /System/Library/Frameworks/QuickLookThumbnailing.framework/Versions/A/QuickLookThumbnailing
        0x7fff3360e000 -     0x7fff33e0ffff  com.apple.vision.EspressoFramework (1.0 - 256.4.4) <46EB212E-0528-3D15-AAA4-207E8B197A75> /System/Library/PrivateFrameworks/Espresso.framework/Versions/A/Espresso
        0x7fff33e10000 -     0x7fff33e27fff  com.apple.ANEServices (4.76 - 4.76) <E54FB6F5-CBF8-3ED2-A73B-47C6D87910A4> /System/Library/PrivateFrameworks/ANEServices.framework/Versions/A/ANEServices
        0x7fff33e28000 -     0x7fff33e8dfff  com.apple.proactive.support.ProactiveSupport (1.0 - 294.7) <3496B6A3-168D-3278-AFB1-14363A6FB4F6> /System/Library/PrivateFrameworks/ProactiveSupport.framework/Versions/A/ProactiveSupport
        0x7fff33e8e000 -     0x7fff33e98fff  com.apple.corerecents (1.0 - 1) <D8991907-F2CC-36AB-B5C6-769A08B4667F> /System/Library/PrivateFrameworks/CoreRecents.framework/Versions/A/CoreRecents
        0x7fff33e99000 -     0x7fff33ecafff  com.apple.iCalendar (7.0 - 833) <632255EA-705A-3C44-80C2-1727D418745B> /System/Library/PrivateFrameworks/iCalendar.framework/Versions/A/iCalendar
        0x7fff33ecb000 -     0x7fff33f3bfff  com.apple.CalendarFoundation (8.0 - 1178.5.2) <2BE0FB9D-963E-3DC6-A60F-8A753EDB453A> /System/Library/PrivateFrameworks/CalendarFoundation.framework/Versions/A/CalendarFoundation
        0x7fff33f3c000 -     0x7fff33f3efff  com.apple.CoreDuetDebugLogging (1.0 - 1) <47F03D98-3BF5-3CAB-B83D-A30A59A5B068> /System/Library/PrivateFrameworks/CoreDuetDebugLogging.framework/Versions/A/CoreDuetDebugLogging
        0x7fff33f3f000 -     0x7fff33f4bfff  com.apple.CoreDuetDaemonProtocol (1.0 - 1) <B6BADDAF-0F79-30B6-8CD4-83C8ACDB12D0> /System/Library/PrivateFrameworks/CoreDuetDaemonProtocol.framework/Versions/A/CoreDuetDaemonProtocol
        0x7fff341df000 -     0x7fff344b2fff  com.apple.spotlight.index (10.7.0 - 2150.26) <D8CB9D18-8903-3E9F-A502-5896DC545BA5> /System/Library/PrivateFrameworks/SpotlightIndex.framework/Versions/A/SpotlightIndex
        0x7fff344cb000 -     0x7fff3451bfff  com.apple.ChunkingLibrary (334.1 - 334.1) <2CD91198-1354-357F-8858-D58244526C15> /System/Library/PrivateFrameworks/ChunkingLibrary.framework/Versions/A/ChunkingLibrary
        0x7fff34652000 -     0x7fff346a1fff  com.apple.CalDAV (8.0 - 795) <C0EAF392-62F0-382C-B832-96DBC6724472> /System/Library/PrivateFrameworks/CalDAV.framework/Versions/A/CalDAV
        0x7fff346a2000 -     0x7fff3473ffff  com.apple.CoreSuggestions (1.0 - 1115.519) <D781EA13-4252-334F-ADCC-F81AF8E6F2DE> /System/Library/PrivateFrameworks/CoreSuggestions.framework/Versions/A/CoreSuggestions
        0x7fff34740000 -     0x7fff348cafff  com.apple.ical.EventKit (3.0 - 1414.5.1) <33EAD078-D1DC-3315-BB80-AE77EE7F52AF> /System/Library/Frameworks/EventKit.framework/Versions/A/EventKit
        0x7fff348cb000 -     0x7fff34b9cfff  com.apple.CalendarPersistence (8.0 - 1071.4.4) <0E5E778E-57BD-3D7C-B875-3AA044100A0F> /System/Library/PrivateFrameworks/CalendarPersistence.framework/Versions/A/CalendarPersistence
        0x7fff34b9d000 -     0x7fff34bc2fff  com.apple.CalendarAgentLink (8.0 - 250) <94D45C00-DDD4-3D08-94A7-5202003B1BAE> /System/Library/PrivateFrameworks/CalendarAgentLink.framework/Versions/A/CalendarAgentLink
        0x7fff34bc3000 -     0x7fff34bcdfff  com.apple.RTCReporting (11.85.2 - 11.85.2) <4C416B6E-005D-3A43-BCB4-FCA93F149D74> /System/Library/PrivateFrameworks/RTCReporting.framework/Versions/A/RTCReporting
        0x7fff34bce000 -     0x7fff34d74fff  com.apple.WebKitLegacy (16611 - 16611.3.10.1.6) <D06037B8-003A-36DA-992F-62B478338C33> /System/Library/Frameworks/WebKit.framework/Versions/A/Frameworks/WebKitLegacy.framework/Versions/A/WebKitLegacy
        0x7fff34d8f000 -     0x7fff34da4fff  com.apple.CoreML.AppleNeuralEngine (1.0 - 1) <C3AA92B0-9BF9-3806-A952-2A318AF1EEE4> /System/Library/PrivateFrameworks/AppleNeuralEngine.framework/Versions/A/AppleNeuralEngine
        0x7fff34dfa000 -     0x7fff34e65fff  com.apple.audio.midi.CoreMIDI (2.0 - 88) <741CCF53-3F51-39A5-B07A-3C14BED77D44> /System/Library/Frameworks/CoreMIDI.framework/Versions/A/CoreMIDI
        0x7fff34e66000 -     0x7fff34e8ffff  com.apple.QTKit (1.0 - 5) <57142B0A-6D02-373B-9335-68AE3209BB4C> /System/Library/Frameworks/QTKit.framework/Versions/A/QTKit
        0x7fff34f2b000 -     0x7fff34f2efff  com.apple.Cocoa (6.11 - 23) <237F7F6E-E7D1-363A-92AF-32B564728891> /System/Library/Frameworks/Cocoa.framework/Versions/A/Cocoa
        0x7fff34f78000 -     0x7fff3536cfff  com.apple.AppleMediaServices (1.0 - 1) <0EBC0F6F-3763-3E66-A92C-CCA9453326FE> /System/Library/PrivateFrameworks/AppleMediaServices.framework/Versions/A/AppleMediaServices
        0x7fff353a4000 -     0x7fff3581cfff  com.apple.MediaRemote (1.0 - 1) <DEF1BED2-78C1-318C-8DB5-FD464941D48B> /System/Library/PrivateFrameworks/MediaRemote.framework/Versions/A/MediaRemote
        0x7fff35b18000 -     0x7fff35b1ffff  com.apple.DisplayServicesFW (3.1 - 380) <F794066C-55D0-3CC6-9BCD-C27207746B97> /System/Library/PrivateFrameworks/DisplayServices.framework/Versions/A/DisplayServices
        0x7fff36059000 -     0x7fff362edfff  libAWDSupportFramework.dylib (4205) <879C09AE-5344-3B02-A93F-8B3C46B39F17> /System/Library/PrivateFrameworks/WirelessDiagnostics.framework/Versions/A/Libraries/libAWDSupportFramework.dylib
        0x7fff36361000 -     0x7fff36391fff  libtidy.A.dylib (18.2) <1AF8A622-91F8-3193-BA3D-CB1A799565A8> /usr/lib/libtidy.A.dylib
        0x7fff36392000 -     0x7fff363b2fff  com.apple.MarkupUI (1.0 - 383.6) <7396A399-E8CE-31B6-8F56-CCCA5BF72669> /System/Library/PrivateFrameworks/MarkupUI.framework/Versions/A/MarkupUI
        0x7fff363b3000 -     0x7fff363c6fff  com.apple.Engram (1.0 - 1) <AED2FFE9-3841-33B1-B552-A75B17A20A3A> /System/Library/PrivateFrameworks/Engram.framework/Versions/A/Engram
        0x7fff363c7000 -     0x7fff363eafff  com.apple.openscripting (1.7 - 190) <A2516A00-ECC2-31F2-9157-90AF9A4C6F56> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/OpenScripting.framework/Versions/A/OpenScripting
        0x7fff363eb000 -     0x7fff363eefff  com.apple.securityhi (9.0 - 55008) <DDAD2F6D-2105-370E-9C96-63ABF95ABF00> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SecurityHI.framework/Versions/A/SecurityHI
        0x7fff363ef000 -     0x7fff363f2fff  com.apple.ink.framework (10.15 - 227) <6177BDED-F304-3EAD-B72E-23A050856753> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink.framework/Versions/A/Ink
        0x7fff363f3000 -     0x7fff363f6fff  com.apple.CommonPanels (1.2.6 - 101) <E6BB8219-34DB-3A11-A3C2-B17AD8E42414> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CommonPanels.framework/Versions/A/CommonPanels
        0x7fff363f7000 -     0x7fff363fefff  com.apple.ImageCapture (1711.5.2 - 1711.5.2) <E3871995-745C-35A8-8B48-647DAAF046E1> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/ImageCapture.framework/Versions/A/ImageCapture
        0x7fff363ff000 -     0x7fff375effff  com.apple.JavaScriptCore (16611 - 16611.3.10.1.6) <E1A54760-8F75-3A78-89F7-232D9EC162E8> /System/Library/Frameworks/JavaScriptCore.framework/Versions/A/JavaScriptCore
        0x7fff3765b000 -     0x7fff3776dfff  com.apple.AVFCapture (1.0 - 82.6) <FA7F06F5-9F18-3DF3-BB00-EA019050812E> /System/Library/PrivateFrameworks/AVFCapture.framework/Versions/A/AVFCapture
        0x7fff3776e000 -     0x7fff37801fff  com.apple.Quagga (47 - 47) <A2CD23BB-59D9-31ED-B980-4CF5379CABDE> /System/Library/PrivateFrameworks/Quagga.framework/Versions/A/Quagga
        0x7fff37802000 -     0x7fff37a4cfff  com.apple.CMCapture (1.0 - 82.6) <DC0EAADD-A8F6-3ECE-8D10-354103DB7767> /System/Library/PrivateFrameworks/CMCapture.framework/Versions/A/CMCapture
        0x7fff37de8000 -     0x7fff37e95fff  com.apple.accounts.AccountsDaemon (113 - 113) <9D7CA3D9-01C2-3D59-9CC7-A37C63C18666> /System/Library/PrivateFrameworks/AccountsDaemon.framework/Versions/A/AccountsDaemon
        0x7fff37e96000 -     0x7fff37e98fff  com.apple.OAuth (25 - 25) <44E3A1F3-08A5-36CB-BB3E-BB1A9BFDCD68> /System/Library/PrivateFrameworks/OAuth.framework/Versions/A/OAuth
        0x7fff38448000 -     0x7fff38457fff  com.apple.HID (1.0 - 1) <2078CFB6-A410-3B7E-B012-AE2BF1A80887> /System/Library/PrivateFrameworks/HID.framework/Versions/A/HID
        0x7fff38458000 -     0x7fff3857ffff  com.apple.QuickLookUIFramework (5.0 - 928.4) <6B0E42FA-C3F3-39CB-A7D0-D1172470B640> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuickLookUI.framework/Versions/A/QuickLookUI
        0x7fff38952000 -     0x7fff389d8fff  com.apple.coredav (1.0.1 - 889) <1B9354FB-A21B-3DC3-B522-6EFC899BBC50> /System/Library/PrivateFrameworks/CoreDAV.framework/Versions/A/CoreDAV
        0x7fff389d9000 -     0x7fff38a2ffff  com.apple.ExchangeWebServices (8.0 - 814.100.1) <01A2D090-AB94-34BF-98E8-1B142DD7EB20> /System/Library/PrivateFrameworks/ExchangeWebServices.framework/Versions/A/ExchangeWebServices
        0x7fff38a30000 -     0x7fff38a70fff  com.apple.MediaServices (1.0 - 1) <F226324E-830D-38BE-A1ED-0EC6A2ED82BB> /System/Library/PrivateFrameworks/MediaServices.framework/Versions/A/MediaServices
        0x7fff38b6c000 -     0x7fff38b6cfff  com.apple.marco (10.0 - 1000) <6E3E4EC3-3DD4-332D-8D0F-DC0F946269CB> /System/Library/PrivateFrameworks/Marco.framework/Versions/A/Marco
        0x7fff38c3f000 -     0x7fff38cadfff  com.apple.Contacts.ContactsUICore (1.0 - 3419.1) <6D0C2E83-AB20-39DF-AA5F-C50AA3966435> /System/Library/PrivateFrameworks/ContactsUICore.framework/Versions/A/ContactsUICore
        0x7fff38d52000 -     0x7fff38d8afff  com.apple.contacts.ContactsAutocomplete (1.0 - 1152.4) <2A0FB524-152A-3539-8613-C04652BC54E0> /System/Library/PrivateFrameworks/ContactsAutocomplete.framework/Versions/A/ContactsAutocomplete
        0x7fff38d8b000 -     0x7fff38d97fff  com.apple.KerberosHelper (4.0 - 1.0) <1C287C65-8440-347F-A77A-E6D51262975D> /System/Library/PrivateFrameworks/KerberosHelper.framework/Versions/A/KerberosHelper
        0x7fff38d98000 -     0x7fff38ddbfff  com.apple.ResponseKit (1.0 - 165.2) <21CE7F8C-F282-3788-80D3-28202C803AC8> /System/Library/PrivateFrameworks/ResponseKit.framework/Versions/A/ResponseKit
        0x7fff38ddc000 -     0x7fff38dfbfff  com.apple.proactive.support.ProactiveEventTracker (1.0 - 294.7) <7AC67187-F443-35EB-B4FF-B59F32DF3D3F> /System/Library/PrivateFrameworks/ProactiveEventTracker.framework/Versions/A/ProactiveEventTracker
        0x7fff3921f000 -     0x7fff3921ffff  com.apple.PhoneNumbers (1.0 - 1) <79C9AAE1-5FEC-3471-8E9D-D39881EDDB19> /System/Library/PrivateFrameworks/PhoneNumbers.framework/Versions/A/PhoneNumbers
        0x7fff39220000 -     0x7fff39227fff  com.apple.URLFormatting (146 - 146.22) <05567C81-E57E-3201-8DB5-9DC03762E7E7> /System/Library/PrivateFrameworks/URLFormatting.framework/Versions/A/URLFormatting
        0x7fff39228000 -     0x7fff39236fff  com.apple.accessibility.AXCoreUtilities (1.0 - 1) <FF5E6B22-0BE8-36A1-90CB-44087715CCCB> /System/Library/PrivateFrameworks/AXCoreUtilities.framework/Versions/A/AXCoreUtilities
        0x7fff39237000 -     0x7fff3924efff  libAccessibility.dylib (2885.49) <0F94A4D4-E4D0-3968-95AF-9A123C5A699E> /usr/lib/libAccessibility.dylib
        0x7fff3924f000 -     0x7fff3b999fff  com.apple.WebCore (16611 - 16611.3.10.1.6) <20CBDB85-8A66-3999-9C7C-45403F05958D> /System/Library/Frameworks/WebKit.framework/Versions/A/Frameworks/WebCore.framework/Versions/A/WebCore
        0x7fff3ba66000 -     0x7fff3ba75fff  com.apple.NetFS (6.0 - 4.0) <D628804B-CDCB-3093-A91C-58B0201B5AF1> /System/Library/Frameworks/NetFS.framework/Versions/A/NetFS
        0x7fff3bc89000 -     0x7fff3bcabfff  com.apple.quicklook.QuickLookSupport (1.0 - 135.5) <CB82EDC5-2A69-3F7D-9A79-C4B186D6F807> /System/Library/PrivateFrameworks/QuickLookSupport.framework/Versions/A/QuickLookSupport
        0x7fff3bcac000 -     0x7fff3bd43fff  com.apple.AirPlaySync (1.0 - 2780.10) <FE97137A-017E-392F-9457-1FF0ACB82681> /System/Library/PrivateFrameworks/AirPlaySync.framework/Versions/A/AirPlaySync
        0x7fff3bf73000 -     0x7fff3bf76fff  com.apple.ExceptionHandling (1.5 - 14) <2EBF4791-A234-3CE8-A17E-FD1818C2FDDB> /System/Library/Frameworks/ExceptionHandling.framework/Versions/A/ExceptionHandling
        0x7fff3bf77000 -     0x7fff3bfc5fff  com.apple.Safari.SafeBrowsing (16611 - 16611.3.10.1.6) <5513EB53-B539-3D8D-801D-E64175D3A03C> /System/Library/PrivateFrameworks/SafariSafeBrowsing.framework/Versions/A/SafariSafeBrowsing
        0x7fff3bfc6000 -     0x7fff3c7a5fff  com.apple.WebKit (16611 - 16611.3.10.1.6) <C2B252E6-5870-3B58-B918-03F8307F0729> /System/Library/Frameworks/WebKit.framework/Versions/A/WebKit
        0x7fff3c8d4000 -     0x7fff3c957fff  com.apple.CorePDF (4.0 - 529) <C37DD615-4ABA-314C-985B-7E496184B997> /System/Library/PrivateFrameworks/CorePDF.framework/Versions/A/CorePDF
        0x7fff3c958000 -     0x7fff3c95bfff  com.apple.print.framework.Print (15 - 271) <29E7EB03-0307-35D9-B56F-B9DCB5C5A4E7> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Print.framework/Versions/A/Print
        0x7fff3c95c000 -     0x7fff3c95ffff  com.apple.Carbon (160 - 164) <B86E3835-F4BE-3DCA-88C7-CEA01227DF58> /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon
        0x7fff3ca58000 -     0x7fff3ca58fff  com.apple.avfoundation (2.0 - 2020.10) <DF72C9C0-236F-326C-84C1-E4F25163310D> /System/Library/Frameworks/AVFoundation.framework/Versions/A/AVFoundation
        0x7fff3cc12000 -     0x7fff3cc31fff  com.apple.private.SystemPolicy (1.0 - 1) <8BC55621-1E45-33B3-BCD6-C59F1F390695> /System/Library/PrivateFrameworks/SystemPolicy.framework/Versions/A/SystemPolicy
        0x7fff3cdd5000 -     0x7fff3cdf2fff  com.apple.sidecar-core (1.0 - 231) <D0C9A506-6BF0-3D13-9D10-489BF305CB79> /System/Library/PrivateFrameworks/SidecarCore.framework/Versions/A/SidecarCore
        0x7fff3cdf3000 -     0x7fff3cdf6fff  com.apple.QuickLookNonBaseSystem (1.0 - 1) <6E5DDB55-9CD1-3245-939E-EA4081430444> /System/Library/PrivateFrameworks/QuickLookNonBaseSystem.framework/Versions/A/QuickLookNonBaseSystem
        0x7fff3d209000 -     0x7fff3d20dfff  com.apple.CoreOptimization (1.0 - 1) <65BA73C7-2DEA-3AA9-B59D-750B505B54EA> /System/Library/PrivateFrameworks/CoreOptimization.framework/Versions/A/CoreOptimization
        0x7fff3d20e000 -     0x7fff3d214fff  com.apple.FeatureFlagsSupport (1.0 - 28.60.1) <17CAEB39-7966-34B7-9E1B-55D64289BFAF> /System/Library/PrivateFrameworks/FeatureFlagsSupport.framework/Versions/A/FeatureFlagsSupport
        0x7fff3d385000 -     0x7fff3d39cfff  com.apple.SafariServices.framework (16611 - 16611.3.10.1.6) <4AC4AD2E-B214-3244-B148-200EFBCE6884> /System/Library/Frameworks/SafariServices.framework/Versions/A/SafariServices
        0x7fff3d54f000 -     0x7fff3d55afff  com.apple.MallocStackLogging (1.0 - 1) <DF41452E-DA3E-3F74-9354-6F82BE363DB8> /System/Library/PrivateFrameworks/MallocStackLogging.framework/Versions/A/MallocStackLogging
        0x7fff3d56f000 -     0x7fff3d581fff  libmis.dylib (274.140.2) <570E2D9A-BC76-37F7-8CFC-E18AD5E81CE0> /usr/lib/libmis.dylib
        0x7fff3d59e000 -     0x7fff3d70dfff  com.apple.CoreHandwriting (161 - 1.2) <DF7F9BC6-ACE1-32CE-9E1E-5642832E10E9> /System/Library/PrivateFrameworks/CoreHandwriting.framework/Versions/A/CoreHandwriting
        0x7fff3d70e000 -     0x7fff3d969fff  com.apple.imageKit (3.0 - 1100) <DFD1D9B4-41BE-30F1-A1B8-9925481B5DA2> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/ImageKit.framework/Versions/A/ImageKit
        0x7fff3d96a000 -     0x7fff3da80fff  com.apple.PencilKit (1.0 - 1) <924D651B-8645-3225-9DE4-BDAB27B1DED7> /System/Library/Frameworks/PencilKit.framework/Versions/A/PencilKit
        0x7fff3da81000 -     0x7fff3da92fff  com.apple.sidecar-ui (1.0 - 231) <363E669A-2E00-3EAB-A7F1-E85836913057> /System/Library/PrivateFrameworks/SidecarUI.framework/Versions/A/SidecarUI
        0x7fff3da9e000 -     0x7fff3daa1fff  com.apple.WebInspectorUI (16611 - 16611.3.10.1.6) <D8D7C00F-BE02-3C77-9603-0ECB13AB881D> /System/Library/PrivateFrameworks/WebInspectorUI.framework/Versions/A/WebInspectorUI
        0x7fff3e0b5000 -     0x7fff3e117fff  com.apple.ImageCaptureCore (1711.5.2 - 1711.5.2) <BC3B41E7-DC5A-3611-ACCA-F9827979CA03> /System/Library/Frameworks/ImageCaptureCore.framework/Versions/A/ImageCaptureCore
        0x7fff3e118000 -     0x7fff3e13dfff  com.apple.quartzfilters (1.10.0 - 98) <B4874E51-0832-3240-8972-8375A13D372B> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuartzFilters.framework/Versions/A/QuartzFilters
        0x7fff3e13e000 -     0x7fff3e16afff  com.apple.IntlPreferences (2.0 - 332.3) <0C57D5EC-F963-33FB-A49F-43FE728EC9E5> /System/Library/PrivateFrameworks/IntlPreferences.framework/Versions/A/IntlPreferences
        0x7fff3e16b000 -     0x7fff3e195fff  com.apple.ToneLibrary (1.0 - 1) <CFF9B577-DFDA-3856-B0F7-AC7B0E145914> /System/Library/PrivateFrameworks/ToneLibrary.framework/Versions/A/ToneLibrary
        0x7fff3e389000 -     0x7fff3e4ebfff  com.apple.MediaPlayer (1.0 - 1.0) <C4577D13-9F8E-3AE5-9D3D-A292F2773A82> /System/Library/Frameworks/MediaPlayer.framework/Versions/A/MediaPlayer
        0x7fff3e4ec000 -     0x7fff3e7cdfff  com.apple.iTunesCloud (1.0 - 1) <CAD253D5-9CAC-368A-8EEB-8576B299256F> /System/Library/PrivateFrameworks/iTunesCloud.framework/Versions/A/iTunesCloud
        0x7fff3e7f9000 -     0x7fff3e925fff  com.apple.AnnotationKit (1.0 - 383.6) <D8726DE5-7A61-3562-9A43-5D2F5E861335> /System/Library/PrivateFrameworks/AnnotationKit.framework/Versions/A/AnnotationKit
        0x7fff3e926000 -     0x7fff3edc6fff  com.apple.QuartzComposer (5.1 - 383) <7704093A-6C35-375F-AA17-756FABB66D1D> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuartzComposer.framework/Versions/A/QuartzComposer
        0x7fff3edc7000 -     0x7fff3eeaffff  com.apple.PDFKit (1.0 - 950.40.3) <0538C0CD-02D4-3684-BBD1-AD5C9F861276> /System/Library/Frameworks/PDFKit.framework/Versions/A/PDFKit
        0x7fff409b7000 -     0x7fff409c2fff  com.apple.CaptiveNetworkSupport (13.0 - 1) <B7F41903-09D2-3BED-A223-7D28603816E9> /System/Library/PrivateFrameworks/CaptiveNetwork.framework/Versions/A/CaptiveNetwork
        0x7fff40e0e000 -     0x7fff40e11fff  com.apple.quartzframework (1.5 - 25) <CB57120A-C7D9-3999-9BD4-EB214E8E3CF3> /System/Library/Frameworks/Quartz.framework/Versions/A/Quartz
        0x7fff41236000 -     0x7fff41254fff  libCGInterfaces.dylib (544.4) <05A5B7E9-C79A-3FEA-AD6C-72FE168004C3> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/Libraries/libCGInterfaces.dylib
        0x7fff414cc000 -     0x7fff415e7fff  com.apple.AddressBook.framework (11.0 - 2452.7) <DB29F211-01A7-3C58-9E5E-DB4823738605> /System/Library/Frameworks/AddressBook.framework/Versions/A/AddressBook
        0x7fff415e8000 -     0x7fff415fdfff  com.apple.ToneKit (1.0 - 1) <C1CA9DE4-AD93-30CB-B839-AD2C8FE13979> /System/Library/PrivateFrameworks/ToneKit.framework/Versions/A/ToneKit
        0x7fff428d4000 -     0x7fff43634fff  libfaceCore.dylib (4.3.1) <8014C48B-E6BC-3AEB-BECE-808158C71EEE> /System/Library/Frameworks/Vision.framework/libfaceCore.dylib
        0x7fff43635000 -     0x7fff43748fff  com.apple.TextRecognition (1.0 - 157) <E100917D-A3D9-36B5-A4B0-C0E131045D87> /System/Library/PrivateFrameworks/TextRecognition.framework/Versions/A/TextRecognition
        0x7fff43749000 -     0x7fff43761fff  com.apple.Futhark (1.0 - 1) <ACB352CB-05F6-33DF-884F-97E73913C577> /System/Library/PrivateFrameworks/Futhark.framework/Versions/A/Futhark
        0x7fff437e3000 -     0x7fff43a56fff  com.apple.RawCamera.bundle (9.10.0 - 1450.3) <2F4C79D7-0A8A-3FE3-9A93-74F78774D0BC> /System/Library/CoreServices/RawCamera.bundle/Contents/MacOS/RawCamera
        0x7fff442bf000 -     0x7fff442c3fff  com.apple.DAAPKit (1.0 - 1) <9947BB10-2335-3BB4-B884-9313DC160E59> /System/Library/PrivateFrameworks/DAAPKit.framework/Versions/A/DAAPKit
        0x7fff45c3a000 -     0x7fff45c3dfff  libpmenergy.dylib (227.140.1) <CFCE74A5-EEF8-36E2-9717-8E4B45F2663C> /usr/lib/libpmenergy.dylib
        0x7fff46329000 -     0x7fff46334fff  libGPUSupportMercury.dylib (18.5.9) <ABA75849-7AA3-30E5-A8FB-F440F3F3DAF0> /System/Library/PrivateFrameworks/GPUSupport.framework/Versions/A/Libraries/libGPUSupportMercury.dylib
        0x7fff4795f000 -     0x7fff4799ffff  com.apple.osanalytics.OSAnalytics (1.0 - 1) <19C9EC00-4A56-303C-9C22-47AF6222F1AF> /System/Library/PrivateFrameworks/OSAnalytics.framework/Versions/A/OSAnalytics
        0x7fff481ed000 -     0x7fff48208fff  com.apple.network.statistics.framework (1.2 - 1) <0AFE927D-702D-35F4-8938-BE33B1A95BF6> /System/Library/PrivateFrameworks/NetworkStatistics.framework/Versions/A/NetworkStatistics
        0x7fff5161e000 -     0x7fff516bdfff  com.apple.Symbolication (12.5 - 64544.70.1) <262C27E9-D575-3209-8403-C314C534D1B0> /System/Library/PrivateFrameworks/Symbolication.framework/Versions/A/Symbolication
        0x7fff518ad000 -     0x7fff518b0fff  libpmsample.dylib (227.140.1) <B2B85546-A9D2-3919-A396-63A26011ECAC> /usr/lib/libpmsample.dylib
        0x7fff53cc9000 -     0x7fff53cdefff  com.apple.ScriptingBridge (1.4 - 80) <DB811F94-A71E-3D96-80AC-39BAC84FC3D9> /System/Library/Frameworks/ScriptingBridge.framework/Versions/A/ScriptingBridge
        0x7fff53f45000 -     0x7fff53f7bfff  com.apple.ReplayKit (1.0 - 1) <E308B8DB-49B7-3ACC-B8F3-F2338036684D> /System/Library/Frameworks/ReplayKit.framework/Versions/A/ReplayKit
        0x7fff55572000 -     0x7fff55575fff  com.apple.ForceFeedback (1.0.6 - 1.0.6) <63184EF1-A02C-3D64-A797-15190247C807> /System/Library/Frameworks/ForceFeedback.framework/Versions/A/ForceFeedback
        0x7fff5e13d000 -     0x7fff5eba0fff  libSC.dylib (4.6.20) <C4EEC78B-6BC3-3324-9053-0A68F3F78FD4> /System/Library/Extensions/AMDShared.bundle/Contents/PlugIns/libSC.dylib
        0x7fff6bab9000 -     0x7fff6babffff  libCoreFSCache.dylib (200.11) <3C96E791-3964-32EA-A84A-00DF3455B43D> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreFSCache.dylib
        0x7fff6bac0000 -     0x7fff6bac4fff  libCoreVMClient.dylib (200.11) <966F49F6-D2D5-3ACB-9CFD-9F8D3C8C82F9> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreVMClient.dylib
        0x7fff6bac5000 -     0x7fff6bad4fff  com.apple.opengl (18.5.9 - 18.5.9) <5C26B170-E22B-3AAD-BA33-61304FFA70B2> /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL
        0x7fff6bad5000 -     0x7fff6bad7fff  libCVMSPluginSupport.dylib (18.5.9) <435F258D-95B5-3015-BDAC-4B8EF8E89F1E> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCVMSPluginSupport.dylib
        0x7fff6bad8000 -     0x7fff6bae0fff  libGFXShared.dylib (18.5.9) <851E0956-A16E-3F5D-B3BE-37B56C2BAA04> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGFXShared.dylib
        0x7fff6bae1000 -     0x7fff6bb14fff  libGLImage.dylib (18.5.9) <687EBB15-1AB3-3815-A69D-58527655A92D> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLImage.dylib
        0x7fff6bb15000 -     0x7fff6bb51fff  libGLU.dylib (18.5.9) <29B7802C-F6E4-3DF1-B5D6-07B29C6D02B2> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLU.dylib
        0x7fff6bb52000 -     0x7fff6bce5fff  libGLProgrammability.dylib (18.5.9) <21D16379-6A2F-3F0A-97A8-8EEF7DC8B27B> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLProgrammability.dylib
        0x7fff6bce6000 -     0x7fff6bcf0fff  libGL.dylib (18.5.9) <8A4ED04C-9171-3CE2-A52A-E7C4D76A6EDA> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib
        0x7fff6bcf1000 -     0x7fff6be6efff  GLEngine (18.5.9) <7D972114-11BA-35EE-87DA-52C0693561FC> /System/Library/Frameworks/OpenGL.framework/Versions/A/Resources/GLEngine.bundle/GLEngine
        0x7fff6be6f000 -     0x7fff6be97fff  GLRendererFloat (18.5.9) <736F454D-9C9F-3391-87F7-2EC17581C926> /System/Library/Frameworks/OpenGL.framework/Versions/A/Resources/GLRendererFloat.bundle/GLRendererFloat
        0x7fff6d130000 -     0x7fff6d188fff  com.apple.opencl (4.6 - 4.6) <713206B3-A335-3AC5-B342-4CE16BDF69F4> /System/Library/Frameworks/OpenCL.framework/Versions/A/OpenCL
        0x7fff6d189000 -     0x7fff6d191fff  libcldcpuengine.dylib (2.19) <3C4000BF-F1B6-329B-A698-942E632D9C14> /System/Library/Frameworks/OpenCL.framework/Versions/A/Libraries/libcldcpuengine.dylib
        0x7fff6e0d2000 -     0x7fff6e121fff  ATIRadeonX6000SCLib.dylib (4.6.20) <91646484-7CB1-372B-9AC2-4EB20CE949C7> /System/Library/Extensions/AMDRadeonX6000GLDriver.bundle/Contents/MacOS/ATIRadeonX6000SCLib.dylib
        0x7fff6e232000 -     0x7fff6e239fff  com.apple.agl (3.3.4 - AGL-3.3.3) <EA70EE49-53F9-35B6-A94B-8819CDE98613> /System/Library/Frameworks/AGL.framework/Versions/A/AGL
        0x7fff6e23a000 -     0x7fff6e321fff  com.apple.audio.AVFAudio (1.0 - 477.88) <5FBB7121-7190-317C-8796-4A64EBEE1629> /System/Library/Frameworks/AVFAudio.framework/Versions/A/AVFAudio
        0x7fff6f8a3000 -     0x7fff6f8b5fff  com.apple.CMImaging (1.0 - 82.6) <91AA282D-81A1-34C3-AFF4-887ABA89CCAA> /System/Library/PrivateFrameworks/CMImaging.framework/Versions/A/CMImaging
        0x7fff73bb3000 -     0x7fff73bbefff  com.apple.SymptomAnalytics (1.0 - 1431.140.1) <0818E06C-B5D7-3AF4-AECD-D29EBD8CD508> /System/Library/PrivateFrameworks/Symptoms.framework/Frameworks/SymptomAnalytics.framework/Versions/A/SymptomAnalytics
        0x7fff73dd4000 -     0x7fff73decfff  com.apple.SymptomPresentationFeed (1.0 - 1431.140.1) <39660362-929E-3A0A-A7D0-80C4F437711B> /System/Library/PrivateFrameworks/Symptoms.framework/Frameworks/SymptomPresentationFeed.framework/Versions/A/SymptomPresentationFeed
        0x7fff77964000 -     0x7fff7796bfff  libRosetta.dylib (203.58) <F72C2D50-7279-3497-8A59-56908F9661F3> /usr/lib/libRosetta.dylib
        0x7fff77bd3000 -     0x7fff77cbefff  libcrypto.0.9.8.dylib (80) <32885A0F-F97D-3817-A50E-E53B2207B9CB> /usr/lib/libcrypto.0.9.8.dylib
        0x7fff77fdb000 -     0x7fff78016fff  libssl.0.9.8.dylib (80) <B0B3D5A4-F9F7-3C44-B177-D6D784174D67> /usr/lib/libssl.0.9.8.dylib
        0x7fff7807e000 -     0x7fff780d1fff  libstdc++.6.dylib (104.1) <665B8A03-3510-34C4-A3D9-3E73CEAA8BC3> /usr/lib/libstdc++.6.dylib
    External Modification Summary:
      Calls made by other processes targeting this process:
        task_for_pid: 0
        thread_create: 0
        thread_set_state: 0
      Calls made by this process:
        task_for_pid: 0
        thread_create: 0
        thread_set_state: 0
      Calls made by all processes on this machine:
        task_for_pid: 0
        thread_create: 0
        thread_set_state: 0
    VM Region Summary:
    ReadOnly portion of Libraries: Total=2.1G resident=0K(0%) swapped_out_or_unallocated=2.1G(100%)
    Writable regions: Total=13.0G written=0K(0%) resident=0K(0%) swapped_out=0K(0%) unallocated=13.0G(100%)
                                    VIRTUAL   REGION
    REGION TYPE                        SIZE    COUNT (non-coalesced)
    Accelerate framework               384K        3
    Activity Tracing                   256K        1
    CG backing stores                 11.2M       12
    CG image                            32K        2
    CoreAnimation                       60K        8
    CoreGraphics                        16K        3
    CoreServices                       624K        2
    CoreUI image data                  560K        5
    Foundation                          16K        1
    Kernel Alloc Once                    8K        1
    MALLOC                             2.1G      268
    MALLOC guard page                   48K       10
    MALLOC_LARGE (reserved)          500.0M        1         reserved VM address space (unallocated)
    MALLOC_MEDIUM (reserved)           1.4G       14         reserved VM address space (unallocated)
    MALLOC_NANO (reserved)           256.0M        1         reserved VM address space (unallocated)
    OpenCL                            35.9M        6
    OpenGL GLSL                        256K        3
    STACK GUARD                       57.4M      347
    Stack                            225.7M      347
    VM_ALLOCATE                        8.2G      268
    VM_ALLOCATE (reserved)           289.0M       73         reserved VM address space (unallocated)
    __DATA                           151.0M      977
    __DATA_CONST                      30.1M      342
    __DATA_DIRTY                      1858K      226
    __FONT_DATA                          4K        1
    __GLSLBUILTINS                    5176K        1
    __LINKEDIT                       901.9M      323
    __NV_CUDA                         1172K        1
    __OBJC_RO                         70.3M        1
    __OBJC_RW                         2496K        2
    __TEXT                             1.2G      816
    __UNICODE                          588K        1
    mapped file                      429.4M       69
    shared memory                     2876K       26
    TOTAL                             15.8G     4162
    TOTAL, minus reserved VM space    13.4G     4162
    Model: MacPro7,1, BootROM 1554.140.20.0.0 (iBridge: 18.16.14759.0.1,0), 12 processors, 12-Core Intel Xeon W, 3.3 GHz, 96 GB, SMC
    Graphics: AMD Radeon Pro W5700X, AMD Radeon Pro W5700X, spdisplays_pcie_device, 16 GB
    Memory Module: Slot 3 (Channel E / DIMM 1), 16 GB, DDR4 R-DIMM, 2933 MHz, Samsung, M393A2K43CB2-CVF
    Memory Module: Slot 4 (Channel E / DIMM 2), 8 GB, DDR4 R-DIMM, 2933 MHz, Micron, 9ASF1G72PZ-2G9E6
    Memory Module: Slot 5 (Channel D / DIMM 1), 16 GB, DDR4 R-DIMM, 2933 MHz, Samsung, M393A2K43CB2-CVF
    Memory Module: Slot 6 (Channel D / DIMM 2), 8 GB, DDR4 R-DIMM, 2933 MHz, Micron, 9ASF1G72PZ-2G9E6
    Memory Module: Slot 7 (Channel A / DIMM 2), 8 GB, DDR4 R-DIMM, 2933 MHz, Micron, 9ASF1G72PZ-2G9E6
    Memory Module: Slot 8 (Channel A / DIMM 1), 16 GB, DDR4 R-DIMM, 2933 MHz, Samsung, M393A2K43CB2-CVF
    Memory Module: Slot 9 (Channel B / DIMM 2), 8 GB, DDR4 R-DIMM, 2933 MHz, Micron, 9ASF1G72PZ-2G9E6
    Memory Module: Slot 10 (Channel B / DIMM 1), 16 GB, DDR4 R-DIMM, 2933 MHz, Samsung, M393A2K43CB2-CVF
    AirPort: spairport_wireless_card_type_airport_extreme (0x14E4, 0x7BF), wl0: Aug 10 2021 20:10:47 version 9.30.444.18.32.5.71 FWID 01-30b2601e
    Bluetooth: Version 8.0.5d7, 3 services, 27 devices, 1 incoming serial ports
    Network Service: Ethernet 2, Ethernet, en1
    Network Service: Wi-Fi, AirPort, en2
    PCI Card: AMD Radeon Pro W5700X, gpu-controller, Slot-1@9,0,0
    PCI Card: pci1002,ab38, sppci_audiodevice, Slot-1@9,0,1
    PCI Card: pci1b21,625, sppci_ahci, Thunderbolt@29,0,0
    PCI Card: XHC4, sppci_usbxhci, Thunderbolt@200,0,0
    PCI Card: pci137a,8, sppci_audio, Thunderbolt@57,0,0
    PCI Card: XHC2, sppci_usbxhci, Thunderbolt@83,0,0
    PCI Card: pci8086,15eb, sppci_thunderbolt, Thunderbolt@201,0,0
    PCI Card: pci8086,15eb, sppci_thunderbolt, Thunderbolt@84,0,0
    PCI Card: XHC3, sppci_usbxhci, Thunderbolt@24,0,0
    PCI Card: pci8086,15eb, sppci_thunderbolt, Thunderbolt@25,0,0
    Serial ATA Device: G-RAID  with Thunderbolt, 16 TB
    USB Device: USB 3.0 Bus
    USB Device: USB3.0 Hub
    USB Device: G-DRIVE USB
    USB Device: Elements 25A3
    USB Device: d2 TBT2 USB 3.0
    USB Device: Backup+  Desk M
    USB Device: USB2.0 Hub
    USB Device: iLok
    USB Device: USB-Serial (0001)
    USB Device: USB 2.0 Hub [MTT]
    USB Device: USB-C dongle
    USB Device: d2 Professional
    USB Device: Apple T2 Bus
    USB Device: Headset
    USB Device: Apple T2 Controller
    Thunderbolt Bus: Mac Pro, Apple Inc., 63.3
    Thunderbolt Device: G-RAID Thunderbolt 3 USB 3.1, G-Technology, 1, 25.2
    Thunderbolt Device: 8M, MOTU, 3, 7.7
    Mac Pro, 3.7 GHz Quad-core, 64GB RAM, G-Tech G-RAID Studio 6TB and 10TB etc. [view my complete system specs]
  • Mon, Jan 24 2022 4:35 PM In reply to
    Re: DISK_LOCKED errors and MC crashes
    Try disabling the timemachine.
    When it is active and it tries to create one, I have this Disk locked error too!
    You could use an app called timemachineeditor to change when timemachine starts backing up.
    Hope this helps,
    Jasper
    Mac Studio M1 Apple M1 Max, 64Gb, Blackmagic Ultrastudio Monitor 3G Mac Pro late 2013 3,5 Ghz 6-Core, 64Gb, Blackmagic Ultrastudio Express Macbook... [view my complete system specs]
Page 1 of 1 (11 items)
