Latest post Fri, Sep 24 2021 5:01 PM by Rob. 3 replies.
  • Fri, Sep 24 2021 2:14 PM
    • Rob
    • Joined on Thu, Nov 11 2010
    • NYC
    • Posts 143
    • Points 1,795
    Effect Editor Disappearing
    Hey all,
    From time to time my effect editor tab will disspear from my saved bin layouts. It's back again. After trying over and over to drag the window to my tab and saving the bin layout and setting. It still dissapears.
    I tried a different user setting and the same issue is happening. I also trashed the MCState file in my setting folder to see if that helped and it didn't.
    Any suggestions?
    MC 2020 HP Z8 / 192gb / NVIDIA Quadro RTX 6000 / Artist DNXiQ HP z820 / 64gb / NVIDIA M5000 MBPro / 64gb / Intel UHD Graphics 630 1536 MB [view my complete system specs]
  • Fri, Sep 24 2021 3:33 PM In reply to
    Re: Effect Editor Disappearing
    Have you tried saving the workspace as well as the bin layout? That's what I'd try next.
    Media Composer 2022.7 w/Symphony/SS/PF options, HP Z-Book G6 17", i7-9850H 2.60GHz, 32gb RAM, NVIDIA Quadro RTX 3000, Blackmagic UltraStudio Mini... [view my complete system specs]
  • Fri, Sep 24 2021 3:38 PM In reply to
    • BarkinMadd
    • Ontario, Canada
    • Posts 4,818
    • Points 63,185
    I believe this is a known defect. It will happen intermittently when you click on the timeline ruler, for example. There is a setting to exit effect editor mode when clicking on the timeline ruler (enabled by default) but the effect of exiting the effect mode shouldn't also close your effect editor tab.
    MC 2021.6 | QT 7.7.9 | Continuum 2021 | Sapphire 2021 | Mocha Pro 2021 | Titler Pro 7.7 | Windows 10 Pro x64 (21H1) | System: Asus x299, i9-7940X (4.1GHz... [view my complete system specs]
    Steve
    ______________________
    www.nelliedogstudios.com
  • Fri, Sep 24 2021 5:01 PM In reply to
    • Rob
    • NYC
    • Posts 143
    • Points 1,795
    I did try saving the workspace and it still doesn't stick.
    If I bring the Effect Editor as it's own window, it won't dissappear. Only when it's in a tab. It was working smoothly for a few months in my bin tab, then there was an Avid crash and my settings probably got all screwey. Now if I set it into a bin tab, the second I'm not using the effect editor it dissappears.
