Latest post Mon, Sep 27 2021 11:23 AM by ripvanmarlowe. 6 replies.
Page 1 of 1 (7 items)
  • Sat, Sep 18 2021 10:19 PM
    • Ssnygg
    • Joined on Tue, Apr 11 2006
    • Allentown PA
    • Posts 411
    • Points 4,935
    "Too long to be played" error
    I put together a bunch of Audio clips imported from one card and I got the error "The sequence or one of it source elements is too long to be played"
    I cut the timeline down and things started playing, but I wan't able to figure out what the limiting factor is for future projects.
    Is it 12 hours?  If so, why?  Time code goes up to one frame shy of 24 hours.
    What about for the raw footage?  Is that also 12 hours?  If I get footage from a live feed that is say... 3 days long,will it play in the preview monitor?  If not, how would I edit it?  Cut randomly at the twelve hour mark and make subclips?  Can I make sublicps from something where the origianl footage is over 12 hours?   Is footage that is over 12 hours entirely unusable?
    I have several systems. 1-Media Composer ver 5 1-Media Composer 2021.6 on Win 10 1-mac Express 2.2 AB/VB Targa set up The computers I use include: 1-Intel... [view my complete system specs]
  • Sun, Sep 19 2021 12:35 AM In reply to
    • jef
    • Joined on Sun, Feb 26 2006
    • Maryland
    • Posts 4,181
    • Points 50,460
    Re: "Too long to be played" error
    Check to see if you have any clips where the time code goes over the 24 hour mark back to 00:00:00:00.
    Jef
    Avid DS 11.0.2 R.I.P | MC "Well, it depends ..." 2023.3.1 iMac w Big Sur and 2018.12.7 on Windows 10 Boot Camp [view my complete system specs]
    Jef Huey
  • Sun, Sep 19 2021 3:54 PM In reply to
    • Ssnygg
    • Allentown PA
    • Posts 411
    • Points 4,935
    None of them do, but I can see how that would create a problem.  Thanks for the heads up.
    That's an interesting point.  If you are shooting a concert or something and you are using true time time-code to synch all of your camras, what do you do if you go past midnight?   The clips might be only five minutes long, but you might run into this error.   Do you have to use another app to sycnch the clips and rewrite the timecode?
  • Mon, Sep 20 2021 8:39 AM In reply to
    Ssnygg:
    I've done multi camera shoots over midhinght. You just chose freerun TC but set it to start at a different hour like 01:00:00:00
    If knowing the relationship to realtime is important then make sure the minutes seconds match realtime just offset the hours.
    Re the sequence length what was your sequence start timecode? If it was 10:00:00:00 then you have already used 10 hrs up.
    T 07581 201248 | E [email protected]
  • Mon, Sep 20 2021 9:48 AM In reply to
    Turn on PlayLength Toggle and this error should go away. You can find this in the command pallet under the "Play" tab. Drag the toggle button to one of your record side buttons and click it to activate it. This makes Avid only look a certain amount before and after the play head so it won't notice that you have a 24 hour long timeline.
    Andi
    HP ZBook G6 15 2.6Ghz 6-core i7 9th Gen Nvidia Quadro T2000 4GB 64GB RAM Win 10 Pro MC Ultimate 2022.10 MacbookPro 15 2019 6 core 2.6GHz i9 32GB... [view my complete system specs]
  • Mon, Sep 27 2021 1:33 AM In reply to
    • Ssnygg
    • Allentown PA
    • Posts 411
    • Points 4,935
    @Pat Horrige and @ripvanmarlowe
    Great ideas!! Thanks!
    Do we know thie limitations of time?  Is it 12 hours or was that just my experience?
  • Mon, Sep 27 2021 11:23 AM In reply to
    I seem to remember it being 12 hours but if you need to know then just whack down 11 hours and 59 minutes of footage and then 12 hours and one minture of footage and see what happens.
    Andi
