Latest post Sun, Dec 11 2022 10:03 PM by Philip Kapadia. 11 replies.
Page 1 of 1 (12 items)
  • Sat, Aug 14 2021 9:20 AM
    • TJGood
    • Joined on Sat, Aug 14 2021
    • Posts 2
    • Points 30
    IO suggestions
    I'm Running media composer on an HP Z4 G4 and looking to add video and pro audio output to a broadcast monitor. There are quite a few options, with most being overkill. I tend to work with proxies at 1920x1080 and finish elsewhere. Aja, Blackmagic and Avid offer solutions with some being PCIE cards with breakout cables or hardware boxes. For me I'm looking to get an SDI output with balanced audio. I don't need any input. What's the best options considering budget but also solid?
    Thanks guys and gals.
  • Sat, Aug 14 2021 11:07 AM In reply to
    Re: IO suggestions
    I reccomend Aja Kona Lhi.
    5 Year guaranty, even if purchased second hand.
    My ebay purchase cost me £120.
    Symphony 2018.12.13 Mac Pro 2x2.66 6-core 32GB Ram Aja Kona Lhi. MC 2018.12.13 OS 10.13.4 Mac Pro 5.1 2x2.97 6-core 32GB ram Aja Kona 4, SNS SANmp 2x Infortrend... [view my complete system specs]
  • Sat, Aug 14 2021 12:38 PM In reply to
    Re: IO suggestions
    I second Aja. Kona Lhi (hdmi and sdi) and Lhe plus (only sdi) and if you don't want the cable clutter from the breakout cable, the Aja I/O express.
    One issue with these cards is the small fans going bad and them making a lot of noise.
    Jeroen van Eekeres
    www.mediaoffline.com
  • Sat, Aug 14 2021 6:48 PM In reply to
    • TJGood
    • Posts 2
    • Points 30
    Re: IO suggestions
    Thanks for the suggestions. Am I right in thinking most of the legacy gear still works? Like the Nitris?
    thanks
  • Sat, Aug 14 2021 8:21 PM In reply to
    Re: IO suggestions
    Not really, DX is end of life and I don't think there are DX drivers that work under Catalina/Big Sur and there have been issues with Win 10 updates as well.
    Media Composer Symphony | PT Ultimate | Win11 HPZ | OSX MBP [view my complete system specs]
  • Sun, Aug 15 2021 10:49 AM In reply to
    Re: IO suggestions
    Am I wong in thinking if you want to use Resolve then you will be forced to buy a Blackmagic card? I thought they had locked it to their own hardware for mointoring? Happy to be proved wrong on this
    Andi
    HP ZBook G6 15 2.6Ghz 6-core i7 9th Gen Nvidia Quadro T2000 4GB 64GB RAM Win 10 Pro MC Ultimate 2022.10 MacbookPro 15 2019 6 core 2.6GHz i9 32GB... [view my complete system specs]
  • Sun, Aug 15 2021 3:42 PM In reply to
    Re: IO suggestions
    You are right, but some of us actually still use the crippled old Colour Correction tool.
    Smile
  • Sun, Aug 15 2021 8:36 PM In reply to
    Re: IO suggestions
    David Yardley:
    Smile
    Try Filmlight's Baselight if you can. It does everything what resolve can do... in MC!!
    Life saver :)
  • Fri, Dec 2 2022 2:37 PM In reply to
    • Mercer
    • Joined on Thu, Apr 15 2010
    • UK
    • Posts 873
    • Points 11,290
    Re: IO suggestions
    Philip Kapadia:
    I recently bought Baselight Editions, mainly because I acquired an Artist Color panel for Resolve, where it works well but was horrified to see how bad it worked in Symphony, even though I'd been warned! How can Filmlight do a so much better job than Avid of ethernet control, with Avid's own hardware/software?
    I also remembered you raving about it PhilipBig Smile and I now do see it used more and more by clients - Symphony is becoming a dead man walking for finishing. It's a joy to use, directly within Avid, and the Color panel works fantastically in it, and it can do everything colour grading wise that Resolve can do, much more straight forwardly IMV too, since I prefer layers to nodes. But it does lack Resolve's huge selection of FX, online and restoration plugins, available directly on the Color page.
    There's a few slight user niggles for me too: It is a bit laggy in playback, due to the ancient AVX structure. It's slightly annoying you have to remove and add the Color panel from Eucontrol too, to switch between Resolve and Avid and there is no way to use it in Avid outside of BE (no great loss there though); and hopefully V6 will enable you to use the interface across 2 monitors, since it gets a bit cramped on one.
    On the whole though it's now joined my 2 software strategy, going forward; Avid, Resolve Studio and now BEYes
    MC with Symphony option, 2022.10, HP ZBook 17 G5, i7-8850H 6 core/64GB ram/512 M2 ssd/Nvidia Quadro P5200/16GB/FHD, HP Thunderbolt Dock G2, BMD Ultrastudio... [view my complete system specs]
  • Sun, Dec 4 2022 12:29 PM In reply to
    Re: IO suggestions
    Hi Mercer, Hope you're well.
    Mercer:
    Philip Kapadia:
    told you Stick out tongue
    Yes, Perhaps I was a little premature when I said you can do everything in resolve in baselight because reflecting back on that now that's not strictly true...
    At the time I was mostly finishing low end TV work in HD. I also had a lot of archive work like this which was all in SD. Most of this work was just 'correcting' rather than 'grading'. In those instances when working with mezzanine level, transcoded SD - HD material, Avid's playback architecture and the AVX plugin limitations were workable.
    However I now find myself working more and more on 4K projects, even 6K projects, HDR. Things like music videos, cinema work, etc. In this scenario where clients and particularly real colourists (not me) want to be working with camera original media rather than mezzanine transcodes, Avid just can't playback those files through baselight no matter the system. So resolve is the obvious choice there.
    Likewise the integration with fusion, easier tracking, title tool within resolve all helps speed things along at the online stage.
    I still dispute that you can do all in resolve in symphony. Can you track a secondary correction mask around a moving object? I still consider that to be part of the 'grading' stage.
    Wouldn't it be nice if Avid intergrated baselight into a panel? Like they did with melodyne and ProTools ;)
  • Sun, Dec 4 2022 1:48 PM In reply to
    • Mercer
    • UK
    • Posts 873
    • Points 11,290
    Re: IO suggestions
    Philip Kapadia:
    Ha ha
    Philip Kapadia:
    No you're right again, my young friend. Avid tracking is abysmmal. You can just about work Symphony still for finishing but as I say it's a dead man walking. However Dave said they have plans for it. Just hope I haven't wasted a grand or soHuh? But somehow I don't think soWink Have you tried the Avid Colour with BE, Philip? Might be worth a look at, they are cheap on eBay and I am suitably impressed.
  • Sun, Dec 11 2022 10:03 PM In reply to
    Re: IO suggestions
    Mercer:
    Philip Kapadia:
    Ha ha
    Philip Kapadia:
    Sorry for my slow response... work means I can't be here as much as I used to
    No, I haven't tried the Artist Colour. I don't do enough colour work to justify it. I'm more into Audio, so I have the Artist Mix.
    I find with the little colour work I do, my Wacom works well enough for me
