Latest post Thu, Aug 5 2021 5:07 PM by Pulck. 14 replies.
Page 1 of 1 (15 items)
  • Wed, Aug 4 2021 3:07 PM
    • Pulck
    • Joined on Fri, May 26 2006
    • London, UK
    • Posts 175
    • Points 2,320
    Filename changes cause AMA link issues
    I've been running into this issue for years and wondered if there's a workaround or at least an explanation.
    Let's say I have a QuickTime file that I want to AMA link and transcode. However, the filename isn't very helpful so I rename it at desktop level first and then I go into MC to AMA link it.
    Most of the time this works fine. But sometimes MC gives me the "MEDIA OFFLINE" screen and I can only get it to see the file after rebooting or after many attempts.
    Other times it weirdly somehow remembers the old filename before I renamed it!
    I'm using MC 2018.12. Any ideas?
  • Wed, Aug 4 2021 7:41 PM In reply to
    Re: Filename changes cause AMA link issues
    IF MC has handled that file at all it will try and stick with the original file name. Turning off managed AMA may help here.
  • Wed, Aug 4 2021 9:06 PM In reply to
    • Pulck
    • London, UK
    • Posts 175
    • Points 2,320
    Thanks, Pat. That sounds like a bug to me.
    Do you mean Linked Media Management in the Link settings?
    I just checked and this was already disabled.
  • Wed, Aug 4 2021 9:24 PM In reply to
    Pat Horridge:
    I wanna try it... how is that done, Pat?
    -Telegram!
  • Thu, Aug 5 2021 10:40 AM In reply to
    • Bruno M
    • Joined on Thu, Feb 11 2010
    • London, UK
    • Posts 920
    • Points 11,770
    Pat Horridge:
    This may also happen if you have it set so that any drive you plug in will be scanned automatically.
    You'll find these settings in Link/Volume Mounting
    HP Z800, HP G3 Studio, SonnetFusion RAID, Mojo DX, Decklink 4K, Symphony 2020, JVC DTV1910 HD tube monitor, HP Dreamcolor, Avid Artist Color, Avid Transport... [view my complete system specs]
  • Thu, Aug 5 2021 10:54 AM In reply to
    • Pulck
    • London, UK
    • Posts 175
    • Points 2,320
    Bruno M:
    Pat Horridge:
    Thanks. That's the "Enable Linked Media Management" setting in the Link Settings, isn't it? I've got that one turned off already.
    If I simply rename an AMA-linked clip to the correct filename, does that cause any problems later on with the conform?
  • Thu, Aug 5 2021 11:11 AM In reply to
    • Bruno M
    • London, UK
    • Posts 920
    • Points 11,770
    Pulck:
    Yes, I believe that's the one.
    You'll probably want to turn the 'auto linking to volumes' off as well
    Pulck:
    This can be a more complicated issue, depending how you relink back to original rushes (if you're working in a proxy workflow). If your rushes have metadata that has roll/reel names or Source file ID, the actual filename may not matter.
  • Thu, Aug 5 2021 11:19 AM In reply to
    • Pulck
    • London, UK
    • Posts 175
    • Points 2,320
    Bruno M:
    Yeah, that's already off too.
    Bruno M:
    Pulck:
    With my current remote workflow, I'm not ingesting the camera rushes. That's done by a post house and the proxies are sent to me.
    The stuff I'm AMA linking and transcoding is archive clips, generally MOVs or MP4s. So I thought renaming the Avid clips to mirror the correct filename might actually help in the conform...?
  • Thu, Aug 5 2021 12:00 PM In reply to
    • Bruno M
    • London, UK
    • Posts 920
    • Points 11,770
    Pulck:
    I'm surprised if the post house hasn't discussed the workflow and conform with you.
    There's many things that can potentially upset a successful conform, and renaming clips could be one of them. If you do a search of relinking problems on these forums, you'll see what I mean.
    Generally, I've found that if you link all your rushes and transcode (to a proxy format) in MC, the resultant AAF is able to relink to camera originals in something like Resolve.
    Where proxies are created outside Avid, or files are renamed, there's the potential for trouble. I've always recommended to my students (who often use multiple bits of software in their projects) that they do a test round-trip to make sure there's a trouble-free experience with the whole proxy-edit-conform-grade workflow.
  • Thu, Aug 5 2021 12:15 PM In reply to
    • Pulck
    • London, UK
    • Posts 175
    • Points 2,320
    Bruno M:
    Pulck:
    Well the project has changed since I first started it months ago. There's a lot more archive in it than I expected so I didn't forewarn the post house. But point taken. The pandemic has made me into my own edit assistant.
    I'm guessing more than 90% of clips work absolutely fine and I haven't renamed anything in Avid, so hopefully I haven't caused too many issues further down the line.
  • Thu, Aug 5 2021 12:17 PM In reply to
    Remember the avid clip names are user definable. They initially are formed from the fileneames (unless the metadata from the camera has already set the clip name)
    Once ingested Avid doesn't care about clip names. The source path and source file columns hold that actual source file name and the original source path. These are whats used for the conform.
    So renaming a clip in Avid is a normal editing process. Renaming source files is a big no no.
    If a clip has to be renamed then it must be done before that file is used in any way in the post process.
    So an archive clip may have an illigal character in it. So it could be renamed before being ingested.
    A source file thats already be transcoded and that media used should never be renamed.
  • Thu, Aug 5 2021 1:31 PM In reply to
    • Pulck
    • London, UK
    • Posts 175
    • Points 2,320
    Pat Horridge:
    Thanks. I never rename the desktop/source files after I've imported. I know that's a big no-no.
    Going back to my original post, the issue is that Avid sometimes imports AMA-linked clips with an old filename. How or why it does this I have no idea. I consider that a bug. But if it's not a problem, I'm happy.
  • Thu, Aug 5 2021 1:46 PM In reply to
    • BarkinMadd
    • Ontario, Canada
    • Posts 4,818
    • Points 63,185
    Pulck:
    I've seen this, too - somehow MC figures out the original filename from its managed media database for AMA linked media. If you disable AMA managed media it won't do this. I've never understood when to use (or when to disabled) AMA managed media (it's enbled by default).
    MC 2021.6 | QT 7.7.9 | Continuum 2021 | Sapphire 2021 | Mocha Pro 2021 | Titler Pro 7.7 | Windows 10 Pro x64 (21H1) | System: Asus x299, i9-7940X (4.1GHz... [view my complete system specs]
    Steve
    ______________________
    www.nelliedogstudios.com
  • Thu, Aug 5 2021 3:21 PM In reply to
    Thats correct AMA linking a clip results in Avid checking its AMA managed databases to see if its seen that cliop before (and somehow it works that out using data other than the file name) If it has it links it but retains the original source file name and a previous path. So if you AMA link a file and then delete the master clip in Avid, then move the source file and AMA link you will see the original source path listed.
    If you have Avid set to auto mount drives in Link/Volume Mounting then just pluging a drive in is enough for Avid to "see" that file and remember it.
    AMA management has very few advantages (it does let you see AMA linked files in the media tool) and plenty of gotchas. SO I ensure I have it off as well as turning off the volume mounting automatically.
    You can even locate the AMA managed folders at C:\Users\Public\Documents\Avid Media Composer\AMA Management
    and delete them to clear out Avid memory of AMA linked media (this shouldn't effect AMA links already in projects)
  • Thu, Aug 5 2021 5:07 PM In reply to
    • Pulck
    • London, UK
    • Posts 175
    • Points 2,320
    Pat Horridge:
    Thank you, Pat. That's very clear.
    Just one thing. In my experience, even if I change a filename BEFORE any attempt to AMA link it, Avid will AMA link it with its old filename. It's as if it scans the directory in the background and decides what the filenames are going to be before you attempt to AMA link. Getting it to accept the new filename is sometimes impossible.
    I appear (through accident rather than choice) to have always had Automatic Volume Linking and Linked Media Management switched off, so I don't understand how this can have occurred.
    Anyway, I least I understand it better now.
