Latest post Wed, Jul 21 2021 3:58 AM by Dom Q. Silverio. 3 replies.
  • Mon, Jul 19 2021 9:49 PM
    • binba
    • Joined on Mon, Jan 15 2007
    • Posts 57
    • Points 735
    Used space vs. used space
    I just pulled a snapshot report on our Nexis.
    If I sum up all the used space in all workspaces = 286TB
    Looking at the Storage Groups console page, used = 365TB
    Please explain the discrepancy. Does the workspace calculation not take into account actual space usage as per the 4MB blocks, whereas the Storage Groups numbers do?
  • Mon, Jul 19 2021 10:38 PM In reply to
    • BobRusso
    • New Jersey
    • Posts 2,374
    • Points 29,545
      Moderator: Avid ISIS
      Moderator: Avid NEXIS PRO
    Re: Used space vs. used space
    Just to explain how file size works on NEXIS.
    With a Scale Out storage group the smallest block is 512KB and 1024KB with High Performance Storage Group.
    With a scale out storage group if the file is 512KB or less it will use 512KB on the disk.
    Then the protection is added to this. As a rule, 2 Disk Protection on disk is best case is 20% for parity on all large files. For files, less than 512KB size it can be as much as 66%.
  • Wed, Jul 21 2021 3:22 AM In reply to
    • binba
    • Posts 57
    • Points 735
    Hi Bob,
    Thank you, I'm aware of all that, but it doesn't address my question?
    As said, Nexis is reporting 2 different sizes - the question is about the discrepency between those 2 Nexis' own reports.
    I did happen to run across a post of yours from 2015: "The difference you’re seeing is the available space from small files that don’t use an entire chunk being added as available, when in fact they aren’t available to store files." This was about ISIS, SNMP and ASM.... but maybe it's the same answer to this. Maybe not, hence me asking. :)
  • Wed, Jul 21 2021 3:58 AM In reply to
    Workspace used space column does not account for parity usage and block waste.
    MC 2021.3, W10, MSI X299M, Intel 9940X, Gigabyte 2080Ti Waterforce, 64GB RAM, Samsung 970 EVO M.2 SSD, BM Mini monitor & Dell UP2718Q. MBP 2012 Thunderbolt... [view my complete system specs]
