Latest post Thu, Jul 15 2021 2:45 PM by ripvanmarlowe. 2 replies.
  • Thu, Jul 15 2021 8:56 AM
    Mocha Pro 2021
    Hi all,
    I'm thinking of buying Mocha plugin for AVid so i don't have to keep jumping out to After Effects.
    There seems to be a couple of options online; Mocha 2020 on the Avid website and Mocha 2021 on the Boris website... are they essentially the same software jst Mocha 2021 is the most recent update?
    Michael
  • Thu, Jul 15 2021 1:17 PM In reply to
    • BarkinMadd
    • Ontario, Canada
    • Posts 4,818
    • Points 63,185
    Re: Mocha Pro 2021
    Check out the BorisFX website to see the new features of Mocha Pro 2021.
    Out of curiosity, how do you intend to use Mocha Pro within Media Composer (i.e., what features of Mocha Pro do you use in After Effects)?
    You should be able to run a trial mode of Mocha Pro in Media Composer just to make sure it does everything you need.
    Cheers
    MC 2021.6 | QT 7.7.9 | Continuum 2021 | Sapphire 2021 | Mocha Pro 2021 | Titler Pro 7.7 | Windows 10 Pro x64 (21H1) | System: Asus x299, i9-7940X (4.1GHz... [view my complete system specs]
    Steve
    ______________________
    www.nelliedogstudios.com
  • Thu, Jul 15 2021 2:45 PM In reply to
    Re: Mocha Pro 2021
    Buy it from Boris not Avid. Might as well go to the source. I have it and love it, use it a lot for stabilising things Avid can't, use it a LOT for it's integration with the Witness protection Continuum plugin effect - it's tracking is soooo much smoother than Avids and the results are far, far better. I also think, if you can put the time in to learn it, the remove module is close to magic. Combined with some basic photoshop you can remove things that you could only dream of removing in MC. If you're doing any sort of onlining then it is very worth it.
    Andi
    HP ZBook G6 15 2.6Ghz 6-core i7 9th Gen Nvidia Quadro T2000 4GB 64GB RAM Win 10 Pro MC Ultimate 2021.12 MacbookPro 15 2019 6 core 2.6GHz i9 32GB... [view my complete system specs]
