Latest post Tue, Jan 25 2022 6:56 PM by dkeeling. 7 replies.
  • Sun, Jun 20 2021 5:19 AM
    MC 2021.6 Unable to Edit Effects
    After updating to MC 2021.6 on macOS 11.4 (Big Sur) clicking into Effects mode produces a blank Effects Editor window.  If I restore the default workspace, I am able to edit the effect.  Click out of it, though, and the issue returns.
    Media Composer 2021.12.1 w/Symphony | macOS 12.2.1 | iMac 2017 (Retina 5K, 27-inch) 4.2 GHz Intel Core i7 | 40 GB 2400 MHz DDR4 | TerraMaster 16TB external... [view my complete system specs]
  • Sun, Jun 20 2021 7:45 AM In reply to
    Re: MC 2021.6 Unable to Edit Effects
    Have you tried creating new user settings.
  • Sun, Jun 20 2021 2:27 PM In reply to
    Pat Horridge:
    That's a good idea, but alas, that does not solve the issue.
  • Mon, Jun 21 2021 9:21 AM In reply to
    • MikeyB
    • Edlesborough, UK
    • Posts 607
    • Points 7,590
    Thre has been a couple of changes to the way Workspaces behave in 2021.6 which have caused this.
    Firstly, "clicking away" from an effect - onto the TC track, for example - now closes the Effect Editor in the Effects workspace, whereas it used to leave it open but go blank. You are, however, still in the Effects Workspace.
    This then combines with an Interface setting that has been introduced to allow you to choose how Workspaces are recalled.
    The default, Load the last known state, means that even if you reselect the Effects workspace, it is recalled as you last left it, with no Effect Editor displayed. So now you can't re-edit your effect...
    This is an example of the law of unintended consequences kicking in!
    Alt/clicking the Effects Workspace will bring you back to the Saved state - ie Default - so brings the Effect Editor back. Or selecting "Load the last saved state" makes MC work as it used to previously.
    The intention of this change was to make Workspaces work "Premiere" style, and in the main it's welcome, I think, but this aspect of it is not helpful!
    2021 MacBook Pro 16" (M1 Max 32GB), 2019 iMac 27" (8-core i9, 40GB) [view my complete system specs]
  • Wed, Jun 23 2021 5:31 AM In reply to
    Thanks for the information regarding the redesigned workspaces in Media Composer.  It is my understanding that if you select a clip that has an effect applied to it and then enter Effects mode, the effect or effects are then editable.  That does not happen on my system; the Effects Editor is blank.
  • Wed, Jun 23 2021 9:25 AM In reply to
    • MikeyB
    • Edlesborough, UK
    • Posts 607
    • Points 7,590
    I initially had the same problem you describe with 2021.6. But since fiddling with that Interface setting it has come good, so I think the two are mysteriously related...
  • Sat, Jun 26 2021 2:44 AM In reply to
    Thanks so much!  I've been away for a few days, and only just now had a chance to try that solution.  Selecting "Load the last saved state" in the Interface settings does indeed make the workspaces in MC work as expected.  I'd read that section in the "What's New" documentation, but it didn't make much sense to me... until you explained it.
  • Tue, Jan 25 2022 6:56 PM In reply to
    • dkeeling
    • Chicago
    • Posts 13
    • Points 125
    This really bugged me in 2021.6 and I hoped it would have been fixed in 2021.12 but it hasn't. Please change the default setting to have "Load the last saved state" selected in future releases?
    Media Composer, ProTools [view my complete system specs]
    Dennis Keeling, MFA
    Post Production Manager
    Cinema and Television Arts
    Columbia College Chicago
    Phone 312-369-6768
    Fax 312-369-8044
    www.colum.edu/ctva
