Latest post Mon, Jun 7 2021 12:33 PM by RickP. 12 replies.
Page 1 of 1 (13 items)
  • Mon, May 31 2021 1:19 PM
    • RickP
    • Cleveland, OH
    • Posts 71
    • Points 775
    Locking out the Mac internal drive from media storage in Catalina
    Since adding first Isis, then Nexis systems for media storage for our editing labs, I have put a file named 'Avid MediaFiles' in the root.  This prevents Media Composer from creating an Avid MediaFiles folder and forcing media to external/networked locations.  This Summer, I am upgrading from Mojave to Catalina and I discover the new OS prevents files and folders from being put in the root.
    Is there another method I can use to lock-out media from the local drive for all users automatically?  It has to be student and instructor proof.  A solution requiring a setting-change for every project and user will not do.
    Media Composer v2018.10 on (30) 27" Core i7 Quad-core iMacs with 16GB RAM and 23 iMac Pros with 32GB RAM, plus an assortment of HP i5s running Windows... [view my complete system specs]
  • Mon, May 31 2021 2:44 PM In reply to
    Re: Locking out the Mac internal drive from media storage in Catalina
    You can add folders at the root on the new Mac OSs it just takes, a little jiigling.but don't worry users can't create media on the internal drive, as the, OS won't let them.
    The downside is I think MC now creates the local media in the users document folder so potentially even more of a problem...
  • Mon, May 31 2021 7:50 PM In reply to
    • RickP
    • Cleveland, OH
    • Posts 71
    • Points 775
    That's not encouraging.  Guess I'll keep looking for something that will do what I need.
  • Wed, Jun 2 2021 8:58 PM In reply to
    • Mercer
    • Joined on Thu, Apr 15 2010
    • UK
    • Posts 639
    • Points 8,185
    Maybe I've misunderstood here but can't you simply filter out out Launch and system drives in Media Creation? If you're talking about another internal drive, then that's a bummer you can't copy files to the root, since I've always used the read only text file method, which still works fine on Windows. As far as I'm aware Avid does not write media files to the user's document folder it only installs medialfiles such as black and 'offline' to 'Avid_MediaFiles', upon intial installation, so I don't think that should be a worry.
    MC with Symphony option, 2021.6, HP ZBook 17 G5, i7-8850H 6 core/64GB ram/512 M2 ssd/Nvidia Quadro P5200/16GB/FHD, HP Thunderbolt Dock G2, BMD Ultrastudio... [view my complete system specs]
  • Thu, Jun 3 2021 12:31 PM In reply to
    • RickP
    • Cleveland, OH
    • Posts 71
    • Points 775
    If I can do so universally for all users, that may work, but I've seen MC put media in the drive with most free space, regardless of which drive is selected.  Is there a Media Creation site setting?  Will a site setting transend all users on a Mac?
    I've added a text file to folder with the application to lock-out certain codecs used in transcoding before.  I wish there was something similar to lock-out media locations.
  • Thu, Jun 3 2021 1:03 PM In reply to
    If there was a way to make 'site' in 'site settings' actually apply to a site, and if MC would always (100%) adhere to the media creation settings... what a wonderful world this would be. [:'(]
    Jeroen van Eekeres
    www.mediaoffline.com
  • Fri, Jun 4 2021 1:44 PM In reply to
    • dlogneb
    • Joined on Wed, Aug 27 2014
    • Posts 84
    • Points 860
    I've always wished Avid could have a "locked" media creation setting where it would at least pop-up a warning when media was going to the "wrong" drive.
    What I do is create an "Avid MediaFiles" folder on the drive I want to omit and then in the Mac OS info for the folder I remove all write permissions for the folder.  This keeps Avid from writing media to the drive, but in v2018 at least it can still revert to that drive and then you just get errors when you try to ingest stuff – the errors don't say "unable to write to drive" or anything like that, so you have to remember that any ingest errors are likely because it is trying to write to the drive you "locked".   I've had a few instances where title tool seems to have stopped working and then I realize that it is trying to create titles on my "locked" drive.  But still, it's worth it not to have media in the wrong place.
    Avid MC 2018.12.14 Mac Os Mojave (10.14.6 iMac 5k (2017) 34ghz Intel Core i5 40 GB 2400 MHz DDR4 Radeon Pro 570 4 GB [view my complete system specs]
  • Fri, Jun 4 2021 1:52 PM In reply to
    Pretty sure just a simple text document called "Avid MediaFiles," will do the same thing.
    Symphony 7.06 OS 10.9.5 QT 7.6.3 Mac Pro 2x2.66 6-core 32GB Ram Aja Kona Lhi. MC 2018.12.13 OS 10.13.4 Mac Pro 5.1 2x2.97 6-core 32GB ram Aja I/O express... [view my complete system specs]
  • Sat, Jun 5 2021 1:01 PM In reply to
    • dlogneb
    • Posts 84
    • Points 860
    Ha ha!  I didn't even think of that.  Lol.
  • Sun, Jun 6 2021 11:33 AM In reply to
    • RickP
    • Cleveland, OH
    • Posts 71
    • Points 775
    That's what I've been doing since my Isis in 2014.  But now with Catalina, I can't put anything in the root.  At least without an elaborate hack.  On each computer.
    So, my problem continues.
  • Sun, Jun 6 2021 1:19 PM In reply to
    • dlogneb
    • Posts 84
    • Points 860
    But, forgive me if I'm wrong, I thought (according to another comment on this thread) that in Catalina the System Drive Media Folder is in the user's documents folder.  Is that correct?
    Can you not just create a locked document called "Avid MediaFiles" in the Documents folder and have the same functionality as pre-Catalina?
    (I'm not on Catalina)
  • Sun, Jun 6 2021 3:56 PM In reply to
    • Mercer
    • UK
    • Posts 639
    • Points 8,185
    The system drive media folder would be 'Avid MediFiles' at the root of the drive, the document folder is 'Avid_MediFiles' and is not for new media only for those system media files such as black and 'Offline' that Avid uses generically, therefore as far as I am aware it is impossible to save media to that folder. Since it is almost always inadvisable to save any media to the main system drive and the media creation settings tab specifically allows you to filter out system/launch drives it maybe that the OP has another partion on his internal drive that was capable of acting as a media drive or otherwise another internal drive altogether. In any case if it is not possible to use the read only text file trick to 'lock' out a specific drive this I can see would be a major problem in a shared environment, something that maybe Avid will address with these later iterations of Mac OS.
  • Mon, Jun 7 2021 12:33 PM In reply to
    • RickP
    • Cleveland, OH
    • Posts 71
    • Points 775
    dlogneb:
    I would put an empty Avid MediaFiles text file in Documents on a single-user computer, but in a lab setting, I have no idea who will be using a computers, plus I would have to take RW control of the users to add a file.
    Sometimes I really hate computers.
