Latest post Tue, Jul 13 2021 8:32 AM by camoscato. 16 replies.
  • Fri, May 14 2021 2:13 PM
    • John
    • Joined on Mon, Oct 15 2012
    • Boise, Idaho
    • Posts 285
    • Points 3,430
    processor not fast enough
    Hello,
    I am editing a sequencing in which I am starting to chroma key some background and now showing some yellow and red lines on the timeline indicating my processor is not fast enough.  Is there a fix to this or do I literally need a faster processor.  Here is shot of my specs.
    Avid MC 2020 iMac 27-inch, Late 2012 Processor 3.4 GHz Intel Core i7 Graphics NVIDIA GeForce GTX 680MX 2048 MB Software OS X 10.8.2 (12C2037... [view my complete system specs]
  • Fri, May 14 2021 3:31 PM In reply to
    Re: processor not fast enough
    16GB is the bare minimum nowadays.
    I recommend a min of 32gb and ideally 64gb or more.
    And sub 3.0 ghz isn't a quick processor. I normally suggest 3.4 ghz.
    But it's also worth checking how fast you media can be read from the drive.
    What codec is you media in?
    Is this linked media or Transcoded Avid media?
  • Fri, May 14 2021 3:37 PM In reply to
    What is the format/resolution of the footage? The larger the format or higher the resolution, the harder it will be for your system to play it.
    Media Composer 2021.6 w/Symphony/SS/PF options, HP Z-Book G6 17", i7-9850H 2.60GHz, 32gb RAM, NVIDIA Quadro RTX 3000, Blackmagic UltraStudio Mini... [view my complete system specs]
  • Fri, May 14 2021 7:17 PM In reply to
    • John
    • Boise, Idaho
    • Posts 285
    • Points 3,430
    Thanks.  It has been transcoded.  How can I check how fast media can be read from the drive?  I suspect I need to upgrade to a new computer as this PC is a whole 5 years old.  Would like to find a way to finish this project with it as I'm working on a school owned computer and it could take a while to replace it.
  • Fri, May 14 2021 9:42 PM In reply to
    John:
    From what to what?
    John:
    It varies based on the speed of the processor, the speed of the drive, the project's format, and the resolution of the media. I don't know of anywhere you can plug those variables in and get a definitive answer.
    It would help to know how your media is stored, what format the project is, and what resolution the clips are.
  • Sat, May 15 2021 9:43 AM In reply to
    I think black magics drive speed test indicates what formats would be supported.
    But you just need the mbps speed and then some maths.
  • Fri, May 21 2021 1:00 PM In reply to
    • B
    • Joined on Fri, May 21 2021
    • NL
    • Posts 2
    • Points 50
    The speed (3.0GHz) has very little to do with how fast the CPU is.
    The reason he gets this error is not because his i7 is even remotely to slow for what is required, and 16GB of RAM is way sufficient, depending on the size of your project/session, and even if it's not, win10 is quite capable of swapping to and from disk these days.
    The cause of these errors is not the user's hardware, it is because avid has badly designed its software, and has been too lazy to fix its horrible coding fest.
    https://www.userbenchmark.com/UserRun/43224910 <- Note how the CPU is performing below expectations because I had to downgrade its settings strictly... [view my complete system specs]
  • Fri, May 21 2021 6:05 PM In reply to
    Not having any issues using chroma key on DNxHD footage on my 2013 iMac i7. Runs MC just fine.
  • Sat, May 22 2021 12:15 AM In reply to
    liefde:
    How do you know this?  Simple answer is you do not!
    These forums are all about users asking for help from other users who help where they can.  Your post does not help the user who asked for the help or any other users that may subsequently find this thread whilst looking for a solution to a similar issue.
    There are better and more effective places to vent your current frustration.
    Andrew
  • Sat, May 22 2021 8:41 AM In reply to
    AndrewAction:
    True, but that said. Avid never publishing any performance numbers and performance measuring methods for MC on supported hardware, except the cooperation with Chris Bove, hasn't been any help either. IMHO this status quo keeps these discussions going, also feeding idea's of covering up (past) bad design choices.
    Jeroen van Eekeres
    www.mediaoffline.com
  • Sat, May 22 2021 9:06 AM In reply to
    This Avid gives some info on the hardware needed based on the codec being used.
    https://avid.secure.force.com/pkb/articles/en_US/Compatibility/en365919
    There are other dowloadable pdfs on CPU specs as well as readmes that give details on RAM.
    It's important to note that lots of RAM is important forcing the OS to use virtual memory is no solution during playback.
    Even with an SSD drive there is a big impact swooping RAM in and out.
    Even at HD effects heavy work will need more than 16gb RAM.
    If you have a supported graphics card real-time performance of effects can be improved.
    So having a fast supported GPU, plenty of RAM, fast access to the media drive, a fast processor and enough cores are key parts of improved real-time performance.
  • Thu, Jun 10 2021 9:46 PM In reply to
    • John
    • Boise, Idaho
    • Posts 285
    • Points 3,430
    Just back from vacation and I went to this article.  Very helpful  Thanks!  I've ordered another 16GB to make this Dell 32.  See if that helps.
  • Fri, Jun 11 2021 7:40 AM In reply to
    More RAM will help but its just a 4 core CPU and running at only 2.7GHz so that will limit you.
    I'm working with 20 cores at 3.1GHz and 128GB RAM and even I get stuff I have to render!
  • Sun, Jun 13 2021 10:51 AM In reply to
    • Mercer
    • Joined on Thu, Apr 15 2010
    • UK
    • Posts 639
    • Points 8,185
    Doubling the ram will certainly help but the gpu is more probably the culprit here too. That graphics card is simply too old and with too little vram for much serious FX work. Cpu is mainly codec decode encode, e.g playback/playout media; gpu/vram is for realtime fx, e.g. layers of real time fx compositing. The processor warning can indicate a defficiency in either or both , since Avid has a distributed processing paradigm. I never have any problem here with a solitary i7 6 core, on a laptop playing all forms of media up to 4K.
    MC with Symphony option, 2021.6, HP ZBook 17 G5, i7-8850H 6 core/64GB ram/512 M2 ssd/Nvidia Quadro P5200/16GB/FHD, HP Thunderbolt Dock G2, BMD Ultrastudio... [view my complete system specs]
  • Sun, Jun 13 2021 3:15 PM In reply to
    • John
    • Boise, Idaho
    • Posts 285
    • Points 3,430
    Thanks for the feedback.  I'm hoping that upping the RAM will get me through this project.  All footage is from either a Sony Camcorder, Canon Rebel t41 or an iphone 10.  The background footage being chroma keyed in is so far from stuff I've filmed.  I've come to realize that most of the issues I've had stems from not consolidating or transcoding properly.  Once the RAM arrives and I've started up again, I'll post progress or issues..
