Latest post Tue, May 11 2021 12:07 PM by meli. 4 replies.
  • Sun, May 9 2021 11:26 PM
    • meli
    • Joined on Fri, Apr 11 2008
    • Posts 61
    • Points 765
    Changing path of keyframes in Blur or Paint effect?
    I'm blurring an object and using multiple keyframes to manually track the object. I've been using either the Blur or Paint effect. Is there a way to adjust the path of all the keyframes to "Shelf" (sometimes called "Hold")?
    Avid Symphony Nitris [view my complete system specs]
  • Tue, May 11 2021 6:02 AM In reply to
    • luca.mg
    • Roma - Italy
    • Posts 5,937
    • Points 70,180
    Re: Changing path of keyframes in Blur or Paint effect?
    Select all the keyframes and modfy the parameter You want to adjust, the change will affect them all.
    Symphony 21.9, BM Intensity Pro 4k, Windows 10, i7-5930K, 32 GB ram, Quadro K620 [view my complete system specs]
    peace luca
  • Tue, May 11 2021 11:32 AM In reply to
    • meli
    • Posts 61
    • Points 765
    Thanks, but I apparently don't have the option to adjust the Path to Shelf with those effects, Blur or Paint.  I do have the ability, and I know how to do it, with other effects.  If you're in front of an Avid, would you be able to confirm that you can change the Path to Shelf for Blur and Paint?  Thanks!
  • Tue, May 11 2021 12:04 PM In reply to
    • BarkinMadd
    • Ontario, Canada
    • Posts 4,818
    • Points 63,185
    Blur and Paint are what Avid calls intraframe effects - they don't have editable keyframe curves in the same way as other effects.
    Add - you can use an acceleration curve to affect motion of all keyframes from linear to s-curve, I believe, but there is no 'hold' for an intraframe effect to the best of my knowledge.
    MC 2021.6 | QT 7.7.9 | Continuum 2021 | Sapphire 2021 | Mocha Pro 2021 | Titler Pro 7.7 | Windows 10 Pro x64 (21H1) | System: Asus x299, i9-7940X (4.1GHz... [view my complete system specs]
    Steve
    ______________________
    www.nelliedogstudios.com
  • Tue, May 11 2021 12:07 PM In reply to
    • meli
    • Posts 61
    • Points 765
    That's unfortunate.  Thanks for the reply.
