Latest post Fri, Aug 27 2021 10:40 PM by IngmarBergman. 26 replies.
Page 2 of 2 (27 items) < Previous 1 2
  • Mon, Aug 23 2021 10:40 PM In reply to
    Re: Audio mixer/controller hardware recommendations
    Job ter Burg:
    OMG....!
    Editing Movie Magic.
    My Equipment & System Specs
    Media Composer Ultimate 2022.7 | Pro Tools Studio 2022.7 | Avid Play | Sibelius Artist 2022.7
  • Tue, Aug 24 2021 6:38 AM In reply to
    I was getting excited about those 1237's.
  • Tue, Aug 24 2021 9:43 AM In reply to
    • Lukas Boeck
    • Joined on Fri, Jul 31 2015
    • Austria
    • Posts 646
    • Points 7,760
    Job ter Burg:
    If your place is big enough... you need 2,5m listening distance from the speakers.
    it's 5,5k€ with GLM set.
    MC 2018.12.2 Cusom bulid Supermicro X9SRL-F, 32 Gig Ram, 3ware 9750 6x6TB Seagate EC Drives, LSI 9207 + LTO-7, Mojo DX, Artist Color, Flanders CM240, GTX... [view my complete system specs]
  • Thu, Aug 26 2021 12:19 AM In reply to
    Thanks for the further input; I hadn't looked hard at the smart monitors and I see there is a choice to be made with the 8330 vs. 8030 perhaps.  So the advantages would be the room correction, digital in, optional volume controller, and lower noise floor?  I'm not sure if I can take advantage of feeding it a digital AES/EBU signal without adding something like a DeckLink Studio 4K card with its breakout cable (based on my rough homework so far).
    Thanks for the food for thought on these smart monitors.
    Bret
  • Thu, Aug 26 2021 8:25 AM In reply to
    • Lukas Boeck
    • Austria
    • Posts 646
    • Points 7,760
    Philip Kapadia:
    Job ter Burg:
    OMG....!
    OMG out of sympathy, he realized that with that many speakers I'm not a hobbyist, but a pathological case.
    IngmarBergman:
    Bret
    You can use all features in analog mode too, only the noise floor gets lower in digital mode.
    If you have an analog mixer now for your PC and decklink card, you can continue using that.
    I'm one step further, no more mixer, only a small RME PCIe card with decklink as an input.
    The Genelec voulme control is really nice, the knob is digital and never crackles, but is haptic like an analog unit.
  • Thu, Aug 26 2021 8:43 PM In reply to
    Lukas Boeck:
    LOL. If only I could come up with a valid reason to get me some 10/1237's for L C and R...
  • Thu, Aug 26 2021 9:40 PM In reply to
    • Lukas Boeck
    • Austria
    • Posts 646
    • Points 7,760
    We live in the future man, we don't need reasons.
    I tell myself this type gear is cheap because it lasts forever, forgetting it's pitfall is it's darn weight.
    If you have a good space, some geometry, a little bit of acoustic treatment and you get to play with it yourself,
    I'll highly recommend.
  • Thu, Aug 26 2021 10:48 PM In reply to
    Thanks for the further info; I'm looking up the RME cards to see what's available.  I see that something like the HDSPe AIO Pro would have the AES/EBU outs that could directly go into the 8330A, with the volume controller on the side.  I think that's the kind of streamlined setup you're mentioning, which makes use of the digital mode on the 8330As.
    Thanks again; I will chew on that possible configuration.
    Bret
  • Fri, Aug 27 2021 3:47 AM In reply to
    Caveat: if you plan on using a video output device as well: MC won't let you send picture to one device and sound to another. So you can't use the RME for audio and, say, a Decklink for video output. If you have such a video output card installed, that is what MC will use.
    You could also consider getting something simple like a Decklink Monitor and use its HDMI output to feed a Home Theatre type pre-amp. Some of those, like the Marantz 7xxx and 8xxx series have XLR outputs. And a Master Volume of course. It's what I do to drive a 5.1 monitoring system from my MC setup.
  • Fri, Aug 27 2021 10:31 AM In reply to
    • Lukas Boeck
    • Austria
    • Posts 646
    • Points 7,760
    Hmm? Yes Job, but you only need a pre-amp for surround,
    for stereo the AES or analog outputs of the decklink will be enough.
    Just the Decklink Mini is HDMI only and needs an audio disembedder, last time I checked.
    I'm still using a Mojo DX, connecting its optical audio output to the RME card.
  • Fri, Aug 27 2021 4:50 PM In reply to
    You could use the preamp as a monitor level controller. Even in stereo. And I was referring to the Decklink Mini monitor, which only has SDI/HDMI outs, with embedded audio. The preamp would function as a disembedder and level controller (and even delay and minor room correction if you wanr).
  • Fri, Aug 27 2021 10:40 PM In reply to
    Thanks both for all of the followup on the separate audio/video output card caveat.  It's much appreciated.
    Bret
