Latest post Wed, May 5 2021 1:10 PM by LDV20. 15 replies.
  • Sat, May 1 2021 12:44 PM
    • LDV20
    • Joined on Fri, Nov 18 2011
    • Posts 381
    • Points 4,530
    Which Sony AMA Plugin for Sony XAVC-I for Sony FX6 Camera
    There are several plugins on Sony's site:
    XAVC/XDCAM Plug-in for Avid (PDZK-MA2) MACWIN This AMA plug-in provides support for XAVC and XDCAM / XDCAM EX files in Avid Media Composer, Symphony and NewsCutter products, allowing viewing and editing capability.
    I am just checking to see if this (above) is the right one - I think FX 6 it is the same file as FS7 - just double checking.   Did anyone use FX 6  yet and know the correct plugin?
    Thank you Larry
    Symphony 2022.7- Win 10 pro (20H2),Gigabyte X299X with i9 10920X CPU, Quadro P2000,driver 51.259; 64gig memory, 1TB NV system drive, WD 4TB, BM Min Monitor... [view my complete system specs]
  • Sat, May 1 2021 3:11 PM In reply to
    Re: Which Sony AMA Plugin for Sony XAVC-I for Sony FX6 Camera
    Sony XAVC AMA plugin is handled by a company called Nablet.
    https://www.nablet.com/products/plugins/avid-media-composer/xavc-xdcam-ama-plugin/
    MC 2022, W10, MSI X299M, Intel 9940X, Gigabyte 3080Ti Waterforce, 64GB RAM, Samsung 970 EVO M.2 SSD, BM Mini monitor & Dell UP2718Q. MBP 2019, Big... [view my complete system specs]
  • Sat, May 1 2021 3:27 PM In reply to
    • Fazz Powell
    • Joined on Sun, Dec 3 2006
    • Naples, FL
    • Posts 476
    • Points 6,550
    I thought that was supported without requiring Nablet in the 2020 + releases. No?
    MC 2020.06 w/Symphony option. BlackMagic DeckLink 12G, HP Z840 Dual 3.2Ghz/8 Core, 1TB SSD, 1TB Cache drive, 128GB Ram, Nvidia RTX2060 Super, BCC2020,... [view my complete system specs]
  • Sat, May 1 2021 4:07 PM In reply to
    • LDV20
    • Posts 381
    • Points 4,530
    Fazz Powell:
    Yes - right now I can link XAVC - S - no problem.  I am going to check my plugin in the folder and see if it is the Sony one - but I thought as well that we no longer need Nablet.
  • Sat, May 1 2021 4:08 PM In reply to
    • LDV20
    • Posts 381
    • Points 4,530
    Also the FX 6  file is XAVC - I - the same one FS7 and FX9 uses.  It also has other flavors but I think this one is the higher end one - I will check t on that
  • Mon, May 3 2021 12:51 PM In reply to
    • BarkinMadd
    • Ontario, Canada
    • Posts 4,818
    • Points 63,185
    LDV20:
    Fazz Powell:
    However, I record using an X70 and it records in XAVC Long GOP and still requires the Nablet XAVC / XDCAM plugin as far as it can tell so perhaps it is also required for the XAVC-I codec? Just guessing - I could be totally off :-)
    Add - If you need the plugin, get it from Nablet (Sony no longer supports these plugins directly - they transferred responsibility to Nablet several years ago).
    MC 2021.6 | QT 7.7.9 | Continuum 2021 | Sapphire 2021 | Mocha Pro 2021 | Titler Pro 7.7 | Windows 10 Pro x64 (21H1) | System: Asus x299, i9-7940X (4.1GHz... [view my complete system specs]
    Steve
    ______________________
    www.nelliedogstudios.com
  • Mon, May 3 2021 1:41 PM In reply to
    • LDV20
    • Posts 381
    • Points 4,530
    BarkinMadd:
    OK will check Nablet - but I found this plugin from sony - maybe it will work, I am  not sure.  Been researching on WEB but did not find any info
    www.sonycreativesoftware.com/pdzk-ma2
    It allows AMA from FS7 - which is same file from the sony FX 6 - I just got the camera today this AM - I am unpacking and will record on it and see if I can bring into MC 2021.3 - if not then I will have to either download the plugin from sony or go to Nablet - I will also check the AVX folder and see what I have their now.  I am not sure either as of yet on the Proper AMA plugin
    thank you
  • Mon, May 3 2021 2:16 PM In reply to
    The Sony Creative version is the older one. They transferred the development of XAVC AMA plugins to Nablet. Use the Nablet version.
  • Mon, May 3 2021 2:25 PM In reply to
    • LDV20
    • Posts 381
    • Points 4,530
    Dom Q. Silverio:
    OK got it will download the Nablet version - Thank you for heads up
  • Mon, May 3 2021 9:46 PM In reply to
    • LDV20
    • Posts 381
    • Points 4,530
    I just shot some test footage and brought into avid using MSP_MXF plugin which I guess is already installed  in MC - I wanted to see if it would link with out Nablet - and it linked.  I will do some more testing - maybe Nablet is better - I do not know.  Footage played well - but not enough of a test to determine anything
  • Mon, May 3 2021 10:31 PM In reply to
    • Fazz Powell
    • Naples, FL
    • Posts 476
    • Points 6,550
    Someone high up at AVID said native support is better. But IDK first hand.
  • Tue, May 4 2021 11:25 AM In reply to
    • LDV20
    • Posts 381
    • Points 4,530
    Fazz Powell:
    Not sure what you mean by native support - do you mean NABLET - if it better than I will get it today.
    Thank you
  • Wed, May 5 2021 11:33 AM In reply to
    • BarkinMadd
    • Ontario, Canada
    • Posts 4,818
    • Points 63,185
    LDV20:
    Fazz Powell:
    Thank you
    I don't have any FX6 footage but it would be interesting to see whether Avid's own plugin provides superior behavior as compared to the Nablet plugin (assuming Nablet works for FX6 footage). Also - Nablet may offer broader export options (not sure about this).
    Steve
  • Wed, May 5 2021 12:17 PM In reply to
    • Fazz Powell
    • Naples, FL
    • Posts 476
    • Points 6,550
    LDV20:
    Native means within AVID and not using a plug-in. And yes XVAC-I is the best as it doesn't have Long GOPs like S and L.  It's individual frames which is easier to edit, but you should transcode to your preferred coodec within AVID. "S" is more or less a consumer format. If you can't get XVAC-I to work without Neblet, then I guess you'll need to get it. One of theirs was free and the other was a nominal fee. (Its been 2 years since I worked with XVAC, so sorry if Im a bit vague)
  • Wed, May 5 2021 1:07 PM In reply to
    • LDV20
    • Posts 381
    • Points 4,530
    BarkinMadd:
    I emailed Nablet and asked them to make sure there plugin will work with camera footage- they emailed me the link to proper plugin and I have it - but did not install it because I am looking for the Plug in folder in MC to make sure I have no duplicates that will interfer with the Nablet but I cannot find it - will look for it again later.  BTW not sure if Avids ability to link will affect Nalet - I do not know which one would be better so for now I am using MC's linking
