Latest post Mon, May 3 2021 1:19 PM by Bruno M. 3 replies.
  • Thu, Apr 29 2021 11:01 AM
    • sergiumm
    • Joined on Mon, Dec 24 2012
    • Posts 85
    • Points 1,005
    Add Tape Name to clip with Alpha channel
    Is it possible?
    Media Composer 2021.3 MSI Z390-A PRO, Intel Core i7-8700, 32GB RAM 2400 MHz DDR4, Windows 10 64-bit, ASUS GeForce GTX 1060 6GB [view my complete system specs]
  • Thu, Apr 29 2021 7:49 PM In reply to
    Re: Add Tape Name to clip with Alpha channel
    Not sure but adding tape names in MC is a risky route. It removes the source name and source path metadata.
  • Fri, Apr 30 2021 9:10 AM In reply to
    • sergiumm
    • Posts 85
    • Points 1,005
    But I can add Tape Name to ordinary clips without alpha
  • Mon, May 3 2021 1:19 PM In reply to
    • Bruno M
    • Joined on Thu, Feb 11 2010
    • London, UK
    • Posts 804
    • Points 10,215
    I've had this problem in the past with clips containing alpha channels.
    Irrespective of whether it's linked or imported, when you try to add a tape name, Avid throws up an error about only being able to perform this operation with master clips with matching frame rates. This is despite the media being at the same frame rate as the project.
    ingesting the same media ignoring the alpha channel (in settings) and you can happily add a tape name/number.
    Not sure why this is, but I viewed it as a bug. Don't know if this was ever fixed as I've not tried this out in quite a while.
    Pat's warning about Tape names is correct in that you lose the source name/path info that might be needed in workflows such as round-tripping or relinking.
    HP Z800, HP G3 Studio, SonnetFusion RAID, Mojo DX, Decklink 4K, Symphony 2020, JVC DTV1910 HD tube monitor, HP Dreamcolor, Avid Artist Color, Avid Transport... [view my complete system specs]
