Hi everyone, I'm trying to achieve this: I applied a timewarp on a segment. I open the motion effect editor window to adjust my keyframes. Add 4 keyframes and I want to the first two keyframes in e.g. "shelf" interpolation and the second couple of keyframes in "linear" mode/interpolation. But when I change one of these it changes all the others. So if I switch the second one frome "shelf" to "linear" it automatically switches the third and the fourth one. I can't achieve this "fluid and free" interpolation modes for each keyframe. Please help
When You select the K/F to adjust are the others highlighted as well?
Tom Pearson
Not possible AFAIK. All interpolation in a graph is one thing or another But ... try Bezier. With care you can fine tune to get the result you are after.
ACI, Dorset, UK. www.avid-companion.co.uk
