Latest post Wed, Mar 24 2021 8:16 PM by MikeyB. 4 replies.
  • Tue, Mar 23 2021 10:45 AM
    • balna
    • Joined on Wed, Jan 10 2007
    • Posts 11
    • Points 155
    Avid Media Composer 2020.12 Workspace reset
    Hi All.
    I am using an avid mediacomposer 2020.12 on a Mac Pro 2013. I love this new intreface and the featuer that I easily can change and modify the workspaces. Unfortunately the software randomly (every 2-4 days)  resets my setups on the defolt workspaces (edit, color, effects, audio) only keep the setups for the costum workspaces that I created. I obviously save the current settings every time I set them up and also testing it by changing the workspaces and restart the software. However it is still doing it. I am 100% sure that it is a bug in the software. So it is a really good feature but absoluutley useless if i have to set them up evry 2-4 days.
    So my question is:
    1. Is there a way around, like a software update or som trick with the settings?
    2. if not, are there a way to delet the defult workspaces and use only costum ones? I like to keep my interface clean and not having anything usless?
    3. Did anyone else met with similar issues?
    4. If I export my setting how can I rename it?
    Thank You all!!!
    Mac Pro (Late 2013), 2.7 GHz 12-Core Intel Xeon E5,32 GB DDR3, Dual AMD FirePro D500 3 GB, 3 monitor software only, Avid Media Composer 2020.12 https... [view my complete system specs]
  • Tue, Mar 23 2021 9:40 PM In reply to
    Re: Avid Media Composer 2020.12 Workspace reset
    balna:
    Hi All.
    So my question is:
    Thank You all!!!
    So i've never had any issues, Lets start with the basics.. Have you re-built your user settings? I usually rectify these sorts of errors by doing that alone
    Ryzen/GTX H/W (I know) [view my complete system specs]
  • Wed, Mar 24 2021 9:55 AM In reply to
    • balna
    • Posts 11
    • Points 155
    HI Philip,
    I have built a new user setting for 2020.
  • Wed, Mar 24 2021 1:38 PM In reply to
    • Ahmad Halimi
    • Joined on Thu, Sep 17 2015
    • Australia
    • Posts 13
    • Points 185
    I have had the same issue, though not as regular as you. Basically the Edit, Effects, Color and Audio workspaces reset back to their default settings randomly.
    My workaround it is to have user added workspaces, which I've called Edit v2, FX v2, etc. It's not ideal, but it works for now.
    Filed under: ,
  • Wed, Mar 24 2021 8:16 PM In reply to
    • MikeyB
    • Edlesborough, UK
    • Posts 561
    • Points 6,965
    My experience is that this will happen if Avid sees - or thinks - that you've changed the display settings on the computer in any way. Why it only affects the default workspaces is a mystery, but at least setting up custom workspaces is a workaround.
    MacBook Pro 15" 2016 2.7GHz i7 Radeon 455 [view my complete system specs]
