Does anyone have avid airspeed multistream windows xp version 3 image ? i already contacted avid support and they don't have a copy for the image ! i already lost the USB drive and i'm trying to reimage the server because its not working probably.
why not working probably because i was trying to let the airspeed work as a standalone but didn't work, so when i want to return everything back to normal i could't, first i cannot open avid service configurattion after select workgroup nur system can connect to edit server configuration!
so im thinking to re-image the server or at least to workaround if possible to delete the asmuser account from windows and re-create a new user, because the server still using the last configuration (standalone mode) even if you changed anything.
just to make sure the issue from airspeed server , when i send to airspeed from edit i recieve the following message:
the project type does not support playback device format for longGOP.[0] unable to send to playback. please check device configuration.
i followed below link samething:
https://avid.secure.force.com/pkb/articles/en_US/troubleshooting/Send-to-Playback-fails-with
Hi Johan,
Yes I still have the usb stick.
The multistream came in 3 models if I remember correctly, The SD model, the HD DNxHD model and the HD model also supporting XDCAM.
Although I might read the error message in the oposite way of what it says I think you are probably trying to send XDCAM HD to a multistream that can only playback DNxHD or SD. If your project is using XDCAM HD do a mixdown to DNxHD or SD and try again.
Jeroen van Eekeres
www.mediaoffline.com
Hello Eekeres,
I tried to mixdown the video to a many formats , and chage project to another formats same thing.
if you remmeber we changed the airspeed from default config to standalone settings, these settigns still exist on the server even if we changed the settigs to defaults using the airspeed application restore interface.
i uploaded a screenshot you can see next to transfer engine a word standalone mode this was not exist when was everything works fine with isis storage.
Johan,
In your first post you mentioned you are using an Airspeed 5000, like it is written is your system specifications. Now you are talking about an Airspeed multistream. While they have many things in common the multistreams were more tricky to setup in my experience. So to give you the correct advise please confirm which model you are using.
Dear Jeroen,
Can you please upload the setup used for airspeed ? i cant find any setup for airspeed from avid support.
or is it ok to backup device drivers and re-install windows xp same version and setup all avid files ?
Let me see if I can prepare an image for you tomorrow.
Jeroen
Avid reseller ACSR at Telmaco
http://www.telmaco.gr/en/
HI,
Thank you man appreciate that.
