Latest post Sat, Jul 22 2023 3:31 PM by dlogneb. 7 replies.
  • Wed, Jan 20 2021 7:48 PM
    • JPBU
    • Joined on Sat, Jan 11 2014
    • Canada
    • Posts 178
    • Points 2,495
    Disable enter FX MODE on lasso
    I recently switched to the 2020.8 version after finishing a year-long project on MC 2018.
    In prior versions I would use the lasso tool to select the edge of clip to automatically enter trim mode on that specific clip (without having to select the appropriates tracks and pressing the trim mode button).
    But now, in the new version, if there is a dissolve/fade (audio or video) on that clip, it automatically enters the Effect editing mode and/or transition manipulation tool. Is there any way to make it behave like it used to?
    Media Composer 2020.8 | iMac Pro (2017) 3.2 GHz Intel Xeon W | 64 GB 2666 MHz DDR4 | Radeon Pro Vega 56 8176 MB | G-Raid 16TB Thunderbolt 3 | macOS... [view my complete system specs]
  • Thu, Jan 21 2021 9:16 AM In reply to
    • MikeyB
    • Edlesborough, UK
    • Posts 619
    • Points 7,765
    Re: Disable enter FX MODE on lasso
    You have the Timeline setting 'Applying effects opens the Effects Editor' selected. Switching this off solves the problem.
    2021 MacBook Pro 16" (M1 Max 32GB), 2019 iMac 27" (8-core i9, 40GB) [view my complete system specs]
  • Thu, Jan 21 2021 3:24 PM In reply to
    • JPBU
    • Canada
    • Posts 178
    • Points 2,495
    Hi MikeyB. Thanks for your help.
    Sadly, this is not working. This option was already off. As you can see in the video below, lassoing a regular cut gets me in trim mode, but if there is a fade it opens up the effect editor.
    https://youtu.be/obnPgoGQqwM
  • Fri, Jan 22 2021 10:10 AM In reply to
    • MikeyB
    • Edlesborough, UK
    • Posts 619
    • Points 7,765
    Hmm. Mine definitely doesn't do that!
    In that case, try creating a new User Settings, just in case yours has got 'stuck'.
    Alternatively, update to 2020.12. Although I don't recall seeing this in a change list, maybe it got 'fixed' somewhere between your version and mine.
  • Tue, Jan 26 2021 9:31 PM In reply to
    • JPBU
    • Canada
    • Posts 178
    • Points 2,495
    So, I found the problem. It was coming from my “panel set up”. It seems like having the Effect Editor at hand in the interface causes this. I rearranged my windows, saved it under a new workspace and now the problem is fixed.
  • Sun, Jul 16 2023 8:05 PM In reply to
    • Travis Greene
    • Joined on Wed, Mar 14 2012
    • Los Angeles, CA
    • Posts 4
    • Points 40
    Thank you for posting the solution - I forgot that I had recently window'd/tabbed my effect editor, thinking that'd be a good idea. Nope! That lasso>to>effect mode was driving me nuts!
    MC 8.4.2 • 10.10.1 • Macbook Pro (Retina, 15-inch Late 2013 • 2.6ghz Intel i7 • 16gb RAM • NVidia GeForce GE 750M 2048MB • 27" Thunderbolt Display... [view my complete system specs]
  • Sat, Jul 22 2023 8:19 AM In reply to
    • Marty
    • Joined on Sat, Dec 3 2005
    • Berlin, Germany
    • Posts 979
    • Points 11,590
    I'm also seeing that new behaviour, that lassoing a clip / edit / audio keyframe always brings you in the effect editor when that is opened. I now have to close it all the time and in the past it was always opened in a tab and worked fine. This should be a bug and it needs to be fixed.
    all different setups in various editing suites. my own: MC 2021.9, OSX 10.14.6, iMac (Retina 5K, 27-inch, 2019), 3,6 GHz Intel Core i9, 64GB RAM, Radeon... [view my complete system specs]
    www.film-editing.de
  • Sat, Jul 22 2023 3:31 PM In reply to
    • dlogneb
    • Joined on Wed, Aug 27 2014
    • Posts 285
    • Points 3,415
    I have found the same issue, but changing the workspace doesn't fix it permanently for me.
    In v2018 when you enter effect mode the effect panel opens and when you closed effect mode (by hitting "Y"-source/record or escape-key, possibly other ways) the effect panel closes and you're back to normal editing mode.
    In v2023 sometimes it works that way, but at some point the effect panel stops closing when exiting effect mode.  Then the only way to get back to normal editing is to use the mouse to close the effect panel.
    I have complained about this issue in various ways over the year.   Many years ago the "source/record" button (Y-key as default) definitively exited all other modes and tools and sent the user back to true source/record mode -- no segment mode, no transition mode, no effect mode, just in and out points and your playhead.
    Over the years I have noticed other issues users have with things like the segment tool, transition tool, and other "modes".  The answer used to be "just press the Y key to reset back to source/record".
    AVID, please give us back a way press one key and return to true source/record mode!  It will save us time and you!
    Avid MC 2022.10 & 2022.7 Mac Os Monterey (12.6.1 & 12.3.1) MacStudio Apple M1 Ultra 128GB [view my complete system specs]
