Latest post Wed, Jun 9 2021 9:39 AM by kd-53. 13 replies.
Page 1 of 1 (14 items)
  • Wed, Dec 23 2020 9:02 PM
    • derekg
    • Los Angeles
    • Posts 46
    • Points 645
    2020.12 Audio mixer - can't type in volume level
    Can't type in a value into the volume window at bottom of fader in Clip Volume mode. This worked in all previous versions (certainly in 2020.9)
    Now I have to move the fader as only way to adjust volume which is slower and less precise than typing in a number
    Derek Goodall
    Goodwood Productions, Inc.
    North Hollywood, CA
    HP z4 G4 3.6,  80GB RAM, GTX 1070, Win 10
    HP z4 G4 3.6 Xeon quad core, 80GB RAM, Nvidia GTX1070, BM Intensity 4k, Win 10 [view my complete system specs]
  • Wed, Dec 23 2020 10:29 PM In reply to
    • SjHutcho
    • Joined on Sat, Nov 3 2018
    • Posts 3
    • Points 65
    Re: 2020.12 Audio mixer - can't type in volume level
    @Derek  - I have also seen this in my install of 2020.12 as well. It happens intermittently and mostly when I have the clip loaded in the source window. I'm just closing and then reopening the audio mixer and it seems to fix it. Annoying little bug.
  • Thu, Dec 24 2020 5:00 AM In reply to
    I just tried this on the system in my specs. If you click the number at the bottom of the fader to highlight it and then type a value on the number pad, it seems not to do anything, but then when you press 'enter' on the number pad the fader jumps to the number you typed and the number at the bottom updates.
    Can you both (and anyone else who is interested) please try this to double-check and make sure which way it's not working? I'm trying to see if it's broken, or a new intended behavior, or a new unintended behavior so I describe it correctly when I ask Raff (customer advocate at Avid) to check for us. Thanks.
    Media Composer 2021.6 w/Symphony/SS/PF options, HP Z-Book G6 17", i7-9850H 2.60GHz, 32gb RAM, NVIDIA Quadro RTX 3000, Blackmagic UltraStudio Mini... [view my complete system specs]
  • Thu, Dec 24 2020 8:24 AM In reply to
    • Vilem
    • Joined on Sat, Apr 10 2010
    • Prague
    • Posts 1,438
    • Points 15,785
    camoscato:
    same behavior for me. Both Entry work.
    V.
    AVID MC2021.06, HP Z620 - 2 x Intel Xeon E5-2620, Quadro P2000 - driver 461.72, RAM 48GB - DDR3, BM Intensity Pro 4k - 12.1, W10 - 64bit Professional... [view my complete system specs]
  • Thu, Dec 24 2020 9:55 AM In reply to
    • kd-53
    • Joined on Wed, Apr 28 2010
    • Duesseldorf, Germany
    • Posts 47
    • Points 620
    same problem here. I also could not change the audio level between in and out point. For me MC2020.12 is unusable so I switched back to 2020.10.  :-(
    I also had problems with color correction. Because of the audio problems I did not verify before switching back.
    Merry chrismas and keep save
    Klaus-Dieter
    Mobo: MSI MPG-Z390 Gaming Edge AC, i9-9900K, 32GB Ram, Win 10 Prof 64, GeForce GTX 2060 Super with 8 GB Ram, BM Intensity Pro 4K, MC 2021.6, BCC2021, Mocha... [view my complete system specs]
  • Thu, Dec 24 2020 10:45 AM In reply to
    Hi Klaus-Dieter, and Merry Christmas to you, too.
    kd-53:
    Sorry, but I could not duplicate this. Setting an audio level in/out works for me on 2020.12 as it did prior to 2020.12. If you decide to try 2020.12 again, please try with a new user setting to see if the problem continues.
    For all of you unable to change audio levels using the input at the bottom of the fader, can you please try creating new user settings and see if the problem persists?
  • Thu, Dec 24 2020 2:53 PM In reply to
    • Posts 11,558
    • Points 255,250
    Merry Christmas folks...
    Cases created so support can get to the bottom of it.  I know Carl couldnt reproduce it but lets see if support can figure it out.
    Klaus - Case # 04084888
    Samuel - Case # 04084887
    Derek - Case # 04084880
    Stand by as support will get on it.
    Thanks Carl for trying.......
    Ho Ho Ho
  • Thu, Dec 24 2020 2:56 PM In reply to
    I'm just happy to be on the team, and I hope to help us get some wins this season. :)
    Merry Christmas, MM, and everyone else, too!
  • Thu, Dec 24 2020 7:26 PM In reply to
    • touviere7
    • Joined on Mon, Mar 15 2010
    • los angeles
    • Posts 698
    • Points 7,975
    camoscato:
    works perfectly here, thanks carl! Yes
    symphony 2020.12 - win 10 pro64 v.21H1 - nVidia gtx1080 OC (462.31 studio) - intel i7 6800k @4.2ghz water cooled by corsair H100i V2 - MSI X99A - 112GB... [view my complete system specs]
  • Thu, Dec 24 2020 10:05 PM In reply to
    • derekg
    • Los Angeles
    • Posts 46
    • Points 645
    Thanks for looking at this. Yes, you are right - it does work by pressing "enter".
    Previously you did not need the "enter" command. Not a big deal but definitely not an improvement.
    Derek
  • Sun, Dec 27 2020 5:03 PM In reply to
    • luca.mg
    • Roma - Italy
    • Posts 5,876
    • Points 69,660
    derekg:
    Derek
    Same here, moreover, in previous versions ALT-click on the number entry at the bottom of the fader would reset the level to zero, that does not work anymore.
    Symphony 21.3, BM Intensity Pro 4k, Windows 10, i7-5930K, 32 GB ram, Quadro K620 [view my complete system specs]
    peace luca
  • Wed, Feb 10 2021 2:46 AM In reply to
  • Wed, Jun 9 2021 7:40 AM In reply to
    • adamfp
    • Joined on Sun, Nov 25 2018
    • Posts 7
    • Points 60
    derekg:
    Same for me on 2021.2
    Definitely a usability downgrade (and a puzzling one).
  • Wed, Jun 9 2021 9:39 AM In reply to
    • kd-53
    • Posts 47
    • Points 620
    The problem has been fixed in the current version (2021.5).
    Best regards
    Klaus-Dieter
