Latest post Sat, Apr 3 2021 7:47 PM by knejmann. 35 replies.
Page 2 of 3 (36 items) < Previous 1 2 3 Next >
  • Fri, Jan 8 2021 12:17 PM In reply to
    • knejmann
    • Århus, Denmark
    • Posts 257
    • Points 2,875
    Re: Media Composer 2020.12 Available NOW - 21 Dec 2020
    You're not alone. Same problem with markers here.
    Anyone having MC crash when using "Set Name column for selected clips..." - or Labroll column or something?
    Media Composer 2020.12.1 - Windows 10 - Dell 8520 - Blackmagic Decklink Studio 4K - Interplay and NEXIS storage - Avid Artist Color. [view my complete system specs]
    Kåre Nejmann
    Danish Broadcasting Corporation - DR
    Aarhus, Denmark
  • Fri, Jan 8 2021 1:19 PM In reply to
    • Polar-Bear
    • Joined on Mon, Dec 28 2020
    • Zurich, Switzerland
    • Posts 8
    • Points 120
    luca.mg:
    Welcome to the forums Polar-Bear, You might be better off by posting over the Mac side of the forums. As for the fonts issue, I've read somewhere that there might be troubles with some fonts on the Mac, You have to use the bold flavour as a workaround, don't know if this applies to Your setup though.
    Thank you! About to continue the discussion there. Sorry.
    16-Core Mac Pro, 192 GB Ram, W5700X, Catalina 10.15.7, MediaComposer 2021.5, Resolve Studio 17 [view my complete system specs]
  • Tue, Jan 19 2021 8:49 PM In reply to
    • TDeng
    • Joined on Mon, Jan 4 2021
    • Posts 1
    • Points 15
    Yes! I am having the same issue. Couldn't find a workaround so I just downgraded to 2020.10.
    Alienware X51 R2, i7-4770 3.40Ghz, 16GB RAM, Windows 10 Home, NVIDIA GeForce GTX 660 [view my complete system specs]
  • Wed, Jan 20 2021 9:29 AM In reply to
    • knejmann
    • Århus, Denmark
    • Posts 257
    • Points 2,875
    I've been in contact with support. MC crashing when using "set ... column" is a known bug (MCCET-3945) and will hopefully be fixed soon.
    Kåre Nejmann
    Aarhus, Denmark
  • Sat, Jan 23 2021 3:35 PM In reply to
    • Todd H
    • Joined on Fri, Jun 9 2006
    • Mansfield, Texas
    • Posts 113
    • Points 1,515
    I am about to upgrade from 2018.12.2   I just never did because this version was stable and I had two jobs going that I couldnt have disruptions.
    Now I have the time to update.  Does anyone have any advice?  Is there anything special I need to do when updating?  Do I need to deactivate my current avid before updating?  I haven't updated in a while and cant remember the steps!
    any help would be appreciated.
    Todd
    Windows 10 pro 64 bit MSI x299 sli plus intel i7 7820x EVGA ge force 1060 G.Skill Ripjaws 31 gb 3200 ram Samsung 960 pro 512gb boot drive 4 tb toshiba... [view my complete system specs]
  • Sat, Jan 23 2021 3:46 PM In reply to
    Hi Todd
    Todd H:
    I've never deactivated and never had a problem. As long as you're upgrading on the same computer you should be fine. I've also never done anything special before upgrading, aside from creating new user settings when Avid says it's mandatory.
    Since you're going from the old UI to the new one, you have to create new user settings. The new UI isn't that different, but if you're not good with change, you might want to look at a guide/tutorial: https://youtu.be/QzZuE5AK2Mk
    You could also rename your 'Avid Projects' folder to 'xAvid Projects' to make sure it's extra safe, but this is not a requirement, and I don't always do it.
    As for the steps, I just download the update, unzip it, and run the installer, which takes care of the rest. It will ask you if you want to deactivate, but you don't have to.
    Media Composer 2021.6 w/Symphony/SS/PF options, HP Z-Book G6 17", i7-9850H 2.60GHz, 32gb RAM, NVIDIA Quadro RTX 3000, Blackmagic UltraStudio Mini... [view my complete system specs]
  • Sat, Jan 23 2021 4:14 PM In reply to
    • Todd H
    • Mansfield, Texas
    • Posts 113
    • Points 1,515
    thank you for the quick reply.  I deactivated and uninstalled.  Then installed and had zero problems!  my projects worked fine and even my keyboard shortcuts were still in tact somehow!!
  • Sat, Jan 23 2021 4:16 PM In reply to
    Todd H:
    Great! Glad to hear it all worked well!
  • Sun, Jan 24 2021 11:53 PM In reply to
    • shonky
    • Joined on Sun, May 20 2012
    • Posts 1
    • Points 5
    Hi Marianna, did this issue with Marker get looked into?  I have the same problem.  I create a new marker be then have to click in the dialogue box to be able to write - previously I could just create a maerker and begin typing.
  • Mon, Jan 25 2021 12:29 AM In reply to
    • Ambar Sidhwani
    • Joined on Fri, Feb 14 2014
    • Sydney, Australia
    • Posts 3
    • Points 35
    Hi all,
    Has anybody had issues with changing bulk values in a bin. Setting disk label for multiple items in a bin at once gives me the wheel of death. Bulk Edit works but I'd like to avoid the extra clicks and use a very simple age old function.
    Thanks!
    -Avid Media Composer 7.0.4.2, Late 2012 Mac Pro,12 Core, 12 GB Ram, OS 10.8.5, Avid ISIS 5500 -Avid Media Composer 8.314, Late 2013 New Mac Pro 3.5... [view my complete system specs]
  • Mon, Jan 25 2021 2:32 PM In reply to
    • knejmann
    • Århus, Denmark
    • Posts 257
    • Points 2,875
    If it's via the menu option "Set ... column for selected clips" then it's a known bug: MCCET-3945
    Kåre Nejmann
    Aarhus, Denmark
  • Fri, Feb 5 2021 2:46 PM In reply to
    • Jannek
    • Joined on Fri, Feb 5 2021
    • Posts 2
    • Points 20
    Super annoying, hope, that will be fixed soon. Wasn't it the same in an older version of Avid? Hmm
  • Sun, Feb 7 2021 2:20 AM In reply to
    • cls105
    • los angeles
    • Posts 536
    • Points 6,925
    Why does the readme say "Windows v10 64-bit v1809 or later".  It should specify the latest windows build that it works on.
    Its much more accurate on the Mac OS builds: "Macintosh 10.13.6, 10.14.6, 10.15.6, 10.15.7, 11.1"
    w10, always the latest version of MC, diy 7940x, gtx 1080 ti. [view my complete system specs]
  • Sun, Feb 7 2021 10:43 PM In reply to
    • jwrl
    • Melbourne, Australia
    • Posts 8,427
    • Points 98,115
    Possibly because Windows updates are seldom as catastrophic as Mac updates?
  • Mon, Feb 22 2021 2:29 PM In reply to
    • foxs
    • Joined on Mon, Feb 22 2021
    • Posts 3
    • Points 25
    Carl!!
    Kicking the tires on 2020.12 for the first time today - struggling with one thing: when I switch workspaces from edit to effect or color correction, I see the project window disappears unless I open it myself -- instead I just see the effects palette. On the edit workspace, I've set up the window to sort of mimic old versions - Project, Effects and Settings tabbed in one window. But in those other workspaces, it doesn't seem to want to let me add the project window to the tabbed window with Effect Palette and Settings - it's a minor thing... but annoying. Any tips?
    WINDOWS 10, AVID MEDIA COMPOSER 20.12 [view my complete system specs]
