Latest post Wed, Dec 2 2020 9:48 AM by knejmann. 7 replies.
  • Mon, Nov 30 2020 3:58 PM
    • cocarroll
    • Joined on Thu, Nov 22 2007
    • Waterford, Ireland
    • Posts 78
    • Points 1,035
    Bulk Edit Mark Out
    I am trying to generate lower thirds for all graduating students for a virtual conferring. There will be about 2000 graduates over about 160 courses.
    I am at the stage where I can generate all the lower thirds in photoshop, import them into MC and drag them onto the timeline. However, I want to dissolve rather than cut between the cards.  I know I can hightlight the cards and double-click on a saved transition, but I need to set a Mark Out point for all the clips. However, Bulk Edit will not let me change the Mark Out point.
    Is there a quick way to do this for all of the clips?
    Cian.
    Windows 11 Pro 64bit Build 22000, Dell Precision 5820 Tower X-Series, Intel i9-10980XE, 64G RAM, NVIDIA Quadro RTX 4000 [view my complete system specs]
  • Mon, Nov 30 2020 9:22 PM In reply to
    • BarkinMadd
    • Ontario, Canada
    • Posts 4,818
    • Points 63,185
    Re: Bulk Edit Mark Out
    See if the inspector will work for this purpose...
    Add - nevermind - I just gave it a try and can't get it to work (I must be missing a step - I could swear that the inspector tool would allow for setting mark in/out across multiple clips).
    MC 2021.6 | QT 7.7.9 | Continuum 2021 | Sapphire 2021 | Mocha Pro 2021 | Titler Pro 7.7 | Windows 10 Pro x64 (21H1) | System: Asus x299, i9-7940X (4.1GHz... [view my complete system specs]
    Steve
    ______________________
    www.nelliedogstudios.com
  • Mon, Nov 30 2020 9:34 PM In reply to
    Yes I was under the impression the inspector tool would do it.
  • Mon, Nov 30 2020 9:44 PM In reply to
    • BarkinMadd
    • Ontario, Canada
    • Posts 4,818
    • Points 63,185
    Hi Pat,
    It was actually JC's idea and I was hoping that it would work. I just gave it a try and perhaps I'm just doing something wrong - have you tried it?
    Steve
    Steve
  • Mon, Nov 30 2020 9:46 PM In reply to
    • cocarroll
    • Posts 78
    • Points 1,035
    Unless there are already marks on the clips, the "Marks" option does not appear in the inspector. When I set the marks on one clip and then select multiple clips, it says "Multiple Values" but this cannot be changed.
  • Wed, Dec 2 2020 8:27 AM In reply to
    • knejmann
    • Århus, Denmark
    • Posts 281
    • Points 3,155
    It works for me in 2020.10 with theese steps:
    1: Select all the clips
    2: Switch to Script View and press T on the keyboard to mark clips (mark in + mark out)
    3: Open Inspector
    4: Click the Mark Out field - it might say Multiple Values - and enter a timecode (200 for 2 seconds)
    It seems that the clips must have both a Mark In and Mark Out set before they can be edited from the inspector tool.
    Media Composer 2020.12.6 - Windows 10 - Dell 8520 - Blackmagic Decklink Studio 4K - Interplay and NEXIS storage - Avid Artist Color. [view my complete system specs]
    Kåre Nejmann
    Danish Broadcasting Corporation - DR
    Aarhus, Denmark
  • Wed, Dec 2 2020 9:27 AM In reply to
    • cocarroll
    • Posts 78
    • Points 1,035
    Thanks so much - that is working perfectly Smile
    Now I just have to find out how to mass add Dissolves! (Although to be fiar, it is musch easier to add the dissolves with a few rapisly repeated keystrokes).
    Thanks Again,
    Cian.
    EDIT: Didn't realise my system specs were so out of date: Windows 10 and MC 2020.10. Working from home means that PC specs are also inacurate. Home Build with AMD Ryzen 5 3600, 16G (soon to be 32G), NVidia GForce GTX 1660
  • Wed, Dec 2 2020 9:48 AM In reply to
    • knejmann
    • Århus, Denmark
    • Posts 281
    • Points 3,155
    Adding dissolves to a bunch of clips can be done in several ways.
    One way is to select the track and set marks. Then open Quick Transitions (in not mapped to a button open Tools -> Command Palette -> FX tab). Choose dissolve settings and check "Apply To All Transitions IN->OUT".
    Kåre Nejmann
    Aarhus, Denmark
