Hello everyone
I am working on an archives documentary
The person who is in charge of archives needs an export of the film with source time code and source clip names burned on the video
The video archives are on tracks V1 and V2. On V2 are the B Roll, illustrations etc. On V1 are the archives with sync sound (mostly interviews, or live music).
I know how to use TC burning plug so i have set the plug to display source time code and clip names of V1, and source time code and clip names of V2
Everything is ok if I have a clip on V2 and a clip on V1,
When there is a clip on V2 and nothing on V1, the plug in displays the clip informations for V2 and "N/A" for V1 timecode and "Filler" for clip name", which is not ideal but it is OK
but if I only have a clip on V1, and nothing on V2, (which is the most frequent case) I was expected that the plug in displays clip informations for V1 and "N/A" + "Filler" for V2 , but this is not the case
The plug in displays twice the same information (V1 and V2), because if it doesn't found something on the highest track, it displays the informations of the lowest track
So most of the time there is too much information, which could be confusing for someone who doesn't know how all these things works...
Is there any solutions to display only TC and Clip Name of a specific track only if there is a clip on it, and N/A and Filler if there is nothing on it ?
Hope everything is clear, thank you for your solutions !
I don't think the TC effect has 'if-then' logic.
Here's something to consider as a work-around: Put your TC effect on a single track for the entire sequence. Then make the TC effect work for your first clip. Now save the effect by dragging the effect icon to a bin and label it appropriately. Then go to where the TC window does not reflect what you want and insert an edit on the TC track, splitting it in two. Now modify the TC effect settings for the split portion to show what you really want at that point, save it by dragging the icon to a bin. Continue down your timeline cutting the TC effect and then dragging from the bin the particular TC effect you want at that point. You can save as many variations of the TC effect as you want, just drag and drop on the timeline.
Eric
Hello Eric, thank you for your answer
I have considered this method before asking, but it is really too much work and manipulations...
I don't think there is a good solution...
But thank you for taking some time to answer !
I've tested the issue and confirm it does behave as you describe. No easy work around I can see.
I've posted it as a possible bug.
T 07581 201248 | E [email protected]
Here is my sleazy idea.
Move all V2 clips to V3 temporarily.
Make a clip of black media. Cut into V2 at the beginning of the sequence and add an effect to make it fully transparent (Mute MIGHT work). Copy this clip with it's effect and paste for the rest of V2.
Now go to V3, select all without gaps and move down to V2.This would at least always give you something other than filler on V2.
No idea if this really would work, but hey ....
Jef Huey
emmanuego: Hello everyone I am working on an archives documentary The person who is in charge of archives needs an export of the film with source time code and source clip names burned on the video The video archives are on tracks V1 and V2. On V2 are the B Roll, illustrations etc. On V1 are the archives with sync sound (mostly interviews, or live music). I know how to use TC burning plug so i have set the plug to display source time code and clip names of V1, and source time code and clip names of V2 Everything is ok if I have a clip on V2 and a clip on V1, When there is a clip on V2 and nothing on V1, the plug in displays the clip informations for V2 and "N/A" for V1 timecode and "Filler" for clip name", which is not ideal but it is OK but if I only have a clip on V1, and nothing on V2, (which is the most frequent case) I was expected that the plug in displays clip informations for V1 and "N/A" + "Filler" for V2 , but this is not the case The plug in displays twice the same information (V1 and V2), because if it doesn't found something on the highest track, it displays the informations of the lowest track So most of the time there is too much information, which could be confusing for someone who doesn't know how all these things works... Is there any solutions to display only TC and Clip Name of a specific track only if there is a clip on it, and N/A and Filler if there is nothing on it ? Hope everything is clear, thank you for your solutions !
emmanuego
I cant create a case for you as your email is not in our system at all. I suggest you create a case on the support portal which you can access via MyAvid master account or email me directly and include:
The link to this thread
Your system ID
Your MyAvid email address
Then I can help you.....
[email protected]
Pat Horridge: I've tested the issue and confirm it does behave as you describe. No easy work around I can see. I've posted it as a possible bug.
Hey Pat
where did you post it - centercode?
