Hi, since upgradinng to Windows 10 Pro, Avid gives me message
Current GPU display driver is unsupported for Nvidia Quadro 4000
Problem is the supported version 353.82 is not compatible with Windows 10 so won't install.
What's the way to deal with this issue?
John
You can try 377.83. We had issues using older graphics cards with Windows 10 so we ended up replacing the GPUs.
DQS
www.mpenyc.com
Thanks for the reply. That's the one I currently had installed but still got the message to install a supported driver. Thankfully just found a thread that had this link https://www.nvidia.com/download/driverResults.aspx/88808/en-us which is a supported version of the driver for windows 10. And it worked!
We could not find a good solution after that other than reverting to Windows 7 or replacing the GPU.
See reply above - or use this link https://www.nvidia.com/download/driverResults.aspx/88808/en-us
It worked for me
