Latest post Fri, Oct 30 2020 11:33 PM by colorgrad. 0 replies.
Page 1 of 1 (1 items)
  • Fri, Oct 30 2020 11:33 PM
    • colorgrad
    • Joined on Fri, Oct 30 2020
    • Posts 1
    • Points 5
    Transcoded clips turning back to AMA links but still referencing transcoded media
    Urgent issue if anyone has any information.
    Mac environment working on a range of imacs and mac minis running 10.14.6, on MC with a split of 2018.12.12 and 2018.12.8
    Large OB truck shoot, transcoded low res media to LB 1/4 res on set. Avid projects prepared on set with full day sync maps. The sync maps were made on set with AMA links, not the low res transcoded media (not sure of the on set workflow there). Post workflow was to receive the 'ingest projects' and low res media from set, copy low res media to NEXIS and relink syncmaps.
    Editorial has begun, sporadically, some of the clips are reverting back to AMA icons, but still referencing the correct media sitting on the NEXIS. When a sequence with one of these clips is opened, an error dialogue box appears "cannot access the ama media stream plugin to play this clip". If you close the dialogue box and sequence without trying to play the sequence you can continue working (just not with that sequence), but if you close the dialogue box and try to play the sequence, the monitor on which you tried to play the sequence freezes and you need to close MC.
    We can relink these issue clips back to NEXIS, but relinking does not stick.
    Any help would be very appreciated.
    Filed under: , , , ,
