Latest post Wed, Nov 18 2020 8:24 AM by Vilem. 4 replies.
  • Mon, Oct 26 2020 10:35 AM
    • steve
    • Joined on Mon, Oct 26 2020
    • paris
    • Posts 1
    • Points 15
    Can't media tool DNX145 Footage from BM - Avid 2020.9
    Hi, hope someone can get me an answer, it's driving me nuts,
    i've got an issue since few month, i've done all the latest update of media composer, 2020.4., 6, 9.. on my main computer.
    at office, we got 4 computer, with composer 6.5 and 2019.
    on the set, we using blackmagic device, VIDEO ASSIST 5" setting up with DNXHD 145 MXF, the result is giving me, 3 files footage named Capture****.V1.mxf (for video) and 2 files A1, A2 for Audio.
    Anyway, at the office, or on older avid device, i'm using media tool, the files are detected as "DNXHD 120" files and everythings working.
    But, on my brand new computer, with latest avid, latest QT, and older DNX Codec Files (and also Blackmagic software for video assist), the files are detected as "Unsupported HD1080p" making Avid Crashes.
    With Error Message : "Exception: FATAL_ERROR, msg:Assertion failed: IndexDuration() <= IndexEntryCount(), file:e:\ws2\workspace\MC\release_Installer_Git\Win_Build\coresw\ame\src\msm\MXFMapperSegmented.c, line:254
    only way to import files is to reencode into media encoder and import classic way (or transcode for bigger files).
    I'm wasting so much time with all of these compression, not talking of losing data/quality in the process.
    Anyone got any idea ?
    thanks
    Win10, 64bits, MSI Tomahawk, I9-7900, 64GB, Nvidia 1080 (x2) SLI, [view my complete system specs]
  • Thu, Oct 29 2020 9:57 AM In reply to
    • Jakub V
    • Joined on Tue, Jul 24 2012
    • Prague
    • Posts 66
    • Points 680
    Re: Can't media tool DNX145 Footage from BM - Avid 2020.9
    Maybe its "wrapped" in bad format... can u send me on file (1 video+2audio mxf) to test it?  - email: 123xyz(a)seznam.cz ?
    Media Composer 2019.12, Win10 DELL Workstation 36300 - i9-9900K (8cores), 32 GB RAM, Nvidia P2000 5GB Mojo DX. [view my complete system specs]
  • Thu, Oct 29 2020 10:13 AM In reply to
    Steve the current versions have updated DNx codecs as we nolonger use the datarate as the name its DNxHD LB SQ HQ HQX now. But it should still work with old media (you have more of an issue trying to go back to the old 6.5 systems)
    I would do a test if I were you. If you make a bit of DNx120 media on your Avid 6.5 system will that come into you new MC Version?
    Also happy to test a short piece of the Blackmagic media if you want to wetransfer a clip to me     pat at vet-training dot co dot uk
  • Tue, Nov 17 2020 11:27 PM In reply to
    • Steve
    • Joined on Wed, Jan 6 2016
    • France
    • Posts 10
    • Points 140
    Ok, thanks for your replies.... (yeah, i've change account in between...find the ID of the old one)
    anyway, so i've run few test and confirm that the incompatibility come from the newest AVID who seems to not support anymore these old codec, so yeah, old DNX120 coming from Avid 6.5 or 8 are detected as unsupported
    The new version of Video Assist coming with the new DNXHR, but the old one we own are not supported anymore and don't have the update.
    So if you want to try few test this is a wetransfer with the following stuff :
    0000 - DNX 145 MXF
    0001 - DNX 145 MOV
    0002 - ApplePro Res
    0003 - DNX 220 MXF
    We are using the 145 MXF because it was fast to import, not too big (in compare of APR or DNX 220) just copy into AMF and media tool.
    And also because, I don't know why but I've never succes to record into DNX 45 (if anyone have an answer for that just for my personal knowledge)
    https://j2fprod.wetransfer.com/downloads/835fe83c103946a21274cc9d073fb35b20201117230930/5b80cc7dd02a0210e895690594e48eaa20201117230930/53cf55
    Keep me update thank you :-)
    Win 10 Intel(R) Core(TM) i9-7900X CPU @ 3.30GHz 3.31 GHz 64,0 Go 1080*2 SLI [view my complete system specs]
  • Wed, Nov 18 2020 8:24 AM In reply to
    • Vilem
    • Joined on Sat, Apr 10 2010
    • Prague
    • Posts 1,438
    • Points 15,785
    Hello,
    I performed an experiment in MC2020.10.
    MOV files are easily connected via an AMA link.
    Both MXF versions, stored in the MC media structure, show "Unsupported (HD1080p)" and do not play. AMA link the same.
    V.
    EDIT: Unsupported format is AMA link.
    When you try to insert an MMOB from a folder with MXF files, an error occurs:
    * Exception: FATAL_ERROR, msg: Assertion failed: IndexDuration () <= IndexEntryCount (), file: e: \ ws2 \ workspace \ MC \ Release_Installer_Git \ Win_Build \ coresw \ ame \ src \ msm \ MXFMapperSegmented.c, line: 254
    AVID MC2021.06, HP Z620 - 2 x Intel Xeon E5-2620, Quadro P2000 - driver 461.72, RAM 48GB - DDR3, BM Intensity Pro 4k - 12.1, W10 - 64bit Professional... [view my complete system specs]
