Latest post Mon, Jan 25 2021 3:16 PM by coaviv. 3 replies.
  • Fri, Oct 16 2020 10:10 PM
    • Leuii
    • Joined on Fri, Oct 16 2020
    • Posts 2
    • Points 30
    NEMFileWriter has detected upstream pipe stall...
    I am trying to transcode clips that are .mov AVC Long-GOP High (HD1080p) 60fps. It does not matter what target video resoultion I choose, I still get this message. I have also tried both choosing a different destination drive as well as moving the original clips to a different drive and I still get the message. The only thing I can successfully transcode is a sequence (I learned this when I accidentally selected the sequence rather than the clip). I am currently running Avid 2020.9 on Windows 10.
    The full message reads:
    Exception: NEMFileWriter::ExecuteInternal TIMEOUT - NEMFileWriter has detected upstream pipe stall...
  • Mon, Oct 19 2020 3:27 PM In reply to
    • Posts 11,551
    • Points 255,080
    Re: NEMFileWriter has detected upstream pipe stall...
    Leuii:
    Leuil
    Google search is your friend....  a lot of scoop out there on this one....
    If possible:
    1. Copy the media to a fast local drive on your workstation.
    2. Transcode on that drive, then...
    3. Copy the transcoded media back up to the server.
    If that doesnt work, google the error.
  • Sat, Oct 31 2020 2:48 AM In reply to
    • Leuii
    • Posts 2
    • Points 30
    As I mentioned in the question, I've already tried this. I also cannot find any other fix on google. Thanks for your help though, I appreciate the quick response.
  • Mon, Jan 25 2021 3:16 PM In reply to
    • coaviv
    • Joined on Mon, Jan 25 2021
    • Posts 1
    • Points 5
    Did you solve the problem?
    I have the same problem.
