Latest post Sat, Oct 10 2020 12:12 AM by Martin Fox. 3 replies.
  • Sun, Oct 4 2020 5:09 PM
    • kd-53
    • Joined on Wed, Apr 28 2010
    • Duesseldorf, Germany
    • Posts 52
    • Points 685
    Howto Resize Audio-Plug-Ins
    a few months ago I switched from two 23” Monitors (HD resolution) to two 27” UHD-Monitors (BenQ PD2700U). I learned that you can resize nearly everthing in the MC 2020.9 GUI. But howto resize (Audio) plug-ins. When I use the 7-band equalizer or the ERA4 Voice Leveler it is nearly impossible to handle the plug-in because they are so small. I could not find a hin in the documentation. Any ideas?
    Best regards and thank you for your assistance
    Klaus-Dieter
    Normal 0 21 false false false DE X-NONE X-NONE /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Normale Tabelle"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-priority:99; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin-top:0cm; mso-para-margin-right:0cm; mso-para-margin-bottom:8.0pt; mso-para-margin-left:0cm; line-height:107%; mso-pagination:widow-orphan; font-size:11.0pt; font-family:"Calibri",sans-serif; mso-ascii-font-family:Calibri; mso-ascii-theme-font:minor-latin; mso-hansi-font-family:Calibri; mso-hansi-theme-font:minor-latin; mso-bidi-font-family:"Times New Roman"; mso-bidi-theme-font:minor-bidi; mso-fareast-language:EN-US;}
    Mobo: MSI MPG-Z390 Gaming Edge AC, i9-9900K, 32GB Ram, Win 10 Prof 64 (2021.1), GeForce GTX 2060 Super with 8 GB Ram, BM Intensity Pro 4K, MC 2021.12,... [view my complete system specs]
  • Fri, Oct 9 2020 10:28 AM In reply to
    • kd-53
    • Posts 52
    • Points 685
    Re: Howto Resize Audio-Plug-Ins
    up to now 147 viewes read this article and not a single reply. Does no one else use a 4k monitor and has the same problem? How do you handle this?
    Best regards
    Klaus-Dieter
  • Fri, Oct 9 2020 1:46 PM In reply to
    • BarkinMadd
    • Ontario, Canada
    • Posts 4,818
    • Points 63,185
    From what I have observed, the ability to resize a VST plugin depends on the plugin. For example, iZotope Neurtron 2 is not resizable, while their latest iZotope Neurtron 3 is.
    I suspect their ability to recognize the hi DPI monitor is also VST plugin-specific but I really don't know.
    MC 2021.6 | QT 7.7.9 | Continuum 2021 | Sapphire 2021 | Mocha Pro 2021 | Titler Pro 7.7 | Windows 10 Pro x64 (21H1) | System: Asus x299, i9-7940X (4.1GHz... [view my complete system specs]
    Steve
    ______________________
    www.nelliedogstudios.com
  • Sat, Oct 10 2020 12:12 AM In reply to
    • Martin Fox
    • Joined on Fri, Mar 14 2014
    • Sydney Australia
    • Posts 281
    • Points 2,990
    I’m using the OS based zoom function to get around lots of UI issues like this and eye fatigue.
    im on Mac so it’s Control + mouse wheel, not sure what the windows equivalent is.
