Latest post Sun, Sep 27 2020 1:20 PM by BarkinMadd. 0 replies.
Page 1 of 1 (1 items)
  • Sun, Sep 27 2020 1:20 PM
    • BarkinMadd
    • Ontario, Canada
    • Posts 4,821
    • Points 63,225
    Bug: Adding keyframe to global foreground/crop can only be done by right-clicking on the effects editor graph
    Steps:
    1. Create title+ title
    2. Add a text box to the title (this will be labeled as layer1 - see 4, below)
    3. In the effects editor, open the global > foreground graph (as the only open graph)
    4. Use the effects editor option to add keyframe to 'open groups', 'enabled groups', etc... (nothing happens or the keyframe is added to the layer1, instead if layer1 happens to be selected in the composer window)
    5. Ues the keyframe button below the composer window to add a keyframe (same result as 4)
    6. Right-click on the foreground graph and select 'Add keyframe' (the keyframe is added as expected)
    Observed:
    Most mechanisms for adding keyframes do not work with the global category.
    Expected:
    Add mechanisms for adding keyframes should work with the global category, presumably.
    Notes:
    MC 2020.8
    MC 2021.6 | QT 7.7.9 | Continuum 2021 | Sapphire 2021 | Mocha Pro 2021 | Titler Pro 7.7 | Windows 10 Pro x64 (21H1) | System: Asus x299, i9-7940X (4.1GHz... [view my complete system specs]
    Steve
    ______________________
    www.nelliedogstudios.com
