Latest post Thu, Oct 1 2020 6:37 PM by BarkinMadd. 4 replies.
  • Sat, Sep 26 2020 5:37 PM
    • Jeff Bass
    • Joined on Thu, Jun 9 2011
    • Poughkeepsie, NY
    • Posts 5
    • Points 75
    inserting keyframes on effects track MC 101 Lesson 10
    Hi all-
    I'm working on a PC, and can't insert a keyframe to save my life.  I've tried other machines, restarting the app and computer, but nothing.  Just trying to complete exercise 10 where we fade a title in and out using keyframes on the Global->Foreground parameter.
    Filed under: ,
  • Sat, Sep 26 2020 8:46 PM In reply to
    • BarkinMadd
    • Ontario, Canada
    • Posts 4,818
    • Points 63,185
    Re: inserting keyframes on effects track MC 101 Lesson 10
    I just tried it with 2020.8 and it seemed to work. What happens when you add a key frame? Also - how are you adding the key frame, from the composer window or the FX panel?
    MC 2021.6 | QT 7.7.9 | Continuum 2021 | Sapphire 2021 | Mocha Pro 2021 | Titler Pro 7.7 | Windows 10 Pro x64 (21H1) | System: Asus x299, i9-7940X (4.1GHz... [view my complete system specs]
    Steve
    ______________________
    www.nelliedogstudios.com
  • Sun, Sep 27 2020 1:11 PM In reply to
    • BarkinMadd
    • Ontario, Canada
    • Posts 4,818
    • Points 63,185
    OK - I just discovered a bug with this in 2020.8...
    I was inserting keyframes for the foreground by opening the foreground > level graph in the effects editor, right-clicking and selecting 'add keyframe'...
    If I use any other approach to adding a keyframe from the effects editor, the keyframe seems to be added to the most recently selected title layer (not the global) - my attempts to add keyframe to open graph or the other more granular options for adding keyframes in the effects editor were ignored.
    So this is a multi-faceted bug... Probably should get a bug report...
    Steve
  • Thu, Oct 1 2020 6:27 PM In reply to
    • Jeff Bass
    • Poughkeepsie, NY
    • Posts 5
    • Points 75
    I get the "ding" that tells me I'm trying to do something I can't.  I tried inserting KF with the button in the effects track as well as they keyboard and in the Effects Editor.  Nothing.
  • Thu, Oct 1 2020 6:37 PM In reply to
    • BarkinMadd
    • Ontario, Canada
    • Posts 4,818
    • Points 63,185
    Jeff Bass:
    Did you right-click on the graph and select 'Add Keyframe'?
    Steve
