Latest post Sat, Sep 26 2020 3:07 PM by Fazz Powell. 3 replies.
  • Thu, Sep 24 2020 8:44 PM
    • GBC
    • Joined on Wed, Dec 10 2008
    • Canmore, Alberta, Canada
    • Posts 44
    • Points 560
    Finally ready to upgrade - advice??
    After decades of working up through upgrades to MC I've been stalled in MC7.04. Now looking to upgrade and invest in a new system. (better late than never) I have always added more storage as needed with eSATA drives. I have an eSATA card on my HP Z400 with multiple ports and also a splitter through which I can access usp to 7 drives at a time. It's worked well for me. Is this the best option with a new system? I've also always run the MOJO DX on my system. Does MC 2020 still use this hardware? Finally, I ocasionally work with H265 4:2:2 from the GH5. Has the issue with this file format been solved in MC running Windows 10? Thanks in advance.
    Filed under: ,
  • Sat, Sep 26 2020 8:25 AM In reply to
    • B3n3d1kt
    • Joined on Tue, Mar 24 2020
    • Germany
    • Posts 24
    • Points 265
    Re: Finally ready to upgrade - advice??
    Mojo DX:
    https://avid.secure.force.com/pkb/servlet/fileField?retURL=%2Fpkb%2Farticles%2Fen_US%2Fcompatibility%2Fen422411%3Fpopup%3Dtrue%26retURL%3D%252Fpkb%252Farticles%252Fen_US%252FUser_Guide%252FNitris-DX-and-Mojo-DX-capabilities&entityId=ka15A000000tb8eQAA&field=Attachment_2__Body__s
    Important not to run the latest Windows 10 version (2004) and stay with 1909.
    Regarding the storage I recommend to get a solution that works best for your workflow. We don't know your requirments (speed, capacity, backup).
    MC 2019.12 (Win 10 1909) custom Workstation: AMD Threadripper 3960X (NH-U14S TR4-SP3 + NF-A15), ASUS TRX40-E Gaming, 64GB DDR4-3200 Corsair, MSI RTX 2070... [view my complete system specs]
  • Sat, Sep 26 2020 1:31 PM In reply to
    • LDV20
    • Joined on Fri, Nov 18 2011
    • Posts 396
    • Points 4,675
    Certified Avid HP or other system is a secure way to go especially if editing is your main source of work - however you can always build your own system as well if you are comfortable with that.  I just built a i9 10920X - all works well.  Thee are also system builders out there as welll that will build a system for you.
    Symphony 2023.12- Win 10 pro (20H2),Gigabyte X299X with i9 10920X CPU, Quadro P2000,driver 51.259; 64gig memory, 1TB NV system drive, WD 4TB, BM Min Monitor... [view my complete system specs]
  • Sat, Sep 26 2020 3:07 PM In reply to
    • Fazz Powell
    • Joined on Sun, Dec 3 2006
    • Naples, FL
    • Posts 476
    • Points 6,550
    I just bought a loaded, refurb HP Z840 for $2K and I added a Nvidia RTX2060 Super, (I'd go with a RTX30XX card now). RTX's aren't officially supported though. There's some Quadro cards out there if you want to be on an approved box. Check out Teksavers, 512-663-5764. The Z840 is a nice upgrade from Z400 or Z800s. They have a configuration tool on their site as if it were a new systems to be configured, which is cool for refurb machines, Warrantee is 3 years. And no, I don't work for them, just a very happy customer.
    HP Z Series Z840 Tower: 2x E5-2667 V3 Eight Core 3.2GHz Processors, 64GB (8 x 8GB) of RAM,1TB 6Gb/s SATA Solid State Drive, 1x Empty SSD Tray with Adapter, DVDRW, Windows 10 Pro Pre-Install, 1125W Power Supply.
    They aren't system integrators but I sent them the Avid set-up guide for Z840 and they set it up based on that document without a charge.
    I added a BMD DeckLink 4K extreme 12G for $895. I have 3 Nitris boxes if you want one cheap, but I'd think you'd want something like the BMD. It's nice to be able to output Resolve and Premiere, along with MC output to the main monitor.
    Good luck!
    MC 2020.06 w/Symphony option. BlackMagic DeckLink 12G, HP Z840 Dual 3.2Ghz/8 Core, 1TB SSD, 1TB Cache drive, 128GB Ram, Nvidia RTX2060 Super, BCC2020,... [view my complete system specs]
