Latest post Sat, Nov 21 2020 5:29 PM by LDV20. 22 replies.
Page 1 of 2 (23 items) 1 2 Next >
  • Tue, Aug 25 2020 5:28 PM
    • Tom Pearson
    • Joined on Thu, Mar 1 2007
    • Los Angeles CA / Dallas TX
    • Posts 2,216
    • Points 23,845
    GUI CONTROL ISSUES 2020.8
    Having this issue when I try to grab a fx like" resize" I place the cursor on the fx and it grabs the one below it like the mouse cursor is off on its x/y grid  and Im not miss selecting
    Mac Pro 3.5 gig 6 core 64 gig ram D700 radons with ssd os drive with a 20 tb raid, Artist Mix and Artist color Artist control [view my complete system specs]
    Tom Pearson
  • Tue, Aug 25 2020 5:50 PM In reply to
    • Tom Pearson
    • Posts 2,216
    • Points 23,845
    Re: GUI CONTROL ISSUES 2020.8
    Add in that when I switch to full screen it will not switch back it just openes full screen and if I hit button to close monitor goes black no GUI no mouse no real  estate nada and I have to restart pgm
    Tom Pearson
  • Tue, Aug 25 2020 6:34 PM In reply to
    Tom Pearson:
    Having this issue when I try to grab a fx like" resize" I place teh cursor on the fx and it grabs the one below it like the mouse cursor is off on its x/y grid  and Im not miss selecting
    Seeing the same thing here. Lots of misses where windows are misplaced and/or mouse clicks/drags are misinterepreted.
    Media Composer Symphony | PT Ultimate | Win11 HPZ | OSX MBP [view my complete system specs]
  • Tue, Aug 25 2020 6:38 PM In reply to
    • RalphC
    • Joined on Wed, Sep 2 2015
    • Posts 2,932
    • Points 32,390
    Hi Tom,
      I'm sending this to support to investigate 04006638.
    RalphC
    MacBook Pro 15 2018 Intel Core i7 2.6GHz Mac 10.15.7 Intel UHD 630. [view my complete system specs]
  • Tue, Aug 25 2020 7:39 PM In reply to
    • Tom Pearson
    • Posts 2,216
    • Points 23,845
    I am finding its worse on the second monitor an ACER Im using a windows 10 hp laptop with an i7 and ssd
    Tom Pearson
  • Tue, Aug 25 2020 8:18 PM In reply to
    It’s weird as for instance the main panel, which should open fullscreen, is placed 2 inches from the top of the screen. After clicking the Green + it snaps back. If I then recall my basic Edit Workspace, some of my floating panels are misaligned (timeline and source/record monitor overlap, mixer is too low and drops partially below the screen).  Recalling the workspace again fixes that sometimes, but sometimes it takes two subsequent recalls of the workspace to get everything where it should be.
    When working, after a while, for no apparent reason, the timeline shifts up an inch on the screen. Then after a while, clicking th V1 track button selects V2. Dragging an Effect from the Effects Palette onto V3 makes the effect be applied to V4. Trying to step into an effect then doesn’t work. Sometimes my AudioSuite panel will not respond properly, meaning that I need to click about half of an inch below a dropdown box to acces it. Similarly, trying to select a frequency on the EQ sliders sometimes simply won’t work unless I drag the EQ Tool out of its panel. When playing a sequence, sometimes the playhead freezes up and I can’t stop the timeline for 6 seconds or so, can’t speed up or reverse, if I click nothing happens for those 6 seconds. I kept switching settings and have restarted MC and then could work for a couple of hours over the past two days.  It’s so bad that I’m planning to move back to 20.6 soon.  J P.S. Mostly been working on an approved z840, 64GB RAM, M4000, three 1900x1200 monitors, DNxHD SQ sequence.
  • Wed, Aug 26 2020 12:10 PM In reply to
    • Tom Pearson
    • Posts 2,216
    • Points 23,845
    Same here booting fixes it then it goes wonkie again I could not get into cc mode and fx are a loss have to step back this version is unworkable
    Tom Pearson
  • Wed, Aug 26 2020 7:49 PM In reply to
    • DStone
    • Massachusetts
    • Posts 3,969
    • Points 50,650
    • Moderator: MCA Mac
    It definitely is not working correctly. Just for grins, I decided to make a new user profile, just in case it was somehow misreading the existing one. As soon as I created the new profile, the main panel floated itself down the primary monitory display. So I don't think it's a profile issue.
    Dave S.
  • Wed, Aug 26 2020 7:56 PM In reply to
    • DStone
    • Massachusetts
    • Posts 3,969
    • Points 50,650
    Tom Pearson:
    Just tried the various modes, and at least on my system everything works.
    Also for grins, I made the panel full screen and then switched projects. The panel remains full screen. It appears to only float after you create a new profile and select the initial project.
    Dave S.
  • Sat, Aug 29 2020 2:31 PM In reply to
    • LDV20
    • Joined on Fri, Nov 18 2011
    • Posts 400
    • Points 4,705
    DStone:
    So is this a stable upgrade?  Reason I ask I will be setting up the new computer next week - would download 2020.8 - but not if it is buggy.  Will just go back to 2020.4 or 2020.5 - but rather not gum up a new machine dowloading applications and then uninstallng them - just to wind up having to download a previous version.
    Thank you
    Larry
    Symphony 2023.12- Win 10 pro (20H2),Gigabyte X299X with i9 10920X CPU, Quadro P2000,driver 51.259; 64gig memory, 1TB NV system drive, WD 4TB, BM Min Monitor... [view my complete system specs]
  • Sat, Aug 29 2020 8:08 PM In reply to
    • Tom Pearson
    • Posts 2,216
    • Points 23,845
    Ok per tech support I made a new user profile issue was still there but it is random I have tried it now with out a second monitor much better but still wonkie FSPB is still a mess
    Tom Pearson
  • Sat, Aug 29 2020 8:17 PM In reply to
    • LDV20
    • Posts 400
    • Points 4,705
    Ok thank you for the heads up - Might just stay on wither 2020.4  or go for 2020.6 - not sure yet.  Lately I feel we all are their BETA TESTERS - I think it is far better to put out versions that have all bugs fixed then new versions with new freatures that have prolemnatic bugs.  I am happy avid/mc is advancing but maybe too fast.
  • Sat, Aug 29 2020 8:31 PM In reply to
    • Tom Pearson
    • Posts 2,216
    • Points 23,845
    FYI I am a beta tester LOL and we are working out the new issues as fast as we can
    Tom Pearson
  • Sat, Aug 29 2020 8:35 PM In reply to
    • Tom Pearson
    • Posts 2,216
    • Points 23,845
    Ok FSPB works right when I use only 1 monitor old user profile and new one so Im leaning away from user profiles more into multi monitor issues  note to tech support both monitors are 1920x1080 video card is a radon hd 7570 m driver#15.201.1301.0
    Tom Pearson
  • Sat, Aug 29 2020 9:13 PM In reply to
    • LDV20
    • Posts 400
    • Points 4,705
    Tom Pearson:
    Well thank you for taking the time in testing the software - my hat is off to you.  I have a few weeks before I have the new project in - so maybe I will see how 2020.8 performs.  I spoke to my IT guy and he said he will mirror the new OS - so if I want to go back to the fresh install I will be able to.  This is in the event I have to uninsstall 2020.8 and go back to a lower version. Also I see from your spec you are on MAC - maybe PC might handle things differently.     Thank you for keep me posted
    Larry
