OS 10.15.4
Hi all, I just upgraded to MC 2020.6 -- cutting video clips onto an audio sequence (for sync) incurs approximately 3-4 seconds of latency, displaying 2 dialog messages: "Loading file media information" & "Relinking" prior to command completion.
Also, when adding a marker onto any clip in the source window, Media Composer crashes.
Should I upgrade to 10.15.6?
TIA
I seem to be having the (above) problems with only Sony A7 footage imported Prores 422, Rec709. All other project footage is Venice, F5 & some A7 all imported slog3, which is functioning correctly.
Any ideas why cutting with this A7 footage would result in latency & crashing by simply adding a marker?
I had an issue a few months ago in a MC 2020 project of DNxHD SQ material forcing me to wait with a prompt "Loading media file information" which lasted about 5sec each time I tried to cut a clip into a timeline. I tried many things with Avid Tech support. But in the end they did not have a solution.
The only solution I could come up with was to import and transcode all my material again. Are you able to do a test to regenerate the material?
Hey Buzzkill.....
2020.8 later today and suggest you upgrade as a lot of fixes since 2020.6
marianna
Thanks morsey - that's exactly what I'm seeing... Just grabbed my source material to reload--I'll give 2020.8 a go then reload if things don't clear up. Appreciate your help!
As always, thank you Ms. Marianna -- hope you're feeling better!
I believe my import settings were incorrect causing the issues cited here. Reloading media with closer attention to import settings & upgrading to 2020.8 seems to have resolved everything.
However Application Manager states; 'dongle not activated' -- but everything is seemingly functioning...
Thank you Marianna & morsey!
Thanks for following up. :)
Robert Davis CEO/Creative Director
Davis Advertising, Inc.
Visit my latest blog, "Concept to Creation" on the Avid Community site
[/url] Visit my Behance portfolio site
• MC 2020.8 • os 10.15.6
Happening again; creating new sequences or insert/over-write command, experiencing 5 second delays with "Loading Media File Information" & "Relinking" messages displayed, also duplicate master clips generated.
Occuring across diverse media; Venice, F5, A7s & older archive camera material.
I'm dead-in-the-water -- any insight much appreciated...
