Latest post Thu, Mar 4 2021 11:01 AM by Rvdhammen. 3 replies.
  • Fri, Apr 24 2020 4:26 PM
    • dklein
    • Joined on Thu, Mar 15 2012
    • Posts 126
    • Points 1,760
    New Location for Color Correction Presets.aep in 2019/2020?
    Hi all,
    Does anyone know the new location of the Color Correction Presets.aep file in Avid 2019/2020 installs? I've got a remote editor on a Mac that is having Avid crashes/freezes while opening Avid and reading "Color Correction Presets".
    The old location in 2018 was  /Applications/Avid Media Composer/SupportingFiles/Avid_EffectsPresets/Color Correction Presets.aep but I'm not seeing the /Avid_EffectsPresets folder with 2019 installs.
  • Fri, Apr 24 2020 4:31 PM In reply to
    • Posts 11,555
    • Points 255,140
    Re: New Location for Color Correction Presets.aep in 2019/2020?
    Effects Palette, do you see a group called "Color Correction Presets"?
  • Fri, Apr 24 2020 4:41 PM In reply to
    • dklein
    • Posts 126
    • Points 1,760
    Hi Marianna,
    I can see the effect filter inside Avid, but I was looking for the Color Correction Presets.aep in the Finder. Previously in 2018 and before, that file could get permission errors or get corrupt, and removing it would imediately correct the issue.
    However, the path /Applications/Avid Media Composer/SupportingFiles/Avid_EffectsPresets/ doesn't appear to exist in 2019/2020 installs.
    I believe I just found it though. It looks like the Avid_EffectsPresets directory has been moved to /Library/Application Support/ColorManagement/Avid_EffectsPresets
  • Thu, Mar 4 2021 11:01 AM In reply to
    • Rvdhammen
    • Joined on Fri, May 16 2008
    • Posts 32
    • Points 395
    Did this solve the issue for you?
    I keep crashing on loading Collor Correction Presets as well. Can't find the presets in either folder though.
    MC 2021.5 - OS X 10.15.7 - 3,2 GHz 8-core Intel Xeon W - 64GB 2666 MHz DDR4 - Aja T-Tap [view my complete system specs]
