Latest post Thu, Jul 15 2021 6:16 PM by Simon_h. 9 replies.
Page 1 of 1 (10 items)
  • Tue, Apr 21 2020 5:18 PM
    • Simon_h
    • Joined on Mon, Jun 20 2011
    • Cambridge, UK
    • Posts 92
    • Points 1,205
    EDL beginner - how do I import this?
    Hi folks!
    Lots of editing experience but I've never used EDLs so I hope you can help.
    I have a very very simple test EDL exported from the very good online transcription tool Trint.  It just a test with 3 clips:
    Here it is:
    TITLE: Editing_test
    FCM: NON-DROP FRAME
    001 AX AA/V  C         00:01:21:810 00:01:43:380 00:00:00:00 00:00:21:570
    * FROM CLIP NAME: 00004.MTS
    002 AX AA/V  C         00:00:36:870 00:01:04:920 00:00:21:570 00:00:49:620
    003 AX AA/V  C         00:00:40:210 00:01:05:69 00:00:49:620 00:01:14:479
    * FROM CLIP NAME: 00001.MTS
    004 AX AA/V  C         00:01:47:290 00:02:10:710 00:01:14:479 00:01:37:899
    So I open the project in Avid which is AMA linked to the footage used in the EDL.  I use "Input>Import EDL in Avid (latest version) and get the dialogue asking me to specify frame rate, project type and audio mapping.  It seems whatever I set these to I can't get it to import properly and it just imports an empty sequence.
    I have more info from the Console etc, but am I missing something really basic?   Is the EDL generated by Trint even the right format?
    Simon
    AVID 2019.12 on HP Z820 MT XEON, 2GhZ, 32GB, Windows 10, Nvidia Quadro 2000, Crucial SSD Hard Drive with several WD Blacks for media. TMPGEnc 7 for encoding... [view my complete system specs]
    New Template
    Filed under: ,
  • Tue, Apr 21 2020 6:25 PM In reply to
    • smrpix
    • Joined on Wed, Sep 5 2012
    • Posts 1,460
    • Points 18,130
    Re: EDL beginner - how do I import this?
    Your sources appear to be in thousands of a second rather than frames, which is fine for subtitles but will throw out errors on an edl.
    Edit: FWIW your list will open successfully in Premiere.  However, I can not bring it into Avid from there using any of the regular methods.
  • Tue, Apr 21 2020 8:44 PM In reply to
    The EDL you pasted here is not in hh:mm:ss:ff, as mentioned. But on top of that, the source for each clip is AX, meaning an Auxilary source, not a source file or tape source, so there's nothing MC can link to.
  • Tue, Apr 21 2020 9:10 PM In reply to
    • Simon_h
    • Cambridge, UK
    • Posts 92
    • Points 1,205
    Thanks both.  Very useful.
    Simon
    New Template
  • Thu, Jul 15 2021 11:23 AM In reply to
    • Ben Mole
    • Joined on Thu, Jul 15 2021
    • Posts 2
    • Points 30
    Did you ever find out how to imort and edl into avid?  I keep getting the error mesage that the file is not supported.
  • Thu, Jul 15 2021 12:52 PM In reply to
    • Simon_h
    • Cambridge, UK
    • Posts 92
    • Points 1,205
    Hi Ben
    The problem for me I think was incorrectly formatted EDL.   The EDL was generated outside Avid by another app.
    Simon
    New Template
  • Thu, Jul 15 2021 1:57 PM In reply to
    • Ben Mole
    • Posts 2
    • Points 30
    Thanks for getting back to me.
    If you do know a way to import an edl into avid I'd love to hear it -- don't need media or linking or anything else - I have a master film (single clip) and the edl and nothing else. I want to be able to jump to cuts on a timeline.
    Any ideas?!
    thanks!
  • Thu, Jul 15 2021 5:27 PM In reply to
    • TrevorA
    • Posts 1,288
    • Points 14,595
    Change the e.g. :810 thousands of a second to :frames - multiply it by the frame rate and keep the integer part should work. eg. 0.810 * 25 = 20.25 - use the 20
    Pretty simple to script if you can code.
    Or make a feature request from Trint that they output an EDL with frames
  • Thu, Jul 15 2021 6:15 PM In reply to
    • Simon_h
    • Cambridge, UK
    • Posts 92
    • Points 1,205
    Ben
    I don't have a live Avid subscription right now to check, but I'm pretty sure it's something simple like File>>import>>EDL>>and browse for your file.  You should then get a unlinked timeline that you can work with.  Sorry not to be more helpful.
    Simon
    New Template
  • Thu, Jul 15 2021 6:16 PM In reply to
    • Simon_h
    • Cambridge, UK
    • Posts 92
    • Points 1,205
    Thanks Trevor.  I've stopped using Trint since that first post because it became too expensive for my low usage.
    Simon
    New Template
