Latest post Sat, Feb 8 2020 8:26 AM by Andrew. 4 replies.
  • Thu, Feb 6 2020 8:27 AM
    • Andrew
    • Joined on Wed, Apr 6 2011
    • Costa Mesa, Orange County, California
    • Posts 143
    • Points 1,680
    How do I open title tool in 2019?
    I used to know how to open the Title Tool in 2018, but not in 2019.
    When I open the Title Tool Application under Tools, I get an error message that reads: "Please use Avid Titler+ from the Effects Palette for this project size."
    When I try to click on New Title under Clip, I get the same error message.
    My video is going to be 640 X 360.
    When I try to open Avid Titler+ under Tools, nothing happens.
    When I click on Title in the Effects Palette, again, nothing.
    So can someone please explain to me how to create titles in 2019?
    Avid MC v2021.12, macOS Monterey 12.1 (w/out dongle), iMac 21.5-inch, late 2015 (purchased new on Jan. 2017), Processor: 2.8 GHz Intel Core i5, Memory... [view my complete system specs]
  • Thu, Feb 6 2020 11:48 AM In reply to
    Re: How do I open title tool in 2019?
    When you went from 2018.x to 2019.x did you create new user settings? If not, I'd try creating a new user and see if you can create a title with either the Title Tool or Titler+.
    Media Composer 2022.7 w/Symphony/SS/PF options, HP Z-Book G6 17", i7-9850H 2.60GHz, 32gb RAM, NVIDIA Quadro RTX 3000, Blackmagic UltraStudio Mini... [view my complete system specs]
  • Thu, Feb 6 2020 9:15 PM In reply to
    • Andrew
    • Posts 143
    • Points 1,680
    camoscato:
    No I did not.  This is not something I've done before.  How do you create user settings?  Do you mean I have to create a new user profile?  I'm afraid if I do that, I'll get the same results.
    UPDATE: OK, I found the user settings and put a check mark on Title Tool under Create New Title Using and a check mark on Yes under Promote Title Tool Titles to Marquee and a check mark on Backup Title On Promote and I'm still getting the same results.
  • Sat, Feb 8 2020 6:47 AM In reply to
    camoscato:
    Andrew:
    Yes, that's what I mean.
    Andrew:
    Well, if you get the same results then you'll know user settings are not causing the problem, we'll need to try other troubleshooting steps, and you can go back to your original user settings.
    If the problem goes away with a new user, then you know your old user settings are corrupt and you need to create new ones.
    It's up to you.
  • Sat, Feb 8 2020 8:26 AM In reply to
    • Andrew
    • Posts 143
    • Points 1,680
    OK, I just created a new user profile and it works now.
    Since the title tool in 2019 is radically different from 2018, I will just need to figure out how to operate it.
    Oh, and thanks.
