Latest post Tue, Jan 21 2020 5:40 PM by Rory T. 3 replies.
  • Mon, Dec 2 2019 2:03 PM
    • Rory T
    • Joined on Wed, Mar 21 2018
    • Posts 62
    • Points 725
    23.976 File Structure
    Is there a way to get Media Composer to interpret 23.976fps as a ratio of 24000/1001.
    Media info will tell you whether the file is 23976/1000 (23.976) or 24000/1001 (23.97602397602398).  We recently got a technical fail over this.  Da Vinchi Resolve seems to do it, as does Vantage.
    Tried on 8.6.5 up to 2018.11
    Regards,
    Rory
  • Tue, Jan 21 2020 10:21 AM In reply to
    • Rory T
    • Posts 62
    • Points 725
    Re: 23.976 File Structure
    Anyone else been burnt by this?
  • Tue, Jan 21 2020 3:07 PM In reply to
    No never come across it before.
    If you are in a 23.98 project and AMA link the sources in Source setting does changing the playback rate to Project rather than source not force it?
  • Tue, Jan 21 2020 5:40 PM In reply to
    • Rory T
    • Posts 62
    • Points 725
    So 23.976 it is a recurring decimal that is rounded down to three decimals.  Are you saying get the Davinchi 23.976023976 ( which appears as a 23.976 export in davichi) file, link in into the 23.976 project? Ok, which setting are you saying to change?  Where I would chage platyback settings would be in format settings.
    If I have a 23.976 exported from avid and a 23.976023976 exported from davinchi both will appear as 23.976 when linked into the avid.  It seems to be only media info which will give the ratio.  The project is still set up as 23.976 in davinchi
