Latest post Fri, Jun 10 2022 9:49 AM by Vilem. 79 replies.
Page 6 of 6 (80 items) « First ... < Previous 2 3 4 5 6
  • Wed, Oct 7 2020 12:37 PM In reply to
    • Posts 11,589
    • Points 255,975
    Re: FrameFlex Quality Issues
    alexdetig:
    Hi Marianna.
    But there is still this huge issue that the image quality is so much worser than in other tools, like DaVinci or Premiere.
    Disabling GPU doesn't solve this immense problem of Media Composer. Almost everywhere in the world we're shooting in 4K, not HD. So a proper downscaling is of the utmost importance.
    Cheers
    Alex
    Alex,
    Aware of that but at least there is a workaround for some people while we FIX it.  There is a new bug # and they are on it.
  • Wed, Oct 7 2020 5:39 PM In reply to
    • jef
    • Joined on Sun, Feb 26 2006
    • Maryland
    • Posts 4,020
    • Points 48,520
    Marianna:
    Freddieie does tetsing and engineering for support so it would be Kate etc... and yes they are looking to improve that feature set in the coming releases.
    Well, since you brought it up ......     Big Smile
    1. Put a button in that says "Promote to 3D Warp" and make 3D Warp resolution independent.
    2. Give us a selection of filter options using industry accepted names.
    3. Give us the ability to copy and paste FrameFlex effects like every other Media composer effect.
    Thank you for opening the topic .........
    Jef
    Avid DS 11.0.2 R.I.P | MC "Well, it depends ..." 2021 iMac w Big Sur [view my complete system specs]
    Jef Huey
  • Wed, Oct 7 2020 7:39 PM In reply to
    • Posts 11,589
    • Points 255,975
    jef:
    Marianna:
    Jef
    Hey Jef
    I sent this along to Kate and Randy :). just for you being you xo
  • Wed, May 5 2021 3:35 PM In reply to
    • Rihafilm
    • Joined on Mon, Jul 19 2010
    • Posts 109
    • Points 1,495
    Looks like this issue has finally been fixed with 2021.5.
    At least at first glance FrameFlex now seems to behave like it should.
    MC 2020.9, DNxIO 11.5, Windows 10 x64 Pro, 2x Xeon E5-2630 v3, Quadro M4000 (452.06), 64GB RAM, RAIDdeluxe 6Gb SAS 96TB 16-bay RAID-6 [view my complete system specs]
  • Fri, Jun 10 2022 9:49 AM In reply to
    • Vilem
    • Joined on Sat, Apr 10 2010
    • Prague
    • Posts 1,444
    • Points 15,855
    Hello,
    I got an error rendering the FrameFlex effect. MC 2022.04, project HD-25p. Imported photos in 4k DNxHR HQX resolution, using the Frameflex effect. When previewing everything ok. After rendering, set HQX quality DNxHD, rendered, according to quality, probably to LB. Turning off the GPU has no effect. The render quality error will also affect the SubCap track, in the parts where FrameFlex is applied under the SubCap.
    V.
    AVID MC2021.12, HP Z620 - 2 x Intel Xeon E5-2620, Quadro P2000 - driver 461.72, RAM 48GB - DDR3, BM Intensity Pro 4k - 12.1, W10 - 64bit Professional... [view my complete system specs]
