Latest post Sun, Sep 29 2019 11:50 PM by cls105. 34 replies.
Page 2 of 3 (35 items) < Previous 1 2 3 Next >
  • Thu, Sep 5 2019 2:34 PM In reply to
    Re: Media Composer 2019.8 Available now!
    One thing of note about when we installed 2019.8, we opted to not have the Open I/O NDI Plug-In added. We do not use that feature.
    We also get a PMS_Not_Ready error on the source monitor, even when nothing is loaded onto it.
    Here is watch the Console reports:
    PlayerHostThread::CheckForExceptions: Exception: PMS_NOT_READY_TO_START
    Monitor Exception:
    * Exception: PMS_NOT_READY_TO_START
    Exception caught in APlayer::Play - Exception: PMS_NOT_READY_TO_START
    This may be something entirely different. This PMS warning pops up in 2019.7, as well.
    Windows 10 Enterprise - Dell Precision 7820 - 32GB RAM - DNxIQ - Nvidia Quadro P4000 [view my complete system specs]
  • Thu, Sep 5 2019 2:45 PM In reply to
    • AntCaladine
    • Joined on Tue, Sep 11 2007
    • Stourbridge, UK
    • Posts 390
    • Points 5,000
    +1 for not installing the I/O plugin either. Although I've not had the PMS error
    2x HP Z8 G4, 96GB ram, Win10 Pro 64bit, Nvidia Quadro P4000 8GB AMC 2020.12 1x HP Z820 16GB ram, Win10 Pro 64bit, Nvidia Quadro 4000 AMC 2020.12 2x Aja... [view my complete system specs]
  • Thu, Sep 5 2019 4:16 PM In reply to
    • ramz434
    • Long Island
    • Posts 255
    • Points 3,225
    I didnt install the plug in either.
    I almost always get a white screen/crash when I've gona away from the app for a few minutes and tried to come back to it.
    - HP Z400/24gb ram/Windows 10/MC2020.5/256gb Samsung SSD/ NVidia GTX 1080 - Macbook Pro/16gb ram/OS 10.15.4/MC2020.4/Intel UHD 630 [view my complete system specs]
  • Thu, Sep 5 2019 4:34 PM In reply to
    As a test, I did an uninstall and re-install of 2019.8 on one of our systems WITH the plug-in to see if I can still get it to crash. I can "fast-crash" the application by using Snipping Tool to capture parts of the screen. It does in 2 minutes what editing for two hours does. I float my bins and tools, then slide the interface to the left to expose the Desktop.
    I was able to crash Media Composer after a FRESH install and restart inside 10 seconds!!!
    I know the folks at Avid are on the case.
  • Thu, Sep 5 2019 5:46 PM In reply to
    • Posts 11,565
    • Points 255,425
    AntCaladine:
    Also I’ve just discovered .8 breaks baselight.
    If you try and apply baselight fx to a project that didn’t have it on, I get the white out issue too
    Are you using the latest version they just released ahead of IBC?
    https://www.filmlight.ltd.uk/store/press_releases/filmlight-releases-baselight-5-0-ahead-of-ibc2017/
    Checking with Tim the AVX guy to see what he might know and will report back.
  • Thu, Sep 5 2019 5:58 PM In reply to
    • AntCaladine
    • Stourbridge, UK
    • Posts 390
    • Points 5,000
    yes running latest version 5.2.11917
  • Fri, Sep 6 2019 3:57 PM In reply to
    • ramz434
    • Long Island
    • Posts 255
    • Points 3,225
    Tried installing with that I/O plugin option and still crashing like crazy. Unusable at this point. Have to revert back to 2019.7
  • Sat, Sep 7 2019 3:56 PM In reply to
    • BarkinMadd
    • Ontario, Canada
    • Posts 4,814
    • Points 63,125
    AntCaladine:
    I'm running a P4000 with 431.86 and not seeing this issue with Baselight and MC 2019.8 - I wonder what is different - what are your project settings and media type. I'm using DNxHR UHD p29.97 in an UHD project. You?
    The other difference is that I'm running Windows 10 1903 (unlikely to be the reason for the issues you are seeing).
    MC 2021.6 | QT 7.7.9 | Continuum 2021 | Sapphire 2021 | Mocha Pro 2021 | Titler Pro 7.7 | Windows 10 Pro x64 (21H1) | System: Asus x299, i9-7940X (4.1GHz... [view my complete system specs]
    Steve
    ______________________
    www.nelliedogstudios.com
  • Sun, Sep 8 2019 10:20 AM In reply to
    • WAIF2318
    • Joined on Tue, Nov 15 2011
    • Posts 352
    • Points 4,295
    hi,When I open the settings of the user item , I can't adjust the size of the option box, so the computer screen can't see the "ok" button below. Is this a bug?
  • Mon, Sep 9 2019 10:15 AM In reply to
    • AntCaladine
    • Stourbridge, UK
    • Posts 390
    • Points 5,000
    Only difference is your running the very slightly newer nvidia driver than me and windows build. (although a separate suite with 1903 on is experiencing that same issue)
    I'll download and test 431.86 later
  • Tue, Sep 10 2019 7:53 PM In reply to
    • John Mac
    • Posts 184
    • Points 2,465
    Hi, I'm having to roll back to previous version as bins would not open in latest version. Just keep getting error messages. Also, when installing it said I was operating an unsupported version of MC, which is clearly not correct.
    John M
    MC 8 Windows 7 Pro 64-bit i7 Intel Core 4 cores 3.5 GHz 16 Gb ram Nvidia quadro 4000 Matrox mini 6TB internal connected to SATA III ports [view my complete system specs]
  • Tue, Sep 10 2019 8:04 PM In reply to
    • RalphC
    • Joined on Wed, Sep 2 2015
    • Posts 2,737
    • Points 30,340
    • Avid Customer Advocate
      Avid Customer Service
      Avid Employee
    What is the error message and when exactly are you getting it?
    RalphC
  • Tue, Sep 10 2019 8:13 PM In reply to
    • John Mac
    • Posts 184
    • Points 2,465
    Hi it said simply could not open. But cannot reacreate now fully as have rolled back and it's working fine again.
    John
  • Tue, Sep 10 2019 9:08 PM In reply to
    • Posts 11,565
    • Points 255,425
    OK John.....
    Next time you get any wacky behavior, screen shot it or capture the crash files so we can try and figure out why it happened.....
  • Wed, Sep 11 2019 11:06 AM In reply to
    • Tim
    • Joined on Mon, Sep 12 2016
    • Posts 29
    • Points 315
    A LOT of white screen crashes. I think most of the times it occurs after i've been in another application like windows explorer or google chrome and when I switch back to MC, then it crashes.
    I cant believe this was released. Super unstable, rolling back now.
    AVID MC 2020.12 / Blackmagic Intensity Pro 4K / Intel Core i7-7700K @ 4.2ghz / 64GB ram / GeForce RTX 2080 Ti / Windows 10 pro / [view my complete system specs]
