Latest post Fri, Sep 13 2019 3:41 PM by Erik. 6 replies.
Page 1 of 1 (7 items)
  • Mon, Aug 26 2019 3:57 AM
    Need 4K storage suggestions Windows users
    I am about to start my first 4K project  and one of my hard drive crash on raid 0 system. I was able to get older projects off of it "lucky" Media was backup anyway. So I began Transcode my 4K footage from my Drobo to my 500GB SSD media drive DNXHR SQ and the driver wasn't big enough. I have order a 1TB SSD but if change my RockStor to a Raid 5 will it be fast enough for 4K? I would like to here from others here or suggestions what you use as a media drive for 4K DNXHR.
    OS Windows 10
    CPU AMD Ryzen 7 1700X 3.70 GHz
    Memory 32 gb
    Hard drives
    C: SSD OS and Programs
    E: Media SSD 500GB
    F: 2 TB Documents and other programs
    G: Drobo 6TB photos and videos
    H: SSD 500 gb Cache drive
    I: RocketStor Raid 0 1x4 TB (Crashed)
    AMD Ryzen X1700 MB Asus Crosshair 6 Hero Asus GTX2070 8MB Memory 32GB Avid Media Composer 2019.9 OS Windows 10 1TB SSD OS and APPs, 2TB SSD Media Drive... [view my complete system specs]
  • Mon, Aug 26 2019 5:27 AM In reply to
    • DStone
    • Massachusetts
    • Posts 3,886
    • Points 49,695
      Moderator: MCA Mac
    Re: Need 4K storage suggestions Windows users
    A quick search for the RockStor shows RAID 5 may be unstable. There's also some discussion that it's not fast performing either. I suggest you do a search on the web and in the RockStor community pages for more information.
    Dave S.
  • Wed, Aug 28 2019 5:55 PM In reply to
    • JDwidell
    • Joined on Sat, Dec 8 2018
    • Posts 9
    • Points 115
    You’ll have to excuse me for being a bit off topic, but ”my curiosity took the better of me”. I see you are using a Ryzen platform for Media Composer. How is that working for you? All I have found was older posts stating that ryzen + MC didn’t work that well...
    Best regards
    MC 2018.12.1, DIY 9900k, asus z390-f mb, 32 GB ram, RTX2070 GPU, 256 GB m2 ssd (OS), 1 TB ssd, 2x8 TB HDD’s, win 10 pro. [view my complete system specs]
  • Thu, Aug 29 2019 10:04 AM In reply to
    • CeeBee
    • Joined on Mon, Sep 5 2016
    • Posts 27
    • Points 335
    I would use SSDs - there are some for 800€ for 8TB - this should be better than every raid solution.
    But i also cut 4k DNXHR SQ via normal external seagate drives (8TB) connected over USB 3. To make them faster I dismantel them and put then inside the PC. Great cheep solution.
    So it depends - but i would not go for a Raid.
    Best C.
  • Mon, Sep 2 2019 2:58 PM In reply to
    • Lukas Boeck
    • Joined on Fri, Jul 31 2015
    • Austria
    • Posts 646
    • Points 7,760
    Depends on how much space you need.
    if a few terrabytes are enough: ssd, like others said.
    if you need 20 or 40 or more you'll want magnetic drives on a decent hardware controller.
    Broadcom or Areca would be the go-to brands.
    MC 2018.12.2 Cusom bulid Supermicro X9SRL-F, 32 Gig Ram, 3ware 9750 6x6TB Seagate EC Drives, LSI 9207 + LTO-7, Mojo DX, Artist Color, Flanders CM240, GTX... [view my complete system specs]
  • Fri, Sep 13 2019 3:11 AM In reply to
    Sorry to get back soooo late it works great no issue.  I just it used Thunderbolt but I have 10 gBt card connected to my NAS I am testing this out.
  • Fri, Sep 13 2019 3:41 PM In reply to
    • Erik
    • Joined on Thu, Oct 5 2006
    • Austin, TX
    • Posts 214
    • Points 2,525
    I use fast 7200rpm 4TB Gdrives connected via USB 3. They work fine for 4k.
    Internally, I have several 2TB SSD drives as well.
    MC 2019.9 Asus Prime X299 Deluxe, 64GB of Memory, Core i9 7940x @3.1Ghz, Nvidia GeForce GTX 1070 Ti. Running Win10 Pro 64bit MC 2018.4 Dell Precision... [view my complete system specs]
