Latest post Fri, Sep 4 2020 3:22 PM by Adman. 5 replies.
Page 1 of 1 (6 items)
  • Wed, Jul 31 2019 10:02 AM
    • SilvaEdit
    • Joined on Wed, Nov 3 2010
    • Posts 111
    • Points 1,335
    MC 2019.7.0 - Bugs? - Can't delete clip from bin and others shenanigans.
    Hi all, I'm running OSX 10.13.6
    Imported some stills into a bin, when I highlight the masterclip and hit delete I get the message:
    "Neither the name column or the handle column can be deleted"
    This message appears when trying to delete in list view however when in frame view I CAN delete the clip as usual.
    Also I can't render a Blur effect? it says the effect is not recognized. I thought it may be because it was a bespoke transition I had created in a previous version however when recreating in the new MC I get the same message.
    Any ideas?
  • Wed, Jul 31 2019 2:19 PM In reply to
    • RalphC
    • Joined on Wed, Sep 2 2015
    • Posts 2,670
    • Points 29,615
    • Avid Customer Advocate
      Avid Customer Service
      Avid Employee
    Re: MC 2019.7.0 - Bugs? - Can't delete clip from bin and others shenanigans.
    Hello SilvaEdit,
       I open a case and forwarded to technical support team 03759458.
    RalphC
  • Thu, Sep 3 2020 3:28 PM In reply to
    • Grey778
    • Joined on Sat, Jun 18 2011
    • Posts 7
    • Points 75
    Hello,
    I am running Mac OS 10.13.6 and MC 2020.8
    I'm trying to delete a clip in a bin and nothing happens.
    Normally a window will pop up and ask if I want to delete associated media or not. This does not happen.
    When I export AAF's I have new media files that I need to delete because they just take up space.
    Why are there so many little annoying bugs happening with Avid Media Composer?
    I've restared the Avid 3 times and nothing happens.
    Very frustrating.
  • Thu, Sep 3 2020 3:57 PM In reply to
    • Grey778
    • Posts 7
    • Points 75
    I don't know why, but I changed my display settings by switching my primary
    monitor settings, and when I went back in to Avid I was able to delete items
    in the bin.
  • Fri, Sep 4 2020 2:57 PM In reply to
    • Grey778
    • Posts 7
    • Points 75
    Nevermind, still doesn't work. Created new user settings. Created new project. Copied folders into new project but still can't delete highlighted clips in a bin.
    I also created a new bin, copied the clips to that bin but still can't delete items.
    I even did a complete fresh install of my Mac OS just to run the new Avid software.
  • Fri, Sep 4 2020 3:22 PM In reply to
    • Adman
    • Atlanta Georgia, USA
    • Posts 5,432
    • Points 61,720
    • BlogAuthor
      Moderator: Avid Free DV
      Moderator: Avid Xpress DV PC
      Moderator: Avid Xpress Studio
    Let us know when you hear back on your case. :)
    Mac Pro, 64GB Ram. 1TB SSD system drive, 250Gb SSD external (media) drive. QHD Ultra wide, thunderbolt LG monitor, MC 2019.12.1. Pro Tools 11 HD (Mbox... [view my complete system specs]
