Latest post Tue, Jun 25 2019 10:35 AM by LDV20. 7 replies.
  • Mon, Jun 24 2019 7:00 PM
    • LDV20
    • Joined on Fri, Nov 18 2011
    • Posts 400
    • Points 4,705
    Few Questions before I install 2019.6
    1) I go to uninstall previous MC - do I do a de-activate?
    2) Do I need the driver for the avid i/0 forgot the name - as I am using BM intensity Pro
    3) Hopefully there should not be any problem opening past projects - I will delete all old settings as stated.
    4)  Also will I have to re-install BORIS it is older program 8.2? - did not have to re-install on precious upgrades/
    Thank you
    Larry
    Symphony 2023.12- Win 10 pro (20H2),Gigabyte X299X with i9 10920X CPU, Quadro P2000,driver 51.259; 64gig memory, 1TB NV system drive, WD 4TB, BM Min Monitor... [view my complete system specs]
  • Mon, Jun 24 2019 7:55 PM In reply to
    Re: Few Questions before I install 2019.6
    While I am on a dongle each time I unistall a version to install a newer MC asks me before uninstallation to deactivate so the answer should be yes.
    The only problem are the User Settings, nothing else.
    I am not sure if Boris 8.2 is compatible but going from one version to the other I have never uninstall the plugins.
    Now for the BM someone else should chim in as I don't use an I/O box.
    Desktop
    Asus Ζ690 TUF Gaming WiFi D4|i5 12600K|Corsair 128G DDR4|Asus 3060 12GB|Samsung 980 500GB(OS)|2X1TB Samsung 980 RAID 0|W11 Pro
    Laptop
    MSI Katana GF76 11UE (i7 11800H|Nvidia 3060|Crucial 64G DDR4)|W11 Pro
    NLE
    DR Studio 19.1.3|MC 2024.12
    VDIM
  • Mon, Jun 24 2019 8:06 PM In reply to
    • LDV20
    • Posts 400
    • Points 4,705
    OK thank you.  Looks like I have to:
    Avid DX Driver Separate Installer
    The Avid DX Driver is not automatically installed when you install the editing application. If you need to install the Avid DX Driver to work with your Avid IO device, you can install it separately.
    The installer is located: • (Mac) /Applications/Utilities/Avid Utilities • (Windows) Program Files\Avid\Utilities\DXDrivers
    "Avid Artist DNxIO and Avid Artist DNxIQ: If you are using Avid Artist DNxIO, Avid Artist DNxIQ, or a BlackMagic Designs video device, please update to Desktop Video software version v11.0 or higher. If you are using Avid Artist DNxIV and Avid Artist DNxIP please update to AJA software v15.2 or later. "
  • Mon, Jun 24 2019 8:19 PM In reply to
    Hi Larry,
    1. I didn't deactivate, and had no trouble.
    2. I don't know, hopefully someone who knows will answer.
    3. No problems here opening past projects.
    4. I have Boris 8.0 and did not have to do any uninstalling or deactivating, the effects are still there and working fine after the 2019.6 install.
    I hope that helps, and good luck with 2019.6!
    Media Composer 2024.6 w/Symphony/SS/PF options, HP Z-Book G6 17", i7-9850H 2.60GHz, 64gb RAM, NVIDIA Quadro RTX 3000, Blackmagic UltraStudio Mini... [view my complete system specs]
  • Mon, Jun 24 2019 8:26 PM In reply to
    • LDV20
    • Posts 400
    • Points 4,705
    camoscato:
    Hi camoscato
    Did you go to program uninstall to remove MC or did you allow AVID LINK do it.  The readme or one document said go tothe program uninstall panel
    Thank you for your help
    L
  • Tue, Jun 25 2019 7:29 AM In reply to
    I did not deactivate (I never do). My reading of the warning is if you are not going to install again relatively immediately they recommend you deactivate.
    I remove MC using the Control Panel uninstall. Then download the update I need from my account and install the parts I use from this download.
  • Tue, Jun 25 2019 8:47 AM In reply to
    LDV20:
    camoscato:
    I didn't use Avid Link. The steps I followed were:
    1. Downloaded 2019.6 from Avid's Download Center.
    2. Used Windows' Add/Remove Programs to uninstall 2018.12.5.
    3. Installed 2019.6.
    (I have nothing against Avid Link, but moderators here get access via the Download Center a day or so before the public release so we can test the download and install, and make sure there are no major last-minute problems.)
  • Tue, Jun 25 2019 10:35 AM In reply to
    • LDV20
    • Posts 400
    • Points 4,705
    OK - just making sure -  Thank you will install
    thanks
