After installing 2019.6 and testing it for a while this is what came up: when opening rather small sequences (small reports and documentaries) with 'Clip Frames' activated, there's no problem at all. This software version is quite stable and reliable.
Then I opened the master sequence of my latest feature film (100' long) and that's where the problem became obvious. Without activated Clip Frames in the Timeline the sequence opens without a glitch and it is business as usual. However, activating the Clip Frames results in a Runtime Error which crashes Avid.
The Avid Readme refers to using the Nvidia vs 411.95 driver with MC2019.6. My system is running vs 425.51 (mainly 'cause Adobe Premiere Pro needs the most recent driver). Could that be the problem? Or is this simply a bug?
Thanks for your advice.
Dell M5760 - Intel Core i9 - 64 gig RAM - Windows 11 Pro - NVIDIA RTX A3000 & Intel UHD Graphics - Media Composer 2022.10 w/Symphony/ScriptSync/PhraseFind options - 4TB Thunderbolt drive - 4 TB eSata Raid box - Pro Tools 2022.10 - Nuendo 12 - DaVinci Resolve Studio 18 w/micro panel & UltraStudio Pro - Wacom Intuos
Limeli1
First, did you create new settings prior to upgradeing to 2019.6? User profile is recommended so things do go wonky... since it is an ntirely new interface.
Second, if the ReadMe recommends that MC and NVIDIA use a specific driver then there is a reason and you should follow the Avid recommendation. That is what I woud do first to see if you have the same issue with the driver we recommend. if it works then, we need to know so we can try to userstand why Adobe needs the latest and we recommend a differnt version.
marianna
[email protected]
To second M use the appropriate driver.
And the clip view is somehow buggy.
Also as M says a new user is a good step always even if it's trouble setting up the Keyboard etc.
Desktop
Asus Ζ690 TUF Gaming WiFi D4|i5 12600K|Corsair 128G DDR4|Asus 3060 12GB|Samsung 980 500GB(OS)|2X1TB Samsung 980 RAID 0|W11 Pro
Laptop
MSI Katana GF76 11UE (i7 11800H|Nvidia 3060|Crucial 64G DDR4)|W11 Pro
NLE
DR Studio 19|MC 2024.2
VDIM
