Latest post Fri, Jun 28 2019 10:17 PM by Michael Ray Brown. 4 replies.
  • Sat, Jun 22 2019 6:13 AM
    MC 2019 Crashes on exit — BCC 12.5 the culprit
    MC 2019 takes a long time to close... and then crashes.  Figuring it might be due to a plugin, I decided to uninstall Boris Continuum Complete AVX 12.5 (the latest release).  That apparently did the trick.  I reinstalled BCC, and Avid again crashed on exit.  Then I uninstalled BCC, and Avid no longer crashes.  Any ideas, aside from reverting to Avid version 2018.12.5?
    Media Composer 2021.3.0 w/Symphony | macOS 11.2.3 | iMac 2017 (Retina 5K, 27-inch) 4.2 GHz Intel Core i7 | 40 GB 2400 MHz DDR4 | TerraMaster 16TB external... [view my complete system specs]
    Filed under: , ,
  • Sat, Jun 22 2019 2:23 PM In reply to
    • Posts 11,553
    • Points 255,110
    Re: MC 2019 Crashes on exit — BCC 12.5 the culprit
    Michael
    Let me check on this......
  • Sat, Jun 22 2019 3:34 PM In reply to
    • jdrouette
    • Montréal, Canada
    • Posts 460
    • Points 6,055
    I can also confirm that removing BBC.avx and BBC 3D Objects.avx from the AVX-2 Plugins folder solves my crash on exit problem with version 2019.6.
    Avid Media Composer 2021.2 Symphony option, Blackmagic Design UltraStudio 4K Mini (Desktop Video Application v12.0), macOS 11.2.2, iMac Pro (2017) 10-Core... [view my complete system specs]
  • Mon, Jun 24 2019 3:10 PM In reply to
    The developers at Boris FX are aware of this issue.  Quoting from a posting on their forum:
    This is not specific to the version of Media Composer, so reverting to Avid 2018.12.5 won’t help. This crash happens only on quit, so shouldn’t cause any data loss, but you could revert to Continuum 2019. Typically it only crashes when you don’t use Continuum during the session. We expect a patch for this to be released within the next few days, however, so since this should be more of an annoyance than actually causing data loss you might want to just wait for the patch.
  • Fri, Jun 28 2019 10:17 PM In reply to
    The 12.5.1 maintenance release of Continuum 2019.5 is now live on the Boris FX website. It fixes both the crash on quit and the problem with launching the standalone version of Title Studio.
    Michael
